MCS unreliable in FHM mode
We are seeing issues with the stability of MCS when fhm mode is enabled, many times the sync will not be stable. Sync is fine in non hopping mode, and corrects itself as soon as hopping mode is disabled. We are using linux, and have MCS for hopping mode enabled in config. On some hops we will get good synchronization, but mostly not.
It is exactly the same as this historical issue which doesn't seem to have a resolution.
Mark
  • What is the frequency by which you are hoping the frequency? If you hop by less than 100MHz, are you seeing issues with MCS? If the frequency hop is more than 100MHz, are you running the QEC and DC offset cals?What is the settling time or the sleep time between hops?
    How much phase error are you seeing with the hops in which the issue is seen?
    We are observing similar issues: MCS unreliable in FHM mode. It works reliable for most of the LO frequencies, but fails specifically at 150, 300, 600, 1200, 2400, and 4800 MHz.
    Since there are quite a few Q&A posts regarding this topic, I wonder if there is a definitive answer to this behavior?
    Thank you
  • We are observing similar issues: MCS unreliable in FHM mode. It works reliable for most of the LO frequencies, but fails specifically at 150, 300, 600, 1200, 2400, and 4800 MHz.
    Is it consistently failing only on 150MHz, 300MHz ,600MHz , 1200Mhz ,2400MHz and 4800MHz frequencies? All these frequencies are all powers-of-two multiples of 150 MHz.
    Does it work with other frequencies?
