ADRV9009
Recommended for New Designs
The ADRV9009 is a highly integrated, radio frequency (RF), agile transceiver offering dual transmitters and receivers, integrated synthesizers, and digital...
Datasheet
ADRV9009 on Analog.com
I am using the ADRV9009-W/PCBZ with custom carrier board,and I got weird data from two RX channels.
When I do not input a signal to the RX port,I should receive the noise, but this is the time domain data and spectrum I received:
The received data is mixed with intermittent signals of approximately 80 MHz.
When I input a 10MHz signal (RF LO=2000MHz,input 2010MHz single tone), the 10MHz signal is superimposed on the above signal:
At first, I suspected this is due to the receiver QEC calibration,and I closed all the tracking calibration and receiver QEC initial calibration,but does not work.
When I change the front-end attenuator, the power of 10MHz signal changes too, but the spurious noise does not change significantly.
This is my talise_config.c file:
taliseInit_t talInit =
/* SPI settings */
.spiSettings =
.MSBFirst = 1, /* 1 = MSBFirst, 0 = LSBFirst */
.enSpiStreaming = 0, /* Not implemented in ADIs platform layer. SW feature to improve SPI throughput */
.autoIncAddrUp = 1, /* Not implemented in ADIs platform layer. For SPI Streaming, set address increment direction. 1= next addr = addr+1, 0:addr=addr-1 */
.fourWireMode = 1, /* 1: Use 4-wire SPI, 0: 3-wire SPI (SDIO pin is bidirectional). NOTE: ADI's FPGA platform always uses 4-wire mode */
.cmosPadDrvStrength = TAL_CMOSPAD_DRV_2X /* Drive strength of CMOS pads when used as outputs (SDIO, SDO, GP_INTERRUPT, GPIO 1, GPIO 0) */
/* Rx settings */
.rx =
.rxProfile =
.rxFir =
.gain_dB = 0, /* filter gain +6, 0, -6, -12 */
.numFirCoefs = 24, /* number of coefficients in the FIR filter 24, 48, 72 */
.coefs = &rxFirCoefs[0]
.rxFirDecimation = 1, /* Rx FIR decimation (1,2,4) */
.rxDec5Decimation = 4, /* Decimation of Dec5 or Dec4 filter (5,4) */
.rhb1Decimation = 1, /* RX Half band 1 decimation (1 or 2) */
.rxOutputRate_kHz = 245760, /* Rx output data rate in kHz */
.rfBandwidth_Hz = 200000000,/* The Rx RF passband bandwidth for the profile */
.rxBbf3dBCorner_kHz = 200000,/* Rx BBF 3dB corner in kHz. 20,000 to 200,000 */
//.rxAdcProfile = {202, 134, 163, 91, 1280, 666, 1371, 175, 1297, 67, 1012, 29, 46, 45, 35, 205, 0, 0, 0, 0, 51, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 21, 905},
.rxAdcProfile = {185, 141, 172, 90, 1280, 942, 1332, 90, 1368, 46, 1016, 19, 48, 48, 37, 208, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}, /* pointer to custom ADC profile */
.rxDdcMode = TAL_RXDDC_BYPASS, /* Rx DDC mode */
.rxNcoShifterCfg =
.bandAInputBandWidth_kHz = 0,
.bandAInputCenterFreq_kHz = 0,
.bandANco1Freq_kHz = 0,
.bandANco2Freq_kHz = 0,
.bandBInputBandWidth_kHz = 0,
.bandBInputCenterFreq_kHz = 0,
.bandBNco1Freq_kHz = 0,
.bandBNco2Freq_kHz = 0
.framerSel = TAL_FRAMER_A, /* Rx JESD204b framer configuration */
.rxGainCtrl =
.gainMode = TAL_MGC, /* taliserxGainMode_t gainMode; */
.rx1GainIndex = 255, /* uint8_t rx1GainIndex */
.rx2GainIndex = 255, /* uint8_t rx2GainIndex */
.rx1MaxGainIndex = 255, /* uint8_t rx1MaxGainIndex; */
.rx1MinGainIndex = 195, /* uint8_t rx1MinGainIndex; */
.rx2MaxGainIndex = 255, /* uint8_t rx2MaxGainIndex; */
.rx2MinGainIndex = 195 /* uint8_t rx2MinGainIndex; */
.rxChannels = TAL_RX1RX2 /* The desired Rx Channels to enable during initialization */
/* Tx settings */
.tx =
.txProfile =
.dacDiv = 1, /* The divider used to generate the DAC clock */
.txFir =
.gain_dB = 0, /* filter gain */
.numFirCoefs = 20, /* number of coefficients in the FIR filter */
.coefs = &txFirCoefs[0]
.txFirInterpolation = 1, /* The Tx digital FIR filter interpolation (1,2,4) */
.thb1Interpolation = 2, /* Tx Halfband1 filter interpolation (1,2) */
.thb2Interpolation = 2, /* Tx Halfband2 filter interpolation (1,2) */
.thb3Interpolation = 1, /* Tx Halfband3 (HB3) filter interpolation (1,2) */
.txInt5Interpolation = 1, /* Tx Int5 filter interpolation (1,5) */
.txInputRate_kHz = 245760, /* Tx input data rate in kHz */
.primarySigBandwidth_Hz = 200000000, /* Primary Signal BW */
.rfBandwidth_Hz = 100000000, /* The Tx RF passband bandwidth for the profile */
.txDac3dBCorner_kHz = 220000, /* The DAC filter 3dB corner in kHz */
.txBbf3dBCorner_kHz = 110000, /* Tx BBF 3dB corner in kHz */
.loopBackAdcProfile = {203, 139, 158, 90, 1280, 639, 1435, 172, 1273, 62, 1007, 30, 48, 44, 35, 207, 0, 0, 0, 0, 52, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905}
.deframerSel = TAL_DEFRAMER_A, /* Talise JESD204b deframer config for the Tx data path */
.txChannels = TAL_TX1TX2, /* The desired Tx channels to enable during initialization */
.txAttenStepSize = TAL_TXATTEN_0P05_DB, /* Tx Attenuation step size */
.tx1Atten_mdB = 10000, /* Initial and current Tx1 Attenuation */
.tx2Atten_mdB = 10000, /* Initial and current Tx2 Attenuation */
.disTxDataIfPllUnlock = TAL_TXDIS_TX_RAMP_DOWN_TO_ZERO /* Options to disable the transmit data when the RFPLL unlocks. */
/* ObsRx settings */
.obsRx =
.orxProfile =
.rxFir =
.numFirCoefs = 24, /* number of coefficients in the FIR filter */
.coefs = &obsrxFirCoefs[0]
.orxOutputRate_kHz = 245760, /* ORx output data rate in kHz */
.rfBandwidth_Hz = 100000000,/* The Rx RF passband bandwidth for the profile */
.rxBbf3dBCorner_kHz = 100000, /* Rx BBF 3dB corner in kHz */
.orxLowPassAdcProfile = {175, 155, 160, 90, 1280, 896, 1671, 472, 1094, 150, 1160, 21, 48, 35, 34, 204, 0, 0, 0, 0, 51, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},
.orxBandPassAdcProfile = {115, 129, 149, 88, 1280, 2619, 1670, 64, 1066, 879, 874, 107, 17, 15, 26, 177, 0, 0, 0, 0, 44, 0, 7, 6, 42, 0, 7, 6, 42, 0, 25, 27, 0, 0, 25, 27, 0, 0, 165, 44, 31, 905},
.orxDdcMode = TAL_ORXDDC_DISABLED, /* ORx DDC mode */
.orxMergeFilter = {-98,413,-310,-382,987,-488,-1131,2215,-622,-4016,9277,21173}
.orxGainCtrl =
.orx1GainIndex = 255,
.orx2GainIndex = 255,
.orx1MaxGainIndex = 255,
.orx1MinGainIndex = 195,
.orx2MaxGainIndex = 255,
.orx2MinGainIndex = 195
.framerSel = TAL_FRAMER_B, /* ObsRx JESD204b framer configuration structure */
.obsRxChannelsEnable = TAL_ORXOFF, /* The desired ObsRx Channels to enable during initialization */
.obsRxLoSource = TAL_AUX_PLL /* The ORx mixers can use the TX_PLL*/
/* Digital Clock settings */
.clocks =
.deviceClock_kHz = 122880, /* CLKPLL and device reference clock frequency in kHz */
.clkPllVcoFreq_kHz = 9830400, /* CLKPLL VCO frequency in kHz */
.clkPllHsDiv = TAL_HSDIV_5, /* CLKPLL high speed clock divider */
.rfPllUseExternalLo = 0, /* 1= Use external LO for RF PLL, 0 = use internal LO generation for RF PLL */
.rfPllPhaseSyncMode = TAL_RFPLLMCS_NOSYNC /* RFPLL MCS (Phase sync) mode */
/* JESD204B settings */
.jesd204Settings =
/* Framer A settings */
.framerA =
.bankId = 0, /* JESD204B Configuration Bank ID -extension to Device ID (Valid 0..15) */
.deviceId = 0, /* JESD204B Configuration Device ID - link identification number. (Valid 0..255) */
.lane0Id = 0, /* JESD204B Configuration starting Lane ID. If more than one lane used, each lane will increment from the Lane0 ID. (Valid 0..31) */
.M = 4, /* number of ADCs (0, 2, or 4) - 2 ADCs per receive chain */
.K = 32, /* number of frames in a multiframe (default=32), F*K must be a multiple of 4. (F=2*M/numberOfLanes) */
.F = 2, /* F (number of bytes per JESD204 Frame) */
.Np = 16, /* Np (converter sample resolution) */
.scramble = 1, /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
.externalSysref = 0, /* 0=use internal SYSREF, 1= use external SYSREF */
.serializerLanesEnabled = 0x0f, /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
.serializerLaneCrossbar = 0xB1, /* serializerLaneCrossbar; */
.lmfcOffset = 0, /* lmfcOffset - LMFC offset value for deterministic latency setting */
.newSysrefOnRelink = 0, /* newSysrefOnRelink */
.syncbInSelect = 0, /* syncbInSelect; */
.overSample = 0, /* 1=overSample, 0=bitRepeat */
.syncbInLvdsMode = 1,
.syncbInLvdsPnInvert = 0,
.enableManualLaneXbar = 1 /* 0=auto, 1=manual */
/* Framer B settings */
.framerB =
.scramble = 0, /* scrambling off if framerScramble= 0, if framerScramble>0 scramble is enabled. */
.serializerLanesEnabled = 0x00, /* serializerLanesEnabled - bit per lane, [0] = Lane0 enabled, [1] = Lane1 enabled */
.serializerLaneCrossbar = 0xd8, /* serializerLaneCrossbar; */
.syncbInSelect = 0, /* SyncbInSelect; */
.enableManualLaneXbar = 0 /* 0=auto, 1=manual */
/* Deframer A settings */
.deframerA =
.bankId = 0, /* bankId extension to Device ID (Valid 0..15) */
.deviceId = 0, /* deviceId link identification number. (Valid 0..255) */
.lane0Id = 0, /* lane0Id Lane0 ID. (Valid 0..31) */
.M = 4, /* M number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
.K = 32, /* K #frames in a multiframe (default=32), F*K=multiple of 4. (F=2*M/numberOfLanes) */
//.S = 1, /* S */
.scramble = 1, /* scramble scrambling off if scramble= 0 */
.externalSysref = 0, /* externalSysref 0= use internal SYSREF, 1= external SYSREF */
.deserializerLanesEnabled = 0x0F, /* deserializerLanesEnabled bit per lane, [0] = Lane0 enabled */
.deserializerLaneCrossbar = 0x8D, /* deserializerLaneCrossbar */
.lmfcOffset = 0, /* lmfcOffset LMFC offset value to adjust deterministic latency */
.syncbOutSelect = 0, /* SYNCBOUT0/1 select */
.syncbOutLvdsMode = 1,
.syncbOutLvdsPnInvert = 0,
.syncbOutCmosSlewRate = 0,
.syncbOutCmosDriveLevel = 0,
/* Deframer B settings */
.deframerB =
.M = 0, /* M number of DACss (0, 2, or 4) - 2 DACs per transmit chain */
//.S = 1, /* S */
.deserializerLanesEnabled = 0x00, /* deserializerLanesEnabled bit per lane, [0] = Lane0 enabled */
.syncbOutSelect = 1, /* syncbOutSelect; */
.serAmplitude = 15, /* Serializer amplitude setting. Default = 15. Range is 0..15 */
.serPreEmphasis = 1, /* Serializer pre-emphasis setting. Default = 1 Range is 0..4 */
.serInvertLanePolarity = 0, /* Serializer Lane PN inversion select. Default = 0. Where, bit[0] = 0 will invert lane [0], bit[1] = 0 will invert lane 1, etc. */
.desInvertLanePolarity = 0, /* Deserializer Lane PN inversion select. bit[0] = 1 Invert PN of Lane 0, bit[1] = Invert PN of Lane 1, etc */
.desEqSetting = 1, /* Deserializer Equalizer setting. Applied to all deserializer lanes. Range is 0..4 */
.sysrefLvdsMode = 1, /* Use LVDS inputs on Talise for SYSREF */
.sysrefLvdsPnInvert = 0 /*0= Do not PN invert SYSREF */
And my RX PFIR coefficient is:
int16_t rxFirCoefs[24] = {
0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 16384,
0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0
Would you like to tell me what caused this phenomenon? How can I eliminate these extra signals?
Thank you very much!
What is the REF_CLK frequency that you are setting? Can you send us the filter file that you are loading into the GUI? Are you using MGC or AGC?
Thanks for your reply,
REF_CLK frequency is 122.88MHz,.
I am using the talise API, so most filters are configured by taliseInit_t in the talise_config.c file. Is there any other filter need to be configured?
I am using the MGC mode.
For filter design you need to use the profile wizard.
https://www.analog.com/en/design-center/landing-pages/001/transceiver-evaluation-software.html
Is the JESD configured successfully ? What is the status of framer and deframer.?
The JESD is working properly...
I have solved this problem, but don't know why.
I changed the RX decimation from 4x to 8x, and set clkPllHsDiv=TAL_HSDIV_2P5, then I got the normal received data.
Why the decimation 4x not work for RX, it works fine on TX.
Did you use the profile wizard for generating profiles with your desired output rates? Tried to generate a profile(using profile wizard) with the same RX rate as yours and the RX decimation comes as 8 instead of 4. You cannot change the decimation rates directly as it will change the clock rates for the entire path and hence the chances of error increases. Please use the wizard for generating profiles as it will take care of all the digital clock rates.
If fix offset between two RX channels. you can delay data of one RX with register.
input adc_clk,
input [15:0] D,
output [15:0] Q
always @(posedge adc_clk) Q <= D // this shift one clk cycle
