ADRV9009-ZU11EG JESD204B Error -22 (VCXO Frequency Change)
Product Number: ADRV9009-ZU11EG Rev B., ADRV2CRR-FMC Rev C.
Software Version: Linux analog 5.10.0-98744-g64e7a607b659 #1789 SMP Fri Mar 31 17:23:38 EEST 2023 aarch64
Question: Where is the system configuration going wrong to not setup the TX JESD204 link correctly for the new clock rates?
Setup: We are currently working with the ADRV9009-ZU11EG Rev B. SOM mounted to the ADRV2CRR-FMC Rev C. carrier board operating the out of the box analog devices Linux OS (Linux analog 5.10.0-98744-g64e7a607b659 #1789 SMP Fri Mar 31 17:23:38 EEST 2023 aarch64).
Hardware Modification: The 122.88 MHz VCXO designated Y2 on the carrier board and Y6 on the SOM were removed and replaced with CVHD-950-80.000 VCXO, a 80 MHz reference. Our project requires a TX and RX sample rate different from what the system can generate with the original 122.88 MHz reference. The hardware replacement has been verified and we are seeing the 80 MHz signal on both the SOM and carrier boards.
The ADRV9008/ADRV9009 Profile Configuration Wizard v2.5 was used to generate this file Tx_BW120_IR240_Rx_BW120_OR240_ORx_BW120_OR240.txt:
<profile Talise version=1 name=Tx_BW120_IR240_Rx_BW120_OR240_ORx_BW120_OR240>
 <clocks>
  <deviceClock_kHz=240000>
  <clkPllVcoFreq_kHz=9600000>
  <clkPllHsDiv=2.5>
 </clocks>
 <rx name=Rx 120.00MHz, OutputRate 240.00MHz, TotalDecimation 8>
  <rxChannels=TAL_RX1RX2>
  <rxFirDecimation=2>
  <rxDec5Decimation=4>
  <rhb1Decimation=1>
  <rxOutputRate_kHz=240000>
  <rfBandwidth_Hz=120000000>
  <rxBbf3dBCorner_kHz=120000>
  <rxDdcMode=0>
  <rxNcoShifterCfg>
   <bandAInputBandWidth_kHz=0>
   <bandAInputCenterFreq_kHz=0>
   <bandANco1Freq_kHz=0>
   <bandANco2Freq_kHz=0>
   <bandBInputBandWidth_kHz=0>
   <bandBInputCenterFreq_kHz=0>
   <bandBNco1Freq_kHz=0>
   <bandBNco2Freq_kHz=0>
  </rxNcoShifterCfg>
  <filter FIR gain_dB=-6 numFirCoefs=48>
  1
  7
  3
  -20
  -37
  10
  103
  94
  -119
  -320
  -106
  486
  686
  -159
  -1327
  -1049
  1157
  2875
  963
  -3904
  -5960
  463
  13871
  25049
  25049
  13871
  463
  -5960
  -3904
  963
  2875
  1157
  -1049
  -1327
  -159
  686
  486
  -106
  -320
  -119
  94
  103
  10
  -37
  -20
  3
  7
  1
  </filter>
  <rxAdcProfile num=42>
  248
  146
  181
  90
  1280
  487
  1274
  38
  1287
  23
  779
  35
  48
  46
  29
  175
  0
  0
  0
  0
  44
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </rxAdcProfile>
 </rx>
 <obsRx name=Rx 120.00MHz, OutputRate 240.00MHz, TotalDecimation 8>
  <obsRxChannelsEnable=TAL_ORX1ORX2>
  <enAdcStitching=0>
  <rxFirDecimation=2>
  <rhb1Decimation=1>
  <orxOutputRate_kHz=240000>
  <rxBbf3dBCorner_kHz=225000>
  <orxDdcMode=0>
  1
  6
  2
  -18
  -29
  10
  77
  49
  -138
  -282
  -59
  452
  574
  -198
  -1172
  -840
  1097
  2473
  662
  -3527
  -4937
  1282
  13584
  23699
  23699
  13584
  1282
  -4937
  -3527
  662
  2473
  1097
  -840
  -1172
  -198
  574
  452
  -59
  -282
  -138
  49
  77
  10
  -29
  -18
  2
  6
  1
  </filter>
  <orxLowPassAdcProfile num=42>
  248
  146
  181
  90
  1280
  487
  1274
  38
  1287
  23
  779
  35
  48
  46
  29
  175
  0
  0
  0
  0
  44
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </orxLowPassAdcProfile>
  <orxBandPassAdcProfile num=42>
  248
  146
  181
  90
  1280
  487
  1274
  38
  1287
  23
  779
  35
  48
  46
  29
  175
  0
  0
  0
  0
  44
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </orxBandPassAdcProfile>
 </obsRx>
 <lpbk>
  <rxFirDecimation=2>
  <rhb1Decimation=1>
  <outputRate_kHz=240000>
  <rfBandwidth_Hz=80000000>
  <filter FIR gain_dB=-6 num=48>
  1
  6
  2
  -18
  -29
  10
  77
  49
  -138
  -282
  -59
  452
  574
  -198
  -1172
  -840
  1097
  2473
  662
  -3527
  -4937
  1282
  13584
  23699
  23699
  13584
  1282
  -4937
  -3527
  662
  2473
  1097
  -840
  -1172
  -198
  574
  452
  -59
  -282
  -138
  49
  77
  10
  -29
  -18
  2
  6
  1
  </filter>
  <lpbkAdcProfile num=42>
  239
  145
  181
  90
  1280
  543
  1282
  43
  1309
  25
  812
  33
  48
  47
  30
  180
  0
  0
  0
  0
  45
  0
  7
  6
  42
  0
  7
  6
  42
  0
  25
  27
  0
  0
  25
  27
  0
  0
  165
  44
  31
  905
  </lpbkAdcProfile>
 </lpbk>
 <tx name=Tx 120.00MHz, InputRate 240.00MHz, TotalInterpolation 8>
  <txChannels=TAL_TX1TX2>
  <dacDiv=1>
  <txFirInterpolation=1>
  <thb1Interpolation=2>
  <thb2Interpolation=2>
  <thb3Interpolation=2>
  <txInt5Interpolation=1>
  <txInputRate_kHz=240000>
  <primarySigBandwidth_Hz=80000000>
  <txDac3dBCorner_kHz=187000>
  <txBbf3dBCorner_kHz=60000>
  <filter FIR gain_dB=0 numFirCoefs=20>
  -706
  87
  1408
  -1846
  -766
  3925
  -1297
  -6533
  9635
  23842
  9635
  -6533
  -1297
  3925
  -766
  -1846
  1408
  87
  -706
  0
  </filter>
 </tx>
</profile>
which was used to update the system.dts file.
Device Tree Modification for the 80 MHz VCXO and desired sample rate (system.dts):
/dts-v1/;
	compatible = "xlnx,zynqmp";
	#address-cells = <0x02>;
	#size-cells = <0x02>;
	model = "Analog Devices ADRV9009-ZU11EG Rev.B";
	cpus {
		#address-cells = <0x01>;
		#size-cells = <0x00>;
		cpu@0 {
			compatible = "arm,cortex-a53";
			device_type = "cpu";
			enable-method = "psci";
			operating-points-v2 = <0x01>;
			reg = <0x00>;
			cpu-idle-states = <0x02>;
			clocks = <0x03 0x0a>;
			phandle = <0x3c>;
		cpu@1 {
			reg = <0x01>;
			phandle = <0x3d>;
		cpu@2 {
			reg = <0x02>;
			phandle = <0x3e>;
		cpu@3 {
			reg = <0x03>;
			phandle = <0x3f>;
		idle-states {
			entry-method = "psci";
			cpu-sleep-0 {
				compatible = "arm,idle-state";
				arm,psci-suspend-param = <0x40000000>;
				local-timer-stop;
				entry-latency-us = <0x12c>;
				exit-latency-us = <0x258>;
				min-residency-us = <0x2710>;
				phandle = <0x02>;
	cpu-opp-table {
		compatible = "operating-points-v2";
		opp-shared;
		phandle = <0x01>;
		opp00 {
			opp-hz = <0x00 0x47868bf4>;
			opp-microvolt = <0xf4240>;
			clock-latency-ns = <0x7a120>;
		opp01 {
			opp-hz = <0x00 0x23c345fa>;
		opp02 {
			opp-hz = <0x00 0x17d783fc>;
		opp03 {
			opp-hz = <0x00 0x11e1a2fd>;
	zynqmp_ipi {
		u-boot,dm-pre-reloc;
		compatible = "xlnx,zynqmp-ipi-mailbox";
		interrupt-parent = <0x04>;
		interrupts = <0x00 0x23 0x04>;
		xlnx,ipi-id = <0x00>;
		ranges;
		phandle = <0x40>;
		mailbox@ff990400 {
			reg = <0x00 0xff9905c0 0x00 0x20 0x00 0xff9905e0 0x00 0x20 0x00 0xff990e80 0x00 0x20 0x00 0xff990ea0 0x00 0x20>;
			reg-names = "local_request_region\0local_response_region\0remote_request_region\0remote_response_region";
			#mbox-cells = <0x01>;
			xlnx,ipi-id = <0x04>;
			phandle = <0x05>;
	dcc {
		compatible = "arm,dcc";
		status = "disabled";
		phandle = <0x41>;
	pmu {
		compatible = "arm,armv8-pmuv3";
		interrupts = <0x00 0x8f 0x04 0x00 0x90 0x04 0x00 0x91 0x04 0x00 0x92 0x04>;
	psci {
		compatible = "arm,psci-0.2";
		method = "smc";
	firmware {
		zynqmp-firmware {
			compatible = "xlnx,zynqmp-firmware";
			#power-domain-cells = <0x01>;
			method = "smc";
			phandle = <0x0c>;
			zynqmp-power {
				compatible = "xlnx,zynqmp-power";
				mboxes = <0x05 0x00 0x05 0x01>;
				mbox-names = "tx\0rx";
				phandle = <0x42>;
			nvmem_firmware {
				compatible = "xlnx,zynqmp-nvmem-fw";
				#size-cells = <0x01>;
				soc_revision@0 {
					reg = <0x00 0x04>;
					phandle = <0x43>;
				efuse_dna@c {
					reg = <0x0c 0x0c>;
					phandle = <0x44>;
				efuse_usr0@20 {
					reg = <0x20 0x04>;
					phandle = <0x45>;
				efuse_usr1@24 {
					reg = <0x24 0x04>;
					phandle = <0x46>;
				efuse_usr2@28 {
					reg = <0x28 0x04>;
					phandle = <0x47>;
				efuse_usr3@2c {
					reg = <0x2c 0x04>;
					phandle = <0x48>;
				efuse_usr4@30 {
					reg = <0x30 0x04>;
					phandle = <0x49>;
				efuse_usr5@34 {
					reg = <0x34 0x04>;
					phandle = <0x4a>;
				efuse_usr6@38 {
					reg = <0x38 0x04>;
					phandle = <0x4b>;
				efuse_usr7@3c {
					reg = <0x3c 0x04>;
					phandle = <0x4c>;
				efuse_miscusr@40 {
					reg = <0x40 0x04>;
					phandle = <0x4d>;
				efuse_chash@50 {
					reg = <0x50 0x04>;
					phandle = <0x4e>;
				efuse_pufmisc@54 {
					reg = <0x54 0x04>;
					phandle = <0x4f>;
				efuse_sec@58 {
					reg = <0x58 0x04>;
					phandle = <0x50>;
				efuse_spkid@5c {
					reg = <0x5c 0x04>;
					phandle = <0x51>;
				efuse_ppk0hash@a0 {
					reg = <0xa0 0x30>;
					phandle = <0x52>;
				efuse_ppk1hash@d0 {
					reg = <0xd0 0x30>;
					phandle = <0x53>;
			pcap {
				compatible = "xlnx,zynqmp-pcap-fpga";
				clock-names = "ref_clk";
				clocks = <0x03 0x29>;
				phandle = <0x0b>;
			zynqmp-aes {
				compatible = "xlnx,zynqmp-aes";
				phandle = <0x54>;
			reset-controller {
				compatible = "xlnx,zynqmp-reset";
				#reset-cells = <0x01>;
				phandle = <0x20>;
			pinctrl {
				compatible = "xlnx,zynqmp-pinctrl";
				status = "okay";
				phandle = <0x55>;
				i2c0-default {
					phandle = <0x15>;
					mux {
						groups = "i2c0_3_grp";
						function = "i2c0";
					conf {
						bias-pull-up;
						slew-rate = <0x01>;
						io-standard = <0x01>;
				i2c0-gpio {
					phandle = <0x16>;
					mux {
						groups = "gpio0_14_grp\0gpio0_15_grp";
						function = "gpio0";
					conf {
						slew-rate = <0x01>;
				i2c1-gpio {
					phandle = <0x17>;
					mux {
						groups = "gpio0_32_grp\0gpio0_33_grp";
						function = "gpio0";
					conf {
						slew-rate = <0x01>;
				uart1-default {
					phandle = <0x29>;
					mux {
						groups = "uart1_4_grp";
						function = "uart1";
					conf {
						slew-rate = <0x01>;
					conf-rx {
						pins = "MIO17";
						bias-high-impedance;
					conf-tx {
						pins = "MIO16";
						bias-disable;
				gem3-default {
					phandle = <0x12>;
					mux {
						function = "ethernet3";
						groups = "ethernet3_0_grp";
					conf {
						slew-rate = <0x01>;
					conf-rx {
						pins = "MIO70\0MIO71\0MIO72\0MIO73\0MIO74\0MIO75";
						low-power-disable;
					conf-tx {
						pins = "MIO64\0MIO65\0MIO66\0MIO67\0MIO68\0MIO69";
						bias-disable;
						low-power-enable;
					mux-mdio {
						function = "mdio3";
						groups = "mdio3_0_grp";
					conf-mdio {
						slew-rate = <0x01>;
						bias-disable;
				sdhci1-default {
					phandle = <0x21>;
					mux {
						groups = "sdio1_0_grp";
						function = "sdio1";
					conf {
						slew-rate = <0x01>;
						bias-disable;
					mux-cd {
						groups = "sdio1_cd_0_grp";
						function = "sdio1_cd";
					conf-cd {
						bias-pull-up;
						slew-rate = <0x01>;
					mux-wp {
						groups = "sdio1_wp_0_grp";
						function = "sdio1_wp";
					conf-wp {
						bias-pull-up;
						slew-rate = <0x01>;
				gpio-default {
					phandle = <0x14>;
					mux-usbsw {
						function = "gpio0";
						groups = "gpio0_35_grp\0gpio0_36_grp\0gpio0_37_grp\0gpio0_38_grp";
					conf-usbsw {
						slew-rate = <0x01>;
				usb0-default {
					phandle = <0x2b>;
					mux {
						groups = "usb0_0_grp";
						function = "usb0";
					conf {
						slew-rate = <0x01>;
					conf-rx {
						pins = "MIO52\0MIO53\0MIO55";
					conf-tx {
						pins = "MIO54\0MIO56\0MIO57\0MIO58\0MIO59\0MIO60\0MIO61\0MIO62\0MIO63";
						bias-disable;
			sha384 {
				compatible = "xlnx,zynqmp-keccak-384";
				phandle = <0x56>;
			zynqmp-rsa {
				compatible = "xlnx,zynqmp-rsa";
				phandle = <0x57>;
			gpio {
				compatible = "xlnx,zynqmp-gpio-modepin";
				gpio-controller;
				#gpio-cells = <0x02>;
				phandle = <0x2a>;
			clock-controller {
				#clock-cells = <0x01>;
				compatible = "xlnx,zynqmp-clk";
				clocks = <0x06 0x07 0x08 0x09 0x0a>;
				clock-names = "pss_ref_clk\0video_clk\0pss_alt_ref_clk\0aux_ref_clk\0gt_crx_ref_clk";
				phandle = <0x03>;
	timer {
		compatible = "arm,armv8-timer";
		interrupts = <0x01 0x0d 0xf08 0x01 0x0e 0xf08 0x01 0x0b 0xf08 0x01 0x0a 0xf08>;
	edac {
		compatible = "arm,cortex-a53-edac";
	fpga-full {
		compatible = "fpga-region";
		fpga-mgr = <0x0b>;
		ranges;
		phandle = <0x58>;
	axi {
		compatible = "simple-bus";
		ranges;
		phandle = <0x59>;
		can@ff060000 {
			compatible = "xlnx,zynq-can-1.0";
			clock-names = "can_clk\0pclk";
			reg = <0x00 0xff060000 0x00 0x1000>;
			interrupts = <0x00 0x17 0x04>;
			tx-fifo-depth = <0x40>;
			rx-fifo-depth = <0x40>;
			power-domains = <0x0c 0x2f>;
			clocks = <0x03 0x3f 0x03 0x1f>;
			phandle = <0x5a>;
		can@ff070000 {
			reg = <0x00 0xff070000 0x00 0x1000>;
			interrupts = <0x00 0x18 0x04>;
			power-domains = <0x0c 0x30>;
			clocks = <0x03 0x40 0x03 0x1f>;
			phandle = <0x5b>;
		cci@fd6e0000 {
			compatible = "arm,cci-400";
			reg = <0x00 0xfd6e0000 0x00 0x9000>;
			ranges = <0x00 0x00 0xfd6e0000 0x10000>;
			phandle = <0x5c>;
			pmu@9000 {
				compatible = "arm,cci-400-pmu,r1";
				reg = <0x9000 0x5000>;
				interrupts = <0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04 0x00 0x7b 0x04>;
		dma@fd500000 {
			compatible = "xlnx,zynqmp-dma-1.0";
			reg = <0x00 0xfd500000 0x00 0x1000>;
			interrupts = <0x00 0x7c 0x04>;
			clock-names = "clk_main\0clk_apb";
			xlnx,bus-width = <0x80>;
			#stream-id-cells = <0x01>;
			iommus = <0x0d 0x14e8>;
			power-domains = <0x0c 0x2a>;
			clocks = <0x03 0x13 0x03 0x1f>;
			phandle = <0x5d>;
		dma@fd510000 {
			reg = <0x00 0xfd510000 0x00 0x1000>;
			interrupts = <0x00 0x7d 0x04>;
			iommus = <0x0d 0x14e9>;
			phandle = <0x5e>;
		dma@fd520000 {
			reg = <0x00 0xfd520000 0x00 0x1000>;
			interrupts = <0x00 0x7e 0x04>;
			iommus = <0x0d 0x14ea>;
			phandle = <0x5f>;
		dma@fd530000 {
			reg = <0x00 0xfd530000 0x00 0x1000>;
			interrupts = <0x00 0x7f 0x04>;
			iommus = <0x0d 0x14eb>;
			phandle = <0x60>;
		dma@fd540000 {
			reg = <0x00 0xfd540000 0x00 0x1000>;
			interrupts = <0x00 0x80 0x04>;
			iommus = <0x0d 0x14ec>;
			phandle = <0x61>;
		dma@fd550000 {
			reg = <0x00 0xfd550000 0x00 0x1000>;
			interrupts = <0x00 0x81 0x04>;
			iommus = <0x0d 0x14ed>;
			phandle = <0x62>;
		dma@fd560000 {
			reg = <0x00 0xfd560000 0x00 0x1000>;
			interrupts = <0x00 0x82 0x04>;
			iommus = <0x0d 0x14ee>;
			phandle = <0x63>;
		dma@fd570000 {
			reg = <0x00 0xfd570000 0x00 0x1000>;
			interrupts = <0x00 0x83 0x04>;
			iommus = <0x0d 0x14ef>;
			phandle = <0x64>;
		interrupt-controller@f9010000 {
			compatible = "arm,gic-400";
			#interrupt-cells = <0x03>;
			reg = <0x00 0xf9010000 0x00 0x10000 0x00 0xf9020000 0x00 0x20000 0x00 0xf9040000 0x00 0x20000 0x00 0xf9060000 0x00 0x20000>;
			interrupt-controller;
			interrupts = <0x01 0x09 0xf04>;
			phandle = <0x04>;
		gpu@fd4b0000 {
			compatible = "arm,mali-400\0arm,mali-utgard";
			reg = <0x00 0xfd4b0000 0x00 0x10000>;
			interrupts = <0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04 0x00 0x84 0x04>;
			interrupt-names = "IRQGP\0IRQGPMMU\0IRQPP0\0IRQPPMMU0\0IRQPP1\0IRQPPMMU1";
			clock-names = "gpu\0gpu_pp0\0gpu_pp1";
			power-domains = <0x0c 0x3a>;
			clocks = <0x03 0x18 0x03 0x19 0x03 0x1a>;
			phandle = <0x65>;
		dma@ffa80000 {
			reg = <0x00 0xffa80000 0x00 0x1000>;
			interrupts = <0x00 0x4d 0x04>;
			xlnx,bus-width = <0x40>;
			power-domains = <0x0c 0x2b>;
			clocks = <0x03 0x44 0x03 0x1f>;
			phandle = <0x66>;
		dma@ffa90000 {
			reg = <0x00 0xffa90000 0x00 0x1000>;
			interrupts = <0x00 0x4e 0x04>;
			phandle = <0x67>;
		dma@ffaa0000 {
			reg = <0x00 0xffaa0000 0x00 0x1000>;
			interrupts = <0x00 0x4f 0x04>;
			phandle = <0x68>;
		dma@ffab0000 {
			reg = <0x00 0xffab0000 0x00 0x1000>;
			interrupts = <0x00 0x50 0x04>;
			phandle = <0x69>;
		dma@ffac0000 {
			reg = <0x00 0xffac0000 0x00 0x1000>;
			interrupts = <0x00 0x51 0x04>;
			phandle = <0x6a>;
		dma@ffad0000 {
			reg = <0x00 0xffad0000 0x00 0x1000>;
			interrupts = <0x00 0x52 0x04>;
			phandle = <0x6b>;
		dma@ffae0000 {
			reg = <0x00 0xffae0000 0x00 0x1000>;
			interrupts = <0x00 0x53 0x04>;
			phandle = <0x6c>;
		dma@ffaf0000 {
			reg = <0x00 0xffaf0000 0x00 0x1000>;
			interrupts = <0x00 0x54 0x04>;
			phandle = <0x6d>;
		memory-controller@fd070000 {
			compatible = "xlnx,zynqmp-ddrc-2.40a";
			reg = <0x00 0xfd070000 0x00 0x30000>;
			interrupts = <0x00 0x70 0x04>;
			phandle = <0x6e>;
		nand-controller@ff100000 {
			compatible = "xlnx,zynqmp-nand-controller\0arasan,nfc-v3p10";
			reg = <0x00 0xff100000 0x00 0x1000>;
			clock-names = "controller\0bus";
			interrupts = <0x00 0x0e 0x04>;
			iommus = <0x0d 0x872>;
			power-domains = <0x0c 0x2c>;
			clocks = <0x03 0x3c 0x03 0x1f>;
			phandle = <0x6f>;
		ethernet@ff0b0000 {
			compatible = "cdns,zynqmp-gem\0cdns,gem";
			status = "okay";
			interrupts = <0x00 0x39 0x04 0x00 0x39 0x04>;
			reg = <0x00 0xff0b0000 0x00 0x1000>;
			clock-names = "pclk\0hclk\0tx_clk\0rx_clk\0tsu_clk";
			iommus = <0x0d 0x874>;
			power-domains = <0x0c 0x1d>;
			clocks = <0x03 0x1f 0x03 0x68 0x03 0x2d 0x03 0x31 0x03 0x2c>;
			phy-handle = <0x0e>;
			phy-mode = "sgmii";
			phys = <0x0f 0x00 0x08 0x00 0x01>;
			mdiobus-connected = <0x10>;
			phandle = <0x70>;
		ethernet@ff0c0000 {
			interrupts = <0x00 0x3b 0x04 0x00 0x3b 0x04>;
			reg = <0x00 0xff0c0000 0x00 0x1000>;
			iommus = <0x0d 0x875>;
			power-domains = <0x0c 0x1e>;
			clocks = <0x03 0x1f 0x03 0x69 0x03 0x2e 0x03 0x32 0x03 0x2c>;
			phandle = <0x71>;
		ethernet@ff0d0000 {
			interrupts = <0x00 0x3d 0x04 0x00 0x3d 0x04>;
			reg = <0x00 0xff0d0000 0x00 0x1000>;
			iommus = <0x0d 0x876>;
			power-domains = <0x0c 0x1f>;
			clocks = <0x03 0x1f 0x03 0x6a 0x03 0x2f 0x03 0x33 0x03 0x2c>;
			phandle = <0x72>;
		ethernet@ff0e0000 {
			status = "okay";
			interrupts = <0x00 0x3f 0x04 0x00 0x3f 0x04>;
			reg = <0x00 0xff0e0000 0x00 0x1000>;
			iommus = <0x0d 0x877>;
			power-domains = <0x0c 0x20>;
			clocks = <0x03 0x1f 0x03 0x6b 0x03 0x30 0x03 0x34 0x03 0x2c>;
			phy-handle = <0x11>;
			phy-mode = "rgmii-id";
			pinctrl-names = "default";
			pinctrl-0 = <0x12>;
			phandle = <0x10>;
			phy@0 {
				device_type = "ethernet-phy";
				reg = <0x00>;
				marvell,reg-init = <0x03 0x10 0xff00 0x1e 0x03 0x11 0xfff0 0x00>;
				reset-gpios = <0x13 0x19 0x01>;
				phandle = <0x11>;
			phy@1 {
				reg = <0x01>;
				reset-gpios = <0x13 0x1f 0x01>;
				phandle = <0x0e>;
		gpio@ff0a0000 {
			compatible = "xlnx,zynqmp-gpio-1.0";
			status = "okay";
			gpio-controller;
			interrupts = <0x00 0x10 0x04>;
			#interrupt-cells = <0x02>;
			reg = <0x00 0xff0a0000 0x00 0x1000>;
			power-domains = <0x0c 0x2e>;
			clocks = <0x03 0x1f>;
			pinctrl-0 = <0x14>;
			phandle = <0x13>;
			phy_reset {
				gpio-hog;
				gpios = <0x0d 0x00>;
				output-high;
				line-name = "ulpi-phy-reset";
			hmc7044_ext_reset {
				gpio-hog;
				gpios = <0xa9 0x01>;
				output-high;
				line-name = "hmc7044_ext-reset";
			hmc7044_ext_vcxo_select {
				gpio-hog;
				gpios = <0xaa 0x00>;
				output-high;
				line-name = "hmc7044_ext-vcxo_select";
		i2c@ff020000 {
			compatible = "cdns,i2c-r1p14";
			status = "okay";
			interrupts = <0x00 0x11 0x04>;
			reg = <0x00 0xff020000 0x00 0x1000>;
			power-domains = <0x0c 0x25>;
			clocks = <0x03 0x3d>;
			clock-frequency = <0x61a80>;
			pinctrl-names = "default\0gpio";
			pinctrl-0 = <0x15>;
			pinctrl-1 = <0x16>;
			scl-gpios = <0x13 0x0e 0x00>;
			sda-gpios = <0x13 0x0f 0x00>;
			phandle = <0x73>;
			current_limiter@58 {
				compatible = "adi,adm1177-iio";
				reg = <0x58>;
				adi,r-sense-mohm = <0x0a>;
				adi,shutdown-threshold-ma = <0x2710>;
				adi,vrange-high-enable;
			ad9542@4b {
				compatible = "adi,ad9542";
				reg = <0x4b>;
			adm1266@48 {
				compatible = "adi,adm1266";
				reg = <0x48>;
			eeprom@2c {
				compatible = "24c16";
				reg = <0x2c>;
		i2c@ff030000 {
			status = "okay";
			interrupts = <0x00 0x12 0x04>;
			reg = <0x00 0xff030000 0x00 0x1000>;
			power-domains = <0x0c 0x26>;
			clocks = <0x03 0x3e>;
			pinctrl-names = "gpio";
			pinctrl-0 = <0x17>;
			scl-gpios = <0x13 0x20 0x00>;
			sda-gpios = <0x13 0x21 0x00>;
			phandle = <0x74>;
			i2c-mux@70 {
				compatible = "nxp,pca9548";
				reg = <0x70>;
				i2c@0 {
					reg = <0x00>;
					adau1761@3b {
						compatible = "adi,adau1761";
						reg = <0x3b>;
						clocks = <0x18>;
						clock-names = "mclk";
						#sound-dai-cells = <0x00>;
						phandle = <0x3b>;
				i2c@1 {
					reg = <0x01>;
					ad9545@4a {
						compatible = "adi,ad9545";
						reg = <0x4a>;
						adi,ref-crystal;
						adi,ref-frequency-hz = <0x2ee0000>;
						clock-names = "Ref-A";
						clocks = <0x19 0x00>;
						#clock-cells = <0x02>;
						assigned-clocks = <0x1a 0x02 0x00 0x1a 0x01 0x00 0x1a 0x00 0x00>;
						assigned-clock-rates = <0x2710 0x543a8000 0x1d4c000>;
						assigned-clock-phases = <0x00 0x00 0x00 0xb4>;
						phandle = <0x1a>;
						aux-nco-clk@0 {
							reg = <0x00>;
							adi,freq-lock-threshold-ps = <0xf42400>;
							adi,phase-lock-threshold-ps = <0xf42400>;
						ref-input-clk@0 {
							reg = <0x00>;
							adi,single-ended-mode = <0x02>;
							adi,r-divider-ratio = <0xc8>;
							adi,ref-dtol-pbb = <0x989680>;
							adi,ref-monitor-hysteresis-pbb = <0x155cc>;
							adi,ref-validation-timer-ms = <0x01>;
							adi,freq-lock-threshold-ps = <0xffffff>;
							adi,phase-lock-threshold-ps = <0xffffff>;
							adi,freq-lock-fill-rate = <0x14>;
							adi,freq-lock-drain-rate = <0x14>;
							adi,phase-lock-fill-rate = <0x14>;
							adi,phase-lock-drain-rate = <0x14>;
						pll-clk@0 {
							reg = <0x00>;
							phandle = <0x75>;
							profile@0 {
								reg = <0x00>;
								adi,pll-source = <0x04>;
								adi,profile-priority = <0x14>;
								adi,pll-loop-bandwidth-uhz = <0xbebc200>;
							profile@1 {
								reg = <0x01>;
								adi,pll-source = <0x00>;
								adi,profile-priority = <0x00>;
						output-clk@0 {
							reg = <0x00>;
							adi,output-mode = <0x00>;
							adi,current-source-microamp = <0x3a98>;
				i2c@2 {
					reg = <0x02>;
				i2c@3 {
					reg = <0x03>;
					eeprom@50 {
						compatible = "at24,24c02";
						reg = <0x50>;
				i2c@4 {
					reg = <0x04>;
					eeprom@50 {
						reg = <0x50>;
				i2c@5 {
					reg = <0x05>;
					phandle = <0x76>;
					eeprom@50 {
						reg = <0x50>;
		memory-controller@ff960000 {
			compatible = "xlnx,zynqmp-ocmc-1.0";
			reg = <0x00 0xff960000 0x00 0x1000>;
			interrupts = <0x00 0x0a 0x04>;
			phandle = <0x77>;
		perf-monitor@ffa00000 {
			compatible = "xlnx,axi-perf-monitor";
			reg = <0x00 0xffa00000 0x00 0x10000>;
			interrupts = <0x00 0x19 0x04>;
			xlnx,enable-profile = <0x00>;
			xlnx,enable-trace = <0x00>;
			xlnx,num-monitor-slots = <0x01>;
			xlnx,enable-event-count = <0x01>;
			xlnx,enable-event-log = <0x01>;
			xlnx,have-sampled-metric-cnt = <0x01>;
			xlnx,num-of-counters = <0x08>;
			xlnx,metric-count-width = <0x20>;
			xlnx,metrics-sample-count-width = <0x20>;
			xlnx,global-count-width = <0x20>;
			xlnx,metric-count-scale = <0x01>;
			phandle = <0x78>;
		perf-monitor@fd0b0000 {
			reg = <0x00 0xfd0b0000 0x00 0x10000>;
			interrupts = <0x00 0x7b 0x04>;
			xlnx,num-monitor-slots = <0x06>;
			xlnx,enable-event-log = <0x00>;
			xlnx,num-of-counters = <0x0a>;
			clocks = <0x03 0x1c>;
			phandle = <0x79>;
		perf-monitor@fd490000 {
			reg = <0x00 0xfd490000 0x00 0x10000>;
			phandle = <0x7a>;
		perf-monitor@ffa10000 {
			reg = <0x00 0xffa10000 0x00 0x10000>;
			phandle = <0x7b>;
		pcie@fd0e0000 {
			compatible = "xlnx,nwl-pcie-2.11";
			#address-cells = <0x03>;
			#interrupt-cells = <0x01>;
			msi-controller;
			device_type = "pci";
			interrupts = <0x00 0x76 0x04 0x00 0x75 0x04 0x00 0x74 0x04 0x00 0x73 0x04 0x00 0x72 0x04>;
			interrupt-names = "misc\0dummy\0intx\0msi1\0msi0";
			msi-parent = <0x1b>;
			reg = <0x00 0xfd0e0000 0x00 0x1000 0x00 0xfd480000 0x00 0x1000 0x80 0x00 0x00 0x1000000>;
			reg-names = "breg\0pcireg\0cfg";
			ranges = <0x2000000 0x00 0xe0000000 0x00 0xe0000000 0x00 0x10000000 0x43000000 0x06 0x00 0x06 0x00 0x02 0x00>;
			bus-range = <0x00 0xff>;
			interrupt-map-mask = <0x00 0x00 0x00 0x07>;
			interrupt-map = <0x00 0x00 0x00 0x01 0x1c 0x01 0x00 0x00 0x00 0x02 0x1c 0x02 0x00 0x00 0x00 0x03 0x1c 0x03 0x00 0x00 0x00 0x04 0x1c 0x04>;
			iommus = <0x0d 0x4d0>;
			power-domains = <0x0c 0x3b>;
			clocks = <0x03 0x17>;
			phandle = <0x1b>;
			legacy-interrupt-controller {
				#address-cells = <0x00>;
				phandle = <0x1c>;
		spi@ff0f0000 {
			compatible = "xlnx,zynqmp-qspi-1.0";
			status = "okay";
			clock-names = "ref_clk\0pclk";
			interrupts = <0x00 0x0f 0x04>;
			num-cs = <0x01>;
			reg = <0x00 0xff0f0000 0x00 0x1000 0x00 0xc0000000 0x00 0x8000000>;
			iommus = <0x0d 0x873>;
			power-domains = <0x0c 0x2d>;
			clocks = <0x03 0x35 0x03 0x1f>;
			is-dual = <0x01>;
			phandle = <0x7c>;
			qspi@0 {
				spi-tx-bus-width = <0x01>;
				spi-rx-bus-width = <0x04>;
				compatible = "n25q512a\0jedec,spi-nor";
				reg = <0x00>;
				spi-max-frequency = <0x2faf080>;
				phandle = <0x7d>;
				partition@qspi-fsbl-uboot {
					label = "qspi-fsbl-uboot";
					reg = <0x00 0x2000000>;
				partition@qspi-uboot-env {
					label = "qspi-uboot-env";
					reg = <0x2000000 0x20000>;
				partition@qspi-nvmfs {
					label = "qspi-nvmfs";
					reg = <0x2020000 0xe0000>;
				partition@qspi-linux {
					label = "qspi-linux";
					reg = <0x2100000 0x5e00000>;
		phy@fd400000 {
			compatible = "xlnx,zynqmp-psgtr-v1.1";
			status = "okay";
			reg = <0x00 0xfd400000 0x00 0x40000 0x00 0xfd3d0000 0x00 0x1000>;
			reg-names = "serdes\0siou";
			#phy-cells = <0x04>;
			clocks = <0x1d 0x1e 0x1f>;
			clock-names = "ref1\0ref2\0ref3";
			phandle = <0x0f>;
		rtc@ffa60000 {
			compatible = "xlnx,zynqmp-rtc";
			reg = <0x00 0xffa60000 0x00 0x100>;
			interrupts = <0x00 0x1a 0x04 0x00 0x1b 0x04>;
			interrupt-names = "alarm\0sec";
			calibration = <0x7fff>;
			phandle = <0x7e>;
		ahci@fd0c0000 {
			compatible = "ceva,ahci-1v84";
			reg = <0x00 0xfd0c0000 0x00 0x2000>;
			interrupts = <0x00 0x85 0x04>;
			power-domains = <0x0c 0x1c>;
			resets = <0x20 0x10>;
			#stream-id-cells = <0x04>;
			clocks = <0x03 0x16>;
			phandle = <0x7f>;
		mmc@ff160000 {
			compatible = "xlnx,zynqmp-8.9a\0arasan,sdhci-8.9a";
			interrupts = <0x00 0x30 0x04>;
			reg = <0x00 0xff160000 0x00 0x1000>;
			clock-names = "clk_xin\0clk_ahb";
			xlnx,device_id = <0x00>;
			iommus = <0x0d 0x870>;
			clock-output-names = "clk_out_sd0\0clk_in_sd0";
			power-domains = <0x0c 0x27>;
			clocks = <0x03 0x36 0x03 0x1f>;
			phandle = <0x80>;
		mmc@ff170000 {
			status = "okay";
			interrupts = <0x00 0x31 0x04>;
			reg = <0x00 0xff170000 0x00 0x1000>;
			xlnx,device_id = <0x01>;
			iommus = <0x0d 0x871>;
			clock-output-names = "clk_out_sd1\0clk_in_sd1";
			power-domains = <0x0c 0x28>;
			clocks = <0x03 0x37 0x03 0x1f>;
			pinctrl-0 = <0x21>;
			no-1-8-v;
			disable-wp;
			xlnx,mio_bank = <0x01>;
			phandle = <0x81>;
		iommu@fd800000 {
			compatible = "arm,mmu-500";
			reg = <0x00 0xfd800000 0x00 0x20000>;
			#iommu-cells = <0x01>;
			#global-interrupts = <0x01>;
			interrupts = <0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04 0x00 0x9b 0x04>;
			phandle = <0x0d>;
		spi@ff040000 {
			compatible = "cdns,spi-r1p6";
			status = "okay";
			interrupts = <0x00 0x13 0x04>;
			reg = <0x00 0xff040000 0x00 0x1000>;
			power-domains = <0x0c 0x23>;
			clocks = <0x03 0x3a 0x03 0x1f>;
			num-cs = <0x08>;
			is-decoded-cs = <0x01>;
			phandle = <0x82>;
			adrv9009-phy@0 {
				compatible = "adrv9009-x2";
				reg = <0x00>;
				spi-max-frequency = <0x17d7840>;
				interrupt-parent = <0x13>;
				clocks = <0x22 0x23 0x24 0x25 0x00 0x25 0x05 0x25 0x01 0x25 0x08 0x25 0x04>;
				clock-names = "jesd_rx_clk\0jesd_tx_clk\0jesd_rx_os_clk\0dev_clk\0fmc_clk\0sysref_dev_clk\0sysref_fmc_clk\0fmc2_clk";
				clock-output-names = "rx_sampl_clk\0rx_os_sampl_clk\0tx_sampl_clk";
				adi,jesd204-framer-a-bank-id = <0x01>;
				adi,jesd204-framer-a-device-id = <0x00>;
				adi,jesd204-framer-a-lane0-id = <0x00>;
				adi,jesd204-framer-a-m = <0x04>;
				adi,jesd204-framer-a-k = <0x20>;
				adi,jesd204-framer-a-f = <0x04>;
				adi,jesd204-framer-a-np = <0x10>;
				adi,jesd204-framer-a-scramble = <0x01>;
				adi,jesd204-framer-a-external-sysref = <0x01>;
				adi,jesd204-framer-a-serializer-lanes-enabled = <0x03>;
				adi,jesd204-framer-a-serializer-lane-crossbar = <0xe4>;
				adi,jesd204-framer-a-lmfc-offset = <0x0f>;
				adi,jesd204-framer-a-new-sysref-on-relink = <0x00>;
				adi,jesd204-framer-a-syncb-in-select = <0x00>;
				adi,jesd204-framer-a-over-sample = <0x00>;
				adi,jesd204-framer-a-syncb-in-lvds-mode = <0x01>;
				adi,jesd204-framer-a-syncb-in-lvds-pn-invert = <0x00>;
				adi,jesd204-framer-a-enable-manual-lane-xbar = <0x00>;
				adi,jesd204-framer-b-bank-id = <0x00>;
				adi,jesd204-framer-b-device-id = <0x00>;
				adi,jesd204-framer-b-lane0-id = <0x00>;
				adi,jesd204-framer-b-m = <0x02>;
				adi,jesd204-framer-b-k = <0x20>;
				adi,jesd204-framer-b-f = <0x04>;
				adi,jesd204-framer-b-np = <0x10>;
				adi,jesd204-framer-b-scramble = <0x01>;
				adi,jesd204-framer-b-external-sysref = <0x01>;
				adi,jesd204-framer-b-serializer-lanes-enabled = <0x0c>;
				adi,jesd204-framer-b-serializer-lane-crossbar = <0xe4>;
				adi,jesd204-framer-b-lmfc-offset = <0x0f>;
				adi,jesd204-framer-b-new-sysref-on-relink = <0x00>;
				adi,jesd204-framer-b-syncb-in-select = <0x01>;
				adi,jesd204-framer-b-over-sample = <0x00>;
				adi,jesd204-framer-b-syncb-in-lvds-mode = <0x01>;
				adi,jesd204-framer-b-syncb-in-lvds-pn-invert = <0x00>;
				adi,jesd204-framer-b-enable-manual-lane-xbar = <0x00>;
				adi,jesd204-deframer-a-bank-id = <0x00>;
				adi,jesd204-deframer-a-device-id = <0x00>;
				adi,jesd204-deframer-a-lane0-id = <0x00>;
				adi,jesd204-deframer-a-m = <0x04>;
				adi,jesd204-deframer-a-k = <0x20>;
				adi,jesd204-deframer-a-scramble = <0x01>;
				adi,jesd204-deframer-a-external-sysref = <0x01>;
				adi,jesd204-deframer-a-deserializer-lanes-enabled = <0x0f>;
				adi,jesd204-deframer-a-deserializer-lane-crossbar = <0xe4>;
				adi,jesd204-deframer-a-lmfc-offset = <0x01>;
				adi,jesd204-deframer-a-new-sysref-on-relink = <0x00>;
				adi,jesd204-deframer-a-syncb-out-select = <0x00>;
				adi,jesd204-deframer-a-np = <0x10>;
				adi,jesd204-deframer-a-syncb-out-lvds-mode = <0x01>;
				adi,jesd204-deframer-a-syncb-out-lvds-pn-invert = <0x00>;
				adi,jesd204-deframer-a-syncb-out-cmos-slew-rate = <0x00>;
				adi,jesd204-deframer-a-syncb-out-cmos-drive-level = <0x00>;
				adi,jesd204-deframer-a-enable-manual-lane-xbar = <0x00>;
				adi,jesd204-ser-amplitude = <0x0f>;
				adi,jesd204-ser-pre-emphasis = <0x01>;
				adi,jesd204-ser-invert-lane-polarity = <0x00>;
				adi,jesd204-des-invert-lane-polarity = <0x00>;
				adi,jesd204-des-eq-setting = <0x01>;
				adi,jesd204-sysref-lvds-mode = <0x01>;
				adi,jesd204-sysref-lvds-pn-invert = <0x00>;
				adi,rx-profile-rx-fir-gain_db = <0xfffffff6>;
				adi,rx-profile-rx-fir-num-fir-coefs = <48>;
				adi,rx-profile-rx-fir-coefs = /bits/ 16 <(1) (7) (3) (-20) (-37) (10) (103) (94) (-119) (-320) (-106) (486) (686) (-159) (-1327) (-1049) (1157) (2875) (963) (-3904) (-5960) (463) (13871) (25049) (25049) (13871) (463) (-5960) (-3904) (963) (2875) (1157) (-1049) (-1327) (-159) (686) (486) (-106) (-320) (-119) (94) (103) (10) (-37) (-20) (3) (7) (1)>;
				adi,rx-profile-rx-fir-decimation = <2>;
				adi,rx-profile-rx-dec5-decimation = <4>;
				adi,rx-profile-rhb1-decimation = <1>;
				adi,rx-profile-rx-output-rate_khz = <240000>;
				adi,rx-profile-rf-bandwidth_hz = <120000000>;
				adi,rx-profile-rx-bbf3d-bcorner_khz = <120000>;
				adi,rx-profile-rx-adc-profile = /bits/ 16 <(248) (146) (181) (90) (1280) (487) (1274) (38) (1287) (23) (779) (35) (48) (46) (29) (175) (0) (0) (0) (0) (44) (0) (7) (6) (42) (0) (7) (6) (42) (0) (25) (27) (0) (0) (25) (27) (0) (0) (165) (44) (31) (905)>;
				adi,rx-profile-rx-ddc-mode = <0>;
				adi,rx-nco-shifter-band-a-input-band-width_khz = <0x00>;
				adi,rx-nco-shifter-band-a-input-center-freq_khz = <0x00>;
				adi,rx-nco-shifter-band-a-nco1-freq_khz = <0x00>;
				adi,rx-nco-shifter-band-a-nco2-freq_khz = <0x00>;
				adi,rx-nco-shifter-band-binput-band-width_khz = <0x00>;
				adi,rx-nco-shifter-band-binput-center-freq_khz = <0x00>;
				adi,rx-nco-shifter-band-bnco1-freq_khz = <0x00>;
				adi,rx-nco-shifter-band-bnco2-freq_khz = <0x00>;
				adi,rx-gain-control-gain-mode = <0x00>;
				adi,rx-gain-control-rx1-gain-index = <0xff>;
				adi,rx-gain-control-rx2-gain-index = <0xff>;
				adi,rx-gain-control-rx1-max-gain-index = <0xff>;
				adi,rx-gain-control-rx1-min-gain-index = <0xc3>;
				adi,rx-gain-control-rx2-max-gain-index = <0xff>;
				adi,rx-gain-control-rx2-min-gain-index = <0xc3>;
				adi,rx-settings-framer-sel = <0x00>;
				adi,rx-settings-rx-channels = <0x03>;
				adi,orx-profile-rx-fir-gain_db = <0xfffffff6>;
				adi,orx-profile-rx-fir-num-fir-coefs = <48>;
				adi,orx-profile-rx-fir-coefs = /bits/ 16 <(1) (6) (2) (-18) (-29) (10) (77) (49) (-138) (-282) (-59) (452) (574) (-198) (-1172) (-840) (1097) (2473) (662) (-3527) (-4937) (1282) (13584) (23699) (23699) (13584) (1282) (-4937) (-3527) (662) (2473) (1097) (-840) (-1172) (-198) (574) (452) (-59) (-282) (-138) (49) (77) (10) (-29) (-18) (2) (6) (1)>;
				adi,orx-profile-rx-fir-decimation = <2>;
				adi,orx-profile-rx-dec5-decimation = <4>;
				adi,orx-profile-rhb1-decimation = <1>;
				adi,orx-profile-orx-output-rate_khz = <240000>;
				adi,orx-profile-rf-bandwidth_hz = <120000000>;
				adi,orx-profile-rx-bbf3d-bcorner_khz = <225000>;
				adi,orx-profile-orx-low-pass-adc-profile = /bits/ 16 <(248) (146) (181) (90) (1280) (487) (1274) (38) (1287) (23) (779) (35) (48) (46) (29) (175) (0) (0) (0) (0) (44) (0) (7) (6) (42) (0) (7) (6) (42) (0) (25) (27) (0) (0) (25) (27) (0) (0) (165) (44) (31) (905)>;
				adi,orx-profile-orx-band-pass-adc-profile = /bits/ 16 <(248) (146) (181) (90) (1280) (487) (1274) (38) (1287) (23) (779) (35) (48) (46) (29) (175) (0) (0) (0) (0) (44) (0) (7) (6) (42) (0) (7) (6) (42) (0) (25) (27) (0) (0) (25) (27) (0) (0) (165) (44) (31) (905)>;
				adi,orx-profile-orx-ddc-mode = <0>;
				adi,orx-profile-orx-merge-filter = <0x00 0x00 0x00 0x00 0x00 0x00>;
				adi,orx-gain-control-gain-mode = <0x00>;
				adi,orx-gain-control-orx1-gain-index = <0xff>;
				adi,orx-gain-control-orx2-gain-index = <0xff>;
				adi,orx-gain-control-orx1-max-gain-index = <0xff>;
				adi,orx-gain-control-orx1-min-gain-index = <0xc3>;
				adi,orx-gain-control-orx2-max-gain-index = <0xff>;
				adi,orx-gain-control-orx2-min-gain-index = <0xc3>;
				adi,obs-settings-framer-sel = <0x01>;
				adi,obs-settings-obs-rx-channels-enable = <0x03>;
				adi,obs-settings-obs-rx-lo-source = <0x00>;
				adi,tx-profile-tx-fir-gain_db = <0>;
				adi,tx-profile-tx-fir-num-fir-coefs = <20>;
				adi,tx-profile-tx-fir-coefs = /bits/ 16 <(-706) (87) (1408) (-1846) (-766) (3925) (-1297) (-6533) (9635) (23842) (9635) (-6533) (-1297) (3925) (-766) (-1846) (1408) (87) (-706) (0)>;
				adi,tx-profile-dac-div = <1>;
				adi,tx-profile-tx-fir-interpolation = <1>;
				adi,tx-profile-thb1-interpolation = <2>;
				adi,tx-profile-thb2-interpolation = <2>;
				adi,tx-profile-thb3-interpolation = <2>;
				adi,tx-profile-tx-int5-interpolation = <1>;
				adi,tx-profile-tx-input-rate_khz = <240000>;
				adi,tx-profile-primary-sig-bandwidth_hz = <80000000>;
				adi,tx-profile-rf-bandwidth_hz = <120000000>;
				adi,tx-profile-tx-dac3d-bcorner_khz = <187000>;
				adi,tx-profile-tx-bbf3d-bcorner_khz = <60000>;
				adi,tx-profile-loop-back-adc-profile = <0xce0084 0xa8005a 0x5000281 0x51b0035 0x54f001c 0x40f001e 0x300030 0x2500d2 0x00 0x00 0x350000 0x70006 0x2a0000 0x70006 0x2a0000 0x19001b 0x00 0x19001b 0x00 0xa5002c 0x1f0389>;
				adi,tx-settings-deframer-sel = <0x00>;
				adi,tx-settings-tx-channels = <0x03>;
				adi,tx-settings-tx-atten-step-size = <0x00>;
				adi,tx-settings-tx1-atten_md-b = <0x2710>;
				adi,tx-settings-tx2-atten_md-b = <0x2710>;
				adi,tx-settings-dis-tx-data-if-pll-unlock = <0x00>;
				adi,dig-clocks-device-clock_khz = <240000>;
				adi,dig-clocks-clk-pll-vco-freq_khz = <9600000>;
				adi,dig-clocks-clk-pll-hs-div = <0x01>;
				adi,dig-clocks-rf-pll-use-external-lo = <0x00>;
				adi,dig-clocks-rf-pll-phase-sync-mode = <0x03>;
				adi,rxagc-peak-agc-under-range-low-interval_ns = <0xcd>;
				adi,rxagc-peak-agc-under-range-mid-interval = <0x02>;
				adi,rxagc-peak-agc-under-range-high-interval = <0x04>;
				adi,rxagc-peak-apd-high-thresh = <0x27>;
				adi,rxagc-peak-apd-low-gain-mode-high-thresh = <0x24>;
				adi,rxagc-peak-apd-low-thresh = <0x17>;
				adi,rxagc-peak-apd-low-gain-mode-low-thresh = <0x13>;
				adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt = <0x06>;
				adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt = <0x03>;
				adi,rxagc-peak-apd-gain-step-attack = <0x04>;
				adi,rxagc-peak-apd-gain-step-recovery = <0x02>;
				adi,rxagc-peak-enable-hb2-overload = <0x01>;
				adi,rxagc-peak-hb2-overload-duration-cnt = <0x01>;
				adi,rxagc-peak-hb2-overload-thresh-cnt = <0x04>;
				adi,rxagc-peak-hb2-high-thresh = <0xb5>;
				adi,rxagc-peak-hb2-under-range-low-thresh = <0x2d>;
				adi,rxagc-peak-hb2-under-range-mid-thresh = <0x5a>;
				adi,rxagc-peak-hb2-under-range-high-thresh = <0x80>;
				adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt = <0x06>;
				adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt = <0x03>;
				adi,rxagc-peak-hb2-gain-step-high-recovery = <0x02>;
				adi,rxagc-peak-hb2-gain-step-low-recovery = <0x04>;
				adi,rxagc-peak-hb2-gain-step-mid-recovery = <0x08>;
				adi,rxagc-peak-hb2-gain-step-attack = <0x04>;
				adi,rxagc-peak-hb2-overload-power-mode = <0x01>;
				adi,rxagc-peak-hb2-ovrg-sel = <0x00>;
				adi,rxagc-peak-hb2-thresh-config = <0x03>;
				adi,rxagc-power-power-enable-measurement = <0x01>;
				adi,rxagc-power-power-use-rfir-out = <0x01>;
				adi,rxagc-power-power-use-bbdc2 = <0x00>;
				adi,rxagc-power-under-range-high-power-thresh = <0x09>;
				adi,rxagc-power-under-range-low-power-thresh = <0x02>;
				adi,rxagc-power-under-range-high-power-gain-step-recovery = <0x04>;
				adi,rxagc-power-under-range-low-power-gain-step-recovery = <0x04>;
				adi,rxagc-power-power-measurement-duration = <0x05>;
				adi,rxagc-power-rx1-tdd-power-meas-duration = <0x05>;
				adi,rxagc-power-rx1-tdd-power-meas-delay = <0x01>;
				adi,rxagc-power-rx2-tdd-power-meas-duration = <0x05>;
				adi,rxagc-power-rx2-tdd-power-meas-delay = <0x01>;
				adi,rxagc-power-upper0-power-thresh = <0x02>;
				adi,rxagc-power-upper1-power-thresh = <0x00>;
				adi,rxagc-power-power-log-shift = <0x00>;
				adi,rxagc-agc-peak-wait-time = <0x04>;
				adi,rxagc-agc-rx1-max-gain-index = <0xff>;
				adi,rxagc-agc-rx1-min-gain-index = <0xc3>;
				adi,rxagc-agc-rx2-max-gain-index = <0xff>;
				adi,rxagc-agc-rx2-min-gain-index = <0xc3>;
				adi,rxagc-agc-gain-update-counter_us = <0xfa>;
				adi,rxagc-agc-rx1-attack-delay = <0x0a>;
				adi,rxagc-agc-rx2-attack-delay = <0x0a>;
				adi,rxagc-agc-slow-loop-settling-delay = <0x10>;
				adi,rxagc-agc-low-thresh-prevent-gain = <0x00>;
				adi,rxagc-agc-change-gain-if-thresh-high = <0x01>;
				adi,rxagc-agc-peak-thresh-gain-control-mode = <0x01>;
				adi,rxagc-agc-reset-on-rxon = <0x00>;
				adi,rxagc-agc-enable-sync-pulse-for-gain-counter = <0x00>;
				adi,rxagc-agc-enable-ip3-optimization-thresh = <0x00>;
				adi,rxagc-ip3-over-range-thresh = <0x1f>;
				adi,rxagc-ip3-over-range-thresh-index = <0xf6>;
				adi,rxagc-ip3-peak-exceeded-cnt = <0x04>;
				adi,rxagc-agc-enable-fast-recovery-loop = <0x00>;
				adi,aux-dac-enables = <0x00>;
				adi,aux-dac-vref0 = <0x03>;
				adi,aux-dac-resolution0 = <0x00>;
				adi,aux-dac-values0 = <0x00>;
				adi,aux-dac-vref1 = <0x03>;
				adi,aux-dac-resolution1 = <0x00>;
				adi,aux-dac-values1 = <0x00>;
				adi,aux-dac-vref2 = <0x03>;
				adi,aux-dac-resolution2 = <0x00>;
				adi,aux-dac-values2 = <0x00>;
				adi,aux-dac-vref3 = <0x03>;
				adi,aux-dac-resolution3 = <0x00>;
				adi,aux-dac-values3 = <0x00>;
				adi,aux-dac-vref4 = <0x03>;
				adi,aux-dac-resolution4 = <0x00>;
				adi,aux-dac-values4 = <0x00>;
				adi,aux-dac-vref5 = <0x03>;
				adi,aux-dac-resolution5 = <0x00>;
				adi,aux-dac-values5 = <0x00>;
				adi,aux-dac-vref6 = <0x03>;
				adi,aux-dac-resolution6 = <0x00>;
				adi,aux-dac-values6 = <0x00>;
				adi,aux-dac-vref7 = <0x03>;
				adi,aux-dac-resolution7 = <0x00>;
				adi,aux-dac-values7 = <0x00>;
				adi,aux-dac-vref8 = <0x03>;
				adi,aux-dac-resolution8 = <0x00>;
				adi,aux-dac-values8 = <0x00>;
				adi,aux-dac-vref9 = <0x03>;
				adi,aux-dac-resolution9 = <0x00>;
				adi,aux-dac-values9 = <0x00>;
				adi,aux-dac-vref10 = <0x03>;
				adi,aux-dac-resolution10 = <0x00>;
				adi,aux-dac-values10 = <0x00>;
				adi,aux-dac-vref11 = <0x03>;
				adi,aux-dac-resolution11 = <0x00>;
				adi,aux-dac-values11 = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel0-pin-polarity = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel0-pin-enable = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel1-pin-polarity = <0x00>;
				adi,arm-gpio-config-orx1-tx-sel1-pin-enable = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel0-pin-polarity = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel0-pin-enable = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel1-pin-polarity = <0x00>;
				adi,arm-gpio-config-orx2-tx-sel1-pin-enable = <0x00>;
				adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel = <0x00>;
				adi,arm-gpio-config-en-tx-tracking-cals-polarity = <0x00>;
				adi,arm-gpio-config-en-tx-tracking-cals-enable = <0x00>;
				adi,orx-lo-cfg-disable-aux-pll-relocking = <0x00>;
				adi,orx-lo-cfg-gpio-select = <0x13>;
				adi,fhm-config-fhm-gpio-pin = <0x00>;
				adi,fhm-config-fhm-min-freq_mhz = <0x960>;
				adi,fhm-config-fhm-max-freq_mhz = <0x9c4>;
				adi,fhm-mode-fhm-enable = <0x00>;
				adi,fhm-mode-enable-mcs-sync = <0x00>;
				adi,fhm-mode-fhm-trigger-mode = <0x00>;
				adi,fhm-mode-fhm-exit-mode = <0x01>;
				adi,fhm-mode-fhm-init-frequency_hz = <0x92080880>;
				adi,rx1-gain-ctrl-pin-inc-step = <0x01>;
				adi,rx1-gain-ctrl-pin-dec-step = <0x01>;
				adi,rx1-gain-ctrl-pin-rx-gain-inc-pin = <0x00>;
				adi,rx1-gain-ctrl-pin-rx-gain-dec-pin = <0x01>;
				adi,rx1-gain-ctrl-pin-enable = <0x00>;
				adi,rx2-gain-ctrl-pin-inc-step = <0x01>;
				adi,rx2-gain-ctrl-pin-dec-step = <0x01>;
				adi,rx2-gain-ctrl-pin-rx-gain-inc-pin = <0x03>;
				adi,rx2-gain-ctrl-pin-rx-gain-dec-pin = <0x04>;
				adi,rx2-gain-ctrl-pin-enable = <0x00>;
				adi,tx1-atten-ctrl-pin-step-size = <0x00>;
				adi,tx1-atten-ctrl-pin-tx-atten-inc-pin = <0x04>;
				adi,tx1-atten-ctrl-pin-tx-atten-dec-pin = <0x05>;
				adi,tx1-atten-ctrl-pin-enable = <0x00>;
				adi,tx2-atten-ctrl-pin-step-size = <0x00>;
				adi,tx2-atten-ctrl-pin-tx-atten-inc-pin = <0x06>;
				adi,tx2-atten-ctrl-pin-tx-atten-dec-pin = <0x07>;
				adi,tx2-atten-ctrl-pin-enable = <0x00>;
				adi,tx-pa-protection-avg-duration = <0x03>;
				adi,tx-pa-protection-tx-atten-step = <0x02>;
				adi,tx-pa-protection-tx1-power-threshold = <0x1000>;
				adi,tx-pa-protection-tx2-power-threshold = <0x1000>;
				adi,tx-pa-protection-peak-count = <0x04>;
				adi,tx-pa-protection-tx1-peak-threshold = <0x8c>;
				adi,tx-pa-protection-tx2-peak-threshold = <0x8c>;
				reset-gpios = <0x13 0x82 0x00>;
				test-gpios = <0x13 0x83 0x00>;
				rx1-enable-gpios = <0x13 0x84 0x00>;
				rx2-enable-gpios = <0x13 0x85 0x00>;
				tx1-enable-gpios = <0x13 0x86 0x00>;
				tx2-enable-gpios = <0x13 0x87 0x00>;
				sysref-req-gpio = <0x13 0xa7 0x00>;
				jesd204-device;
				#jesd204-cells = <0x02>;
				jesd204-top-device = <0x00>;
				jesd204-link-ids = <0x00 0x01 0x02>;
				jesd204-inputs = <0x26 0x00 0x01 0x26 0x00 0x02 0x26 0x00 0x00>;
				phandle = <0x35>;
			adrv9009-phy-b@1 {
				compatible = "adrv9009";
				reg = <0x01>;
				clocks = <0x22 0x23 0x24 0x25 0x02 0x25 0x05 0x25 0x03 0x25 0x09 0x25 0x04>;
				reset-gpios = <0x13 0x9c 0x00>;
				test-gpios = <0x13 0x9d 0x00>;
				rx1-enable-gpios = <0x13 0x9e 0x00>;
				rx2-enable-gpios = <0x13 0x9f 0x00>;
				tx1-enable-gpios = <0x13 0xa0 0x00>;
				tx2-enable-gpios = <0x13 0xa1 0x00>;
				jesd204-device;
				jesd204-inputs = <0x22 0x00 0x01 0x24 0x00 0x02 0x27 0x00 0x00>;
				phandle = <0x26>;
			hmc7044@2 {
				compatible = "adi,hmc7044";
				reg = <0x02>;
				spi-max-frequency = <0x989680>;
				adi,pll1-clkin-frequencies = <0x4c4b400 0x4c4b400 0x00 0x00>;
				adi,pll1-ref-prio-ctrl = <0xaa>;
				adi,clkin0-buffer-mode = <0x09>;
				adi,clkin1-buffer-mode = <0x0b>;
				adi,sync-pin-mode = <0x01>;
				adi,pfd1-maximum-limit-frequency-hz = <0x4c4b400>;
				adi,vcxo-frequency = <0x4c4b400>;
				adi,pll2-output-frequency = <2400000000>;
				adi,sysref-timer-divider = <0xf00>;
				adi,pulse-generator-mode = <0x05>;
				adi,oscin-buffer-mode = <0x15>;
				adi,gpi-controls = <0x00 0x00 0x00 0x11>;
				adi,gpo-controls = <0x1f 0x2b 0x00 0x00>;
				adi,high-performance-mode-clock-dist-enable;
				clock-output-names = "hmc7044_out0_DEV_REFCLK_A\0hmc7044_out1_DEV_SYSREF_A\0hmc7044_out2_DEV_REFCLK_B\0hmc7044_out3_DEV_SYSREF_B\0hmc7044_out4_JESD_REFCLK_TX_OBS_AB\0hmc7044_out5_JESD_REFCLK_RX_AB\0hmc7044_out6_CORE_CLK_TX_OBS_AB\0hmc7044_out7_CORE_CLK_RX_AB\0hmc7044_out8_FPGA_SYSREF_TX_OBS_AB\0hmc7044_out9_FPGA_SYSREF_RX_AB\0hmc7044_out10\0hmc7044_out11\0hmc7044_out12\0hmc7044_out13";
				clocks = <0x28 0x02>;
				clock-names = "clkin1";
				jesd204-device;
				jesd204-inputs = <0x28 0x00 0x01 0x28 0x00 0x02 0x28 0x00 0x00>;
				adi,hmc-two-level-tree-sync-en;
				phandle = <0x25>;
				channel@0 {
					reg = <0x00>;
					adi,extended-name = "DEV_REFCLK_A";
					adi,divider = <0x0c>;
					adi,driver-mode = <0x02>;
					adi,coarse-digital-delay = <0x0f>;
					phandle = <0x83>;
				channel@1 {
					reg = <0x01>;
					adi,extended-name = "DEV_SYSREF_A";
					adi,divider = <0xf00>;
					adi,driver-mode = <0x01>;
					adi,startup-mode-dynamic-enable;
					adi,high-performance-mode-disable;
					adi,driver-impedance-mode = <0x01>;
					adi,force-mute-enable;
					phandle = <0x84>;
				channel@2 {
					reg = <0x02>;
					adi,extended-name = "DEV_REFCLK_B";
					phandle = <0x85>;
				channel@3 {
					reg = <0x03>;
					adi,extended-name = "DEV_SYSREF_B";
					phandle = <0x86>;
				channel@4 {
					reg = <0x04>;
					adi,extended-name = "JESD_REFCLK_TX_OBS_AB";
					phandle = <0x87>;
				channel@5 {
					reg = <0x05>;
					adi,extended-name = "JESD_REFCLK_RX_AB";
					phandle = <0x88>;
				channel@6 {
					reg = <0x06>;
					adi,extended-name = "CORE_CLK_TX_OBS_AB";
					adi,divider = <0x18>;
					adi,driver-mode = <0x00>;
					phandle = <0x89>;
				channel@7 {
					reg = <0x07>;
					adi,extended-name = "CORE_CLK_RX_AB";
					phandle = <0x8a>;
				channel@8 {
					reg = <0x08>;
					adi,extended-name = "FPGA_SYSREF_TX_OBS_AB";
					phandle = <0x8b>;
				channel@9 {
					reg = <0x09>;
					adi,extended-name = "FPGA_SYSREF_RX_AB";
					phandle = <0x8c>;
			hmc7044-car@3 {
				reg = <0x03>;
				adi,pll1-clkin-frequencies = <0x4c4b400 0x4c4b400 0x00 0x249f000>;
				adi,pll1-ref-autorevert-enable;
				adi,clkin1-buffer-mode = <0x07>;
				adi,clkin3-buffer-mode = <0x11>;
				adi,sync-pin-mode = <0x00>;
				clock-output-names = "hmc7044_c_out0_REFCLK_OUT0\0hmc7044_c_out1\0hmc7044_c_out2_REFCLK_OUT2\0hmc7044_c_out3\0hmc7044_c_out4\0hmc7044_c_out5_SYNC_OUT1\0hmc7044_c_out6_SYNC_OUT2\0hmc7044_c_out7\0hmc7044_c_out8_REFCLK_OUT3\0hmc7044_c_out9_REFCLK_OUT4\0hmc7044_c_out10_REFCLK_QSFP\0hmc7044_c_out11_REFCLK_SFP\0hmc7044_c_out12\0hmc7044_c_out13";
				adi,clkin0-buffer-mode = <0x07>;
				jesd204-device;
				jesd204-sysref-provider;
				phandle = <0x28>;
				channel@0 {
					reg = <0x00>;
					adi,extended-name = "REFCLK_OUT0";
					adi,divider = <0x60>;
					phandle = <0x8d>;
				channel@2 {
					reg = <0x02>;
					adi,extended-name = "REFCLK_OUT2";
					phandle = <0x8e>;
				channel@5 {
					reg = <0x05>;
					adi,extended-name = "SYNC_OUT1";
					adi,driver-mode = <0x03>;
					adi,driver-impedance-mode = <0x03>;
					phandle = <0x8f>;
				channel@6 {
					reg = <0x06>;
					adi,extended-name = "SYNC_OUT2";
					phandle = <0x90>;
				channel@8 {
					reg = <0x08>;
					adi,extended-name = "REFCLK_OUT3";
					phandle = <0x91>;
				channel@9 {
					reg = <0x09>;
					adi,extended-name = "REFCLK_OUT4";
					phandle = <0x92>;
				channel@10 {
					reg = <0x0a>;
					adi,extended-name = "REFCLK_QSFP";
					phandle = <0x93>;
				channel@11 {
					reg = <0x0b>;
					adi,extended-name = "REFCLK_SFP";
					phandle = <0x94>;
			hmc7044-ext@4 {
				reg = <0x04>;
				spi-max-frequency = <0xf4240>;
				adi,pll1-clkin-frequencies = <0x00 0x1d4c000 0x1d4c000 0x249f000>;
				adi,pll1-loop-bandwidth-hz = <0xc8>;
				adi,pfd1-maximum-limit-frequency-hz = <0x3a9800>;
				adi,pll1-ref-prio-ctrl = <0x39>;
				adi,vcxo-frequency = <0x7530000>;
				adi,pll2-output-frequency = <0xafc80000>;
				adi,pulse-generator-mode = <0x01>;
				adi,clkin2-buffer-mode = <0x07>;
				adi,clkin3-buffer-mode = <0x07>;
				adi,gpi-controls = <0x00 0x00 0x00 0x00>;
				clock-output-names = "hmc7044_e_out0\0hmc7044_e_out1\0hmc7044_e_out2\0hmc7044_e_out3\0hmc7044_e_out4_SYNC_OUT1\0hmc7044_e_out5_REFCLK_OUT0\0hmc7044_e_out6_SYNC_OUT2\0hmc7044_e_out7\0hmc7044_e_out8\0hmc7044_e_out9\0hmc7044_e_out10\0hmc7044_e_out11\0hmc7044_e_out12_REFCLK_OUT2\0hmc7044_e_out13";
				phandle = <0x95>;
				channel@4 {
					reg = <0x04>;
					phandle = <0x96>;
				channel@5 {
					reg = <0x05>;
					phandle = <0x97>;
				channel@6 {
					reg = <0x06>;
					phandle = <0x98>;
				channel@12 {
					reg = <0x0c>;
					phandle = <0x99>;
		spi@ff050000 {
			interrupts = <0x00 0x14 0x04>;
			reg = <0x00 0xff050000 0x00 0x1000>;
			power-domains = <0x0c 0x24>;
			clocks = <0x03 0x3b 0x03 0x1f>;
			phandle = <0x9a>;
		timer@ff110000 {
			compatible = "cdns,ttc";
			interrupts = <0x00 0x24 0x04 0x00 0x25 0x04 0x00 0x26 0x04>;
			reg = <0x00 0xff110000 0x00 0x1000>;
			timer-width = <0x20>;
			power-domains = <0x0c 0x18>;
			phandle = <0x9b>;
		timer@ff120000 {
			interrupts = <0x00 0x27 0x04 0x00 0x28 0x04 0x00 0x29 0x04>;
			reg = <0x00 0xff120000 0x00 0x1000>;
			power-domains = <0x0c 0x19>;
			phandle = <0x9c>;
		timer@ff130000 {
			interrupts = <0x00 0x2a 0x04 0x00 0x2b 0x04 0x00 0x2c 0x04>;
			reg = <0x00 0xff130000 0x00 0x1000>;
			power-domains = <0x0c 0x1a>;
			phandle = <0x9d>;
		timer@ff140000 {
			interrupts = <0x00 0x2d 0x04 0x00 0x2e 0x04 0x00 0x2f 0x04>;
			reg = <0x00 0xff140000 0x00 0x1000>;
			power-domains = <0x0c 0x1b>;
			phandle = <0x9e>;
		serial@ff000000 {
			compatible = "cdns,uart-r1p12\0xlnx,xuartps";
			interrupts = <0x00 0x15 0x04>;
			reg = <0x00 0xff000000 0x00 0x1000>;
			clock-names = "uart_clk\0pclk";
			power-domains = <0x0c 0x21>;
			clocks = <0x03 0x38 0x03 0x1f>;
			phandle = <0x9f>;
		serial@ff010000 {
			status = "okay";
			interrupts = <0x00 0x16 0x04>;
			reg = <0x00 0xff010000 0x00 0x1000>;
			power-domains = <0x0c 0x22>;
			clocks = <0x03 0x39 0x03 0x1f>;
			pinctrl-0 = <0x29>;
			phandle = <0xa0>;
		usb0@ff9d0000 {
			status = "okay";
			compatible = "xlnx,zynqmp-dwc3";
			reg = <0x00 0xff9d0000 0x00 0x100>;
			clock-names = "bus_clk\0ref_clk";
			power-domains = <0x0c 0x16>;
			resets = <0x20 0x3b 0x20 0x3d 0x20 0x3f>;
			reset-names = "usb_crst\0usb_hibrst\0usb_apbrst";
			reset-gpio = <0x2a 0x01 0x00>;
			ranges;
			clocks = <0x03 0x20 0x03 0x22>;
			pinctrl-0 = <0x2b>;
			phandle = <0xa1>;
			dwc3@fe200000 {
				compatible = "snps,dwc3";
				status = "okay";
				reg = <0x00 0xfe200000 0x00 0x40000>;
				interrupt-names = "dwc_usb3\0otg\0hiber";
				interrupts = <0x00 0x41 0x04 0x00 0x45 0x04 0x00 0x4b 0x04>;
				iommus = <0x0d 0x860>;
				snps,quirk-frame-length-adjustment = <0x20>;
				snps,refclk_fladj;
				snps,enable_guctl1_resume_quirk;
				snps,enable_guctl1_ipd_quirk;
				snps,xhci-stream-quirk;
				dr_mode = "otg";
				phy-names = "usb3-phy";
				phys = <0x0f 0x01 0x04 0x00 0x03>;
				maximum-speed = "super-speed";
				phandle = <0xa2>;
		usb1@ff9e0000 {
			reg = <0x00 0xff9e0000 0x00 0x100>;
			power-domains = <0x0c 0x17>;
			resets = <0x20 0x3c 0x20 0x3e 0x20 0x40>;
			ranges;
			clocks = <0x03 0x21 0x03 0x22>;
			phandle = <0xa3>;
			dwc3@fe300000 {
				reg = <0x00 0xfe300000 0x00 0x40000>;
				interrupts = <0x00 0x46 0x04 0x00 0x4a 0x04 0x00 0x4c 0x04>;
				iommus = <0x0d 0x861>;
				snps,refclk_fladj;
				phandle = <0xa4>;
		watchdog@fd4d0000 {
			compatible = "cdns,wdt-r1p2";
			status = "okay";
			interrupts = <0x00 0x71 0x01>;
			reg = <0x00 0xfd4d0000 0x00 0x1000>;
			timeout-sec = <0x3c>;
			reset-on-timeout;
			clocks = <0x03 0x4b>;
			phandle = <0xa5>;
		watchdog@ff150000 {
			interrupts = <0x00 0x34 0x01>;
			reg = <0x00 0xff150000 0x00 0x1000>;
			timeout-sec = <0x0a>;
			clocks = <0x03 0x70>;
			phandle = <0xa6>;
		ams@ffa50000 {
			compatible = "xlnx,zynqmp-ams";
			status = "okay";
			interrupts = <0x00 0x38 0x04>;
			interrupt-names = "ams-irq";
			reg = <0x00 0xffa50000 0x00 0x800>;
			reg-names = "ams-base";
			#io-channel-cells = <0x01>;
			ranges;
			clocks = <0x03 0x46>;
			phandle = <0xa7>;
			ams_ps@ffa50800 {
				compatible = "xlnx,zynqmp-ams-ps";
				status = "okay";
				reg = <0x00 0xffa50800 0x00 0x400>;
				phandle = <0xa8>;
			ams_pl@ffa50c00 {
				compatible = "xlnx,zynqmp-ams-pl";
				status = "okay";
				reg = <0x00 0xffa50c00 0x00 0x400>;
				phandle = <0xa9>;
		dma-controller@fd4c0000 {
			compatible = "xlnx,zynqmp-dpdma";
			status = "okay";
			reg = <0x00 0xfd4c0000 0x00 0x1000>;
			interrupts = <0x00 0x7a 0x04>;
			clock-names = "axi_clk";
			power-domains = <0x0c 0x29>;
			dma-channels = <0x06>;
			iommus = <0x0d 0xce4>;
			#dma-cells = <0x01>;
			clocks = <0x03 0x14>;
			phandle = <0x2c>;
		display@fd4a0000 {
			compatible = "xlnx,zynqmp-dpsub-1.7";
			status = "okay";
			reg = <0x00 0xfd4a0000 0x00 0x1000 0x00 0xfd4aa000 0x00 0x1000 0x00 0xfd4ab000 0x00 0x1000 0x00 0xfd4ac000 0x00 0x1000>;
			reg-names = "dp\0blend\0av_buf\0aud";
			interrupts = <0x00 0x77 0x04>;
			iommus = <0x0d 0xce3>;
			clock-names = "dp_apb_clk\0dp_aud_clk\0dp_vtc_pixel_clk_in";
			resets = <0x20 0x03>;
			dma-names = "vid0\0vid1\0vid2\0gfx0";
			dmas = <0x2c 0x00 0x2c 0x01 0x2c 0x02 0x2c 0x03>;
			clocks = <0x2d 0x03 0x11 0x03 0x10>;
			phy-names = "dp-phy0\0dp-phy1";
			phys = <0x0f 0x03 0x06 0x00 0x02 0x0f 0x02 0x06 0x01 0x02>;
			phandle = <0xaa>;
			i2c-bus {
			zynqmp_dp_snd_codec0 {
				compatible = "xlnx,dp-snd-codec";
				clock-names = "aud_clk";
				clocks = <0x03 0x11>;
				status = "okay";
				phandle = <0x30>;
			zynqmp_dp_snd_pcm0 {
				compatible = "xlnx,dp-snd-pcm0";
				dmas = <0x2c 0x04>;
				dma-names = "tx";
				status = "okay";
				phandle = <0x2e>;
			zynqmp_dp_snd_pcm1 {
				compatible = "xlnx,dp-snd-pcm1";
				dmas = <0x2c 0x05>;
				dma-names = "tx";
				status = "okay";
				phandle = <0x2f>;
			zynqmp_dp_snd_card {
				compatible = "xlnx,dp-snd-card";
				xlnx,dp-snd-pcm = <0x2e 0x2f>;
				xlnx,dp-snd-codec = <0x30>;
				status = "okay";
				phandle = <0xab>;
	fclk0 {
		status = "okay";
		compatible = "xlnx,fclk";
		clocks = <0x03 0x47>;
		phandle = <0xac>;
	fclk1 {
		status = "okay";
		clocks = <0x03 0x48>;
		phandle = <0xad>;
	fclk2 {
		status = "okay";
		clocks = <0x03 0x49>;
		phandle = <0xae>;
	fclk3 {
		status = "okay";
		clocks = <0x03 0x4a>;
		phandle = <0xaf>;
	pss_ref_clk {
		compatible = "fixed-clock";
		#clock-cells = <0x00>;
		clock-frequency = <0x1fca055>;
		phandle = <0x06>;
	video_clk {
		clock-frequency = <0x19bfcc0>;
		phandle = <0x07>;
	pss_alt_ref_clk {
		clock-frequency = <0x00>;
		phandle = <0x08>;
	gt_crx_ref_clk {
		clock-frequency = <0x66ff300>;
		phandle = <0x0a>;
	aux_ref_clk {
		phandle = <0x09>;
	dp_aclk {
		clock-frequency = <0x5f5e100>;
		clock-accuracy = <0x64>;
		phandle = <0x2d>;
	aliases {
		ethernet0 = "/axi/ethernet@ff0e0000";
		ethernet1 = "/axi/ethernet@ff0b0000";
		gpio0 = "/axi/gpio@ff0a0000";
		i2c0 = "/axi/i2c@ff020000";
		i2c1 = "/axi/i2c@ff030000";
		mmc0 = "/axi/mmc@ff170000";
		rtc0 = "/axi/rtc@ffa60000";
		serial0 = "/axi/serial@ff010000";
		serial1 = "/axi/serial@ff000000";
		serial2 = "/dcc";
		spi0 = "/axi/spi@ff0f0000";
		usb0 = "/axi/usb0@ff9d0000";
	chosen {
		bootargs = "earlycon";
		stdout-path = "serial0:115200n8";
	memory@0 {
		device_type = "memory";
		reg = <0x00 0x00 0x00 0x80000000 0x08 0x00 0x00 0x80000000>;
	fpga-axi@0 {
		ranges = <0x00 0x00 0x00 0x00 0xffffffff>;
		phandle = <0xb0>;
		axi-adxcvr-rx@84a40000 {
			compatible = "adi,axi-adxcvr-1.0";
			reg = <0x00 0x84a40000 0x1000>;
			clocks = <0x25 0x05>;
			clock-names = "conv";
			clock-output-names = "rx_gt_clk\0rx_out_clk";
			adi,sys-clk-select = <0x00>;
			adi,out-clk-select = <0x03>;
			adi,use-lpm-enable;
			jesd204-device;
			jesd204-inputs = <0x25 0x00 0x01>;
			phandle = <0x31>;
		axi-jesd204-rx@84a50000 {
			compatible = "adi,axi-jesd204-rx-1.0";
			reg = <0x00 0x84a50000 0x1000>;
			interrupts = <0x00 0x6d 0x04>;
			clocks = <0x03 0x47 0x25 0x07 0x31 0x00>;
			clock-names = "s_axi_aclk\0device_clk\0lane_clk";
			clock-output-names = "jesd_rx_lane_clk";
			adi,octets-per-frame = <0x04>;
			adi,frames-per-multiframe = <0x20>;
			jesd204-device;
			jesd204-inputs = <0x31 0x00 0x01>;
			phandle = <0x22>;
		axi-adxcvr-rx-os@84a60000 {
			reg = <0x00 0x84a60000 0x1000>;
			clocks = <0x25 0x04>;
			clock-output-names = "rx_os_gt_clk\0rx_os_out_clk";
			adi,use-lpm-enable;
			jesd204-device;
			jesd204-inputs = <0x25 0x00 0x02>;
			phandle = <0x32>;
		axi-jesd204-rx@84a70000 {
			reg = <0x00 0x84a70000 0x1000>;
			interrupts = <0x00 0x6b 0x04>;
			clocks = <0x03 0x47 0x25 0x06 0x32 0x00>;
			clock-output-names = "jesd_rx_os_lane_clk";
			jesd204-device;
			jesd204-inputs = <0x32 0x00 0x02>;
			phandle = <0x24>;
		axi-adxcvr-tx@84a20000 {
			reg = <0x00 0x84a20000 0x1000>;
			clock-output-names = "tx_gt_clk\0tx_out_clk";
			adi,sys-clk-select = <0x03>;
			jesd204-device;
			jesd204-inputs = <0x25 0x00 0x00>;
			phandle = <0x33>;
		axi-jesd204-tx@84a30000 {
			compatible = "adi,axi-jesd204-tx-1.0";
			reg = <0x00 0x84a30000 0x1000>;
			interrupts = <0x00 0x6c 0x04>;
			clocks = <0x03 0x47 0x25 0x06 0x33 0x00>;
			clock-output-names = "jesd_tx_lane_clk";
			adi,octets-per-frame = <0x02>;
			adi,converter-resolution = <0x0e>;
			adi,bits-per-sample = <0x10>;
			adi,converters-per-device = <0x04>;
			adi,control-bits-per-sample = <0x02>;
			jesd204-device;
			jesd204-inputs = <0x33 0x00 0x00>;
			phandle = <0x23>;
		axi-fan-control@80000000 {
			compatible = "adi,axi-fan-control-1.00.a";
			reg = <0x00 0x80000000 0x10000>;
			interrupts = <0x00 0x6e 0x04>;
			pulses-per-revolution = <0x02>;
			phandle = <0xb1>;
		dma@9c420000 {
			compatible = "adi,axi-dmac-1.00.a";
			reg = <0x00 0x9c420000 0x10000>;
			interrupts = <0x00 0x6a 0x04>;
			phandle = <0x34>;
			adi,channels {
				dma-channel@0 {
					reg = <0x00>;
					adi,source-bus-width = <0x80>;
					adi,source-bus-type = <0x02>;
					adi,destination-bus-width = <0x80>;
					adi,destination-bus-type = <0x00>;
					phandle = <0xb2>;
		dma@9c440000 {
			reg = <0x00 0x9c440000 0x10000>;
			interrupts = <0x00 0x68 0x04>;
			phandle = <0x36>;
			adi,channels {
				dma-channel@0 {
					reg = <0x00>;
					phandle = <0xb3>;
		dma@9c400000 {
			reg = <0x00 0x9c400000 0x10000>;
			interrupts = <0x00 0x69 0x04>;
			phandle = <0x37>;
			adi,channels {
				dma-channel@0 {
					reg = <0x00>;
					adi,source-bus-type = <0x00>;
					adi,destination-bus-width = <0x100>;
					adi,destination-bus-type = <0x01>;
					phandle = <0xb4>;
		axi-adrv9009-rx-hpc@84a00000 {
			compatible = "adi,axi-adrv9009-rx-1.0";
			reg = <0x00 0x84a00000 0x2000>;
			dmas = <0x34 0x00>;
			dma-names = "rx";
			spibus-connected = <0x35>;
			adi,axi-pl-fifo-enable;
			phandle = <0xb5>;
		axi-adrv9009-rx-obs-hpc@84a08000 {
			compatible = "adi,axi-adrv9009-obs-1.0";
			reg = <0x00 0x84a08000 0x1000>;
			dmas = <0x36 0x00>;
			dma-names = "rx";
			clocks = <0x35 0x01>;
			clock-names = "sampl_clk";
			phandle = <0xb6>;
		axi-adrv9009-tx-hpc@84a04000 {
			compatible = "adi,axi-adrv9009-x2-tx-1.0";
			reg = <0x00 0x84a04000 0x2000>;
			dmas = <0x37 0x00>;
			dma-names = "tx";
			clocks = <0x35 0x02>;
			plddrbypass-gpios = <0x13 0xa8 0x00>;
			jesd204-device;
			jesd204-inputs = <0x23 0x00 0x00>;
			phandle = <0x27>;
		axi-sysid-0@85000000 {
			compatible = "adi,axi-sysid-1.00.a";
			reg = <0x00 0x85000000 0x10000>;
			phandle = <0xb7>;
		dma@81001000 {
			reg = <0x00 0x81001000 0x1000>;
			interrupts = <0x00 0x5f 0x04>;
			phandle = <0x38>;
			adi,channels {
				dma-channel@0 {
					reg = <0x00>;
					adi,source-bus-width = <0x40>;
					adi,destination-bus-width = <0x20>;
		dma@81000000 {
			reg = <0x00 0x81000000 0x1000>;
			interrupts = <0x00 0x60 0x04>;
			phandle = <0x39>;
			adi,channels {
				dma-channel@0 {
					reg = <0x00>;
					adi,source-bus-width = <0x20>;
					adi,source-bus-type = <0x01>;
					adi,destination-bus-width = <0x40>;
		axi-i2s-adi@82000000 {
			compatible = "adi,axi-i2s-1.00.a";
			reg = <0x00 0x82000000 0x10000>;
			dmas = <0x38 0x00 0x39 0x00>;
			dma-names = "tx\0rx";
			clocks = <0x03 0x49 0x18>;
			clock-names = "axi\0ref";
			phandle = <0x3a>;
	ref_clk_0 {
		clock-frequency = <0x989680>;
		clock-output-names = "Ref-A";
		phandle = <0x19>;
	leds {
		compatible = "gpio-leds";
		led0 {
			label = "led0:green";
			gpios = <0x13 0x56 0x00>;
		led1 {
			label = "led1:green";
			gpios = <0x13 0x57 0x00>;
		led2 {
			label = "led2:green";
			gpios = <0x13 0x58 0x00>;
		led3 {
			label = "led3:green";
			gpios = <0x13 0x59 0x00>;
	gpio_keys {
		compatible = "gpio-keys";
		autorepeat;
		bt0 {
			label = "BT0";
			linux,code = <0x69>;
			gpios = <0x13 0x4e 0x00>;
		bt1 {
			label = "BT1";
			linux,code = <0x6a>;
			gpios = <0x13 0x4f 0x00>;
		bt2 {
			label = "BT2";
			linux,code = <0x1c>;
			gpios = <0x13 0x50 0x00>;
		bt3 {
			label = "BT3";
			linux,code = <0x01>;
			gpios = <0x13 0x51 0x00>;
		sw0 {
			label = "SW0";
			linux,input-type = <0x05>;
			linux,code = <0x0d>;
			gpios = <0x13 0x52 0x00>;
		sw1 {
			label = "SW1";
			gpios = <0x13 0x53 0x00>;
		sw2 {
			label = "SW2";
			linux,code = <0x02>;
			gpios = <0x13 0x54 0x00>;
		sw3 {
			label = "SW3";
			linux,code = <0x03>;
			gpios = <0x13 0x55 0x00>;
	audio_clock {
		clock-frequency = <0xbb8000>;
		phandle = <0x18>;
	talise_sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "ADRV9009 ZU11EG ADAU1761";
		simple-audio-card,widgets = "Microphone\0Mic In\0Headphone\0Headphone Out\0Line\0Line In\0Line\0Line Out";
		simple-audio-card,routing = "Line Out\0LOUT\0Line Out\0ROUT\0Headphone Out\0LHP\0Headphone Out\0RHP\0Mic In\0MICBIAS\0LINN\0Mic In\0RINN\0Mic In\0LAUX\0Line In\0RAUX\0Line In";
		simple-audio-card,dai-link@0 {
			format = "i2s";
			cpu {
				sound-dai = <0x3a>;
				frame-master;
				bitclock-master;
			codec {
				sound-dai = <0x3b>;
	ad9542_out0_c {
		clock-frequency = <0x7735940>;
		phandle = <0x1d>;
	ad9542_out1_a {
		phandle = <0x1e>;
	ad9542_out1_b {
		clock-frequency = <0x18cba80>;
		phandle = <0x1f>;
	__symbols__ {
		cpu0 = "/cpus/cpu@0";
		cpu1 = "/cpus/cpu@1";
		cpu2 = "/cpus/cpu@2";
		cpu3 = "/cpus/cpu@3";
		CPU_SLEEP_0 = "/cpus/idle-states/cpu-sleep-0";
		cpu_opp_table = "/cpu-opp-table";
		zynqmp_ipi = "/zynqmp_ipi";
		ipi_mailbox_pmu1 = "/zynqmp_ipi/mailbox@ff990400";
		dcc = "/dcc";
		zynqmp_firmware = "/firmware/zynqmp-firmware";
		zynqmp_power = "/firmware/zynqmp-firmware/zynqmp-power";
		soc_revision = "/firmware/zynqmp-firmware/nvmem_firmware/soc_revision@0";
		efuse_dna = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_dna@c";
		efuse_usr0 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr0@20";
		efuse_usr1 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr1@24";
		efuse_usr2 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr2@28";
		efuse_usr3 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr3@2c";
		efuse_usr4 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr4@30";
		efuse_usr5 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr5@34";
		efuse_usr6 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr6@38";
		efuse_usr7 = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_usr7@3c";
		efuse_miscusr = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_miscusr@40";
		efuse_chash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_chash@50";
		efuse_pufmisc = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_pufmisc@54";
		efuse_sec = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_sec@58";
		efuse_spkid = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_spkid@5c";
		efuse_ppk0hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk0hash@a0";
		efuse_ppk1hash = "/firmware/zynqmp-firmware/nvmem_firmware/efuse_ppk1hash@d0";
		zynqmp_pcap = "/firmware/zynqmp-firmware/pcap";
		xlnx_aes = "/firmware/zynqmp-firmware/zynqmp-aes";
		zynqmp_reset = "/firmware/zynqmp-firmware/reset-controller";
		pinctrl0 = "/firmware/zynqmp-firmware/pinctrl";
		pinctrl_i2c0_default = "/firmware/zynqmp-firmware/pinctrl/i2c0-default";
		pinctrl_i2c0_gpio = "/firmware/zynqmp-firmware/pinctrl/i2c0-gpio";
		pinctrl_i2c1_gpio = "/firmware/zynqmp-firmware/pinctrl/i2c1-gpio";
		pinctrl_uart1_default = "/firmware/zynqmp-firmware/pinctrl/uart1-default";
		pinctrl_gem3_default = "/firmware/zynqmp-firmware/pinctrl/gem3-default";
		pinctrl_sdhci1_default = "/firmware/zynqmp-firmware/pinctrl/sdhci1-default";
		pinctrl_gpio_default = "/firmware/zynqmp-firmware/pinctrl/gpio-default";
		pinctrl_usb0_default = "/firmware/zynqmp-firmware/pinctrl/usb0-default";
		xlnx_keccak_384 = "/firmware/zynqmp-firmware/sha384";
		xlnx_rsa = "/firmware/zynqmp-firmware/zynqmp-rsa";
		modepin_gpio = "/firmware/zynqmp-firmware/gpio";
		zynqmp_clk = "/firmware/zynqmp-firmware/clock-controller";
		fpga_full = "/fpga-full";
		amba = "/axi";
		can0 = "/axi/can@ff060000";
		can1 = "/axi/can@ff070000";
		cci = "/axi/cci@fd6e0000";
		fpd_dma_chan1 = "/axi/dma@fd500000";
		fpd_dma_chan2 = "/axi/dma@fd510000";
		fpd_dma_chan3 = "/axi/dma@fd520000";
		fpd_dma_chan4 = "/axi/dma@fd530000";
		fpd_dma_chan5 = "/axi/dma@fd540000";
		fpd_dma_chan6 = "/axi/dma@fd550000";
		fpd_dma_chan7 = "/axi/dma@fd560000";
		fpd_dma_chan8 = "/axi/dma@fd570000";
		gic = "/axi/interrupt-controller@f9010000";
		gpu = "/axi/gpu@fd4b0000";
		lpd_dma_chan1 = "/axi/dma@ffa80000";
		lpd_dma_chan2 = "/axi/dma@ffa90000";
		lpd_dma_chan3 = "/axi/dma@ffaa0000";
		lpd_dma_chan4 = "/axi/dma@ffab0000";
		lpd_dma_chan5 = "/axi/dma@ffac0000";
		lpd_dma_chan6 = "/axi/dma@ffad0000";
		lpd_dma_chan7 = "/axi/dma@ffae0000";
		lpd_dma_chan8 = "/axi/dma@ffaf0000";
		mc = "/axi/memory-controller@fd070000";
		nand0 = "/axi/nand-controller@ff100000";
		gem0 = "/axi/ethernet@ff0b0000";
		gem1 = "/axi/ethernet@ff0c0000";
		gem2 = "/axi/ethernet@ff0d0000";
		gem3 = "/axi/ethernet@ff0e0000";
		phy0 = "/axi/ethernet@ff0e0000/phy@0";
		phy1 = "/axi/ethernet@ff0e0000/phy@1";
		gpio = "/axi/gpio@ff0a0000";
		adau1761 = "/axi/i2c@ff030000/i2c-mux@70/i2c@0/adau1761@3b";
		ad9545_clock = "/axi/i2c@ff030000/i2c-mux@70/i2c@1/ad9545@4a";
		ad9545_apll0 = "/axi/i2c@ff030000/i2c-mux@70/i2c@1/ad9545@4a/pll-clk@0";
		i2c_fmc = "/axi/i2c@ff030000/i2c-mux@70/i2c@5";
		ocm = "/axi/memory-controller@ff960000";
		perf_monitor_ocm = "/axi/perf-monitor@ffa00000";
		perf_monitor_ddr = "/axi/perf-monitor@fd0b0000";
		perf_monitor_cci = "/axi/perf-monitor@fd490000";
		perf_monitor_lpd = "/axi/perf-monitor@ffa10000";
		pcie = "/axi/pcie@fd0e0000";
		pcie_intc = "/axi/pcie@fd0e0000/legacy-interrupt-controller";
		qspi = "/axi/spi@ff0f0000";
		primary_flash = "/axi/spi@ff0f0000/qspi@0";
		psgtr = "/axi/phy@fd400000";
		rtc = "/axi/rtc@ffa60000";
		sata = "/axi/ahci@fd0c0000";
		sdhci0 = "/axi/mmc@ff160000";
		sdhci1 = "/axi/mmc@ff170000";
		smmu = "/axi/iommu@fd800000";
		spi0 = "/axi/spi@ff040000";
		trx0_adrv9009 = "/axi/spi@ff040000/adrv9009-phy@0";
		trx1_adrv9009 = "/axi/spi@ff040000/adrv9009-phy-b@1";
		hmc7044 = "/axi/spi@ff040000/hmc7044@2";
		hmc7044_c0 = "/axi/spi@ff040000/hmc7044@2/channel@0";
		hmc7044_c1 = "/axi/spi@ff040000/hmc7044@2/channel@1";
		hmc7044_c2 = "/axi/spi@ff040000/hmc7044@2/channel@2";
		hmc7044_c3 = "/axi/spi@ff040000/hmc7044@2/channel@3";
		hmc7044_c4 = "/axi/spi@ff040000/hmc7044@2/channel@4";
		hmc7044_c5 = "/axi/spi@ff040000/hmc7044@2/channel@5";
		hmc7044_c6 = "/axi/spi@ff040000/hmc7044@2/channel@6";
		hmc7044_c7 = "/axi/spi@ff040000/hmc7044@2/channel@7";
		hmc7044_c8 = "/axi/spi@ff040000/hmc7044@2/channel@8";
		hmc7044_c9 = "/axi/spi@ff040000/hmc7044@2/channel@9";
		hmc7044_car = "/axi/spi@ff040000/hmc7044-car@3";
		hmc7044_car_c0 = "/axi/spi@ff040000/hmc7044-car@3/channel@0";
		hmc7044_car_c2 = "/axi/spi@ff040000/hmc7044-car@3/channel@2";
		hmc7044_car_c5 = "/axi/spi@ff040000/hmc7044-car@3/channel@5";
		hmc7044_car_c6 = "/axi/spi@ff040000/hmc7044-car@3/channel@6";
		hmc7044_car_c8 = "/axi/spi@ff040000/hmc7044-car@3/channel@8";
		hmc7044_car_c9 = "/axi/spi@ff040000/hmc7044-car@3/channel@9";
		hmc7044_car_c10 = "/axi/spi@ff040000/hmc7044-car@3/channel@10";
		hmc7044_car_c11 = "/axi/spi@ff040000/hmc7044-car@3/channel@11";
		hmc7044_ext = "/axi/spi@ff040000/hmc7044-ext@4";
		hmc7044_ext_c4 = "/axi/spi@ff040000/hmc7044-ext@4/channel@4";
		hmc7044_ext_c5 = "/axi/spi@ff040000/hmc7044-ext@4/channel@5";
		hmc7044_ext_c6 = "/axi/spi@ff040000/hmc7044-ext@4/channel@6";
		hmc7044_ext_c12 = "/axi/spi@ff040000/hmc7044-ext@4/channel@12";
		spi1 = "/axi/spi@ff050000";
		ttc0 = "/axi/timer@ff110000";
		ttc1 = "/axi/timer@ff120000";
		ttc2 = "/axi/timer@ff130000";
		ttc3 = "/axi/timer@ff140000";
		uart0 = "/axi/serial@ff000000";
		uart1 = "/axi/serial@ff010000";
		dwc3_0 = "/axi/usb0@ff9d0000/dwc3@fe200000";
		usb1 = "/axi/usb1@ff9e0000";
		dwc3_1 = "/axi/usb1@ff9e0000/dwc3@fe300000";
		watchdog0 = "/axi/watchdog@fd4d0000";
		lpd_watchdog = "/axi/watchdog@ff150000";
		xilinx_ams = "/axi/ams@ffa50000";
		ams_ps = "/axi/ams@ffa50000/ams_ps@ffa50800";
		ams_pl = "/axi/ams@ffa50000/ams_pl@ffa50c00";
		zynqmp_dpdma = "/axi/dma-controller@fd4c0000";
		zynqmp_dpsub = "/axi/display@fd4a0000";
		zynqmp_dp_snd_codec0 = "/axi/display@fd4a0000/zynqmp_dp_snd_codec0";
		zynqmp_dp_snd_pcm0 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm0";
		zynqmp_dp_snd_pcm1 = "/axi/display@fd4a0000/zynqmp_dp_snd_pcm1";
		zynqmp_dp_snd_card0 = "/axi/display@fd4a0000/zynqmp_dp_snd_card";
		fclk0 = "/fclk0";
		fclk1 = "/fclk1";
		fclk2 = "/fclk2";
		fclk3 = "/fclk3";
		pss_ref_clk = "/pss_ref_clk";
		video_clk = "/video_clk";
		pss_alt_ref_clk = "/pss_alt_ref_clk";
		gt_crx_ref_clk = "/gt_crx_ref_clk";
		aux_ref_clk = "/aux_ref_clk";
		dp_aclk = "/dp_aclk";
		fpga_axi = "/fpga-axi@0";
		axi_adrv9009_adxcvr_rx = "/fpga-axi@0/axi-adxcvr-rx@84a40000";
		axi_adrv9009_rx_jesd = "/fpga-axi@0/axi-jesd204-rx@84a50000";
		axi_adrv9009_adxcvr_rx_os = "/fpga-axi@0/axi-adxcvr-rx-os@84a60000";
		axi_adrv9009_rx_os_jesd = "/fpga-axi@0/axi-jesd204-rx@84a70000";
		axi_adrv9009_adxcvr_tx = "/fpga-axi@0/axi-adxcvr-tx@84a20000";
		axi_adrv9009_tx_jesd = "/fpga-axi@0/axi-jesd204-tx@84a30000";
		axi_fan_control = "/fpga-axi@0/axi-fan-control@80000000";
		rx_dma = "/fpga-axi@0/dma@9c420000";
		rx_dma_channel = "/fpga-axi@0/dma@9c420000/adi,channels/dma-channel@0";
		rx_obs_dma = "/fpga-axi@0/dma@9c440000";
		rx_obs_dma_channel = "/fpga-axi@0/dma@9c440000/adi,channels/dma-channel@0";
		tx_dma = "/fpga-axi@0/dma@9c400000";
		tx_dma_channel = "/fpga-axi@0/dma@9c400000/adi,channels/dma-channel@0";
		axi_adrv9009_core_rx = "/fpga-axi@0/axi-adrv9009-rx-hpc@84a00000";
		axi_adrv9009_core_rx_obs = "/fpga-axi@0/axi-adrv9009-rx-obs-hpc@84a08000";
		axi_adrv9009_core_tx = "/fpga-axi@0/axi-adrv9009-tx-hpc@84a04000";
		axi_sysid_0 = "/fpga-axi@0/axi-sysid-0@85000000";
		i2s_tx_dma = "/fpga-axi@0/dma@81001000";
		i2s_rx_dma = "/fpga-axi@0/dma@81000000";
		axi_i2s_adi = "/fpga-axi@0/axi-i2s-adi@82000000";
		ref_clk0 = "/ref_clk_0";
		audio_clock = "/audio_clock";
		psgtr_ref1 = "/ad9542_out0_c";
		psgtr_ref2 = "/ad9542_out1_a";
		psgtr_ref3 = "/ad9542_out1_b";
The JESD204 Link is disabled:
Here is the status of the two HMC7044:
The boot log showing the -22 error 1st on line 407:
analog@analog:~ $ journalctl -b
-- Journal begins at Sun 2023-06-04 09:24:13 BST, ends at Fri 2023-06-30 20:07:32 BST. --
Jun 30 19:51:21 analog kernel: Booting Linux on physical CPU 0x0000000000 [0x410fd034]
Jun 30 19:51:21 analog kernel: Linux version 5.10.0-98744-g64e7a607b659 (jenkins@romlxbuild1) (aarch64-xilinx-linux-gcc.real (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.0.202>
Jun 30 19:51:21 analog kernel: Machine model: Analog Devices ADRV9009-ZU11EG Rev.B
Jun 30 19:51:21 analog kernel: earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
Jun 30 19:51:21 analog kernel: printk: bootconsole [cdns0] enabled
Jun 30 19:51:21 analog kernel: efi: UEFI not found.
Jun 30 19:51:21 analog kernel: cma: Reserved 256 MiB at 0x0000000070000000
Jun 30 19:51:21 analog kernel: Zone ranges:
Jun 30 19:51:21 analog kernel:   DMA      [mem 0x0000000000000000-0x000000003fffffff]
Jun 30 19:51:21 analog kernel:   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
Jun 30 19:51:21 analog kernel:   Normal   [mem 0x0000000100000000-0x000000087fffffff]
Jun 30 19:51:21 analog kernel: Movable zone start for each node
Jun 30 19:51:21 analog kernel: Early memory node ranges
Jun 30 19:51:21 analog kernel:   node   0: [mem 0x0000000000000000-0x000000007fffffff]
Jun 30 19:51:21 analog kernel:   node   0: [mem 0x0000000800000000-0x000000087fffffff]
Jun 30 19:51:21 analog kernel: Initmem setup node 0 [mem 0x0000000000000000-0x000000087fffffff]
Jun 30 19:51:21 analog kernel: On node 0 totalpages: 1048576
Jun 30 19:51:21 analog kernel:   DMA zone: 3584 pages used for memmap
Jun 30 19:51:21 analog kernel:   DMA zone: 0 pages reserved
Jun 30 19:51:21 analog kernel:   DMA zone: 262144 pages, LIFO batch:63
Jun 30 19:51:21 analog kernel:   DMA32 zone: 3584 pages used for memmap
Jun 30 19:51:21 analog kernel:   DMA32 zone: 262144 pages, LIFO batch:63
Jun 30 19:51:21 analog kernel:   Normal zone: 7168 pages used for memmap
Jun 30 19:51:21 analog kernel:   Normal zone: 524288 pages, LIFO batch:63
Jun 30 19:51:21 analog kernel: psci: probing for conduit method from DT.
Jun 30 19:51:21 analog kernel: psci: PSCIv1.1 detected in firmware.
Jun 30 19:51:21 analog kernel: psci: Using standard PSCI v0.2 function IDs
Jun 30 19:51:21 analog kernel: psci: MIGRATE_INFO_TYPE not supported.
Jun 30 19:51:21 analog kernel: psci: SMC Calling Convention v1.2
Jun 30 19:51:21 analog kernel: percpu: Embedded 22 pages/cpu s49496 r8192 d32424 u90112
Jun 30 19:51:21 analog kernel: pcpu-alloc: s49496 r8192 d32424 u90112 alloc=22*4096
Jun 30 19:51:21 analog kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Jun 30 19:51:21 analog kernel: Detected VIPT I-cache on CPU0
Jun 30 19:51:21 analog kernel: CPU features: detected: ARM erratum 845719
Jun 30 19:51:21 analog kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1034240
Jun 30 19:51:21 analog kernel: Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlycon rootfstype=ext4 rootwait clk_ignore_unused cpuidle.off=1
Jun 30 19:51:21 analog kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Jun 30 19:51:21 analog kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Jun 30 19:51:21 analog kernel: mem auto-init: stack:off, heap alloc:off, heap free:off
Jun 30 19:51:21 analog kernel: software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB)
Jun 30 19:51:21 analog kernel: Memory: 3761172K/4194304K available (15552K kernel code, 1676K rwdata, 12112K rodata, 2496K init, 650K bss, 170988K reserved, 262144K cma-re>
Jun 30 19:51:21 analog kernel: rcu: Hierarchical RCU implementation.
Jun 30 19:51:21 analog kernel: rcu:         RCU event tracing is enabled.
Jun 30 19:51:21 analog kernel: rcu:         RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
Jun 30 19:51:21 analog kernel: rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
Jun 30 19:51:21 analog kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jun 30 19:51:21 analog kernel: NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Jun 30 19:51:21 analog kernel: GIC: Adjusting CPU interface base to 0x00000000f902f000
Jun 30 19:51:21 analog kernel: GIC: Using split EOI/Deactivate mode
Jun 30 19:51:21 analog kernel: random: get_random_bytes called from start_kernel+0x31c/0x550 with crng_init=0
Jun 30 19:51:21 analog kernel: arch_timer: cp15 timer(s) running at 33.33MHz (phys).
Jun 30 19:51:21 analog kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b00c47c0, max_idle_ns: 440795202120 ns
Jun 30 19:51:21 analog kernel: sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255541ns
Jun 30 19:51:21 analog kernel: Console: colour dummy device 80x25
Jun 30 19:51:21 analog kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133333)
Jun 30 19:51:21 analog kernel: pid_max: default: 32768 minimum: 301
Jun 30 19:51:21 analog kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jun 30 19:51:21 analog kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jun 30 19:51:21 analog kernel: rcu: Hierarchical SRCU implementation.
Jun 30 19:51:21 analog kernel: EFI services will not be available.
Jun 30 19:51:21 analog kernel: smp: Bringing up secondary CPUs ...
Jun 30 19:51:21 analog kernel: Detected VIPT I-cache on CPU1
Jun 30 19:51:21 analog kernel: CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
Jun 30 19:51:21 analog kernel: Detected VIPT I-cache on CPU2
Jun 30 19:51:21 analog kernel: CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
Jun 30 19:51:21 analog kernel: Detected VIPT I-cache on CPU3
Jun 30 19:51:21 analog kernel: CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
Jun 30 19:51:21 analog kernel: smp: Brought up 1 node, 4 CPUs
Jun 30 19:51:21 analog kernel: SMP: Total of 4 processors activated.
Jun 30 19:51:21 analog kernel: CPU features: detected: 32-bit EL0 Support
Jun 30 19:51:21 analog kernel: CPU features: detected: CRC32 instructions
Jun 30 19:51:21 analog kernel: CPU: All CPU(s) started at EL2
Jun 30 19:51:21 analog kernel: alternatives: patching kernel code
Jun 30 19:51:21 analog kernel: devtmpfs: initialized
Jun 30 19:51:21 analog kernel: Registered cp15_barrier emulation handler
Jun 30 19:51:21 analog kernel: Registered setend emulation handler
Jun 30 19:51:21 analog kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun 30 19:51:21 analog kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Jun 30 19:51:21 analog kernel: pinctrl core: initialized pinctrl subsystem
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 16
Jun 30 19:51:21 analog kernel: DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
Jun 30 19:51:21 analog kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Jun 30 19:51:21 analog kernel: DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Jun 30 19:51:21 analog kernel: audit: initializing netlink subsys (disabled)
Jun 30 19:51:21 analog kernel: audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
Jun 30 19:51:21 analog kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jun 30 19:51:21 analog kernel: ASID allocator initialised with 65536 entries
Jun 30 19:51:21 analog kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Jun 30 19:51:21 analog kernel: HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
Jun 30 19:51:21 analog kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Jun 30 19:51:21 analog kernel: HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
Jun 30 19:51:21 analog kernel: DRBG: Continuing without Jitter RNG
Jun 30 19:51:21 analog kernel: raid6: neonx8   gen()  2347 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx8   xor()  1754 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx4   gen()  2407 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx4   xor()  1716 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx2   gen()  2281 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx2   xor()  1568 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx1   gen()  1951 MB/s
Jun 30 19:51:21 analog kernel: raid6: neonx1   xor()  1339 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x8  gen()  1578 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x8  xor()   846 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x4  gen()  1757 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x4  xor()   891 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x2  gen()  1534 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x2  xor()   820 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x1  gen()  1134 MB/s
Jun 30 19:51:21 analog kernel: raid6: int64x1  xor()   567 MB/s
Jun 30 19:51:21 analog kernel: raid6: using algorithm neonx4 gen() 2407 MB/s
Jun 30 19:51:21 analog kernel: raid6: .... xor() 1716 MB/s, rmw enabled
Jun 30 19:51:21 analog kernel: raid6: using neon recovery algorithm
Jun 30 19:51:21 analog kernel: iommu: Default domain type: Translated
Jun 30 19:51:21 analog kernel: SCSI subsystem initialized
Jun 30 19:51:21 analog kernel: libata version 3.00 loaded.
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver usbfs
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver hub
Jun 30 19:51:21 analog kernel: usbcore: registered new device driver usb
Jun 30 19:51:21 analog kernel: mc: Linux media interface: v0.10
Jun 30 19:51:21 analog kernel: videodev: Linux video capture interface: v2.00
Jun 30 19:51:21 analog kernel: EDAC MC: Ver: 3.0.0
Jun 30 19:51:21 analog kernel: zynqmp-ipi-mbox mailbox@ff990400: Registered ZynqMP IPI mbox with TX/RX channels.
Jun 30 19:51:21 analog kernel: jesd204: created con: id=0, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@84a30000 <-> /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-adxcvr-tx@84a20000 <-> /fpga-axi@0/axi-jesd204-tx@84a30000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=2, topo=0, link=0, /axi/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-tx@84a20000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=3, topo=0, link=2, /fpga-axi@0/axi-adxcvr-rx-os@84a60000 <-> /fpga-axi@0/axi-jesd204-rx@84a70000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=4, topo=0, link=2, /axi/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-rx-os@84a60000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=5, topo=0, link=1, /fpga-axi@0/axi-adxcvr-rx@84a40000 <-> /fpga-axi@0/axi-jesd204-rx@84a50000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=6, topo=0, link=1, /axi/spi@ff040000/hmc7044@2 <-> /fpga-axi@0/axi-adxcvr-rx@84a40000
Jun 30 19:51:21 analog kernel: jesd204: created con: id=7, topo=0, link=1, /axi/spi@ff040000/hmc7044-car@3 <-> /axi/spi@ff040000/hmc7044@2
Jun 30 19:51:21 analog kernel: jesd204: created con: id=8, topo=0, link=2, /axi/spi@ff040000/hmc7044-car@3 <-> /axi/spi@ff040000/hmc7044@2
Jun 30 19:51:21 analog kernel: jesd204: created con: id=9, topo=0, link=0, /axi/spi@ff040000/hmc7044-car@3 <-> /axi/spi@ff040000/hmc7044@2
Jun 30 19:51:21 analog kernel: jesd204: created con: id=10, topo=0, link=1, /fpga-axi@0/axi-jesd204-rx@84a50000 <-> /axi/spi@ff040000/adrv9009-phy-b@1
Jun 30 19:51:21 analog kernel: jesd204: created con: id=11, topo=0, link=2, /fpga-axi@0/axi-jesd204-rx@84a70000 <-> /axi/spi@ff040000/adrv9009-phy-b@1
Jun 30 19:51:21 analog kernel: jesd204: created con: id=12, topo=0, link=0, /fpga-axi@0/axi-adrv9009-tx-hpc@84a04000 <-> /axi/spi@ff040000/adrv9009-phy-b@1
Jun 30 19:51:21 analog kernel: jesd204: created con: id=13, topo=0, link=1, /axi/spi@ff040000/adrv9009-phy-b@1 <-> /axi/spi@ff040000/adrv9009-phy@0
Jun 30 19:51:21 analog kernel: jesd204: created con: id=14, topo=0, link=2, /axi/spi@ff040000/adrv9009-phy-b@1 <-> /axi/spi@ff040000/adrv9009-phy@0
Jun 30 19:51:21 analog kernel: jesd204: created con: id=15, topo=0, link=0, /axi/spi@ff040000/adrv9009-phy-b@1 <-> /axi/spi@ff040000/adrv9009-phy@0
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0: JESD204[0:0] transition uninitialized -> initialized
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0: JESD204[0:1] transition uninitialized -> initialized
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0: JESD204[0:2] transition uninitialized -> initialized
Jun 30 19:51:21 analog kernel: jesd204: found 11 devices and 1 topologies
Jun 30 19:51:21 analog kernel: FPGA manager framework
Jun 30 19:51:21 analog kernel: Advanced Linux Sound Architecture Driver Initialized.
Jun 30 19:51:21 analog kernel: Bluetooth: Core ver 2.22
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 31
Jun 30 19:51:21 analog kernel: Bluetooth: HCI device and connection manager initialized
Jun 30 19:51:21 analog kernel: Bluetooth: HCI socket layer initialized
Jun 30 19:51:21 analog kernel: Bluetooth: L2CAP socket layer initialized
Jun 30 19:51:21 analog kernel: Bluetooth: SCO socket layer initialized
Jun 30 19:51:21 analog kernel: clocksource: Switched to clocksource arch_sys_counter
Jun 30 19:51:21 analog kernel: VFS: Disk quotas dquot_6.6.0
Jun 30 19:51:21 analog kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 2
Jun 30 19:51:21 analog kernel: tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
Jun 30 19:51:21 analog kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
Jun 30 19:51:21 analog kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
Jun 30 19:51:21 analog kernel: TCP: Hash tables configured (established 32768 bind 32768)
Jun 30 19:51:21 analog kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
Jun 30 19:51:21 analog kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
Jun 30 19:51:21 analog kernel: RPC: Registered named UNIX socket transport module.
Jun 30 19:51:21 analog kernel: RPC: Registered udp transport module.
Jun 30 19:51:21 analog kernel: RPC: Registered tcp transport module.
Jun 30 19:51:21 analog kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jun 30 19:51:21 analog kernel: PCI: CLS 0 bytes, default 64
Jun 30 19:51:21 analog kernel: hw perfevents: no interrupt-affinity property for /pmu, guessing.
Jun 30 19:51:21 analog kernel: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jun 30 19:51:21 analog kernel: Initialise system trusted keyrings
Jun 30 19:51:21 analog kernel: workingset: timestamp_bits=62 max_order=20 bucket_order=0
Jun 30 19:51:21 analog kernel: NFS: Registering the id_resolver key type
Jun 30 19:51:21 analog kernel: Key type id_resolver registered
Jun 30 19:51:21 analog kernel: Key type id_legacy registered
Jun 30 19:51:21 analog kernel: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Jun 30 19:51:21 analog kernel: jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
Jun 30 19:51:21 analog kernel: fuse: init (API version 7.32)
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 38
Jun 30 19:51:21 analog kernel: xor: measuring software checksum speed
Jun 30 19:51:21 analog kernel:    8regs           :  2593 MB/sec
Jun 30 19:51:21 analog kernel:    32regs          :  3071 MB/sec
Jun 30 19:51:21 analog kernel:    arm64_neon      :  2612 MB/sec
Jun 30 19:51:21 analog kernel: xor: using function: 32regs (3071 MB/sec)
Jun 30 19:51:21 analog kernel: Key type asymmetric registered
Jun 30 19:51:21 analog kernel: Asymmetric key parser 'x509' registered
Jun 30 19:51:21 analog kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Jun 30 19:51:21 analog kernel: io scheduler mq-deadline registered
Jun 30 19:51:21 analog kernel: io scheduler kyber registered
Jun 30 19:51:21 analog kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jun 30 19:51:21 analog kernel: cacheinfo: Unable to detect cache hierarchy for CPU 0
Jun 30 19:51:21 analog kernel: brd: module loaded
Jun 30 19:51:21 analog kernel: loop: module loaded
Jun 30 19:51:21 analog kernel: Registered mathworks_ip class
Jun 30 19:51:21 analog kernel: libphy: Fixed MDIO Bus: probed
Jun 30 19:51:21 analog kernel: tun: Universal TUN/TAP device driver, 1.6
Jun 30 19:51:21 analog kernel: CAN device driver interface
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver asix
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver ax88179_178a
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver cdc_ether
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver net1080
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver cdc_subset
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver zaurus
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver cdc_ncm
Jun 30 19:51:21 analog kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun 30 19:51:21 analog kernel: ehci-pci: EHCI PCI platform driver
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver uas
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver usb-storage
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver usbserial_generic
Jun 30 19:51:21 analog kernel: usbserial: USB Serial support registered for generic
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver ftdi_sio
Jun 30 19:51:21 analog kernel: usbserial: USB Serial support registered for FTDI USB Serial Device
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver upd78f0730
Jun 30 19:51:21 analog kernel: usbserial: USB Serial support registered for upd78f0730
Jun 30 19:51:21 analog kernel: i2c /dev entries driver
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver uvcvideo
Jun 30 19:51:21 analog kernel: USB Video Class driver (1.1.1)
Jun 30 19:51:21 analog kernel: axi_fan_control_driver 80000000.axi-fan-control: clk_get failed with -517
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART driver ver 2.3
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol H4 registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol BCSP registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol LL registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol ATH3K registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol Intel registered
Jun 30 19:51:21 analog kernel: Bluetooth: HCI UART protocol QCA registered
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver bcm203x
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver bpa10x
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver bfusb
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver btusb
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver ath3k
Jun 30 19:51:21 analog kernel: EDAC MC0: Giving out device to module 1 controller synps_ddr_controller: DEV synps_edac (INTERRUPT)
Jun 30 19:51:21 analog kernel: EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
Jun 30 19:51:21 analog kernel: sdhci: Secure Digital Host Controller Interface driver
Jun 30 19:51:21 analog kernel: sdhci: Copyright(c) Pierre Ossman
Jun 30 19:51:21 analog kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jun 30 19:51:21 analog kernel: ledtrig-cpu: registered to indicate activity on CPUs
Jun 30 19:51:21 analog kernel: SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
Jun 30 19:51:21 analog kernel: zynqmp_firmware_probe Platform Management API v1.1
Jun 30 19:51:21 analog kernel: zynqmp_firmware_probe Trustzone version v1.0
Jun 30 19:51:21 analog kernel: zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
Jun 30 19:51:21 analog kernel: zynqmp-aes firmware:zynqmp-firmware:zynqmp-aes: will run requests pump with realtime priority
Jun 30 19:51:21 analog kernel: alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
Jun 30 19:51:21 analog kernel: alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver usbhid
Jun 30 19:51:21 analog kernel: usbhid: USB HID core driver
Jun 30 19:51:21 analog kernel: axi_sysid 85000000.axi-sysid-0: AXI System ID core version (1.01.a) found
Jun 30 19:51:21 analog kernel: axi_sysid 85000000.axi-sysid-0: [(null)] on [adrv9009zu11eg] git branch <hdl_2021_r2> git <a83056b11d6b092d342b72c68ef713b362b10521> clean [>
Jun 30 19:51:21 analog kernel: fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
Jun 30 19:51:21 analog kernel: usbcore: registered new interface driver snd-usb-audio
Jun 30 19:51:21 analog kernel: pktgen: Packet Generator for packet performance testing. Version: 2.75
Jun 30 19:51:21 analog kernel: Initializing XFRM netlink socket
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 10
Jun 30 19:51:21 analog kernel: Segment Routing with IPv6
Jun 30 19:51:21 analog kernel: sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 17
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 15
Jun 30 19:51:21 analog kernel: can: controller area network core
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 29
Jun 30 19:51:21 analog kernel: can: raw protocol
Jun 30 19:51:21 analog kernel: can: broadcast manager protocol
Jun 30 19:51:21 analog kernel: can: netlink gateway - max_hops=1
Jun 30 19:51:21 analog kernel: Bluetooth: RFCOMM TTY layer initialized
Jun 30 19:51:21 analog kernel: Bluetooth: RFCOMM socket layer initialized
Jun 30 19:51:21 analog kernel: Bluetooth: RFCOMM ver 1.11
Jun 30 19:51:21 analog kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun 30 19:51:21 analog kernel: Bluetooth: BNEP filters: protocol multicast
Jun 30 19:51:21 analog kernel: Bluetooth: BNEP socket layer initialized
Jun 30 19:51:21 analog kernel: Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Jun 30 19:51:21 analog kernel: Bluetooth: HIDP socket layer initialized
Jun 30 19:51:21 analog kernel: 9pnet: Installing 9P2000 support
Jun 30 19:51:21 analog kernel: NET: Registered protocol family 36
Jun 30 19:51:21 analog kernel: Key type dns_resolver registered
Jun 30 19:51:21 analog kernel: registered taskstats version 1
Jun 30 19:51:21 analog kernel: Loading compiled-in X.509 certificates
Jun 30 19:51:21 analog kernel: Btrfs loaded, crc32c=crc32c-generic
Jun 30 19:51:21 analog kernel: ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 31, base_baud = 6249999) is a xuartps
Jun 30 19:51:21 analog kernel: printk: console [ttyPS0] enabled
Jun 30 19:51:21 analog kernel: printk: bootconsole [cdns0] disabled
Jun 30 19:51:21 analog kernel: of-fpga-region fpga-full: FPGA Region probed
Jun 30 19:51:21 analog kernel: gpio-13 (ulpi-phy-reset): hogged as output/high
Jun 30 19:51:21 analog kernel: gpio-169 (hmc7044_ext-reset): hogged as output/high
Jun 30 19:51:21 analog kernel: gpio-170 (hmc7044_ext-vcxo_select): hogged as output/high
Jun 30 19:51:21 analog kernel: xilinx-zynqmp-dpdma fd4c0000.dma-controller: Xilinx DPDMA engine is probed
Jun 30 19:51:21 analog kernel: zynqmp-display fd4a0000.display: vtc bridge property not present
Jun 30 19:51:21 analog kernel: xilinx-dp-snd-codec fd4a0000.display:zynqmp_dp_snd_codec0: Failed to get required clock freq
Jun 30 19:51:21 analog kernel: xilinx-dp-snd-codec: probe of fd4a0000.display:zynqmp_dp_snd_codec0 failed with error -22
Jun 30 19:51:21 analog kernel: xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
Jun 30 19:51:21 analog kernel: xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
Jun 30 19:51:21 analog kernel: OF: graph: no port node found in /axi/display@fd4a0000
Jun 30 19:51:21 analog kernel: xlnx-drm xlnx-drm.0: bound fd4a0000.display (ops 0xffffffc01100c920)
Jun 30 19:51:21 analog kernel: Console: switching to colour frame buffer device 480x135
Jun 30 19:51:21 analog kernel: zynqmp-display fd4a0000.display: [drm] fb0: xlnxdrmfb frame buffer device
Jun 30 19:51:21 analog kernel: [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.display on minor 0
Jun 30 19:51:21 analog kernel: zynqmp-display fd4a0000.display: ZynqMP DisplayPort Subsystem driver probed
Jun 30 19:51:21 analog kernel: adrv9009 spi1.0: adrv9009_probe : enter
Jun 30 19:51:21 analog kernel: adrv9009 spi1.1: adrv9009_probe : enter
Jun 30 19:51:21 analog kernel: hmc7044 spi1.3: PLL1: Holdover, CLKIN0 @ 80000000 Hz, PFD: 3200 kHz - PLL2: Locked @ 2400.000000 MHz
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/hmc7044-car@3,jesd204:3,parent=spi1.3: Using as SYSREF provider
Jun 30 19:51:21 analog kernel: hmc7044 spi1.4: Read/Write check failed (0xFF)
Jun 30 19:51:21 analog kernel: random: fast init done
Jun 30 19:51:21 analog kernel: hmc7044 spi1.4: Probed, SPI read support failed
Jun 30 19:51:21 analog kernel: spi-nor spi0.0: SPI-NOR-UniqueID 104000323e0e000915001900e8907a32c3
Jun 30 19:51:21 analog kernel: spi-nor spi0.0: trying to lock already unlocked area
Jun 30 19:51:21 analog kernel: spi-nor spi0.0: n25q512a (131072 Kbytes)
Jun 30 19:51:21 analog kernel: 4 fixed-partitions partitions found on MTD device spi0.0
Jun 30 19:51:21 analog kernel: Creating 4 MTD partitions on "spi0.0":
Jun 30 19:51:21 analog kernel: 0x000000000000-0x000002000000 : "qspi-fsbl-uboot"
Jun 30 19:51:21 analog kernel: 0x000002000000-0x000002020000 : "qspi-uboot-env"
Jun 30 19:51:21 analog kernel: 0x000002020000-0x000002100000 : "qspi-nvmfs"
Jun 30 19:51:21 analog kernel: 0x000002100000-0x000007f00000 : "qspi-linux"
Jun 30 19:51:21 analog kernel: macb ff0e0000.ethernet: Not enabling partial store and forward
Jun 30 19:51:21 analog kernel: libphy: MACB_mii_bus: probed
Jun 30 19:51:21 analog kernel: macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 21 (00:e0:22:fe:23:88)
Jun 30 19:51:21 analog kernel: xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
Jun 30 19:51:21 analog kernel: xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
Jun 30 19:51:21 analog kernel: xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
Jun 30 19:51:21 analog kernel: xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
Jun 30 19:51:21 analog kernel: OF: graph: no port node found in /axi/phy@fd400000
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000002010010
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: irq 45, io mem 0xfe200000
Jun 30 19:51:21 analog kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
Jun 30 19:51:21 analog kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 30 19:51:21 analog kernel: usb usb1: Product: xHCI Host Controller
Jun 30 19:51:21 analog kernel: usb usb1: Manufacturer: Linux 5.10.0-98744-g64e7a607b659 xhci-hcd
Jun 30 19:51:21 analog kernel: usb usb1: SerialNumber: xhci-hcd.0.auto
Jun 30 19:51:21 analog kernel: hub 1-0:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 1-0:1.0: 1 port detected
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Jun 30 19:51:21 analog kernel: xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
Jun 30 19:51:21 analog kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
Jun 30 19:51:21 analog kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
Jun 30 19:51:21 analog kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun 30 19:51:21 analog kernel: usb usb2: Product: xHCI Host Controller
Jun 30 19:51:21 analog kernel: usb usb2: Manufacturer: Linux 5.10.0-98744-g64e7a607b659 xhci-hcd
Jun 30 19:51:21 analog kernel: usb usb2: SerialNumber: xhci-hcd.0.auto
Jun 30 19:51:21 analog kernel: hub 2-0:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 2-0:1.0: 1 port detected
Jun 30 19:51:21 analog kernel: at24 0-002c: supply vcc not found, using dummy regulator
Jun 30 19:51:21 analog kernel: at24 0-002c: 2048 byte 24c16 EEPROM, writable, 1 bytes/write
Jun 30 19:51:21 analog kernel: cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 23
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 3
Jun 30 19:51:21 analog kernel: usb 1-1: new high-speed USB device number 2 using xhci-hcd
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 4
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 5
Jun 30 19:51:21 analog kernel: at24 6-0050: supply vcc not found, using dummy regulator
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 6
Jun 30 19:51:21 analog kernel: at24 7-0050: supply vcc not found, using dummy regulator
Jun 30 19:51:21 analog kernel: usb 1-1: New USB device found, idVendor=045b, idProduct=0209, bcdDevice= 1.00
Jun 30 19:51:21 analog kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 7
Jun 30 19:51:21 analog kernel: at24 8-0050: supply vcc not found, using dummy regulator
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 8
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 9
Jun 30 19:51:21 analog kernel: i2c i2c-1: Added multiplexed i2c bus 10
Jun 30 19:51:21 analog kernel: pca954x 1-0070: registered 8 multiplexed busses for I2C switch pca9548
Jun 30 19:51:21 analog kernel: cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 24
Jun 30 19:51:21 analog kernel: hub 1-1:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 1-1:1.0: 4 ports detected
Jun 30 19:51:21 analog kernel: cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer with timeout 60s
Jun 30 19:51:21 analog kernel: cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1316666653 (-34)
Jun 30 19:51:21 analog kernel: cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1316666 KHz, changing to: 1199999 KHz
Jun 30 19:51:21 analog kernel: usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
Jun 30 19:51:21 analog kernel: axi-i2s 82000000.axi-i2s-adi: probed, capture enabled, playback enabled
Jun 30 19:51:21 analog kernel: mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
Jun 30 19:51:21 analog kernel: usb 2-1: New USB device found, idVendor=045b, idProduct=0210, bcdDevice= 1.00
Jun 30 19:51:21 analog kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 30 19:51:21 analog kernel: hub 2-1:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 2-1:1.0: 4 ports detected
Jun 30 19:51:21 analog kernel: mmc0: new high speed SDHC card at address aaaa
Jun 30 19:51:21 analog kernel: mmcblk0: mmc0:aaaa SB16G 14.8 GiB
Jun 30 19:51:21 analog kernel: hmc7044 spi1.2: PLL1: Holdover, CLKIN0 @ 80000000 Hz, PFD: 5000 kHz - PLL2: Locked @ 2400.000000 MHz
Jun 30 19:51:21 analog kernel: macb ff0b0000.ethernet: Not enabling partial store and forward
Jun 30 19:51:21 analog kernel:  mmcblk0: p1 p2 p3
Jun 30 19:51:21 analog kernel: macb ff0b0000.ethernet eth1: Cadence GEM rev 0x50070106 at 0xff0b0000 irq 20 (4e:45:2b:1c:ed:9c)
Jun 30 19:51:21 analog kernel: axi_adxcvr 84a40000.axi-adxcvr-rx: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A40000. Number of lanes: 4.
Jun 30 19:51:21 analog kernel: axi_adxcvr 84a60000.axi-adxcvr-rx-os: AXI-ADXCVR-RX (17.05.a) using CPLL on GTH4 at 0x84A60000. Number of lanes: 4.
Jun 30 19:51:21 analog kernel: axi_adxcvr 84a20000.axi-adxcvr-tx: AXI-ADXCVR-TX (17.05.a) using QPLL on GTH4 at 0x84A20000. Number of lanes: 8.
Jun 30 19:51:21 analog kernel: axi-jesd204-rx 84a50000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A50000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
Jun 30 19:51:21 analog kernel: axi-jesd204-rx 84a70000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a) at 0x84A70000. Encoder 8b10b, width 4/4, lanes 4, jesd204-fsm.
Jun 30 19:51:21 analog kernel: axi-jesd204-tx 84a30000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a) at 0x84A30000. Encoder 8b10b, width 4/4, lanes 8, jesd204-fsm.
Jun 30 19:51:21 analog kernel: cf_axi_adc 84a00000.axi-adrv9009-rx-hpc: ADI AIM (10.02.b) at 0x84A00000 mapped to 0x(____ptrval____) probed ADC ADRV9009-X2 as MASTER
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition initialized -> probed
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition initialized -> probed
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition initialized -> probed
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition probed -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition probed -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition probed -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition idle -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> link_supported
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
Jun 30 19:51:21 analog kernel: usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
Jun 30 19:51:21 analog kernel: axi-jesd204-tx 84a30000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_pre_setup: Link0 set lane rate 4800000 kHz failed (-22)
Jun 30 19:51:21 analog kernel: jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:9,parent=84a30000.axi-jesd204-tx: JESD204[0:0] In link_pre_setup got error from cb: -22
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
Jun 30 19:51:21 analog kernel: adrv9009 spi1.0: ADIHAL_resetHw
Jun 30 19:51:21 analog kernel: adrv9009 spi1.1: ADIHAL_resetHw
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_pre_setup
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_pre_setup -> link_supported
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -22
Jun 30 19:51:21 analog kernel: cf_axi_dds 84a04000.axi-adrv9009-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.01.b) at 0x84A04000 mapped to 0x(____ptrval____), probed DD>
Jun 30 19:51:21 analog kernel: input: gpio_keys as /devices/platform/gpio_keys/input/input0
Jun 30 19:51:21 analog kernel: of_cfs_init
Jun 30 19:51:21 analog kernel: of_cfs_init: OK
Jun 30 19:51:21 analog kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jun 30 19:51:21 analog kernel: usb 1-1.1: New USB device found, idVendor=045b, idProduct=0209, bcdDevice= 1.00
Jun 30 19:51:21 analog kernel: usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 30 19:51:21 analog kernel: hub 1-1.1:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 1-1.1:1.0: 4 ports detected
Jun 30 19:51:21 analog kernel: usb 2-1.1: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
Jun 30 19:51:21 analog kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Jun 30 19:51:21 analog kernel: usb 2-1.1: New USB device found, idVendor=045b, idProduct=0210, bcdDevice= 1.00
Jun 30 19:51:21 analog kernel: clk: Not disabling unused clocks
Jun 30 19:51:21 analog kernel: usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun 30 19:51:21 analog kernel: ALSA device list:
Jun 30 19:51:21 analog kernel:   #0: ADRV9009 ZU11EG ADAU1761
Jun 30 19:51:21 analog kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
Jun 30 19:51:21 analog kernel: cfg80211: failed to load regulatory.db
Jun 30 19:51:21 analog kernel: hub 2-1.1:1.0: USB hub found
Jun 30 19:51:21 analog kernel: hub 2-1.1:1.0: 4 ports detected
Jun 30 19:51:21 analog kernel: EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jun 30 19:51:21 analog kernel: VFS: Mounted root (ext4 filesystem) on device 179:2.
Jun 30 19:51:21 analog kernel: devtmpfs: mounted
Jun 30 19:51:21 analog kernel: Freeing unused kernel memory: 2496K
Jun 30 19:51:21 analog kernel: Run /sbin/init as init process
Jun 30 19:51:21 analog kernel:   with arguments:
Jun 30 19:51:21 analog kernel:     /sbin/init
Jun 30 19:51:21 analog kernel:   with environment:
Jun 30 19:51:21 analog kernel:     HOME=/
Jun 30 19:51:21 analog kernel:     TERM=linux
Jun 30 19:51:21 analog kernel: usb 1-1.1.1: new low-speed USB device number 4 using xhci-hcd
Jun 30 19:51:21 analog kernel: usb 1-1.1.1: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
Jun 30 19:51:21 analog kernel: usb 1-1.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 30 19:51:21 analog kernel: usb 1-1.1.1: Product: USB Optical Mouse
Jun 30 19:51:21 analog kernel: usb 1-1.1.1: Manufacturer: Logitech
Jun 30 19:51:21 analog kernel: input: Logitech USB Optical Mouse as /devices/platform/axi/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.0/00>
Jun 30 19:51:21 analog kernel: hid-generic 0003:046D:C077.0001: input: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-xhci-hcd.0.auto-1.1.1/input0
Jun 30 19:51:21 analog kernel: usb 1-1.1.2: new low-speed USB device number 5 using xhci-hcd
Jun 30 19:51:21 analog systemd[1]: System time before build time, advancing clock.
Jun 30 19:51:21 analog kernel: usb 1-1.1.2: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 5.02
Jun 30 19:51:21 analog kernel: usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun 30 19:51:21 analog kernel: usb 1-1.1.2: Product: Dell USB Entry Keyboard
Jun 30 19:51:21 analog kernel: usb 1-1.1.2: Manufacturer: Dell
Jun 30 19:51:21 analog systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT >
Jun 30 19:51:21 analog systemd[1]: Detected architecture arm64.
Jun 30 19:51:21 analog kernel: input: Dell Dell USB Entry Keyboard as /devices/platform/axi/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/>
Jun 30 19:51:21 analog systemd[1]: Set hostname to <analog>.
Jun 30 19:51:21 analog kernel: hid-generic 0003:413C:2107.0002: input: USB HID v1.10 Keyboard [Dell Dell USB Entry Keyboard] on usb-xhci-hcd.0.auto-1.1.2/input0
Jun 30 19:51:21 analog systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process li>
Jun 30 19:51:21 analog systemd[1]: Queued start job for default target Graphical Interface.
Jun 30 19:51:21 analog kernel: random: systemd: uninitialized urandom read (16 bytes read)
Jun 30 19:51:21 analog systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
Jun 30 19:51:21 analog systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
Jun 30 19:51:21 analog systemd[1]: Created slice system-getty.slice.
Jun 30 19:51:21 analog systemd[1]: Created slice system-modprobe.slice.
Jun 30 19:51:21 analog systemd[1]: Created slice system-serial\x2dgetty.slice.
Jun 30 19:51:21 analog systemd[1]: Created slice system-systemd\x2dfsck.slice.
Jun 30 19:51:21 analog systemd[1]: Created slice User and Session Slice.
Jun 30 19:51:21 analog systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
Jun 30 19:51:21 analog systemd[1]: Reached target Slices.
Jun 30 19:51:21 analog systemd[1]: Reached target Swap.
Jun 30 19:51:21 analog systemd[1]: Listening on Syslog Socket.
Jun 30 19:51:21 analog systemd[1]: Listening on fsck to fsckd communication Socket.
Jun 30 19:51:21 analog systemd[1]: Listening on initctl Compatibility Named Pipe.
Jun 30 19:51:21 analog systemd[1]: Listening on Journal Audit Socket.
Jun 30 19:51:21 analog systemd[1]: Listening on Journal Socket (/dev/log).
Jun 30 19:51:21 analog systemd[1]: Listening on Journal Socket.
Jun 30 19:51:21 analog systemd[1]: Listening on udev Control Socket.
Jun 30 19:51:21 analog systemd[1]: Listening on udev Kernel Socket.
Jun 30 19:51:21 analog systemd[1]: Mounting Huge Pages File System...
Jun 30 19:51:21 analog systemd[1]: Mounting POSIX Message Queue File System...
Jun 30 19:51:21 analog systemd[1]: Mounting RPC Pipe File System...
Jun 30 19:51:21 analog systemd[1]: Mounting Kernel Debug File System...
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
Jun 30 19:51:21 analog systemd[1]: Starting Restore / save the current clock...
Jun 30 19:51:21 analog systemd[1]: Starting Set the console keyboard layout...
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
Jun 30 19:51:21 analog systemd[1]: Starting Load Kernel Module configfs...
Jun 30 19:51:21 analog systemd[1]: Starting Load Kernel Module drm...
Jun 30 19:51:21 analog systemd[1]: Starting Load Kernel Module fuse...
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jun 30 19:51:21 analog systemd[1]: Starting Journal Service...
Jun 30 19:51:21 analog systemd[1]: Starting Load Kernel Modules...
Jun 30 19:51:21 analog systemd[1]: Starting Remount Root and Kernel File Systems...
Jun 30 19:51:21 analog systemd[1]: Starting Coldplug All udev Devices...
Jun 30 19:51:21 analog systemd[1]: Mounted Huge Pages File System.
Jun 30 19:51:21 analog systemd[1]: Mounted POSIX Message Queue File System.
Jun 30 19:51:21 analog systemd[1]: Mounted RPC Pipe File System.
Jun 30 19:51:21 analog systemd[1]: Mounted Kernel Debug File System.
Jun 30 19:51:21 analog systemd[1]: Finished Restore / save the current clock.
Jun 30 19:51:21 analog systemd[1]: Finished Set the console keyboard layout.
Jun 30 19:51:21 analog systemd-journald[203]: Journal started
Jun 30 19:51:21 analog systemd-journald[203]: Runtime Journal (/run/log/journal/48091d887958484e9057caa528d7bf9c) is 8.0M, max 78.6M, 70.6M free.
Jun 30 19:51:21 analog systemd-modules-load[204]: Failed to look up module alias 'lp': Function not implemented
Jun 30 19:51:21 analog systemd-modules-load[204]: Failed to look up module alias 'ppdev': Function not implemented
Jun 30 19:51:21 analog systemd-modules-load[204]: Failed to look up module alias 'parport_pc': Function not implemented
Jun 30 19:51:21 analog systemd-modules-load[204]: Failed to look up module alias 'i2c-dev': Function not implemented
Jun 30 19:51:21 analog fake-hwclock[188]: Fri 30 Jun 2023 06:51:21 PM UTC
Jun 30 19:51:21 analog systemd[1]: Started Journal Service.
Jun 30 19:51:21 analog systemd[1]: modprobe@configfs.service: Succeeded.
Jun 30 19:51:21 analog systemd[1]: Finished Load Kernel Module configfs.
Jun 30 19:51:21 analog systemd[1]: modprobe@drm.service: Succeeded.
Jun 30 19:51:21 analog systemd[1]: Finished Load Kernel Module drm.
Jun 30 19:51:21 analog systemd[1]: modprobe@fuse.service: Succeeded.
Jun 30 19:51:21 analog systemd[1]: Finished Load Kernel Module fuse.
Jun 30 19:51:21 analog kernel: random: crng init done
Jun 30 19:51:21 analog kernel: random: 7 urandom warning(s) missed due to ratelimiting
Jun 30 19:51:21 analog systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jun 30 19:51:21 analog systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Jun 30 19:51:21 analog systemd[1]: Failed to start Load Kernel Modules.
Jun 30 19:51:21 analog systemd[1]: Mounting FUSE Control File System...
Jun 30 19:51:21 analog systemd[1]: Mounting Kernel Configuration File System...
Jun 30 19:51:21 analog systemd[1]: Starting Apply Kernel Variables...
Jun 30 19:51:21 analog systemd[1]: Mounted FUSE Control File System.
Jun 30 19:51:21 analog systemd-sysctl[212]: Couldn't write '1' to 'kernel/unprivileged_userns_clone', ignoring: No such file or directory
Jun 30 19:51:21 analog systemd[1]: Mounted Kernel Configuration File System.
Jun 30 19:51:21 analog systemd[1]: Finished Apply Kernel Variables.
Jun 30 19:51:21 analog kernel: EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jun 30 19:51:21 analog systemd[1]: Finished Remount Root and Kernel File Systems.
Jun 30 19:51:21 analog systemd[1]: Finished Coldplug All udev Devices.
Jun 30 19:51:21 analog systemd[1]: Starting Helper to synchronize boot up for ifupdown...
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jun 30 19:51:21 analog systemd[1]: Starting Flush Journal to Persistent Storage...
Jun 30 19:51:21 analog systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Jun 30 19:51:21 analog systemd[1]: Starting Load/Save Random Seed...
Jun 30 19:51:21 analog systemd-journald[203]: Time spent on flushing to /var/log/journal/48091d887958484e9057caa528d7bf9c is 52.726ms for 555 entries.
Jun 30 19:51:21 analog systemd-journald[203]: System Journal (/var/log/journal/48091d887958484e9057caa528d7bf9c) is 1.1G, max 1.2G, 71.1M free.
Jun 30 19:51:21 analog systemd[1]: Starting Create System Users...
Jun 30 19:51:21 analog systemd[1]: Starting Wait for udev To Complete Device Initialization...
Jun 30 19:51:21 analog systemd[1]: Finished Helper to synchronize boot up for ifupdown.
Jun 30 19:51:22 analog systemd[1]: Finished Create System Users.
Jun 30 19:51:22 analog systemd[1]: Finished Load/Save Random Seed.
Jun 30 19:51:22 analog systemd[1]: Condition check resulted in First Boot Complete being skipped.
Jun 30 19:51:22 analog systemd[1]: Starting Create Static Device Nodes in /dev...
Jun 30 19:51:22 analog systemd[1]: Finished Create Static Device Nodes in /dev.
Jun 30 19:51:22 analog systemd[1]: Reached target Local File Systems (Pre).
Jun 30 19:51:22 analog systemd[1]: Starting Rule-based Manager for Device Events and Files...
Jun 30 19:51:22 analog systemd[1]: Finished Flush Journal to Persistent Storage.
Jun 30 19:51:22 analog systemd[1]: Started Rule-based Manager for Device Events and Files.
Jun 30 19:51:22 analog systemd[1]: Starting Show Plymouth Boot Screen...
Jun 30 19:51:22 analog systemd[1]: Received SIGRTMIN+20 from PID 248 (plymouthd).
Jun 30 19:51:22 analog systemd[1]: Started Show Plymouth Boot Screen.
Jun 30 19:51:22 analog systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
Jun 30 19:51:22 analog systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Jun 30 19:51:22 analog systemd[1]: Reached target Local Encrypted Volumes.
Jun 30 19:51:23 analog systemd[1]: Found device /dev/ttyPS0.
Jun 30 19:51:23 analog systemd-udevd[245]: Using default interface naming scheme 'v247'.
Jun 30 19:51:23 analog systemd-udevd[227]: Using default interface naming scheme 'v247'.
Jun 30 19:51:23 analog systemd-udevd[229]: 8-0050: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[238]: spi1.2: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[232]: spi1.4: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[233]: spi1.0: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[239]: 1-0070: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[224]: 0-0048: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[228]: 0-004b: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[242]: spi1.3: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[237]: spi1.1: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[247]: 6-0050: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[226]: 7-0050: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[230]: 0-0058: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[241]: 0-002c: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd[1]: Found device /dev/disk/by-partuuid/9785213e-01.
Jun 30 19:51:23 analog systemd-udevd[234]: 3-003b: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[235]: 4-004a: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:23 analog systemd-udevd[223]: spi0.0: Process '/usr/lib/raspberrypi-sys-mods/i2cprobe' failed with exit code 1.
Jun 30 19:51:24 analog systemd-udevd[223]: event0: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jun 30 19:51:24 analog systemd[1]: Found device /dev/ttyS0.
Jun 30 19:51:24 analog mtp-probe[537]: checking bus 1, device 4: "/sys/devices/platform/axi/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1.1"
Jun 30 19:51:24 analog mtp-probe[537]: bus: 1, device: 4 was not an MTP device
Jun 30 19:51:24 analog mtp-probe[540]: checking bus 1, device 5: "/sys/devices/platform/axi/ff9d0000.usb0/fe200000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1.2"
Jun 30 19:51:24 analog mtp-probe[540]: bus: 1, device: 5 was not an MTP device
Jun 30 19:51:24 analog systemd-udevd[241]: event1: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jun 30 19:51:24 analog udevadm[218]: systemd-udev-settle.service is deprecated. Please fix iiod.service, iiod_ffs.service not to pull it in.
Jun 30 19:51:24 analog systemd-udevd[247]: event2: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Jun 30 19:51:24 analog systemd[1]: Finished Wait for udev To Complete Device Initialization.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
Jun 30 19:51:25 analog systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jun 30 19:51:25 analog systemd[1]: Starting File System Check on /dev/disk/by-partuuid/9785213e-01...
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jun 30 19:51:25 analog systemd[1]: Starting Load Kernel Modules...
Jun 30 19:51:25 analog systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
Jun 30 19:51:25 analog systemd-modules-load[579]: Failed to look up module alias 'lp': Function not implemented
Jun 30 19:51:25 analog systemd-modules-load[579]: Failed to look up module alias 'ppdev': Function not implemented
Jun 30 19:51:25 analog systemd-modules-load[579]: Failed to look up module alias 'parport_pc': Function not implemented
Jun 30 19:51:25 analog systemd-modules-load[579]: Failed to look up module alias 'i2c-dev': Function not implemented
Jun 30 19:51:25 analog systemd[1]: Started File System Check Daemon to report status.
Jun 30 19:51:25 analog systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Jun 30 19:51:25 analog systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Jun 30 19:51:25 analog systemd[1]: Failed to start Load Kernel Modules.
Jun 30 19:51:26 analog systemd-fsck[582]: fsck.fat 4.2 (2021-01-31)
Jun 30 19:51:26 analog systemd-fsck[582]: /dev/mmcblk0p1: 872 files, 310893/523260 clusters
Jun 30 19:51:26 analog systemd[1]: Finished File System Check on /dev/disk/by-partuuid/9785213e-01.
Jun 30 19:51:26 analog systemd[1]: Mounting /boot...
Jun 30 19:51:26 analog systemd[1]: Mounted /boot.
Jun 30 19:51:26 analog systemd[1]: Reached target Local File Systems.
Jun 30 19:51:26 analog systemd[1]: Starting Set console font and keymap...
Jun 30 19:51:26 analog systemd[1]: Starting Raise network interfaces...
Jun 30 19:51:26 analog systemd[1]: Starting Preprocess NFS configuration...
Jun 30 19:51:26 analog systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jun 30 19:51:26 analog systemd[1]: Starting Create Volatile Files and Directories...
Jun 30 19:51:26 analog systemd[1]: Finished Set console font and keymap.
Jun 30 19:51:26 analog systemd[1]: Received SIGRTMIN+20 from PID 248 (plymouthd).
Jun 30 19:51:26 analog systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
Jun 30 19:51:26 analog systemd[1]: nfs-config.service: Succeeded.
Jun 30 19:51:26 analog systemd[1]: Finished Preprocess NFS configuration.
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Jun 30 19:51:26 analog systemd[1]: Reached target NFS client services.
Jun 30 19:51:26 analog systemd[1]: Reached target Remote File Systems (Pre).
Jun 30 19:51:26 analog systemd[1]: Reached target Remote File Systems.
Jun 30 19:51:26 analog systemd[1]: Finished Create Volatile Files and Directories.
Jun 30 19:51:26 analog systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jun 30 19:51:26 analog systemd[1]: Finished Update UTMP about System Boot/Shutdown.
Jun 30 19:51:26 analog systemd[1]: Reached target System Initialization.
Jun 30 19:51:26 analog systemd[1]: Started CUPS Scheduler.
Jun 30 19:51:26 analog systemd[1]: Started Daily apt download activities.
Jun 30 19:51:26 analog systemd[1]: Started Daily apt upgrade and clean activities.
Jun 30 19:51:26 analog systemd[1]: Started Periodic ext4 Online Metadata Check for All Filesystems.
Jun 30 19:51:26 analog systemd[1]: Started Discard unused blocks once a week.
Jun 30 19:51:26 analog systemd[1]: Started Daily rotation of log files.
Jun 30 19:51:26 analog systemd[1]: Started Daily man-db regeneration.
Jun 30 19:51:26 analog systemd[1]: Started Daily Cleanup of Temporary Directories.
Jun 30 19:51:26 analog systemd[1]: Reached target Paths.
Jun 30 19:51:26 analog systemd[1]: Reached target Timers.
Jun 30 19:51:26 analog systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jun 30 19:51:26 analog systemd[1]: Listening on CUPS Scheduler.
Jun 30 19:51:26 analog systemd[1]: Listening on D-Bus System Message Bus Socket.
Jun 30 19:51:26 analog systemd[1]: Listening on Erlang Port Mapper Daemon Activation Socket.
Jun 30 19:51:26 analog systemd[1]: Listening on GPS (Global Positioning System) Daemon Sockets.
Jun 30 19:51:26 analog systemd[1]: Listening on triggerhappy.socket.
Jun 30 19:51:26 analog systemd[1]: Reached target Sockets.
Jun 30 19:51:26 analog systemd[1]: Reached target Basic System.
Jun 30 19:51:26 analog systemd[1]: Starting Analog Devices power up/down sequence...
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
Jun 30 19:51:26 analog systemd[1]: Starting Save/Restore Sound Card State...
Jun 30 19:51:26 analog systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jun 30 19:51:26 analog systemd[1]: Started Regular background program processing daemon.
Jun 30 19:51:26 analog systemd[1]: Started D-Bus System Message Bus.
Jun 30 19:51:26 analog systemd[1]: Starting dphys-swapfile - set up, mount/unmount, and delete a swap file...
Jun 30 19:51:26 analog cron[623]: (CRON) INFO (pidfile fd = 3)
Jun 30 19:51:26 analog systemd[1]: Starting Remove Stale Online ext4 Metadata Check Snapshots...
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in getty on tty2-tty6 if dbus and logind are not available being skipped.
Jun 30 19:51:26 analog systemd[1]: Starting Creating IIOD Context Attributes......
Jun 30 19:51:26 analog systemd[1]: Starting Authorization Manager...
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in Copy user wpa_supplicant.conf being skipped.
Jun 30 19:51:26 analog systemd[1]: Starting DHCP Client Daemon...
Jun 30 19:51:26 analog systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Jun 30 19:51:26 analog systemd[1]: Starting LSB: rng-tools (Debian variant)...
Jun 30 19:51:26 analog systemd[1]: Starting System Logging Service...
Jun 30 19:51:26 analog systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Jun 30 19:51:26 analog systemd[1]: Starting User Login Management...
Jun 30 19:51:26 analog systemd[1]: Starting triggerhappy global hotkey daemon...
Jun 30 19:51:26 analog systemd[1]: Starting Disk Manager...
Jun 30 19:51:26 analog systemd[1]: Starting WPA supplicant...
Jun 30 19:51:26 analog systemd[1]: Finished Save/Restore Sound Card State.
Jun 30 19:51:26 analog systemd[1]: Reached target Sound Card.
Jun 30 19:51:26 analog cron[623]: (CRON) INFO (Running @reboot jobs)
Jun 30 19:51:26 analog avahi-daemon[621]: Found user 'avahi' (UID 107) and group 'avahi' (GID 112).
Jun 30 19:51:26 analog avahi-daemon[621]: Successfully dropped root privileges.
Jun 30 19:51:26 analog systemd[1]: e2scrub_reap.service: Succeeded.
Jun 30 19:51:26 analog avahi-daemon[621]: avahi-daemon 0.8 starting up.
Jun 30 19:51:26 analog systemd[1]: Finished Remove Stale Online ext4 Metadata Check Snapshots.
Jun 30 19:51:26 analog thd[660]: Found socket passed from systemd
Jun 30 19:51:26 analog systemd[1]: Started triggerhappy global hotkey daemon.
Jun 30 19:51:26 analog dhcpcd[647]: dev: loaded udev
Jun 30 19:51:26 analog systemd-logind[658]: New seat seat0.
Jun 30 19:51:26 analog dhcpcd[647]: forked to background, child pid 699
Jun 30 19:51:26 analog systemd[1]: Started DHCP Client Daemon.
Jun 30 19:51:26 analog systemd-logind[658]: Watching system buttons on /dev/input/event2 (Dell Dell USB Entry Keyboard)
Jun 30 19:51:26 analog systemd[1]: Finished Raise network interfaces.
Jun 30 19:51:26 analog rng-tools-debian[737]: not starting: no hardware RNG device found
Jun 30 19:51:27 analog udisksd[662]: udisks daemon version 2.9.2 starting
Jun 30 19:51:27 analog rsyslogd[656]: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.2102.0]
Jun 30 19:51:27 analog rsyslogd[656]: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="656" x-info="https://www.rsyslog.com"] start
Jun 30 19:51:27 analog systemd[1]: Started System Logging Service.
Jun 30 19:51:27 analog rng-tools-debian[655]: Configuring Hardware RNG entropy gatherer daemon: no hardware RNG device found!
Jun 30 19:51:27 analog rng-tools-debian[739]:  failed!
Jun 30 19:51:27 analog systemd[1]: Started LSB: rng-tools (Debian variant).
Jun 30 19:51:27 analog dphys-swapfile[635]: want /var/swap=100MByte, checking existing: keeping it
Jun 30 19:51:27 analog dhcpcd[699]: eth0: waiting for carrier
Jun 30 19:51:27 analog kernel: macb ff0e0000.ethernet eth0: PHY [ff0e0000.ethernet-ffffffff:00] driver [Marvell 88E1510] (irq=POLL)
Jun 30 19:51:27 analog kernel: macb ff0e0000.ethernet eth0: configuring for phy/rgmii-id link mode
Jun 30 19:51:27 analog kernel: macb ff0b0000.ethernet eth1: PHY [ff0e0000.ethernet-ffffffff:01] driver [Marvell 88E1510] (irq=POLL)
Jun 30 19:51:27 analog kernel: macb ff0b0000.ethernet eth1: configuring for phy/sgmii link mode
Jun 30 19:51:27 analog dhcpcd[699]: eth1: waiting for carrier
Jun 30 19:51:27 analog systemd[1]: Finished dphys-swapfile - set up, mount/unmount, and delete a swap file.
Jun 30 19:51:27 analog kernel: Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SS
Jun 30 19:51:27 analog systemd[1]: Started User Login Management.
Jun 30 19:51:27 analog systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jun 30 19:51:27 analog wpa_supplicant[663]: Successfully initialized wpa_supplicant
Jun 30 19:51:27 analog systemd[1]: Started WPA supplicant.
Jun 30 19:51:27 analog systemd[1]: Reached target Network.
Jun 30 19:51:27 analog avahi-daemon[621]: Successfully called chroot().
Jun 30 19:51:27 analog systemd[1]: Reached target Network is Online.
Jun 30 19:51:27 analog avahi-daemon[621]: Successfully dropped remaining capabilities.
Jun 30 19:51:27 analog avahi-daemon[621]: Loading service file /services/ssh.service.
Jun 30 19:51:27 analog avahi-daemon[621]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Jun 30 19:51:27 analog systemd[1]: Starting CUPS Scheduler...
Jun 30 19:51:27 analog avahi-daemon[621]: New relevant interface lo.IPv6 for mDNS.
Jun 30 19:51:27 analog avahi-daemon[621]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jun 30 19:51:27 analog avahi-daemon[621]: New relevant interface lo.IPv4 for mDNS.
Jun 30 19:51:27 analog avahi-daemon[621]: Network interface enumeration completed.
Jun 30 19:51:27 analog avahi-daemon[621]: Registering new address record for ::1 on lo.*.
Jun 30 19:51:27 analog avahi-daemon[621]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jun 30 19:51:27 analog systemd[1]: Started Erlang Port Mapper Daemon.
Jun 30 19:51:27 analog systemd[1]: Starting HTTP based time synchronization tool...
Jun 30 19:51:27 analog systemd[1]: Starting Internet superserver...
Jun 30 19:51:27 analog systemd[1]: Starting /etc/rc.local Compatibility...
Jun 30 19:51:27 analog systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
Jun 30 19:51:27 analog systemd[1]: Starting OpenBSD Secure Shell server...
Jun 30 19:51:27 analog systemd[1]: Starting Permit User Sessions...
Jun 30 19:51:27 analog systemd[1]: Started Unattended Upgrades Shutdown.
Jun 30 19:51:27 analog systemd[1]: Started /etc/rc.local Compatibility.
Jun 30 19:51:27 analog systemd[1]: Finished Permit User Sessions.
Jun 30 19:51:27 analog systemd[1]: Starting Light Display Manager...
Jun 30 19:51:27 analog systemd[1]: Starting Hold until boot process finishes up...
Jun 30 19:51:27 analog polkitd[646]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jun 30 19:51:27 analog systemd[1]: Started Authorization Manager.
Jun 30 19:51:27 analog systemd[1]: Starting Modem Manager...
Jun 30 19:51:27 analog systemd[1]: Started Internet superserver.
Jun 30 19:51:27 analog systemd[1]: htpdate.service: Can't open PID file /run/htpdate.pid (yet?) after start: Operation not permitted
Jun 30 19:51:27 analog htpdate[773]: htpdate version 1.2.2 started
Jun 30 19:51:27 analog systemd[1]: htpdate.service: Supervising process 774 which is not our child. We'll most likely not notice when it exits.
Jun 30 19:51:27 analog systemd[1]: Started HTTP based time synchronization tool.
Jun 30 19:51:27 analog htpdate[774]: www.pool.ntp.org host or service unavailable
Jun 30 19:51:27 analog lightdm[770]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop>
Jun 30 19:51:27 analog systemd[1]: Finished Creating IIOD Context Attributes....
Jun 30 19:51:27 analog systemd[1]: Started IIO Daemon.
Jun 30 19:51:27 analog sshd[800]: Server listening on 0.0.0.0 port 22.
Jun 30 19:51:27 analog sshd[800]: Server listening on :: port 22.
Jun 30 19:51:27 analog systemd[1]: Started OpenBSD Secure Shell server.
Jun 30 19:51:27 analog ModemManager[772]: <info>  ModemManager (version 1.14.12) starting in system bus...
Jun 30 19:51:27 analog udisksd[662]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Jun 30 19:51:27 analog systemd[1]: Received SIGRTMIN+21 from PID 248 (plymouthd).
Jun 30 19:51:27 analog systemd[1]: Finished Hold until boot process finishes up.
Jun 30 19:51:27 analog systemd[1]: Started Getty on tty1.
Jun 30 19:51:27 analog systemd[1]: Started Serial Getty on ttyPS0.
Jun 30 19:51:27 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:51:27 analog udisksd[662]: Failed to load the 'mdraid' libblockdev plugin
Jun 30 19:51:27 analog systemd[1]: Started Light Display Manager.
Jun 30 19:51:27 analog systemd[1]: Starting VNC Server for X11...
Jun 30 19:51:27 analog iiod[807]: ERROR: host analog
Jun 30 19:51:27 analog avahi-daemon[621]: Server startup complete. Host name is analog.local. Local service cookie is 1821455044.
Jun 30 19:51:28 analog python3[617]: Found model name: Analog Devices ADRV9009-ZU11EG Rev.B
Jun 30 19:51:28 analog raspi-config[651]: Checking if shift key is held down: No. Switching to ondemand scaling governor/etc/init.d/raspi-config: 35: echo: echo: I/O error
Jun 30 19:51:28 analog raspi-config[651]: /etc/init.d/raspi-config: 35: echo: echo: I/O error
Jun 30 19:51:28 analog systemd[1]: Finished Analog Devices power up/down sequence.
Jun 30 19:51:28 analog raspi-config[651]: /etc/init.d/raspi-config: 38: cannot create /sys/devices/system/cpu/cpufreq/ondemand/up_threshold: Directory nonexistent
Jun 30 19:51:28 analog raspi-config[651]: /etc/init.d/raspi-config: 39: cannot create /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate: Directory nonexistent
Jun 30 19:51:28 analog raspi-config[651]: /etc/init.d/raspi-config: 40: cannot create /sys/devices/system/cpu/cpufreq/ondemand/sampling_down_factor: Directory nonexistent
Jun 30 19:51:28 analog raspi-config[651]: /etc/init.d/raspi-config: 41: cannot create /sys/devices/system/cpu/cpufreq/ondemand/io_is_busy: Directory nonexistent
Jun 30 19:51:28 analog raspi-config[651]: .
Jun 30 19:51:28 analog systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Jun 30 19:51:28 analog systemd[1]: Started CUPS Scheduler.
Jun 30 19:51:28 analog systemd[1]: Started Make remote CUPS printers available locally.
Jun 30 19:51:28 analog x11vnc[818]: 30/06/2023 19:51:28 passing arg to libvncserver: -rfbauth
Jun 30 19:51:28 analog x11vnc[818]: 30/06/2023 19:51:28 passing arg to libvncserver: /home/analog/.vnc/passwd
Jun 30 19:51:28 analog x11vnc[818]: 30/06/2023 19:51:28 x11vnc version: 0.9.16 lastmod: 2019-01-05  pid: 818
Jun 30 19:51:28 analog systemd[1]: Started Modem Manager.
Jun 30 19:51:28 analog systemd[1]: Started Disk Manager.
Jun 30 19:51:28 analog udisksd[662]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 30 19:51:28 analog avahi-daemon[621]: Service "analog" (/services/ssh.service) successfully established.
Jun 30 19:51:31 analog dhcpcd[699]: eth1: carrier acquired
Jun 30 19:51:31 analog kernel: macb ff0b0000.ethernet eth1: unable to generate target frequency: 125000000 Hz
Jun 30 19:51:31 analog kernel: macb ff0b0000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Jun 30 19:51:31 analog kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Jun 30 19:51:31 analog dhcpcd[699]: DUID 00:01:00:01:2b:bc:a5:58:56:5c:21:e5:94:29
Jun 30 19:51:31 analog dhcpcd[699]: eth1: IAID 2b:1c:ed:9c
Jun 30 19:51:31 analog dhcpcd[699]: eth1: adding address fe80::accb:688e:40ff:bb60
Jun 30 19:51:31 analog avahi-daemon[621]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::accb:688e:40ff:bb60.
Jun 30 19:51:31 analog dhcpcd[699]: eth1: probing address 192.168.70.94/24
Jun 30 19:51:31 analog avahi-daemon[621]: New relevant interface eth1.IPv6 for mDNS.
Jun 30 19:51:31 analog avahi-daemon[621]: Registering new address record for fe80::accb:688e:40ff:bb60 on eth1.*.
Jun 30 19:51:31 analog x11vnc[818]: No protocol specified
Jun 30 19:51:31 analog x11vnc[818]: 30/06/2023 19:51:31 XOpenDisplay(":0") failed.
Jun 30 19:51:31 analog x11vnc[818]: 30/06/2023 19:51:31 Trying again with XAUTHLOCALHOSTNAME=localhost ...
Jun 30 19:51:31 analog x11vnc[818]: 30/06/2023 19:51:31 ***************************************
Jun 30 19:51:31 analog x11vnc[818]: 30/06/2023 19:51:31 *** XOpenDisplay failed (:0)
Jun 30 19:51:31 analog x11vnc[818]: *** x11vnc was unable to open the X DISPLAY: ":0", it cannot continue.
Jun 30 19:51:31 analog x11vnc[818]: *** There may be "Xlib:" error messages above with details about the failure.
Jun 30 19:51:31 analog x11vnc[818]: Some tips and guidelines:
Jun 30 19:51:31 analog x11vnc[818]: ** An X server (the one you wish to view) must be running before x11vnc is
Jun 30 19:51:31 analog x11vnc[818]:    started: x11vnc does not start the X server.  (however, see the -create
Jun 30 19:51:31 analog x11vnc[818]:    option if that is what you really want).
Jun 30 19:51:31 analog x11vnc[818]: ** You must use -display <disp>, -OR- set and export your $DISPLAY
Jun 30 19:51:31 analog x11vnc[818]:    environment variable to refer to the display of the desired X server.
Jun 30 19:51:31 analog x11vnc[818]:  - Usually the display is simply ":0" (in fact x11vnc uses this if you forget
Jun 30 19:51:31 analog x11vnc[818]:    to specify it), but in some multi-user situations it could be ":1", ":2",
Jun 30 19:51:31 analog x11vnc[818]:    or even ":137".  Ask your administrator or a guru if you are having
Jun 30 19:51:31 analog x11vnc[818]:    difficulty determining what your X DISPLAY is.
Jun 30 19:51:31 analog x11vnc[818]: ** Next, you need to have sufficient permissions (Xauthority)
Jun 30 19:51:31 analog x11vnc[818]:    to connect to the X DISPLAY.   Here are some Tips:
Jun 30 19:51:31 analog x11vnc[818]:  - Often, you just need to run x11vnc as the user logged into the X session.
Jun 30 19:51:31 analog x11vnc[818]:    So make sure to be that user when you type x11vnc.
Jun 30 19:51:31 analog x11vnc[818]:  - Being root is usually not enough because the incorrect MIT-MAGIC-COOKIE
Jun 30 19:51:31 analog x11vnc[818]:    file may be accessed.  The cookie file contains the secret key that
Jun 30 19:51:31 analog x11vnc[818]:    allows x11vnc to connect to the desired X DISPLAY.
Jun 30 19:51:31 analog x11vnc[818]:  - You can explicitly indicate which MIT-MAGIC-COOKIE file should be used
Jun 30 19:51:31 analog x11vnc[818]:    by the -auth option, e.g.:
Jun 30 19:51:31 analog x11vnc[818]:        x11vnc -auth /home/someuser/.Xauthority -display :0
Jun 30 19:51:31 analog x11vnc[818]:        x11vnc -auth /tmp/.gdmzndVlR -display :0
Jun 30 19:51:31 analog x11vnc[818]:    you must have read permission for the auth file.
Jun 30 19:51:31 analog x11vnc[818]:    See also '-auth guess' and '-findauth' discussed below.
Jun 30 19:51:31 analog x11vnc[818]: ** If NO ONE is logged into an X session yet, but there is a greeter login
Jun 30 19:51:31 analog x11vnc[818]:    program like "gdm", "kdm", "xdm", or "dtlogin" running, you will need
Jun 30 19:51:31 analog x11vnc[818]:    to find and use the raw display manager MIT-MAGIC-COOKIE file.
Jun 30 19:51:31 analog x11vnc[818]:    Some examples for various display managers:
Jun 30 19:51:31 analog x11vnc[818]:      gdm:     -auth /var/gdm/:0.Xauth
Jun 30 19:51:31 analog x11vnc[818]:               -auth /var/lib/gdm/:0.Xauth
Jun 30 19:51:31 analog x11vnc[818]:      kdm:     -auth /var/lib/kdm/A:0-crWk72
Jun 30 19:51:31 analog x11vnc[818]:               -auth /var/run/xauth/A:0-crWk72
Jun 30 19:51:31 analog x11vnc[818]:      xdm:     -auth /var/lib/xdm/authdir/authfiles/A:0-XQvaJk
Jun 30 19:51:31 analog x11vnc[818]:      dtlogin: -auth /var/dt/A:0-UgaaXa
Jun 30 19:51:31 analog x11vnc[818]:    Sometimes the command "ps wwwwaux | grep auth" can reveal the file location.
Jun 30 19:51:31 analog x11vnc[818]:    Starting with x11vnc 0.9.9 you can have it try to guess by using:
Jun 30 19:51:31 analog x11vnc[818]:               -auth guess
Jun 30 19:51:31 analog x11vnc[818]:    (see also the x11vnc -findauth option.)
Jun 30 19:51:31 analog x11vnc[818]:    Only root will have read permission for the file, and so x11vnc must be run
Jun 30 19:51:31 analog x11vnc[818]:    as root (or copy it).  The random characters in the filenames will of course
Jun 30 19:51:31 analog x11vnc[818]:    change and the directory the cookie file resides in is system dependent.
Jun 30 19:51:31 analog x11vnc[818]: See also: http://www.karlrunge.com/x11vnc/faq.html
Jun 30 19:51:31 analog systemd[1]: x11vnc.service: Control process exited, code=exited, status=1/FAILURE
Jun 30 19:51:31 analog systemd[1]: x11vnc.service: Failed with result 'exit-code'.
Jun 30 19:51:31 analog systemd[1]: Failed to start VNC Server for X11.
Jun 30 19:51:31 analog lightdm[858]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop>
Jun 30 19:51:31 analog lightdm[858]: pam_unix(lightdm-autologin:session): session opened for user analog(uid=1000) by (uid=0)
Jun 30 19:51:31 analog dhcpcd[699]: eth1: soliciting an IPv6 router
Jun 30 19:51:31 analog systemd[1]: Created slice User Slice of UID 1000.
Jun 30 19:51:31 analog systemd[1]: Starting User Runtime Directory /run/user/1000...
Jun 30 19:51:31 analog systemd-logind[658]: New session 1 of user analog.
Jun 30 19:51:31 analog systemd[1]: Finished User Runtime Directory /run/user/1000.
Jun 30 19:51:31 analog systemd[1]: Starting User Manager for UID 1000...
Jun 30 19:51:31 analog systemd[863]: pam_unix(systemd-user:session): session opened for user analog(uid=1000) by (uid=0)
Jun 30 19:51:31 analog ModemManager[772]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/axi/ff0b0000.ethernet': not supported by any plug>
Jun 30 19:51:31 analog ModemManager[772]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/axi/ff0e0000.ethernet': not supported by any plug>
Jun 30 19:51:32 analog agetty[817]: /dev/ttyS0: not a tty
Jun 30 19:51:32 analog login[816]: pam_unix(login:session): session opened for user root(uid=0) by LOGIN(uid=0)
Jun 30 19:51:32 analog login[815]: pam_unix(login:session): session opened for user analog(uid=1000) by LOGIN(uid=0)
Jun 30 19:51:32 analog systemd[1]: Created slice User Slice of UID 0.
Jun 30 19:51:32 analog systemd[1]: Starting User Runtime Directory /run/user/0...
Jun 30 19:51:32 analog systemd-logind[658]: New session 4 of user root.
Jun 30 19:51:32 analog systemd-logind[658]: New session 3 of user analog.
Jun 30 19:51:33 analog systemd[1]: Finished User Runtime Directory /run/user/0.
Jun 30 19:51:33 analog systemd[1]: Starting User Manager for UID 0...
Jun 30 19:51:33 analog systemd[889]: pam_unix(systemd-user:session): session opened for user root(uid=0) by (uid=0)
Jun 30 19:51:33 analog systemd-xdg-autostart-generator[903]: Configuration file /root/.config/autostart/jesd_eye_scan.desktop is marked executable. Please remove executabl>
Jun 30 19:51:33 analog systemd[863]: Queued start job for default target Main User Target.
Jun 30 19:51:33 analog systemd[863]: Created slice User Application Slice.
Jun 30 19:51:33 analog systemd[863]: Reached target Paths.
Jun 30 19:51:33 analog systemd[863]: Reached target Timers.
Jun 30 19:51:33 analog systemd[863]: Starting D-Bus User Message Bus Socket.
Jun 30 19:51:33 analog systemd[863]: Listening on GnuPG network certificate management daemon.
Jun 30 19:51:33 analog systemd[863]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 30 19:51:33 analog systemd[863]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jun 30 19:51:33 analog systemd[863]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jun 30 19:51:33 analog systemd[863]: Listening on GnuPG cryptographic agent and passphrase cache.
Jun 30 19:51:33 analog systemd[863]: Listening on Multimedia System.
Jun 30 19:51:33 analog systemd[863]: Listening on debconf communication socket.
Jun 30 19:51:33 analog systemd[863]: Listening on Sound System.
Jun 30 19:51:33 analog systemd[863]: Listening on D-Bus User Message Bus Socket.
Jun 30 19:51:33 analog systemd[863]: Reached target Sockets.
Jun 30 19:51:33 analog systemd[863]: Reached target Basic System.
Jun 30 19:51:33 analog systemd[1]: Started User Manager for UID 1000.
Jun 30 19:51:33 analog systemd[863]: Started Multimedia Service.
Jun 30 19:51:33 analog systemd[1]: Started Session 1 of user analog.
Jun 30 19:51:33 analog systemd[1]: Started Session 3 of user analog.
Jun 30 19:51:33 analog systemd[863]: Starting Sound Service...
Jun 30 19:51:34 analog dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.23' (uid>
Jun 30 19:51:34 analog systemd[863]: Started D-Bus User Message Bus.
Jun 30 19:51:34 analog systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Jun 30 19:51:34 analog dbus-daemon[624]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun 30 19:51:34 analog systemd[1]: Started RealtimeKit Scheduling Policy Service.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully called chroot.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully dropped privileges.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully limited resources.
Jun 30 19:51:34 analog rtkit-daemon[921]: Running.
Jun 30 19:51:34 analog rtkit-daemon[921]: Watchdog thread running.
Jun 30 19:51:34 analog rtkit-daemon[921]: Canary thread running.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully made thread 905 of process 905 owned by '1000' high priority at nice level -11.
Jun 30 19:51:34 analog rtkit-daemon[921]: Supervising 1 threads of 1 processes of 1 users.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully made thread 906 of process 906 owned by '1000' high priority at nice level -11.
Jun 30 19:51:34 analog rtkit-daemon[921]: Supervising 2 threads of 2 processes of 1 users.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully made thread 915 of process 905 owned by '1000' RT at priority 20.
Jun 30 19:51:34 analog rtkit-daemon[921]: Supervising 3 threads of 2 processes of 1 users.
Jun 30 19:51:34 analog pipewire[905]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': >
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully made thread 949 of process 949 owned by '1000' high priority at nice level -11.
Jun 30 19:51:34 analog rtkit-daemon[921]: Supervising 4 threads of 3 processes of 1 users.
Jun 30 19:51:34 analog rtkit-daemon[921]: Successfully made thread 950 of process 949 owned by '1000' RT at priority 20.
Jun 30 19:51:34 analog rtkit-daemon[921]: Supervising 5 threads of 3 processes of 1 users.
Jun 30 19:51:35 analog systemd[889]: Queued start job for default target Main User Target.
Jun 30 19:51:35 analog systemd[889]: Created slice User Application Slice.
Jun 30 19:51:35 analog systemd[889]: Reached target Paths.
Jun 30 19:51:35 analog systemd[889]: Reached target Timers.
Jun 30 19:51:35 analog systemd[889]: Starting D-Bus User Message Bus Socket.
Jun 30 19:51:35 analog systemd[889]: Listening on GnuPG network certificate management daemon.
Jun 30 19:51:35 analog systemd[889]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jun 30 19:51:35 analog systemd[889]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jun 30 19:51:35 analog systemd[889]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jun 30 19:51:35 analog systemd[889]: Listening on GnuPG cryptographic agent and passphrase cache.
Jun 30 19:51:35 analog systemd[889]: Condition check resulted in Multimedia System being skipped.
Jun 30 19:51:35 analog systemd[889]: Listening on debconf communication socket.
Jun 30 19:51:35 analog systemd[889]: Condition check resulted in Sound System being skipped.
Jun 30 19:51:35 analog systemd[889]: Listening on D-Bus User Message Bus Socket.
Jun 30 19:51:35 analog systemd[889]: Reached target Sockets.
Jun 30 19:51:35 analog systemd[889]: Reached target Basic System.
Jun 30 19:51:35 analog systemd[1]: Started User Manager for UID 0.
Jun 30 19:51:35 analog systemd[1]: Started Session 4 of user root.
Jun 30 19:51:35 analog systemd[889]: Condition check resulted in Multimedia Service being skipped.
Jun 30 19:51:35 analog systemd[889]: Condition check resulted in Sound Service being skipped.
Jun 30 19:51:35 analog systemd[889]: Reached target Main User Target.
Jun 30 19:51:35 analog systemd[889]: Startup finished in 2.027s.
Jun 30 19:51:35 analog login[967]: ROOT LOGIN  on '/dev/ttyPS0'
Jun 30 19:51:35 analog dbus-daemon[624]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.28' (uid=1000 pid=906 com>
Jun 30 19:51:35 analog systemd[1]: Starting Bluetooth service...
Jun 30 19:51:35 analog systemd[863]: Started Sound Service.
Jun 30 19:51:35 analog systemd[863]: Reached target Main User Target.
Jun 30 19:51:35 analog systemd[863]: Startup finished in 3.549s.
Jun 30 19:51:36 analog dhcpcd[699]: eth1: using static address 192.168.70.94/24
Jun 30 19:51:36 analog dhcpcd[699]: eth1: adding route to 192.168.70.0/24
Jun 30 19:51:36 analog dhcpcd[699]: eth1: adding default route via 192.168.70.254
Jun 30 19:51:36 analog avahi-daemon[621]: Joining mDNS multicast group on interface eth1.IPv4 with address 192.168.70.94.
Jun 30 19:51:36 analog avahi-daemon[621]: New relevant interface eth1.IPv4 for mDNS.
Jun 30 19:51:36 analog avahi-daemon[621]: Registering new address record for 192.168.70.94 on eth1.IPv4.
Jun 30 19:51:36 analog bluetoothd[1021]: Bluetooth daemon 5.55
Jun 30 19:51:36 analog dbus-daemon[624]: [system] Successfully activated service 'org.bluez'
Jun 30 19:51:36 analog systemd[1]: Started Bluetooth service.
Jun 30 19:51:36 analog bluetoothd[1021]: Starting SDP server
Jun 30 19:51:36 analog dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested >
Jun 30 19:51:36 analog bluetoothd[1021]: Bluetooth management interface 1.18 initialized
Jun 30 19:51:36 analog systemd[1]: Starting Hostname Service...
Jun 30 19:51:36 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.6>
Jun 30 19:51:36 analog systemd[863]: Starting Virtual filesystem service...
Jun 30 19:51:37 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.Daemon'
Jun 30 19:51:37 analog systemd[1]: Started Hostname Service.
Jun 30 19:51:37 analog dbus-daemon[624]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jun 30 19:51:37 analog systemd[863]: Started Virtual filesystem service.
Jun 30 19:51:37 analog polkitd(authority=local)[646]: Registered Authentication Agent for unix-session:1 (system bus name :1.33 [lxpolkit], object path /org/freedesktop/Po>
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monit>
Jun 30 19:51:39 analog systemd[863]: Starting Virtual filesystem service - disk device monitor...
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Jun 30 19:51:39 analog systemd[863]: Started Virtual filesystem service - disk device monitor.
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.servi>
Jun 30 19:51:39 analog systemd[863]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Jun 30 19:51:39 analog systemd[863]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.servi>
Jun 30 19:51:39 analog systemd[863]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Jun 30 19:51:39 analog systemd[863]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Jun 30 19:51:39 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.servi>
Jun 30 19:51:39 analog systemd[863]: Starting Virtual filesystem service - Apple File Conduit monitor...
Jun 30 19:51:40 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Jun 30 19:51:40 analog systemd[863]: Started Virtual filesystem service - Apple File Conduit monitor.
Jun 30 19:51:40 analog dbus-daemon[920]: [session uid=1000 pid=920] Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monit>
Jun 30 19:51:40 analog systemd[863]: Starting Virtual filesystem service - digital camera monitor...
Jun 30 19:51:40 analog dbus-daemon[920]: [session uid=1000 pid=920] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Jun 30 19:51:40 analog systemd[863]: Started Virtual filesystem service - digital camera monitor.
Jun 30 19:51:41 analog systemd[1]: x11vnc.service: Scheduled restart job, restart counter is at 1.
Jun 30 19:51:41 analog systemd[1]: Stopped VNC Server for X11.
Jun 30 19:51:41 analog systemd[1]: Starting VNC Server for X11...
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 passing arg to libvncserver: -rfbauth
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 passing arg to libvncserver: /home/analog/.vnc/passwd
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 x11vnc version: 0.9.16 lastmod: 2019-01-05  pid: 1286
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Using X display :0
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 rootwin: 0x401 reswin: 0x1400001 dpy: 0xa40ea0
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 ------------------ USEFUL INFORMATION ------------------
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Wireframing: -wireframe mode is in effect for window moves.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   If this yields undesired behavior (poor response, painting
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   errors, etc) it may be disabled:
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41    - use '-nowf' to disable wireframing completely.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41    - use '-nowcr' to disable the Copy Rectangle after the
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41      moved window is released in the new position.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   Also see the -help entry for tuning parameters.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   You can press 3 Alt_L's (Left "Alt" key) in a row to
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   repaint the screen, also see the -fixscreen option for
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   periodic repaints.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 XFIXES available on display, resetting cursor mode
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   to: '-cursor most'.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   to disable this behavior use: '-cursor arrow'
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   or '-noxfixes'.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 using XFIXES for cursor drawing.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 GrabServer control via XTEST.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Scroll Detection: -scrollcopyrect mode is in effect to
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   use RECORD extension to try to detect scrolling windows
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   (induced by either user keystroke or mouse input).
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   errors, etc) it may be disabled via: '-noscr'
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 XKEYBOARD: number of keysyms per keycode 7 is greater
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   than 4 and 51 keysyms are mapped above 4.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   Automatically switching to -xkb mode.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   If this makes the key mapping worse you can
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   disable it with the "-noxkb" option.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41   Also, remember "-remap DEAD" for accenting characters.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 X FBPM extension not supported.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 X display is capable of DPMS.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 --------------------------------------------------------
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Default visual ID: 0x21
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Read initial data from X display into framebuffer.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 initialize_screen: fb_depth/fb_bpp/fb_Bpl 16/16/7680
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 X display :0 is 16bpp depth=16 true color
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Autoprobing TCP port
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Autoprobing selected TCP port 5900
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Autoprobing TCP6 port
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Autoprobing selected TCP6 port 5900
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 listen6: bind: Address already in use
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Not listening on IPv6 interface.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Xinerama is present and active (e.g. multi-head).
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Xinerama: number of sub-screens: 1
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 Xinerama: no blackouts needed (only one sub-screen)
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 fb read rate: 551 MB/sec
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 fast read: reset -defer ms to: 10
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 The X server says there are 10 mouse buttons.
Jun 30 19:51:41 analog x11vnc[1286]: 30/06/2023 19:51:41 screen setup finished.
Jun 30 19:51:41 analog x11vnc[1286]: The VNC desktop is:      analog:0
Jun 30 19:51:41 analog x11vnc[1286]: PORT=5900
Jun 30 19:51:41 analog x11vnc[1286]: ******************************************************************************
Jun 30 19:51:41 analog x11vnc[1286]: Have you tried the x11vnc '-ncache' VNC client-side pixel caching feature yet?
Jun 30 19:51:41 analog x11vnc[1286]: The scheme stores pixel data offscreen on the VNC viewer side for faster
Jun 30 19:51:41 analog x11vnc[1286]: retrieval.  It should work with any VNC viewer.  Try it by running:
Jun 30 19:51:41 analog x11vnc[1286]:     x11vnc -ncache 10 ...
Jun 30 19:51:41 analog x11vnc[1286]: One can also add -ncache_cr for smooth 'copyrect' window motion.
Jun 30 19:51:41 analog x11vnc[1286]: More info: http://www.karlrunge.com/x11vnc/faq.html#faq-client-caching
Jun 30 19:51:41 analog systemd[1]: Started VNC Server for X11.
Jun 30 19:51:42 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:51:42 analog dbus-daemon[624]: [system] Activating via systemd: service name='org.freedesktop.PackageKit' unit='packagekit.service' requested by ':1.37' (uid=100>
Jun 30 19:51:42 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 1.
Jun 30 19:51:42 analog systemd[1]: Starting PackageKit Daemon...
Jun 30 19:51:42 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:51:42 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:51:43 analog PackageKit[1313]: daemon start
Jun 30 19:51:43 analog dbus-daemon[624]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun 30 19:51:43 analog systemd[1]: Started PackageKit Daemon.
Jun 30 19:51:43 analog PackageKit[1313]: uid 1000 is trying to obtain org.freedesktop.packagekit.system-sources-refresh auth (only_trusted:0)
Jun 30 19:51:43 analog PackageKit[1313]: uid 1000 obtained auth for org.freedesktop.packagekit.system-sources-refresh
Jun 30 19:51:45 analog dhcpcd[699]: eth1: no IPv6 Routers available
Jun 30 19:51:48 analog agetty[1314]: /dev/ttyS0: not a tty
Jun 30 19:51:56 analog systemd[1]: systemd-fsckd.service: Succeeded.
Jun 30 19:51:58 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:51:58 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 2.
Jun 30 19:51:58 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:51:58 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:52:00 analog packagekitd[1313]: http://raspbian.raspberrypi.org/raspbian bullseye InRelease is not (yet) available (503  Service Unavailable [IP: 93.93.128.193 8>
Jun 30 19:52:00 analog packagekitd[1313]: http://archive.raspberrypi.org/debian bullseye InRelease is not (yet) available (503  Service Unavailable [IP: 46.235.231.151 80])
Jun 30 19:52:00 analog PackageKit[1313]: refresh-cache transaction /39_cbedeeed from uid 1000 finished with failed after 17444ms
Jun 30 19:52:03 analog agetty[1341]: /dev/ttyS0: not a tty
Jun 30 19:52:07 analog systemd[1]: systemd-hostnamed.service: Succeeded.
Jun 30 19:52:09 analog polkitd(authority=local)[646]: Operator of unix-session:1 successfully authenticated as unix-user:analog to gain TEMPORARY authorization for action >
Jun 30 19:52:09 analog pkexec[1343]: pam_unix(polkit-1:session): session opened for user root(uid=0) by (uid=1000)
Jun 30 19:52:09 analog pkexec[1343]: analog: Executing command [USER=root] [TTY=unknown] [CWD=/home/analog] [COMMAND=/usr/local/bin/osc]
Jun 30 19:52:13 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:52:13 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 3.
Jun 30 19:52:13 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:52:13 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:52:18 analog agetty[1359]: /dev/ttyS0: not a tty
Jun 30 19:52:28 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:52:28 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 4.
Jun 30 19:52:28 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:52:28 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:52:33 analog agetty[1371]: /dev/ttyS0: not a tty
Jun 30 19:52:43 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:52:43 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 5.
Jun 30 19:52:43 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:52:43 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:52:45 analog kernel: adrv9009 spi1.1: initialize ignored: in multichip configuration this is only allowed by the top device
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition idle -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> idle
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition idle -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> link_supported
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
Jun 30 19:52:45 analog kernel: axi-jesd204-tx 84a30000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_pre_setup: Link0 set lane rate 4800000 kHz failed (-22)
Jun 30 19:52:45 analog kernel: jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:9,parent=84a30000.axi-jesd204-tx: JESD204[0:0] In link_pre_setup got error from cb: -22
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
Jun 30 19:52:45 analog kernel: adrv9009 spi1.0: ADIHAL_resetHw
Jun 30 19:52:45 analog kernel: adrv9009 spi1.1: ADIHAL_resetHw
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_pre_setup
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_pre_setup -> link_supported
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
Jun 30 19:52:45 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -22
Jun 30 19:52:48 analog agetty[1377]: /dev/ttyS0: not a tty
Jun 30 19:52:50 analog systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/start timed out.
Jun 30 19:52:50 analog systemd[1]: Timed out waiting for device /dev/ttyGS0.
Jun 30 19:52:50 analog systemd[1]: Dependency failed for Serial Getty on ttyGS0.
Jun 30 19:52:50 analog systemd[1]: serial-getty@ttyGS0.service: Job serial-getty@ttyGS0.service/start failed with result 'dependency'.
Jun 30 19:52:50 analog systemd[1]: dev-ttyGS0.device: Job dev-ttyGS0.device/start failed with result 'timeout'.
Jun 30 19:52:50 analog systemd[1]: dev-ttyGS1.device: Job dev-ttyGS1.device/start timed out.
Jun 30 19:52:50 analog systemd[1]: Timed out waiting for device /dev/ttyGS1.
Jun 30 19:52:50 analog systemd[1]: Dependency failed for Serial Getty on ttyGS1.
Jun 30 19:52:50 analog systemd[1]: serial-getty@ttyGS1.service: Job serial-getty@ttyGS1.service/start failed with result 'dependency'.
Jun 30 19:52:50 analog systemd[1]: dev-ttyGS1.device: Job dev-ttyGS1.device/start failed with result 'timeout'.
Jun 30 19:52:50 analog systemd[1]: Reached target Login Prompts.
Jun 30 19:52:50 analog systemd[1]: Reached target Multi-User System.
Jun 30 19:52:50 analog systemd[1]: Reached target Graphical Interface.
Jun 30 19:52:50 analog systemd[1]: Starting Update UTMP about System Runlevel Changes...
Jun 30 19:52:50 analog systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Jun 30 19:52:50 analog systemd[1]: Finished Update UTMP about System Runlevel Changes.
Jun 30 19:52:50 analog systemd[1]: Startup finished in 6.570s (kernel) + 1min 31.893s (userspace) = 1min 38.464s.
Jun 30 19:52:58 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:52:59 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 6.
Jun 30 19:52:59 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:52:59 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:52:59 analog agetty[1379]: /dev/ttyS0: not a tty
Jun 30 19:53:09 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:53:09 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 7.
Jun 30 19:53:09 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:53:09 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:53:09 analog agetty[1380]: /dev/ttyS0: not a tty
Jun 30 19:53:19 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:53:19 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 8.
Jun 30 19:53:19 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:53:19 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:53:19 analog agetty[1381]: /dev/ttyS0: not a tty
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition idle -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> idle
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition idle -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition idle -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition idle -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition device_init -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> link_supported
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
Jun 30 19:53:24 analog kernel: axi-jesd204-tx 84a30000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_pre_setup: Link0 set lane rate 4800000 kHz failed (-22)
Jun 30 19:53:24 analog kernel: jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:9,parent=84a30000.axi-jesd204-tx: JESD204[0:0] In link_pre_setup got error from cb: -22
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
Jun 30 19:53:24 analog kernel: adrv9009 spi1.0: ADIHAL_resetHw
Jun 30 19:53:24 analog kernel: adrv9009 spi1.1: ADIHAL_resetHw
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_pre_setup
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> link_supported
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_pre_setup -> link_supported
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> link_supported
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_supported -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_supported -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_supported -> link_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:2] transition link_init -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:1] transition link_init -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: JESD204[0:0] transition link_init -> device_init
Jun 30 19:53:24 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: FSM completed with error -22
Jun 30 19:53:29 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:53:29 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 9.
Jun 30 19:53:29 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:53:29 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:53:29 analog agetty[1393]: /dev/ttyS0: not a tty
Jun 30 19:53:39 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:53:40 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 10.
Jun 30 19:53:40 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:53:40 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:53:40 analog agetty[1395]: /dev/ttyS0: not a tty
Jun 30 19:53:50 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:53:50 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 11.
Jun 30 19:53:50 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:53:50 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:53:50 analog agetty[1396]: /dev/ttyS0: not a tty
Jun 30 19:54:00 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:00 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 12.
Jun 30 19:54:00 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:00 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:00 analog agetty[1399]: /dev/ttyS0: not a tty
Jun 30 19:54:10 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:10 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 13.
Jun 30 19:54:10 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:10 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:10 analog agetty[1400]: /dev/ttyS0: not a tty
Jun 30 19:54:20 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:21 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 14.
Jun 30 19:54:21 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:21 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:21 analog agetty[1401]: /dev/ttyS0: not a tty
Jun 30 19:54:31 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:31 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 15.
Jun 30 19:54:31 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:31 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:31 analog agetty[1402]: /dev/ttyS0: not a tty
Jun 30 19:54:41 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:41 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 16.
Jun 30 19:54:41 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:41 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:41 analog agetty[1403]: /dev/ttyS0: not a tty
Jun 30 19:54:51 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:54:51 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 17.
Jun 30 19:54:51 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:54:51 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:54:51 analog agetty[1404]: /dev/ttyS0: not a tty
Jun 30 19:55:01 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:02 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 18.
Jun 30 19:55:02 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:02 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:02 analog agetty[1405]: /dev/ttyS0: not a tty
Jun 30 19:55:12 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:12 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 19.
Jun 30 19:55:12 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:12 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:12 analog agetty[1406]: /dev/ttyS0: not a tty
Jun 30 19:55:22 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:22 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 20.
Jun 30 19:55:22 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:22 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:22 analog agetty[1407]: /dev/ttyS0: not a tty
Jun 30 19:55:26 analog kernel: adrv9009 spi1.1: initialize ignored: in multichip configuration this is only allowed by the top device
Jun 30 19:55:27 analog kernel: adrv9009 spi1.1: initialize ignored: in multichip configuration this is only allowed by the top device
Jun 30 19:55:32 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:32 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 21.
Jun 30 19:55:32 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:32 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:32 analog agetty[1408]: /dev/ttyS0: not a tty
Jun 30 19:55:42 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:43 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 22.
Jun 30 19:55:43 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:43 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:43 analog agetty[1410]: /dev/ttyS0: not a tty
Jun 30 19:55:53 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:55:53 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 23.
Jun 30 19:55:53 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:55:53 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:55:53 analog agetty[1411]: /dev/ttyS0: not a tty
Jun 30 19:56:03 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:03 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 24.
Jun 30 19:56:03 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:03 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:03 analog agetty[1412]: /dev/ttyS0: not a tty
Jun 30 19:56:13 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:13 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 25.
Jun 30 19:56:13 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:13 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:13 analog agetty[1413]: /dev/ttyS0: not a tty
Jun 30 19:56:23 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:24 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 26.
Jun 30 19:56:24 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:24 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:24 analog agetty[1416]: /dev/ttyS0: not a tty
Jun 30 19:56:34 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:34 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 27.
Jun 30 19:56:34 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:34 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:34 analog agetty[1417]: /dev/ttyS0: not a tty
Jun 30 19:56:44 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:44 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 28.
Jun 30 19:56:44 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:44 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:44 analog agetty[1420]: /dev/ttyS0: not a tty
Jun 30 19:56:54 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:56:54 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 29.
Jun 30 19:56:54 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:56:54 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:56:54 analog agetty[1421]: /dev/ttyS0: not a tty
Jun 30 19:57:04 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:05 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 30.
Jun 30 19:57:05 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:05 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:05 analog agetty[1422]: /dev/ttyS0: not a tty
Jun 30 19:57:15 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:15 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 31.
Jun 30 19:57:15 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:15 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:15 analog agetty[1424]: /dev/ttyS0: not a tty
Jun 30 19:57:25 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:25 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 32.
Jun 30 19:57:25 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:25 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:25 analog agetty[1425]: /dev/ttyS0: not a tty
Jun 30 19:57:35 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:35 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 33.
Jun 30 19:57:35 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:35 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:35 analog agetty[1427]: /dev/ttyS0: not a tty
Jun 30 19:57:45 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:46 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 34.
Jun 30 19:57:46 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:46 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:46 analog agetty[1428]: /dev/ttyS0: not a tty
Jun 30 19:57:56 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:57:56 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 35.
Jun 30 19:57:56 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:57:56 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:57:56 analog agetty[1429]: /dev/ttyS0: not a tty
Jun 30 19:58:06 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:06 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 36.
Jun 30 19:58:06 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:06 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:06 analog agetty[1430]: /dev/ttyS0: not a tty
Jun 30 19:58:16 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:16 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 37.
Jun 30 19:58:16 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:16 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:16 analog agetty[1432]: /dev/ttyS0: not a tty
Jun 30 19:58:26 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:27 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 38.
Jun 30 19:58:27 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:27 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:27 analog agetty[1433]: /dev/ttyS0: not a tty
Jun 30 19:58:37 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:37 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 39.
Jun 30 19:58:37 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:37 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:37 analog agetty[1434]: /dev/ttyS0: not a tty
Jun 30 19:58:47 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:47 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 40.
Jun 30 19:58:47 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:47 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:47 analog agetty[1435]: /dev/ttyS0: not a tty
Jun 30 19:58:57 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:58:57 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 41.
Jun 30 19:58:57 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:58:57 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:58:57 analog agetty[1436]: /dev/ttyS0: not a tty
Jun 30 19:59:07 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:08 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 42.
Jun 30 19:59:08 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:08 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:08 analog agetty[1437]: /dev/ttyS0: not a tty
Jun 30 19:59:18 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:18 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 43.
Jun 30 19:59:18 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:18 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:18 analog agetty[1438]: /dev/ttyS0: not a tty
Jun 30 19:59:28 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:28 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 44.
Jun 30 19:59:28 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:28 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:28 analog agetty[1439]: /dev/ttyS0: not a tty
Jun 30 19:59:38 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:38 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 45.
Jun 30 19:59:38 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:38 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:38 analog agetty[1440]: /dev/ttyS0: not a tty
Jun 30 19:59:48 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:49 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 46.
Jun 30 19:59:49 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:49 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:49 analog agetty[1441]: /dev/ttyS0: not a tty
Jun 30 19:59:59 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 19:59:59 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 47.
Jun 30 19:59:59 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 19:59:59 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 19:59:59 analog agetty[1442]: /dev/ttyS0: not a tty
Jun 30 20:00:09 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:00:09 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 48.
Jun 30 20:00:09 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:00:09 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:00:09 analog agetty[1443]: /dev/ttyS0: not a tty
Jun 30 20:00:19 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:00:19 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 49.
Jun 30 20:00:19 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:00:19 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:00:19 analog agetty[1444]: /dev/ttyS0: not a tty
Jun 30 20:00:29 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:00:30 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 50.
Jun 30 20:00:30 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:00:30 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:00:30 analog agetty[1445]: /dev/ttyS0: not a tty
Jun 30 20:00:40 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:00:40 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 51.
Jun 30 20:00:40 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:00:40 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:00:40 analog agetty[1446]: /dev/ttyS0: not a tty
Jun 30 20:00:50 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:00:50 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 52.
Jun 30 20:00:50 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:00:50 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:00:50 analog agetty[1447]: /dev/ttyS0: not a tty
Jun 30 20:01:00 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:01:00 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 53.
Jun 30 20:01:00 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:01:00 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:01:00 analog agetty[1448]: /dev/ttyS0: not a tty
Jun 30 20:01:10 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:01:11 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 54.
Jun 30 20:01:11 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:01:11 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:01:11 analog agetty[1449]: /dev/ttyS0: not a tty
Jun 30 20:01:21 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:01:21 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 55.
Jun 30 20:01:21 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:01:21 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:01:21 analog agetty[1451]: /dev/ttyS0: not a tty
Jun 30 20:01:31 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:01:31 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 56.
Jun 30 20:01:31 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:01:31 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:01:31 analog agetty[1454]: /dev/ttyS0: not a tty
Jun 30 20:01:41 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:01:41 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 57.
Jun 30 20:01:41 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:01:41 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:01:41 analog agetty[1456]: /dev/ttyS0: not a tty
Jun 30 20:01:44 analog htpdate[774]: www.wikipedia.org no timestamp
Jun 30 20:01:50 analog htpdate[774]: www.wikipedia.org no timestamp
Jun 30 20:01:50 analog htpdate[774]: Setting 44.000 seconds
Jun 30 20:01:50 analog htpdate[774]: Set: Fri Jun 30 20:02:34 2023
Jun 30 20:02:35 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:02:35 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 58.
Jun 30 20:02:35 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:02:35 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:02:35 analog agetty[1457]: /dev/ttyS0: not a tty
Jun 30 20:02:45 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:02:45 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 59.
Jun 30 20:02:45 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:02:45 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:02:45 analog agetty[1458]: /dev/ttyS0: not a tty
Jun 30 20:02:55 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:02:55 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 60.
Jun 30 20:02:55 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:02:55 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:02:55 analog agetty[1459]: /dev/ttyS0: not a tty
Jun 30 20:03:05 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:06 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 61.
Jun 30 20:03:06 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:06 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:06 analog agetty[1460]: /dev/ttyS0: not a tty
Jun 30 20:03:16 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:16 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 62.
Jun 30 20:03:16 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:16 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:16 analog agetty[1461]: /dev/ttyS0: not a tty
Jun 30 20:03:26 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:26 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 63.
Jun 30 20:03:26 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:26 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:26 analog agetty[1463]: /dev/ttyS0: not a tty
Jun 30 20:03:36 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:36 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 64.
Jun 30 20:03:36 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:36 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:36 analog agetty[1464]: /dev/ttyS0: not a tty
Jun 30 20:03:46 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:47 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 65.
Jun 30 20:03:47 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:47 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:47 analog agetty[1465]: /dev/ttyS0: not a tty
Jun 30 20:03:57 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:03:57 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 66.
Jun 30 20:03:57 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:03:57 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:03:57 analog agetty[1466]: /dev/ttyS0: not a tty
Jun 30 20:04:07 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:07 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 67.
Jun 30 20:04:07 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:07 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:07 analog agetty[1467]: /dev/ttyS0: not a tty
Jun 30 20:04:17 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:17 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 68.
Jun 30 20:04:17 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:17 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:17 analog agetty[1471]: /dev/ttyS0: not a tty
Jun 30 20:04:18 analog sshd[1468]: Accepted password for analog from 192.168.20.27 port 59419 ssh2
Jun 30 20:04:18 analog sshd[1468]: pam_unix(sshd:session): session opened for user analog(uid=1000) by (uid=0)
Jun 30 20:04:18 analog systemd-logind[658]: New session 6 of user analog.
Jun 30 20:04:18 analog systemd[1]: Started Session 6 of user analog.
Jun 30 20:04:19 analog sshd[1472]: Accepted password for analog from 192.168.20.27 port 59420 ssh2
Jun 30 20:04:19 analog sshd[1472]: pam_unix(sshd:session): session opened for user analog(uid=1000) by (uid=0)
Jun 30 20:04:19 analog systemd-logind[658]: New session 7 of user analog.
Jun 30 20:04:19 analog systemd[1]: Started Session 7 of user analog.
Jun 30 20:04:27 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:28 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 69.
Jun 30 20:04:28 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:28 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:28 analog agetty[1556]: /dev/ttyS0: not a tty
Jun 30 20:04:38 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:38 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 70.
Jun 30 20:04:38 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:38 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:38 analog agetty[1618]: /dev/ttyS0: not a tty
Jun 30 20:04:48 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:48 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 71.
Jun 30 20:04:48 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:48 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:48 analog agetty[1679]: /dev/ttyS0: not a tty
Jun 30 20:04:58 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:04:58 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 72.
Jun 30 20:04:58 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:04:58 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:04:58 analog agetty[1740]: /dev/ttyS0: not a tty
Jun 30 20:05:08 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:05:09 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 73.
Jun 30 20:05:09 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:05:09 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:05:09 analog agetty[1801]: /dev/ttyS0: not a tty
Jun 30 20:05:19 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:05:19 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 74.
Jun 30 20:05:19 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:05:19 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:05:19 analog agetty[1862]: /dev/ttyS0: not a tty
Jun 30 20:05:29 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:05:29 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 75.
Jun 30 20:05:29 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:05:29 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:05:29 analog agetty[1923]: /dev/ttyS0: not a tty
Jun 30 20:05:39 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:05:39 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 76.
Jun 30 20:05:39 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:05:39 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:05:39 analog agetty[1991]: /dev/ttyS0: not a tty
Jun 30 20:05:49 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:05:50 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 77.
Jun 30 20:05:50 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:05:50 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:05:50 analog agetty[2052]: /dev/ttyS0: not a tty
Jun 30 20:06:00 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:00 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 78.
Jun 30 20:06:00 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:00 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:00 analog agetty[2113]: /dev/ttyS0: not a tty
Jun 30 20:06:10 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:10 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 79.
Jun 30 20:06:10 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:10 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:10 analog agetty[2174]: /dev/ttyS0: not a tty
Jun 30 20:06:20 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:20 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 80.
Jun 30 20:06:20 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:20 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:20 analog agetty[2235]: /dev/ttyS0: not a tty
Jun 30 20:06:30 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:31 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 81.
Jun 30 20:06:31 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:31 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:31 analog agetty[2296]: /dev/ttyS0: not a tty
Jun 30 20:06:41 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:41 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 82.
Jun 30 20:06:41 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:41 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:41 analog agetty[2357]: /dev/ttyS0: not a tty
Jun 30 20:06:51 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:06:51 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 83.
Jun 30 20:06:51 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:06:51 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:06:51 analog agetty[2418]: /dev/ttyS0: not a tty
Jun 30 20:06:58 analog systemd[1]: Starting Cleanup of Temporary Directories...
Jun 30 20:06:58 analog systemd[1]: systemd-tmpfiles-clean.service: Succeeded.
Jun 30 20:06:58 analog systemd[1]: Finished Cleanup of Temporary Directories.
Jun 30 20:07:01 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:07:01 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 84.
Jun 30 20:07:01 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:07:01 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:07:01 analog agetty[2480]: /dev/ttyS0: not a tty
Jun 30 20:07:11 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:07:12 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 85.
Jun 30 20:07:12 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:07:12 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:07:12 analog agetty[2541]: /dev/ttyS0: not a tty
Jun 30 20:07:22 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:07:22 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 86.
Jun 30 20:07:22 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:07:22 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:07:22 analog agetty[2603]: /dev/ttyS0: not a tty
Jun 30 20:07:32 analog systemd[1]: serial-getty@ttyS0.service: Succeeded.
Jun 30 20:07:32 analog systemd[1]: serial-getty@ttyS0.service: Scheduled restart job, restart counter is at 87.
Jun 30 20:07:32 analog systemd[1]: Stopped Serial Getty on ttyS0.
Jun 30 20:07:32 analog systemd[1]: Started Serial Getty on ttyS0.
Jun 30 20:07:32 analog agetty[2670]: /dev/ttyS0: not a tty
lines 1657-1715/1715 (END)
Jun 30 19:51:21 analog kernel: axi-jesd204-tx 84a30000.axi-jesd204-tx: axi_jesd204_tx_jesd204_link_pre_setup: Link0 set lane rate 4800000 kHz failed (-22)
Jun 30 19:51:21 analog kernel: jesd204: /fpga-axi@0/axi-jesd204-tx@84a30000,jesd204:9,parent=84a30000.axi-jesd204-tx: JESD204[0:0] In link_pre_setup got error from cb: -22
Jun 30 19:51:21 analog kernel: jesd204: /axi/spi@ff040000/adrv9009-phy@0,jesd204:0,parent=spi1.0: Rolling back from 'link_supported', got error -22
Thread Notes
  • Was this board working with 122.88MHz oscillator earlier? Was the JESD up and running with 122.88MHz oscillator? If not can you test with 122.88MHz default crystal and verify if its working fine or not ?
    What is the Dev clock, I hope you have generated the configuration files correctly, it looks like Dev clock is 240MHz, right?
    Have you tried PRBS testing for Signal integrity?
    Can you readback the framer and deframer status once ?
  • Yes, we verified the board and JESD with the 122.88 MHz VCXO as working well with our test setup. The desired device clock is 240 MHz, correct. I have not tried a PRBS test. That requires the TALISE API? Is this the status you are asking for?
    analog@analog:~ $ sudo grep "" /sys/bus/platform/devices/*.axi-jesd*/status*
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Link is disabled
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Measured Link Clock: 120.001 MHz
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Reported Link Clock: 120.000 MHz
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Measured Device Clock: 120.001 MHz
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Reported Device Clock: 120.000 MHz
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:Desired Device Clock: 120.000 MHz
    /sys/bus/platform/devices/84a30000.axi-jesd204-tx/status:External reset is deasserted
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Link is disabled
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Measured Link Clock: 240.002 MHz
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Reported Link Clock: 240.000 MHz
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Measured Device Clock: 240.002 MHz
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Reported Device Clock: 240.000 MHz
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:Desired Device Clock: 240.000 MHz
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/status:External reset is deasserted
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Link is disabled
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Measured Link Clock: 120.001 MHz
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Reported Link Clock: 120.000 MHz
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Measured Device Clock: 120.001 MHz
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Reported Device Clock: 120.000 MHz
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:Desired Device Clock: 120.000 MHz
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/status:External reset is deasserted
    analog@analog:~ $ sudo grep "" /sys/bus/platform/devices/*.axi-jesd*/lane*
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane0_info:Errors: 0
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane0_info:CGS state: INIT
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane0_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane1_info:Errors: 0
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane1_info:CGS state: INIT
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane1_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane2_info:Errors: 0
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane2_info:CGS state: INIT
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane2_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane3_info:Errors: 0
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane3_info:CGS state: INIT
    /sys/bus/platform/devices/84a50000.axi-jesd204-rx/lane3_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane0_info:Errors: 0
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane0_info:CGS state: INIT
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane0_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane1_info:Errors: 0
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane1_info:CGS state: INIT
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane1_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane2_info:Errors: 0
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane2_info:CGS state: INIT
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane2_info:Initial Frame Synchronization: No
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane3_info:Errors: 0
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane3_info:CGS state: INIT
    /sys/bus/platform/devices/84a70000.axi-jesd204-rx/lane3_info:Initial Frame Synchronization: No
    analog@analog:~ $
  • I am seeing the HMC7044 and HMC7044-car using the CLKIN0 for PLL1 when it has been configured to use CLKIN1.
    adi,pll1-ref-prio-ctrl = <0xaa>;
  • analog@analog:~ $ sudo iio_info
    [sudo] password for analog:
    Library version: 0.24 (git tag: accb7b5)
    Compiled with backends: local xml ip usb serial
    IIO context created with local backend.
    Backend version: 0.24 (git tag: accb7b5)
    Backend description string: Linux analog 5.10.0-98744-g64e7a607b659 #1789 SMP Fri Mar 31 17:23:38 EEST 2023 aarch64
    IIO context has 5 attributes:
    	hdl_system_id: [(null)] on [adrv9009zu11eg] git branch [hdl_2021_r2] git [a83056b11d6b092d342b72c68ef713b362b10521] clean [2023-03-31 20:39:12] UTC
    	hw_carrier: Analog Devices ADRV9009-ZU11EG Rev.B
    	unique_id: 104000323e0e000915001900e8907a32c3
    	local,kernel: 5.10.0-98744-g64e7a607b659
    	uri: local:
    IIO context has 14 devices:
    	hwmon0: ff0e0000ethernetffffffff00
    		1 channels found:
    			temp1:  (input)
    			3 channel-specific attributes found:
    				attr  0: crit value: 100000
    				attr  1: input value: 34000
    				attr  2: max_alarm value: 0
    		No trigger on this device
    	hwmon1: ff0e0000ethernetffffffff01
    		1 channels found:
    			temp1:  (input)
    				attr  1: input value: 28000
    	hwmon2: adm1266
    		17 channels found:
    			in4:  (input)
    			6 channel-specific attributes found:
    				attr  0: crit value: 31130000
    				attr  1: crit_alarm value: 0
    				attr  2: input value: 29451000
    				attr  3: label value: vout4
    				attr  4: lcrit value: 27853000
    				attr  5: lcrit_alarm value: 0
    			in15:  (input)
    			8 channel-specific attributes found:
    				attr  0: crit value: 1900
    				attr  1: crit_alarm ERROR: No such device or address (6)
    				attr  2: input value: 1799
    				attr  3: label value: vout15
    				attr  4: lcrit value: 1700
    				attr  6: max value: 0
    				attr  7: max_alarm value: 0
    			in16:  (input)
    				attr  3: label value: vout16
    			in2:  (input)
    				attr  0: crit value: 57344000
    				attr  2: input value: 53843000
    				attr  3: label value: vout2
    				attr  4: lcrit value: 49152000
    			in13:  (input)
    				attr  0: crit value: 1380
    				attr  2: input ERROR: No such device or address (6)
    				attr  3: label value: vout13
    				attr  4: lcrit value: 1200
    			in12:  (input)
    				attr  0: crit value: 45220000
    				attr  2: input value: 42359000
    				attr  3: label value: vout12
    				attr  4: lcrit value: 39322000
    			in11:  (input)
    				attr  2: input value: 1293
    				attr  3: label value: vout11
    			in3:  (input)
    				attr  0: crit value: 13000
    				attr  2: input value: 11968
    				attr  3: label value: vout3
    				attr  4: lcrit value: 11000
    			in8:  (input)
    				attr  2: input value: 29572000
    				attr  3: label value: vout8
    			in5:  (input)
    				attr  0: crit value: 899
    				attr  2: input value: 849
    				attr  3: label value: vout5
    				attr  4: max value: 0
    				attr  5: max_alarm value: 0
    			in7:  (input)
    				attr  3: label value: vout7
    				attr  4: lcrit value: 799
    			in1:  (input)
    				attr  2: input value: 11976
    				attr  6: min value: 11500
    				attr  7: min_alarm value: 0
    			in17:  (input)
    				attr  0: crit value: 1399
    				attr  2: input value: 906
    				attr  3: label value: vout17
    				attr  4: lcrit value: 765
    			in10:  (input)
    				attr  0: crit value: 41943000
    				attr  2: input value: 39329000
    				attr  3: label value: vout10
    				attr  4: lcrit value: 36045000
    			in14:  (input)
    				attr  0: crit ERROR: No such device or address (6)
    				attr  2: input value: 42541000
    				attr  3: label value: vout14
    			in9:  (input)
    				attr  0: crit value: 950
    				attr  2: input value: 900
    				attr  3: label value: vout9
    				attr  4: lcrit value: 850
    			in6:  (input)
    				attr  0: crit value: 29491000
    				attr  2: input value: 27989000
    				attr  3: label value: vout6
    				attr  4: lcrit value: 26214000
    	hwmon3: axi_fan_control
    		3 channels found:
    			fan1:  (input)
    				attr  0: fault value: 0
    				attr  1: input value: 1765
    				attr  2: label value: FAN
    			temp1:  (input)
    			2 channel-specific attributes found:
    				attr  0: input value: 36437
    				attr  1: label value: SYSMON4
    			pwm1:  (input)
    			1 channel-specific attributes found:
    				attr  0: pwm1 value: 64
    	iio:device0: ams
    		30 channels found:
    			voltage6: vccpsintfpddr (input)
    				attr  0: raw value: 18543
    				attr  1: scale value: 0.045776367
    			voltage14: vccpsio2 (input)
    				attr  0: raw value: 19461
    				attr  1: scale value: 0.091552734
    			voltage16: psmgtravtt (input)
    				attr  0: raw value: 39421
    			voltage23: vccplintlp (input)
    				attr  0: raw value: 0
    			voltage0: vcc_pspll0 (input)
    				attr  0: raw value: 26149
    			voltage22: vccbram (input)
    			voltage26: vccams (input)
    				attr  1: scale value: 0.015258789
    			voltage8: vccpsintfp (input)
    				attr  0: raw value: 18596
    			temp1: remote_temp (input)
    				attr  0: offset value: -36058
    				attr  1: raw value: 40748
    				attr  2: scale value: 7.771514892
    			voltage9: vccpsaux (input)
    				attr  0: raw value: 39198
    			voltage25: vccplaux (input)
    			voltage18: vccint (input)
    			voltage15: psmgtravcc (input)
    				attr  0: raw value: 18580
    			temp0: ps_temp (input)
    				attr  1: raw value: 41030
    			voltage2: vccint (input)
    				attr  0: raw value: 18506
    			voltage5: vcc_psddrpll (input)
    				attr  0: raw value: 39164
    			voltage21: vccvrefn (input)
    			voltage7: vccpsintlp (input)
    				attr  0: raw value: 18575
    			voltage11: vccpsio3 (input)
    				attr  0: raw value: 19476
    			temp2: pl_temp (input)
    				attr  1: raw value: 0
    			voltage13: vccpsio1 (input)
    				attr  0: raw value: 19459
    			voltage3: vccbram (input)
    				attr  0: raw value: 18481
    			voltage4: vccaux (input)
    				attr  0: raw value: 39130
    			voltage12: vccpsio0 (input)
    				attr  0: raw value: 19483
    			voltage10: vccpsddr (input)
    				attr  0: raw value: 25987
    			voltage24: vccplintfp (input)
    			voltage1: vcc_psbatt (input)
    				attr  0: raw value: 34800
    			voltage19: vccaux (input)
    			voltage17: vccams (input)
    				attr  0: raw value: 39064
    			voltage20: vccvrefp (input)
    		1 device-specific attributes found:
    				attr  0: sampling_frequency ERROR: Invalid argument (22)
    	iio:device1: hmc7044-car
    		8 channels found:
    			altvoltage6: SYNC_OUT2 (output)
    				attr  0: frequency value: 3750000
    				attr  1: phase value: 0.000000
    			altvoltage10: REFCLK_QSFP (output)
    				attr  0: frequency value: 25000000
    			altvoltage8: REFCLK_OUT3 (output)
    			altvoltage9: REFCLK_OUT4 (output)
    			altvoltage2: REFCLK_OUT2 (output)
    			altvoltage5: SYNC_OUT1 (output)
    			altvoltage11: REFCLK_SFP (output)
    				attr  0: frequency value: 100000000
    			altvoltage0: REFCLK_OUT0 (output)
    		7 device-specific attributes found:
    				attr  0: mute_request value: 0
    				attr  1: reseed_request value: 0
    				attr  2: reset_dividers_request value: 0
    				attr  3: sleep_request value: 0
    				attr  4: sync_pin_mode value: disable
    				attr  5: sync_pin_mode_available value: disable sync sysref sync_else_sysref
    				attr  6: sysref_request value: 0
    		2 debug attributes found:
    				debug attr  0: status value: --- PLL1 ---
    Status:	Holdover
    Using:	CLKIN0 @ 80000000 Hz
    PFD:	3200 kHz
    --- PLL2 ---
    Status:	Locked (Synchronized)
    Frequency:	2400000000 Hz (Autocal cap bank value: 14)
    SYSREF Status:	Valid & Locked
    SYNC Status:	Synchronized
    Lock Status:	Unlocked
    				debug attr  1: direct_reg_access value: 0x0
    	iio:device2: hmc7044-ext
    		4 channels found:
    			altvoltage4: SYNC_OUT1 (output)
    				attr  0: frequency value: 768000
    				attr  1: phase value: 0.025362
    			altvoltage12: REFCLK_OUT2 (output)
    				attr  0: frequency value: 30720000
    				attr  1: phase value: 1.014472
    			altvoltage5: REFCLK_OUT0 (output)
    				attr  0: mute_request value: 1
    				attr  1: reseed_request value: 1
    				attr  2: reset_dividers_request value: 1
    				attr  3: sleep_request value: 1
    				attr  4: sync_pin_mode value: sync_else_sysref
    				attr  6: sysref_request value: 1
    				debug attr  0: status ERROR: Input/output error (5)
    				debug attr  1: direct_reg_access value: 0xFF
    	iio:device3: hmc7044
    		10 channels found:
    			altvoltage8: FPGA_SYSREF_TX_OBS_AB (output)
    			altvoltage7: CORE_CLK_RX_AB (output)
    				attr  0: frequency value: 120000000
    			altvoltage5: JESD_REFCLK_RX_AB (output)
    				attr  0: frequency value: 200000000
    			altvoltage9: FPGA_SYSREF_RX_AB (output)
    			altvoltage4: JESD_REFCLK_TX_OBS_AB (output)
    			altvoltage0: DEV_REFCLK_A (output)
    				attr  1: phase value: 3.926990
    			altvoltage3: DEV_SYSREF_B (output)
    			altvoltage1: DEV_SYSREF_A (output)
    			altvoltage6: CORE_CLK_TX_OBS_AB (output)
    			altvoltage2: DEV_REFCLK_B (output)
    Status:	Holdover
    PFD:	5000 kHz
    --- PLL2 ---
    	iio:device4: adrv9009-phy
    		25 channels found:
    			altvoltage1:  (output)
    				attr  0: AUX_OBS_RX_LO_frequency ERROR: Device or resource busy (16)
    			voltage9:  (output)
    			4 channel-specific attributes found:
    				attr  0: offset ERROR: Device or resource busy (16)
    				attr  1: raw ERROR: Device or resource busy (16)
    				attr  2: sampling_frequency ERROR: Device or resource busy (16)
    				attr  3: scale ERROR: Device or resource busy (16)
    			voltage8:  (output)
    			voltage3:  (input)
    				attr  0: bb_dc_offset_tracking_en ERROR: Device or resource busy (16)
    				attr  1: hardwaregain ERROR: Device or resource busy (16)
    				attr  2: powerdown ERROR: Device or resource busy (16)
    				attr  3: quadrature_tracking_en ERROR: Device or resource busy (16)
    				attr  4: rf_bandwidth ERROR: Device or resource busy (16)
    				attr  5: rf_port_select value: OBS_TX_LO
    				attr  6: rf_port_select_available value: OBS_TX_LO OBS_AUX_LO
    				attr  7: sampling_frequency ERROR: Device or resource busy (16)
    			voltage2:  (output)
    			voltage1:  (output)
    				attr  0: atten_control_pin_mode_en ERROR: Device or resource busy (16)
    				attr  2: lo_leakage_tracking_en ERROR: Device or resource busy (16)
    				attr  3: pa_protection_en ERROR: Device or resource busy (16)
    				attr  4: powerdown ERROR: Device or resource busy (16)
    				attr  5: quadrature_tracking_en ERROR: Device or resource busy (16)
    				attr  6: rf_bandwidth ERROR: Device or resource busy (16)
    			voltage0:  (output)
    			altvoltage0: TRX_LO (output)
    				attr  0: frequency ERROR: Device or resource busy (16)
    				attr  1: frequency_hopping_mode ERROR: Device or resource busy (16)
    				attr  2: frequency_hopping_mode_enable ERROR: Device or resource busy (16)
    			voltage2:  (input)
    			voltage5:  (input)
    				attr  2: scale ERROR: Device or resource busy (16)
    			voltage6:  (input)
    			voltage12:  (output)
    				attr  0: raw ERROR: Device or resource busy (16)
    				attr  1: sampling_frequency ERROR: Device or resource busy (16)
    			voltage6:  (output)
    			voltage13:  (output)
    			voltage4:  (input)
    			voltage5:  (output)
    			voltage1:  (input)
    			11 channel-specific attributes found:
    				attr  1: gain_control_mode value: manual
    				attr  2: gain_control_mode_available value: manual slow_attack
    				attr  3: gain_control_pin_mode_en ERROR: Device or resource busy (16)
    				attr  4: hardwaregain ERROR: Device or resource busy (16)
    				attr  5: hd2_tracking_en ERROR: Device or resource busy (16)
    				attr  6: powerdown ERROR: Device or resource busy (16)
    				attr  7: quadrature_tracking_en ERROR: Device or resource busy (16)
    				attr  8: rf_bandwidth ERROR: Device or resource busy (16)
    				attr  9: rssi ERROR: Device or resource busy (16)
    				attr 10: sampling_frequency ERROR: Device or resource busy (16)
    			voltage3:  (output)
    			voltage10:  (output)
    			voltage7:  (input)
    			voltage0:  (input)
    			voltage4:  (output)
    			voltage11:  (output)
    			voltage7:  (output)
    			temp0:  (input)
    				attr  0: input ERROR: Device or resource busy (16)
    		17 device-specific attributes found:
    				attr  0: calibrate value: 0
    				attr  1: calibrate_fhm_en value: 0
    				attr  2: calibrate_rx_phase_correction_en value: 0
    				attr  3: calibrate_rx_qec_en value: 0
    				attr  4: calibrate_tx_lol_en value: 0
    				attr  5: calibrate_tx_lol_ext_en value: 0
    				attr  6: calibrate_tx_qec_en value: 0
    				attr  7: ensm_mode value: radio_off
    				attr  8: ensm_mode_available value: radio_on radio_off
    				attr  9: gain_table_config ERROR: Permission denied (13)
    				attr 10: jesd204_fsm_ctrl value: 0
    				attr 11: jesd204_fsm_error value: -22
    				attr 12: jesd204_fsm_paused value: 0
    				attr 13: jesd204_fsm_resume ERROR: Permission denied (13)
    				attr 14: jesd204_fsm_state value: idle
    				attr 15: multichip_sync ERROR: Permission denied (13)
    				attr 16: profile_config value: TB
    		306 debug attributes found:
    				debug attr  0: gpio3v3 value: 0
    				debug attr  1: bist_tone value: 0
    				debug attr  2: bist_framer_b_loopback value: 0
    				debug attr  3: bist_framer_a_loopback value: 0
    				debug attr  4: bist_framer_b_prbs value: 0
    				debug attr  5: bist_framer_a_prbs value: 0
    				debug attr  6: initialize value: 0
    				debug attr  7: adi,aux-pll-lo-frequency_hz value: 2500000000
    				debug attr  8: adi,trx-pll-lo-frequency_hz value: 2400000000
    				debug attr  9: adi,dig-clocks-rf-pll-phase-sync-mode value: 3
    				debug attr 10: adi,dig-clocks-rf-pll-use-external-lo value: 0
    				debug attr 11: adi,dig-clocks-clk-pll-hs-div value: 1
    				debug attr 12: adi,dig-clocks-clk-pll-vco-freq_khz value: 9600000
    				debug attr 13: adi,dig-clocks-device-clock_khz value: 240000
    				debug attr 14: adi,tx-settings-dis-tx-data-if-pll-unlock value: 0
    				debug attr 15: adi,tx-settings-tx2-atten_md-b value: 10000
    				debug attr 16: adi,tx-settings-tx1-atten_md-b value: 10000
    				debug attr 17: adi,tx-settings-tx-atten-step-size value: 0
    				debug attr 18: adi,tx-settings-tx-channels value: 3
    				debug attr 19: adi,tx-settings-deframer-sel value: 0
    				debug attr 20: adi,tx-profile-tx-bbf3d-bcorner_khz value: 60000
    				debug attr 21: adi,tx-profile-tx-dac3d-bcorner_khz value: 187000
    				debug attr 22: adi,tx-profile-rf-bandwidth_hz value: 120000000
    				debug attr 23: adi,tx-profile-primary-sig-bandwidth_hz value: 80000000
    				debug attr 24: adi,tx-profile-tx-input-rate_khz value: 240000
    				debug attr 25: adi,tx-profile-tx-int5-interpolation value: 1
    				debug attr 26: adi,tx-profile-thb3-interpolation value: 2
    				debug attr 27: adi,tx-profile-thb2-interpolation value: 2
    				debug attr 28: adi,tx-profile-thb1-interpolation value: 2
    				debug attr 29: adi,tx-profile-tx-fir-interpolation value: 1
    				debug attr 30: adi,tx-profile-dac-div value: 1
    				debug attr 31: adi,tx-profile-tx-fir-num-fir-coefs value: 20
    				debug attr 32: adi,tx-profile-tx-fir-gain_db value: 0
    				debug attr 33: adi,obs-settings-obs-rx-lo-source value: 0
    				debug attr 34: adi,obs-settings-obs-rx-channels-enable value: 3
    				debug attr 35: adi,obs-settings-framer-sel value: 1
    				debug attr 36: adi,orx-gain-control-orx2-min-gain-index value: 195
    				debug attr 37: adi,orx-gain-control-orx2-max-gain-index value: 255
    				debug attr 38: adi,orx-gain-control-orx1-min-gain-index value: 195
    				debug attr 39: adi,orx-gain-control-orx1-max-gain-index value: 255
    				debug attr 40: adi,orx-gain-control-orx2-gain-index value: 255
    				debug attr 41: adi,orx-gain-control-orx1-gain-index value: 255
    				debug attr 42: adi,orx-gain-control-gain-mode value: 0
    				debug attr 43: adi,orx-profile-orx-ddc-mode value: 0
    				debug attr 44: adi,orx-profile-rx-bbf3d-bcorner_khz value: 225000
    				debug attr 45: adi,orx-profile-rf-bandwidth_hz value: 120000000
    				debug attr 46: adi,orx-profile-orx-output-rate_khz value: 240000
    				debug attr 47: adi,orx-profile-rhb1-decimation value: 1
    				debug attr 48: adi,orx-profile-rx-dec5-decimation value: 4
    				debug attr 49: adi,orx-profile-rx-fir-decimation value: 2
    				debug attr 50: adi,orx-profile-rx-fir-num-fir-coefs value: 48
    				debug attr 51: adi,orx-profile-rx-fir-gain_db value: 246
    				debug attr 52: adi,rx-settings-rx-channels value: 3
    				debug attr 53: adi,rx-settings-framer-sel value: 0
    				debug attr 54: adi,rx-gain-control-rx2-min-gain-index value: 195
    				debug attr 55: adi,rx-gain-control-rx2-max-gain-index value: 255
    				debug attr 56: adi,rx-gain-control-rx1-min-gain-index value: 195
    				debug attr 57: adi,rx-gain-control-rx1-max-gain-index value: 255
    				debug attr 58: adi,rx-gain-control-rx2-gain-index value: 255
    				debug attr 59: adi,rx-gain-control-rx1-gain-index value: 255
    				debug attr 60: adi,rx-gain-control-gain-mode value: 0
    				debug attr 61: adi,rx-nco-shifter-band-bnco2-freq_khz value: 0
    				debug attr 62: adi,rx-nco-shifter-band-bnco1-freq_khz value: 0
    				debug attr 63: adi,rx-nco-shifter-band-binput-center-freq_khz value: 0
    				debug attr 64: adi,rx-nco-shifter-band-binput-band-width_khz value: 0
    				debug attr 65: adi,rx-nco-shifter-band-a-nco2-freq_khz value: 0
    				debug attr 66: adi,rx-nco-shifter-band-a-nco1-freq_khz value: 0
    				debug attr 67: adi,rx-nco-shifter-band-a-input-center-freq_khz value: 0
    				debug attr 68: adi,rx-nco-shifter-band-a-input-band-width_khz value: 0
    				debug attr 69: adi,rx-profile-rx-ddc-mode value: 0
    				debug attr 70: adi,rx-profile-rx-bbf3d-bcorner_khz value: 80000
    				debug attr 71: adi,rx-profile-rf-bandwidth_hz value: 80000000
    				debug attr 72: adi,rx-profile-rx-output-rate_khz value: 120000
    				debug attr 73: adi,rx-profile-rhb1-decimation value: 2
    				debug attr 74: adi,rx-profile-rx-dec5-decimation value: 4
    				debug attr 75: adi,rx-profile-rx-fir-decimation value: 2
    				debug attr 76: adi,rx-profile-rx-fir-num-fir-coefs value: 72
    				debug attr 77: adi,rx-profile-rx-fir-gain_db value: 246
    				debug attr 78: adi,tx-pa-protection-tx2-peak-threshold value: 140
    				debug attr 79: adi,tx-pa-protection-tx1-peak-threshold value: 140
    				debug attr 80: adi,tx-pa-protection-peak-count value: 4
    				debug attr 81: adi,tx-pa-protection-tx2-power-threshold value: 4096
    				debug attr 82: adi,tx-pa-protection-tx1-power-threshold value: 4096
    				debug attr 83: adi,tx-pa-protection-tx-atten-step value: 2
    				debug attr 84: adi,tx-pa-protection-avg-duration value: 3
    				debug attr 85: adi,tx2-atten-ctrl-pin-enable value: 0
    				debug attr 86: adi,tx2-atten-ctrl-pin-tx-atten-dec-pin value: 7
    				debug attr 87: adi,tx2-atten-ctrl-pin-tx-atten-inc-pin value: 6
    				debug attr 88: adi,tx2-atten-ctrl-pin-step-size value: 0
    				debug attr 89: adi,tx1-atten-ctrl-pin-enable value: 0
    				debug attr 90: adi,tx1-atten-ctrl-pin-tx-atten-dec-pin value: 5
    				debug attr 91: adi,tx1-atten-ctrl-pin-tx-atten-inc-pin value: 4
    				debug attr 92: adi,tx1-atten-ctrl-pin-step-size value: 0
    				debug attr 93: adi,rx2-gain-ctrl-pin-enable value: 0
    				debug attr 94: adi,rx2-gain-ctrl-pin-rx-gain-dec-pin value: 4
    				debug attr 95: adi,rx2-gain-ctrl-pin-rx-gain-inc-pin value: 3
    				debug attr 96: adi,rx2-gain-ctrl-pin-dec-step value: 1
    				debug attr 97: adi,rx2-gain-ctrl-pin-inc-step value: 1
    				debug attr 98: adi,rx1-gain-ctrl-pin-enable value: 0
    				debug attr 99: adi,rx1-gain-ctrl-pin-rx-gain-dec-pin value: 1
    				debug attr 100: adi,rx1-gain-ctrl-pin-rx-gain-inc-pin value: 0
    				debug attr 101: adi,rx1-gain-ctrl-pin-dec-step value: 1
    				debug attr 102: adi,rx1-gain-ctrl-pin-inc-step value: 1
    				debug attr 103: adi,fhm-mode-fhm-init-frequency_hz value: 2450000000
    				debug attr 104: adi,fhm-mode-fhm-exit-mode value: 1
    				debug attr 105: adi,fhm-mode-fhm-trigger-mode value: 0
    				debug attr 106: adi,fhm-mode-enable-mcs-sync value: 0
    				debug attr 107: adi,fhm-mode-fhm-enable value: 0
    				debug attr 108: adi,fhm-config-fhm-max-freq_mhz value: 2500
    				debug attr 109: adi,fhm-config-fhm-min-freq_mhz value: 2400
    				debug attr 110: adi,fhm-config-fhm-gpio-pin value: 0
    				debug attr 111: adi,orx-lo-cfg-gpio-select value: 19
    				debug attr 112: adi,orx-lo-cfg-disable-aux-pll-relocking value: 0
    				debug attr 113: adi,gpio3v3-output-level-mask value: 0
    				debug attr 114: adi,gpio3v3-output-enable-mask value: 0
    				debug attr 115: adi,gpio3v3-source-control value: 0
    				debug attr 116: adi,arm-gpio-config-en-tx-tracking-cals-enable value: 0
    				debug attr 117: adi,arm-gpio-config-en-tx-tracking-cals-polarity value: 0
    				debug attr 118: adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel value: 0
    				debug attr 119: adi,arm-gpio-config-orx2-tx-sel1-pin-enable value: 0
    				debug attr 120: adi,arm-gpio-config-orx2-tx-sel1-pin-polarity value: 0
    				debug attr 121: adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel value: 0
    				debug attr 122: adi,arm-gpio-config-orx2-tx-sel0-pin-enable value: 0
    				debug attr 123: adi,arm-gpio-config-orx2-tx-sel0-pin-polarity value: 0
    				debug attr 124: adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel value: 0
    				debug attr 125: adi,arm-gpio-config-orx1-tx-sel1-pin-enable value: 0
    				debug attr 126: adi,arm-gpio-config-orx1-tx-sel1-pin-polarity value: 0
    				debug attr 127: adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel value: 0
    				debug attr 128: adi,arm-gpio-config-orx1-tx-sel0-pin-enable value: 0
    				debug attr 129: adi,arm-gpio-config-orx1-tx-sel0-pin-polarity value: 0
    				debug attr 130: adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel value: 0
    				debug attr 131: adi,jesd204-sysref-lvds-pn-invert value: 0
    				debug attr 132: adi,jesd204-sysref-lvds-mode value: 1
    				debug attr 133: adi,jesd204-des-eq-setting value: 1
    				debug attr 134: adi,jesd204-des-invert-lane-polarity value: 0
    				debug attr 135: adi,jesd204-ser-invert-lane-polarity value: 0
    				debug attr 136: adi,jesd204-ser-pre-emphasis value: 1
    				debug attr 137: adi,jesd204-ser-amplitude value: 15
    				debug attr 138: adi,jesd204-deframer-b-enable-manual-lane-xbar value: 0
    				debug attr 139: adi,jesd204-deframer-b-syncb-out-cmos-drive-level value: 0
    				debug attr 140: adi,jesd204-deframer-b-syncb-out-cmos-slew-rate value: 0
    				debug attr 141: adi,jesd204-deframer-b-syncb-out-lvds-pn-invert value: 0
    				debug attr 142: adi,jesd204-deframer-b-syncb-out-lvds-mode value: 1
    				debug attr 143: adi,jesd204-deframer-b-np value: 16
    				debug attr 144: adi,jesd204-deframer-b-syncb-out-select value: 0
    				debug attr 145: adi,jesd204-deframer-b-new-sysref-on-relink value: 0
    				debug attr 146: adi,jesd204-deframer-b-lmfc-offset value: 0
    				debug attr 147: adi,jesd204-deframer-b-deserializer-lane-crossbar value: 228
    				debug attr 148: adi,jesd204-deframer-b-deserializer-lanes-enabled value: 0
    				debug attr 149: adi,jesd204-deframer-b-external-sysref value: 1
    				debug attr 150: adi,jesd204-deframer-b-scramble value: 1
    				debug attr 151: adi,jesd204-deframer-b-k value: 32
    				debug attr 152: adi,jesd204-deframer-b-m value: 0
    				debug attr 153: adi,jesd204-deframer-b-lane0-id value: 0
    				debug attr 154: adi,jesd204-deframer-b-device-id value: 0
    				debug attr 155: adi,jesd204-deframer-b-bank-id value: 0
    				debug attr 156: adi,jesd204-deframer-a-enable-manual-lane-xbar value: 0
    				debug attr 157: adi,jesd204-deframer-a-syncb-out-cmos-drive-level value: 0
    				debug attr 158: adi,jesd204-deframer-a-syncb-out-cmos-slew-rate value: 0
    				debug attr 159: adi,jesd204-deframer-a-syncb-out-lvds-pn-invert value: 0
    				debug attr 160: adi,jesd204-deframer-a-syncb-out-lvds-mode value: 1
    				debug attr 161: adi,jesd204-deframer-a-np value: 16
    				debug attr 162: adi,jesd204-deframer-a-syncb-out-select value: 0
    				debug attr 163: adi,jesd204-deframer-a-new-sysref-on-relink value: 0
    				debug attr 164: adi,jesd204-deframer-a-lmfc-offset value: 1
    				debug attr 165: adi,jesd204-deframer-a-deserializer-lane-crossbar value: 228
    				debug attr 166: adi,jesd204-deframer-a-deserializer-lanes-enabled value: 15
    				debug attr 167: adi,jesd204-deframer-a-external-sysref value: 1
    				debug attr 168: adi,jesd204-deframer-a-scramble value: 1
    				debug attr 169: adi,jesd204-deframer-a-k value: 32
    				debug attr 170: adi,jesd204-deframer-a-m value: 4
    				debug attr 171: adi,jesd204-deframer-a-lane0-id value: 0
    				debug attr 172: adi,jesd204-deframer-a-device-id value: 0
    				debug attr 173: adi,jesd204-deframer-a-bank-id value: 0
    				debug attr 174: adi,jesd204-framer-b-enable-manual-lane-xbar value: 0
    				debug attr 175: adi,jesd204-framer-b-syncb-in-lvds-pn-invert value: 0
    				debug attr 176: adi,jesd204-framer-b-syncb-in-lvds-mode value: 1
    				debug attr 177: adi,jesd204-framer-b-over-sample value: 0
    				debug attr 178: adi,jesd204-framer-b-syncb-in-select value: 1
    				debug attr 179: adi,jesd204-framer-b-new-sysref-on-relink value: 0
    				debug attr 180: adi,jesd204-framer-b-lmfc-offset value: 15
    				debug attr 181: adi,jesd204-framer-b-serializer-lane-crossbar value: 228
    				debug attr 182: adi,jesd204-framer-b-serializer-lanes-enabled value: 12
    				debug attr 183: adi,jesd204-framer-b-external-sysref value: 1
    				debug attr 184: adi,jesd204-framer-b-scramble value: 1
    				debug attr 185: adi,jesd204-framer-b-np value: 16
    				debug attr 186: adi,jesd204-framer-b-f value: 4
    				debug attr 187: adi,jesd204-framer-b-k value: 32
    				debug attr 188: adi,jesd204-framer-b-m value: 2
    				debug attr 189: adi,jesd204-framer-b-lane0-id value: 0
    				debug attr 190: adi,jesd204-framer-b-device-id value: 0
    				debug attr 191: adi,jesd204-framer-b-bank-id value: 0
    				debug attr 192: adi,jesd204-framer-a-enable-manual-lane-xbar value: 0
    				debug attr 193: adi,jesd204-framer-a-syncb-in-lvds-pn-invert value: 0
    				debug attr 194: adi,jesd204-framer-a-syncb-in-lvds-mode value: 1
    				debug attr 195: adi,jesd204-framer-a-over-sample value: 0
    				debug attr 196: adi,jesd204-framer-a-syncb-in-select value: 0
    				debug attr 197: adi,jesd204-framer-a-new-sysref-on-relink value: 0
    				debug attr 198: adi,jesd204-framer-a-lmfc-offset value: 15
    				debug attr 199: adi,jesd204-framer-a-serializer-lane-crossbar value: 228
    				debug attr 200: adi,jesd204-framer-a-serializer-lanes-enabled value: 3
    				debug attr 201: adi,jesd204-framer-a-external-sysref value: 1
    				debug attr 202: adi,jesd204-framer-a-scramble value: 1
    				debug attr 203: adi,jesd204-framer-a-np value: 16
    				debug attr 204: adi,jesd204-framer-a-f value: 4
    				debug attr 205: adi,jesd204-framer-a-k value: 32
    				debug attr 206: adi,jesd204-framer-a-m value: 4
    				debug attr 207: adi,jesd204-framer-a-lane0-id value: 0
    				debug attr 208: adi,jesd204-framer-a-device-id value: 0
    				debug attr 209: adi,jesd204-framer-a-bank-id value: 1
    				debug attr 210: adi,aux-dac-values11 value: 0
    				debug attr 211: adi,aux-dac-values10 value: 0
    				debug attr 212: adi,aux-dac-values9 value: 0
    				debug attr 213: adi,aux-dac-resolution9 value: 0
    				debug attr 214: adi,aux-dac-vref9 value: 3
    				debug attr 215: adi,aux-dac-values8 value: 0
    				debug attr 216: adi,aux-dac-resolution8 value: 0
    				debug attr 217: adi,aux-dac-vref8 value: 3
    				debug attr 218: adi,aux-dac-values7 value: 0
    				debug attr 219: adi,aux-dac-resolution7 value: 0
    				debug attr 220: adi,aux-dac-vref7 value: 3
    				debug attr 221: adi,aux-dac-values6 value: 0
    				debug attr 222: adi,aux-dac-resolution6 value: 0
    				debug attr 223: adi,aux-dac-vref6 value: 3
    				debug attr 224: adi,aux-dac-values5 value: 0
    				debug attr 225: adi,aux-dac-resolution5 value: 0
    				debug attr 226: adi,aux-dac-vref5 value: 3
    				debug attr 227: adi,aux-dac-values4 value: 0
    				debug attr 228: adi,aux-dac-resolution4 value: 0
    				debug attr 229: adi,aux-dac-vref4 value: 3
    				debug attr 230: adi,aux-dac-values3 value: 0
    				debug attr 231: adi,aux-dac-resolution3 value: 0
    				debug attr 232: adi,aux-dac-vref3 value: 3
    				debug attr 233: adi,aux-dac-values2 value: 0
    				debug attr 234: adi,aux-dac-resolution2 value: 0
    				debug attr 235: adi,aux-dac-vref2 value: 3
    				debug attr 236: adi,aux-dac-values1 value: 0
    				debug attr 237: adi,aux-dac-resolution1 value: 0
    				debug attr 238: adi,aux-dac-vref1 value: 3
    				debug attr 239: adi,aux-dac-values0 value: 0
    				debug attr 240: adi,aux-dac-resolution0 value: 0
    				debug attr 241: adi,aux-dac-vref0 value: 3
    				debug attr 242: adi,aux-dac-enables value: 0
    				debug attr 243: adi,rxagc-agc-enable-fast-recovery-loop value: 0
    				debug attr 244: adi,rxagc-ip3-peak-exceeded-cnt value: 4
    				debug attr 245: adi,rxagc-ip3-over-range-thresh-index value: 246
    				debug attr 246: adi,rxagc-ip3-over-range-thresh value: 31
    				debug attr 247: adi,rxagc-agc-enable-ip3-optimization-thresh value: 0
    				debug attr 248: adi,rxagc-agc-enable-sync-pulse-for-gain-counter value: 0
    				debug attr 249: adi,rxagc-agc-reset-on-rxon value: 0
    				debug attr 250: adi,rxagc-agc-peak-thresh-gain-control-mode value: 1
    				debug attr 251: adi,rxagc-agc-change-gain-if-thresh-high value: 1
    				debug attr 252: adi,rxagc-agc-low-thresh-prevent-gain value: 0
    				debug attr 253: adi,rxagc-agc-slow-loop-settling-delay value: 16
    				debug attr 254: adi,rxagc-agc-rx2-attack-delay value: 10
    				debug attr 255: adi,rxagc-agc-rx1-attack-delay value: 10
    				debug attr 256: adi,rxagc-agc-gain-update-counter_us value: 250
    				debug attr 257: adi,rxagc-agc-rx2-min-gain-index value: 195
    				debug attr 258: adi,rxagc-agc-rx2-max-gain-index value: 255
    				debug attr 259: adi,rxagc-agc-rx1-min-gain-index value: 195
    				debug attr 260: adi,rxagc-agc-rx1-max-gain-index value: 255
    				debug attr 261: adi,rxagc-agc-peak-wait-time value: 4
    				debug attr 262: adi,rxagc-power-power-log-shift value: 0
    				debug attr 263: adi,rxagc-power-upper1-power-thresh value: 0
    				debug attr 264: adi,rxagc-power-upper0-power-thresh value: 2
    				debug attr 265: adi,rxagc-power-rx2-tdd-power-meas-delay value: 1
    				debug attr 266: adi,rxagc-power-rx2-tdd-power-meas-duration value: 5
    				debug attr 267: adi,rxagc-power-rx1-tdd-power-meas-delay value: 1
    				debug attr 268: adi,rxagc-power-rx1-tdd-power-meas-duration value: 5
    				debug attr 269: adi,rxagc-power-power-measurement-duration value: 5
    				debug attr 270: adi,rxagc-power-under-range-low-power-gain-step-recovery value: 4
    				debug attr 271: adi,rxagc-power-under-range-high-power-gain-step-recovery value: 4
    				debug attr 272: adi,rxagc-power-under-range-low-power-thresh value: 2
    				debug attr 273: adi,rxagc-power-under-range-high-power-thresh value: 9
    				debug attr 274: adi,rxagc-power-power-use-bbdc2 value: 0
    				debug attr 275: adi,rxagc-power-power-use-rfir-out value: 1
    				debug attr 276: adi,rxagc-power-power-enable-measurement value: 1
    				debug attr 277: adi,rxagc-peak-hb2-thresh-config value: 3
    				debug attr 278: adi,rxagc-peak-hb2-ovrg-sel value: 0
    				debug attr 279: adi,rxagc-peak-hb2-overload-power-mode value: 1
    				debug attr 280: adi,rxagc-peak-hb2-gain-step-attack value: 4
    				debug attr 281: adi,rxagc-peak-hb2-gain-step-mid-recovery value: 8
    				debug attr 282: adi,rxagc-peak-hb2-gain-step-low-recovery value: 4
    				debug attr 283: adi,rxagc-peak-hb2-gain-step-high-recovery value: 2
    				debug attr 284: adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt value: 3
    				debug attr 285: adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt value: 6
    				debug attr 286: adi,rxagc-peak-hb2-under-range-high-thresh value: 128
    				debug attr 287: adi,rxagc-peak-hb2-under-range-mid-thresh value: 90
    				debug attr 288: adi,rxagc-peak-hb2-under-range-low-thresh value: 45
    				debug attr 289: adi,rxagc-peak-hb2-high-thresh value: 181
    				debug attr 290: adi,rxagc-peak-hb2-overload-thresh-cnt value: 4
    				debug attr 291: adi,rxagc-peak-hb2-overload-duration-cnt value: 1
    				debug attr 292: adi,rxagc-peak-enable-hb2-overload value: 1
    				debug attr 293: adi,rxagc-peak-apd-gain-step-recovery value: 2
    				debug attr 294: adi,rxagc-peak-apd-gain-step-attack value: 4
    				debug attr 295: adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt value: 3
    				debug attr 296: adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt value: 6
    				debug attr 297: adi,rxagc-peak-apd-low-gain-mode-low-thresh value: 19
    				debug attr 298: adi,rxagc-peak-apd-low-thresh value: 23
    				debug attr 299: adi,rxagc-peak-apd-low-gain-mode-high-thresh value: 36
    				debug attr 300: adi,rxagc-peak-apd-high-thresh value: 39
    				debug attr 301: adi,rxagc-peak-agc-under-range-high-interval value: 4
    				debug attr 302: adi,rxagc-peak-agc-under-range-mid-interval value: 2
    				debug attr 303: adi,rxagc-peak-agc-under-range-low-interval_ns value: 205
    				debug attr 304: adi,default-initial-calibrations-mask value: 9362927
    				debug attr 305: direct_reg_access value: 0xFF
    	iio:device5: adrv9009-phy-b
    		25 channels found:
    			voltage9:  (output)
    			voltage8:  (output)
    			voltage3:  (input)
    			voltage2:  (output)
    			voltage1:  (output)
    			voltage0:  (output)
    			voltage2:  (input)
    			voltage5:  (input)
    			voltage6:  (input)
    			voltage12:  (output)
    			voltage6:  (output)
    			voltage13:  (output)
    			voltage4:  (input)
    			voltage5:  (output)
    			voltage1:  (input)
    			voltage3:  (output)
    			voltage10:  (output)
    			voltage7:  (input)
    			voltage0:  (input)
    			voltage4:  (output)
    			voltage11:  (output)
    			voltage7:  (output)
    			temp0:  (input)
    	iio:device6: axi-adrv9009-rx-hpc (buffer capable)
    		8 channels found:
    			voltage0_i:  (input, index: 0, format: le:S16/16>>0)
    			5 channel-specific attributes found:
    				attr  0: calibbias value: 0
    				attr  1: calibphase value: 0.000000
    				attr  2: calibscale value: 0.000000
    				attr  3: label ERROR: Function not implemented (38)
    				attr  4: sampling_frequency value: 120000000
    			voltage0_q:  (input, index: 1, format: le:S16/16>>0)
    			voltage1_i:  (input, index: 2, format: le:S16/16>>0)
    			voltage1_q:  (input, index: 3, format: le:S16/16>>0)
    			voltage2_i:  (input, index: 4, format: le:S16/16>>0)
    			voltage2_q:  (input, index: 5, format: le:S16/16>>0)
    			voltage3_i:  (input, index: 6, format: le:S16/16>>0)
    			voltage3_q:  (input, index: 7, format: le:S16/16>>0)
    		2 device-specific attributes found:
    				attr  0: sync_start_enable value: disarm
    				attr  1: sync_start_enable_available value: arm disarm trigger_manual
    		2 buffer-specific attributes found:
    				attr  0: data_available value: 0
    				attr  1: length_align_bytes value: 16
    				debug attr  0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error
    CH1 : PN9 : Out of Sync : PN Error
    CH2 : PN9 : Out of Sync : PN Error
    CH3 : PN9 : Out of Sync : PN Error
    CH4 : PN9 : Out of Sync : PN Error
    CH5 : PN9 : Out of Sync : PN Error
    CH6 : PN9 : Out of Sync : PN Error
    CH7 : PN9 : Out of Sync : PN Error
    	iio:device7: axi-adrv9009-rx-obs-hpc (buffer capable)
    		4 channels found:
    				attr  0: sampling_frequency value: 240000000
    		1 debug attributes found:
    				debug attr  0: direct_reg_access value: 0xA0262
    	iio:device8: axi-adrv9009-tx-hpc (buffer capable)
    		24 channels found:
    			voltage0:  (output, index: 0, format: le:S16/16>>0)
    				attr  0: calibphase value: 0.000000
    				attr  1: calibscale value: 0.000000
    				attr  2: sampling_frequency value: 240000000
    			voltage1:  (output, index: 1, format: le:S16/16>>0)
    			voltage2:  (output, index: 2, format: le:S16/16>>0)
    			voltage3:  (output, index: 3, format: le:S16/16>>0)
    			voltage4:  (output, index: 4, format: le:S16/16>>0)
    			voltage5:  (output, index: 5, format: le:S16/16>>0)
    			voltage6:  (output, index: 6, format: le:S16/16>>0)
    			voltage7:  (output, index: 7, format: le:S16/16>>0)
    			altvoltage11: TX3_Q_F2 (output)
    				attr  0: frequency value: 40001831
    				attr  2: raw value: 1
    				attr  3: sampling_frequency value: 240000000
    				attr  4: scale value: 0.000000
    			altvoltage3: TX1_Q_F2 (output)
    			altvoltage9: TX3_I_F2 (output)
    				attr  1: phase value: 90000
    			altvoltage5: TX2_I_F2 (output)
    			altvoltage2: TX1_Q_F1 (output)
    				attr  4: scale value: 0.251160
    			altvoltage8: TX3_I_F1 (output)
    			altvoltage12: TX4_I_F1 (output)
    			altvoltage1: TX1_I_F2 (output)
    			altvoltage7: TX2_Q_F2 (output)
    			altvoltage4: TX2_I_F1 (output)
    			altvoltage14: TX4_Q_F1 (output)
    			altvoltage13: TX4_I_F2 (output)
    			altvoltage0: TX1_I_F1 (output)
    			altvoltage10: TX3_Q_F1 (output)
    			altvoltage6: TX2_Q_F1 (output)
    			altvoltage15: TX4_Q_F2 (output)
    				debug attr  0: pl_ddr_fifo_enable value: 1
    				debug attr  1: direct_reg_access value: 0x90162
    	iio_sysfs_trigger:
    		0 channels found:
    				attr  0: add_trigger ERROR: Permission denied (13)
    				attr  1: remove_trigger ERROR: Permission denied (13)
  • The HMC7044 PLLs are now locked. The output channel dividers were fixed.
    https://wiki.analog.com/resources/eval/user-guides/rf-trx-vcxo-and-profiles is showing vc01_min of 9800000 or 9600000 kHz. I am configuring my vco to be 9.6 GHz. Is this my issue with the JESD204B being in idle state with error -22?
    adi,dig-clocks-device-clock_khz = <240000>;
    adi,dig-clocks-clk-pll-vco-freq_khz = <9600000>;
  •  It looks like the JESD thinks my device clock is 120 MHz instead of 240 MHz.
  • I added
    jesd204-ignore-errors;
    which allowed the JESD bus to be enabled after boot. I was then able to load a profile from the filter wizard through osc. I have the new sample rates working/tested for Rx but am still not sure what in the DTS configuration was incorrect.
  • Can you try device clock with 120MHz and check if you still see issue ?
