AD-JUPITER-EBZ: TDD support
Product Number: ADRV9002
Software Version: Linux Software drivers
I'd like to use the axi_adrv9001 TDD engine on the Jupiter SDR, but neither the Kuiper image shipped with the board nor the meta-adi devicetrees include the axi-adrv9002-core-tdd nodes.
In the Jupiter HDL project (projects/jupiter_sdr/system_bd.tcl), tdd_sync is tied to ground (ad_connect GND axi_adrv9001/tdd_sync). Looking at ad_tdd_control.v, the TDD state machine only starts on a rising edge of tdd_sync, so it never starts. In the ADRV9002 ZCU102 HDL project (projects/adrv9001/zcu102), tdd_sync is instead connected to the PMOD0_0 pin, or driven from gpio_o[56] .
Questions:
  1. Are there any limitations on using TDD on Jupiter?
  2. What is the recommended way to provide tdd_sync on Jupiter (which PS GPIO or external connector)?
Thanks.
  • the HDL Design for Jupiter - SDR, there is no ADI AXI TDD Controller incorporated within the design.
    The pin are linked with:
    gpio_rx1_enable_in with gpio[47]
    gpio_rx2_enable_in with gpio[46]
    gpio_tx1_enable_in with gpio[45]
    gpio_tx2_enable_in with gpio[44]
    these are basically emio gpio in linux
    base_gpio + offset + x
    512 + 78 + hdl_offset
    If you want to use the TDD Engine, you need to include ADI AXI TDD controller within the design, and reconnect these to tdd pins in system_top.v and also modifications in devicetree are needed.
