Hi Everyone,
Currently we want to test adrv9009-W/PCBZ with ZCU102 and Petalinux. We use HDL and Linux kernel from ADI's github. After adrv9009 initialize and nothing is transmitted, I see that LO tone at center frequency and other tone appear at frequency 3.932Mhz (approximately16 times of device clock 245.76 MHz).). I try changing center frequency in driver and boot up zcu102 again, unwanted tone still appear at this frequency. Here is my issue:
Here is my device tree:
#include <dt-bindings/iio/frequency/ad9528.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
clocks {
adrv9009_clkin: clock@0 {
compatible = "fixed-clock";
clock-frequency = <12288000>;
clock-output-names = "adrv9009_ext_refclk";
#clock-cells = <0>;
&fmc_spi {
clk0_ad9528: ad9528-1@0 {
compatible = "adi,ad9528";
reg = <0>;
#address-cells = <1>;
#size-cells = <0>;
spi-max-frequency = <1000000>;
//adi,spi-3wire-enable;
clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2",
"ad9528-1_out3", "ad9528-1_out4", "ad9528-1_out5", "ad9528-1_out6",
"ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9", "ad9528-1_out10",
"ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13";
#clock-cells = <1>;
adi,vcxo-freq = <122880000>;
adi,refa-enable;
adi,refa-diff-rcv-enable;
adi,refa-r-div = <4>;
adi,osc-in-cmos-neg-inp-enable;
/* PLL1 config */
adi,pll1-feedback-div = <4>;
adi,pll1-charge-pump-current-nA = <5000>;
/* PLL2 config */
adi,pll2-vco-div-m1 = <3>; /* use 5 for 184320000 output device clock */
adi,pll2-n2-div = <10>; /* N / M1 */
adi,pll2-r1-div = <1>;
adi,pll2-charge-pump-current-nA = <805000>;
/* SYSREF config */
adi,sysref-src = <SYSREF_SRC_INTERNAL>;
adi,sysref-pattern-mode = <SYSREF_PATTERN_CONTINUOUS>;
adi,sysref-k-div = <512>;
adi,sysref-request-enable;
adi,sysref-nshot-mode = <SYSREF_NSHOT_4_PULSES>;
adi,sysref-request-trigger-mode = <SYSREF_LEVEL_HIGH>;
adi,rpole2 = <RPOLE2_900_OHM>;
adi,rzero = <RZERO_1850_OHM>;
adi,cpole1 = <CPOLE1_16_PF>;
adi,status-mon-pin0-function-select = <1>; /* PLL1 & PLL2 Locked */
adi,status-mon-pin1-function-select = <7>; /* REFA Correct */
ad9528_0_c13: channel@13 {
reg = <13>;
adi,extended-name = "DEV_CLK";
adi,driver-mode = <DRIVER_MODE_LVDS>;
adi,divider-phase = <0>;
adi,channel-divider = <5>;
adi,signal-source = <SOURCE_VCO>;
ad9528_0_c1: channel@1 {
reg = <1>;
adi,extended-name = "FMC_CLK";
ad9528_0_c12: channel@12 {
reg = <12>;
adi,extended-name = "DEV_SYSREF";
adi,signal-source = <SOURCE_SYSREF_VCO>;
ad9528_0_c3: channel@3 {
reg = <3>;
adi,extended-name = "FMC_SYSREF";
trx0_adrv9009: adrv9009-phy@1 {
compatible = "adrv9009";
reg = <1>;
#size-cells = <0>;
/* SPI Setup */
interrupt-parent = <&gpio>;
interrupts = <129 IRQ_TYPE_EDGE_RISING>;
/* Clocks */
clocks = <&axi_adrv9009_rx_jesd>, <&axi_adrv9009_tx_jesd>,
<&axi_adrv9009_rx_os_jesd>, <&clk0_ad9528 13>,
<&clk0_ad9528 1>, <&clk0_ad9528 12>, <&clk0_ad9528 3>;
clock-names = "jesd_rx_clk", "jesd_tx_clk", "jesd_rx_os_clk",
"dev_clk", "fmc_clk", "sysref_dev_clk",
"sysref_fmc_clk";
clock-output-names = "rx_sampl_clk", "rx_os_sampl_clk", "tx_sampl_clk";
#clock-cells = <1>;
/* JESD204 */
/* JESD204 RX */
adi,jesd204-framer-a-bank-id = <1>;
adi,jesd204-framer-a-device-id = <0>;
adi,jesd204-framer-a-lane0-id = <0>;
adi,jesd204-framer-a-m = <4>;
adi,jesd204-framer-a-k = <32>;
adi,jesd204-framer-a-f = <4>;
adi,jesd204-framer-a-np = <16>;
adi,jesd204-framer-a-scramble = <1>;
adi,jesd204-framer-a-external-sysref = <1>;
adi,jesd204-framer-a-serializer-lanes-enabled = <0x03>;
adi,jesd204-framer-a-serializer-lane-crossbar = <0xE4>;
adi,jesd204-framer-a-lmfc-offset = <31>;
adi,jesd204-framer-a-new-sysref-on-relink = <0>;
adi,jesd204-framer-a-syncb-in-select = <0>;
adi,jesd204-framer-a-over-sample = <0>;
adi,jesd204-framer-a-syncb-in-lvds-mode = <1>;
adi,jesd204-framer-a-syncb-in-lvds-pn-invert = <0>;
adi,jesd204-framer-a-enable-manual-lane-xbar = <0>;
/* JESD204 OBS */
adi,jesd204-framer-b-bank-id = <0>;
adi,jesd204-framer-b-device-id = <0>;
adi,jesd204-framer-b-lane0-id = <0>;
adi,jesd204-framer-b-m = <2>;
adi,jesd204-framer-b-k = <32>;
adi,jesd204-framer-b-f = <2>;
adi,jesd204-framer-b-np = <16>;
adi,jesd204-framer-b-scramble = <1>;
adi,jesd204-framer-b-external-sysref = <1>;
adi,jesd204-framer-b-serializer-lanes-enabled = <0x0C>;
adi,jesd204-framer-b-serializer-lane-crossbar = <0xE4>;
adi,jesd204-framer-b-lmfc-offset = <31>;
adi,jesd204-framer-b-new-sysref-on-relink = <0>;
adi,jesd204-framer-b-syncb-in-select = <1>;
adi,jesd204-framer-b-over-sample = <0>;
adi,jesd204-framer-b-syncb-in-lvds-mode = <1>;
adi,jesd204-framer-b-syncb-in-lvds-pn-invert = <0>;
adi,jesd204-framer-b-enable-manual-lane-xbar = <0>;
/* JESD204 TX */
adi,jesd204-deframer-a-bank-id = <0>;
adi,jesd204-deframer-a-device-id = <0>;
adi,jesd204-deframer-a-lane0-id = <0>;
adi,jesd204-deframer-a-m = <4>;
adi,jesd204-deframer-a-k = <32>;
adi,jesd204-deframer-a-scramble = <1>;
adi,jesd204-deframer-a-external-sysref = <1>;
adi,jesd204-deframer-a-deserializer-lanes-enabled = <0x0F>;
adi,jesd204-deframer-a-deserializer-lane-crossbar = <0xE4>;
adi,jesd204-deframer-a-lmfc-offset = <17>;
adi,jesd204-deframer-a-new-sysref-on-relink = <0>;
adi,jesd204-deframer-a-syncb-out-select = <0>;
adi,jesd204-deframer-a-np = <16>;
adi,jesd204-deframer-a-syncb-out-lvds-mode = <1>;
adi,jesd204-deframer-a-syncb-out-lvds-pn-invert = <0>;
adi,jesd204-deframer-a-syncb-out-cmos-slew-rate = <0>;
adi,jesd204-deframer-a-syncb-out-cmos-drive-level = <0>;
adi,jesd204-deframer-a-enable-manual-lane-xbar = <0>;
adi,jesd204-ser-amplitude = <15>;
adi,jesd204-ser-pre-emphasis = <1>;
adi,jesd204-ser-invert-lane-polarity = <0>;
adi,jesd204-des-invert-lane-polarity = <0>;
adi,jesd204-des-eq-setting = <1>;
adi,jesd204-sysref-lvds-mode = <1>;
adi,jesd204-sysref-lvds-pn-invert = <0>;
/* RX */
adi,rx-profile-rx-fir-gain_db = <(-6)>;
adi,rx-profile-rx-fir-num-fir-coefs = <72>;
adi,rx-profile-rx-fir-coefs = /bits/ 16 <(0) (0) (2) (0) (-7) (-1) (15) (4) (-31) (-10) (57) (23) (-99) (-47) (161) (86) (-247) (-146) (372) (238) (-542) (-381) (762) (583) (-1064) (-883) (1470) (1331) (-2057) (-2059) (2975) (3403) (-4748) (-6898) (9698) (30806) (30806) (9698) (-6898) (-4748) (3403) (2975) (-2059) (-2057) (1331) (1470) (-883) (-1064) (583) (762) (-381) (-542) (238) (372) (-146) (-247) (86) (161) (-47) (-99) (23) (57) (-10) (-31) (4) (15) (-1) (-7) (0) (2) (0) (0)>;
adi,rx-profile-rx-fir-decimation = <2>;
adi,rx-profile-rx-dec5-decimation = <4>;
adi,rx-profile-rhb1-decimation = <2>;
adi,rx-profile-rx-output-rate_khz = <122880>;
adi,rx-profile-rf-bandwidth_hz = <100000000>;
adi,rx-profile-rx-bbf3d-bcorner_khz = <100000>;
adi,rx-profile-rx-adc-profile = /bits/ 16 <265 146 181 90 1280 366 1257 27 1258 17 718 39 48 46 27 161 0 0 0 0 40 0 7 6 42 0 7 6 42 0 25 27 0 0 25 27 0 0 165 44 31 905>;
adi,rx-profile-rx-ddc-mode = <0>;
adi,rx-nco-shifter-band-a-input-band-width_khz = <0>;
adi,rx-nco-shifter-band-a-input-center-freq_khz = <0>;
adi,rx-nco-shifter-band-a-nco1-freq_khz = <0>;
adi,rx-nco-shifter-band-a-nco2-freq_khz = <0>;
adi,rx-nco-shifter-band-binput-band-width_khz = <0>;
adi,rx-nco-shifter-band-binput-center-freq_khz = <0>;
adi,rx-nco-shifter-band-bnco1-freq_khz = <0>;
adi,rx-nco-shifter-band-bnco2-freq_khz = <0>;
adi,rx-gain-control-gain-mode = <0>;
adi,rx-gain-control-rx1-gain-index = <255>;
adi,rx-gain-control-rx2-gain-index = <255>;
adi,rx-gain-control-rx1-max-gain-index = <255>;
adi,rx-gain-control-rx1-min-gain-index = <195>;
adi,rx-gain-control-rx2-max-gain-index = <255>;
adi,rx-gain-control-rx2-min-gain-index = <195>;
adi,rx-settings-framer-sel = <0>;
adi,rx-settings-rx-channels = <3>;
/* ORX */
adi,orx-profile-rx-fir-gain_db = <6>;
adi,orx-profile-rx-fir-num-fir-coefs = <24>;
adi,orx-profile-rx-fir-coefs = /bits/ 16 <(-15) (9) (-13) (19) (-28) (38) (-73) (110) (-195) (409) (-1006) (17711) (-1006) (409) (-195) (110) (-73) (38) (-28) (19) (-13) (9) (-15) (0)>;
adi,orx-profile-rx-fir-decimation = <1>;
adi,orx-profile-rx-dec5-decimation = <4>;
adi,orx-profile-rhb1-decimation = <1>;
adi,orx-profile-orx-output-rate_khz = <491520>;
adi,orx-profile-rf-bandwidth_hz = <450000000>;
adi,orx-profile-rx-bbf3d-bcorner_khz = <225000>;
adi,orx-profile-orx-low-pass-adc-profile = /bits/ 16 <155 163 181 90 1280 1254 1572 340 1431 142 973 8 48 47 36 205 0 0 0 0 51 0 0 6 24 0 0 6 24 0 25 27 0 0 25 27 0 0 165 44 15 905>;
adi,orx-profile-orx-band-pass-adc-profile = /bits/ 16 <124 131 154 90 1280 2779 1986 0 1037 839 988 109 11 15 28 179 0 0 0 0 45 0 0 0 24 0 0 0 24 0 25 27 0 0 25 27 0 0 165 44 15 905>;
adi,orx-profile-orx-ddc-mode = <0>;
adi,orx-profile-orx-merge-filter = /bits/ 16 <(-167) (419) (-208) (-498) (968) (-320) (-1273) (2154) (-402) (-4155) (9170) (21413)>;
adi,orx-gain-control-gain-mode = <0>;
adi,orx-gain-control-orx1-gain-index = <255>;
adi,orx-gain-control-orx2-gain-index = <255>;
adi,orx-gain-control-orx1-max-gain-index = <255>;
adi,orx-gain-control-orx1-min-gain-index = <195>;
adi,orx-gain-control-orx2-max-gain-index = <255>;
adi,orx-gain-control-orx2-min-gain-index = <195>;
adi,obs-settings-framer-sel = <1>;
adi,obs-settings-obs-rx-channels-enable = <1>;
adi,obs-settings-obs-rx-lo-source = <0>;
/* TX */
adi,tx-profile-tx-fir-gain_db = <6>;
adi,tx-profile-tx-fir-num-fir-coefs = <20>;
adi,tx-profile-tx-fir-coefs = /bits/ 16 <(-39) (24) (-62) (112) (-175) (298) (-574) (1284) (-2814) (20281) (-2814) (1284) (-574) (298) (-175) (112) (-62) (24) (-39) (0)>;
adi,tx-profile-dac-div = <1>;
adi,tx-profile-tx-fir-interpolation = <1>;
adi,tx-profile-thb1-interpolation = <2>;
adi,tx-profile-thb2-interpolation = <2>;
adi,tx-profile-thb3-interpolation = <1>;
adi,tx-profile-tx-int5-interpolation = <1>;
adi,tx-profile-tx-input-rate_khz = <491520>;
adi,tx-profile-primary-sig-bandwidth_hz = <200000000>;
adi,tx-profile-rf-bandwidth_hz = <450000000>;
adi,tx-profile-tx-dac3d-bcorner_khz = <450000>;
adi,tx-profile-tx-bbf3d-bcorner_khz = <225000>;
adi,tx-profile-loop-back-adc-profile = /bits/ 16 <150 178 181 90 1280 1338 1699 493 1386 162 934 4 48 46 35 201 0 0 0 0 50 0 0 6 24 0 0 6 24 0 25 27 0 0 25 27 0 0 165 44 15 905>;
adi,tx-settings-deframer-sel = <0>;
adi,tx-settings-tx-channels = <3>;
adi,tx-settings-tx-atten-step-size = <0>;
adi,tx-settings-tx1-atten_md-b = <0>;
adi,tx-settings-tx2-atten_md-b = <0>;
adi,tx-settings-dis-tx-data-if-pll-unlock = <0>;
/* Clocks */
adi,dig-clocks-device-clock_khz = <245760>;
adi,dig-clocks-clk-pll-vco-freq_khz = <9830400>;
adi,dig-clocks-clk-pll-hs-div = <1>;
adi,dig-clocks-rf-pll-use-external-lo = <0>;
adi,dig-clocks-rf-pll-phase-sync-mode = <1>;
/* AGC */
adi,rxagc-peak-agc-under-range-low-interval_ns = <205>;
adi,rxagc-peak-agc-under-range-mid-interval = <2>;
adi,rxagc-peak-agc-under-range-high-interval = <4>;
adi,rxagc-peak-apd-high-thresh = <39>;
adi,rxagc-peak-apd-low-gain-mode-high-thresh = <36>;
adi,rxagc-peak-apd-low-thresh = <23>;
adi,rxagc-peak-apd-low-gain-mode-low-thresh = <19>;
adi,rxagc-peak-apd-upper-thresh-peak-exceeded-cnt = <6>;
adi,rxagc-peak-apd-lower-thresh-peak-exceeded-cnt = <3>;
adi,rxagc-peak-apd-gain-step-attack = <4>;
adi,rxagc-peak-apd-gain-step-recovery = <2>;
adi,rxagc-peak-enable-hb2-overload = <1>;
adi,rxagc-peak-hb2-overload-duration-cnt = <1>;
adi,rxagc-peak-hb2-overload-thresh-cnt = <4>;
adi,rxagc-peak-hb2-high-thresh = <181>;
adi,rxagc-peak-hb2-under-range-low-thresh = <45>;
adi,rxagc-peak-hb2-under-range-mid-thresh = <90>;
adi,rxagc-peak-hb2-under-range-high-thresh = <128>;
adi,rxagc-peak-hb2-upper-thresh-peak-exceeded-cnt = <6>;
adi,rxagc-peak-hb2-lower-thresh-peak-exceeded-cnt = <3>;
adi,rxagc-peak-hb2-gain-step-high-recovery = <2>;
adi,rxagc-peak-hb2-gain-step-low-recovery = <4>;
adi,rxagc-peak-hb2-gain-step-mid-recovery = <8>;
adi,rxagc-peak-hb2-gain-step-attack = <4>;
adi,rxagc-peak-hb2-overload-power-mode = <1>;
adi,rxagc-peak-hb2-ovrg-sel = <0>;
adi,rxagc-peak-hb2-thresh-config = <3>;
adi,rxagc-power-power-enable-measurement = <1>;
adi,rxagc-power-power-use-rfir-out = <1>;
adi,rxagc-power-power-use-bbdc2 = <0>;
adi,rxagc-power-under-range-high-power-thresh = <9>;
adi,rxagc-power-under-range-low-power-thresh = <2>;
adi,rxagc-power-under-range-high-power-gain-step-recovery = <4>;
adi,rxagc-power-under-range-low-power-gain-step-recovery = <4>;
adi,rxagc-power-power-measurement-duration = <5>;
adi,rxagc-power-rx1-tdd-power-meas-duration = <5>;
adi,rxagc-power-rx1-tdd-power-meas-delay = <1>;
adi,rxagc-power-rx2-tdd-power-meas-duration = <5>;
adi,rxagc-power-rx2-tdd-power-meas-delay = <1>;
adi,rxagc-power-upper0-power-thresh = <2>;
adi,rxagc-power-upper1-power-thresh = <0>;
adi,rxagc-power-power-log-shift = <0>;
adi,rxagc-agc-peak-wait-time = <4>;
adi,rxagc-agc-rx1-max-gain-index = <255>;
adi,rxagc-agc-rx1-min-gain-index = <195>;
adi,rxagc-agc-rx2-max-gain-index = <255>;
adi,rxagc-agc-rx2-min-gain-index = <195>;
adi,rxagc-agc-gain-update-counter_us = <250>;
adi,rxagc-agc-rx1-attack-delay = <10>;
adi,rxagc-agc-rx2-attack-delay = <10>;
adi,rxagc-agc-slow-loop-settling-delay = <16>;
adi,rxagc-agc-low-thresh-prevent-gain = <0>;
adi,rxagc-agc-change-gain-if-thresh-high = <1>;
adi,rxagc-agc-peak-thresh-gain-control-mode = <1>;
adi,rxagc-agc-reset-on-rxon = <0>;
adi,rxagc-agc-enable-sync-pulse-for-gain-counter = <0>;
adi,rxagc-agc-enable-ip3-optimization-thresh = <0>;
adi,rxagc-ip3-over-range-thresh = <31>;
adi,rxagc-ip3-over-range-thresh-index = <246>;
adi,rxagc-ip3-peak-exceeded-cnt = <4>;
adi,rxagc-agc-enable-fast-recovery-loop = <0>;
/* Misc */
adi,aux-dac-enables = <0x00>; /* Mask */
adi,aux-dac-vref0 = <3>;
adi,aux-dac-resolution0 = <0>;
adi,aux-dac-values0 = <0>;
adi,aux-dac-vref1 = <3>;
adi,aux-dac-resolution1 = <0>;
adi,aux-dac-values1 = <0>;
adi,aux-dac-vref2 = <3>;
adi,aux-dac-resolution2 = <0>;
adi,aux-dac-values2 = <0>;
adi,aux-dac-vref3 = <3>;
adi,aux-dac-resolution3 = <0>;
adi,aux-dac-values3 = <0>;
adi,aux-dac-vref4 = <3>;
adi,aux-dac-resolution4 = <0>;
adi,aux-dac-values4 = <0>;
adi,aux-dac-vref5 = <3>;
adi,aux-dac-resolution5 = <0>;
adi,aux-dac-values5 = <0>;
adi,aux-dac-vref6 = <3>;
adi,aux-dac-resolution6 = <0>;
adi,aux-dac-values6 = <0>;
adi,aux-dac-vref7 = <3>;
adi,aux-dac-resolution7 = <0>;
adi,aux-dac-values7 = <0>;
adi,aux-dac-vref8 = <3>;
adi,aux-dac-resolution8 = <0>;
adi,aux-dac-values8 = <0>;
adi,aux-dac-vref9 = <3>;
adi,aux-dac-resolution9 = <0>;
adi,aux-dac-values9 = <0>;
adi,aux-dac-vref10 = <3>;
adi,aux-dac-resolution10 = <0>;
adi,aux-dac-values10 = <0>;
adi,aux-dac-vref11 = <3>;
adi,aux-dac-resolution11 = <0>;
adi,aux-dac-values11 = <0>;
adi,arm-gpio-config-orx1-tx-sel0-pin-gpio-pin-sel = <10>;
adi,arm-gpio-config-orx1-tx-sel0-pin-polarity = <0>;
adi,arm-gpio-config-orx1-tx-sel0-pin-enable = <0>;
adi,arm-gpio-config-orx1-tx-sel1-pin-gpio-pin-sel = <11>;
adi,arm-gpio-config-orx1-tx-sel1-pin-polarity = <0>;
adi,arm-gpio-config-orx1-tx-sel1-pin-enable = <0>;
adi,arm-gpio-config-orx2-tx-sel0-pin-gpio-pin-sel = <0>;
adi,arm-gpio-config-orx2-tx-sel0-pin-polarity = <0>;
adi,arm-gpio-config-orx2-tx-sel0-pin-enable = <0>;
adi,arm-gpio-config-orx2-tx-sel1-pin-gpio-pin-sel = <0>;
adi,arm-gpio-config-orx2-tx-sel1-pin-polarity = <0>;
adi,arm-gpio-config-orx2-tx-sel1-pin-enable = <0>;
adi,arm-gpio-config-en-tx-tracking-cals-gpio-pin-sel = <0>;
adi,arm-gpio-config-en-tx-tracking-cals-polarity = <0>;
adi,arm-gpio-config-en-tx-tracking-cals-enable = <0>;
adi,orx-lo-cfg-disable-aux-pll-relocking = <0>;
adi,orx-lo-cfg-gpio-select = <19>;
adi,fhm-config-fhm-gpio-pin = <0>;
adi,fhm-config-fhm-min-freq_mhz = <2400>;
adi,fhm-config-fhm-max-freq_mhz = <2500>;
adi,fhm-mode-fhm-enable = <0>;
adi,fhm-mode-enable-mcs-sync = <0>;
adi,fhm-mode-fhm-trigger-mode = <0>;
adi,fhm-mode-fhm-exit-mode = <1>;
adi,fhm-mode-fhm-init-frequency_hz = <2450000000>;
adi,rx1-gain-ctrl-pin-inc-step = <1>;
adi,rx1-gain-ctrl-pin-dec-step = <1>;
adi,rx1-gain-ctrl-pin-rx-gain-inc-pin = <0>;
adi,rx1-gain-ctrl-pin-rx-gain-dec-pin = <1>;
adi,rx1-gain-ctrl-pin-enable = <0>;
adi,rx2-gain-ctrl-pin-inc-step = <1>;
adi,rx2-gain-ctrl-pin-dec-step = <1>;
adi,rx2-gain-ctrl-pin-rx-gain-inc-pin = <3>;
adi,rx2-gain-ctrl-pin-rx-gain-dec-pin = <4>;
adi,rx2-gain-ctrl-pin-enable = <0>;
adi,tx1-atten-ctrl-pin-step-size = <0>;
adi,tx1-atten-ctrl-pin-tx-atten-inc-pin = <4>;
adi,tx1-atten-ctrl-pin-tx-atten-dec-pin = <5>;
adi,tx1-atten-ctrl-pin-enable = <0>;
adi,tx2-atten-ctrl-pin-step-size = <0>;
adi,tx2-atten-ctrl-pin-tx-atten-inc-pin = <6>;
adi,tx2-atten-ctrl-pin-tx-atten-dec-pin = <7>;
adi,tx2-atten-ctrl-pin-enable = <0>;
adi,tx-pa-protection-avg-duration = <3>;
adi,tx-pa-protection-tx-atten-step = <2>;
adi,tx-pa-protection-tx1-power-threshold = <4096>;
adi,tx-pa-protection-tx2-power-threshold = <4096>;
adi,tx-pa-protection-peak-count = <4>;
adi,tx-pa-protection-tx1-peak-threshold = <140>;
adi,tx-pa-protection-tx2-peak-threshold = <140>;
Please help me to fix thís issue.
Ha Pham Van
