Frequency Hopping Dynamic Dwell Time
The user inquired about the possibility of dynamic dwell times for fast frequency hopping, specifically staying at 915 MHz for X ms and then at 2.4 GHz for Y ms. The final answer confirmed that this is possible by controlling the HOP signal, which triggers frequency changes on its transitions. The device remains at the current frequency as long as the HOP signal is steady.
Hey all, quick question. Can we have dynamic dwell time for fast frequency hopping? i.e. stay at 915mhz for X ms, then go to 2.4ghz for Y ms. Or is the dwell time / hop signal on a fixed rate. The user guide seems to indicate its the latter, just want to clarify.
Parents
    Yes, it is possible to configure different dwell times, and this behavior is entirely controlled by the HOP signal. The RF frequency changes only when the HOP signal transitions (either a rising or a falling edge). In other words, the device remains on the current frequency as long as the HOP signal does not toggle.
    For example, you can stay at 915 MHz for X ms by holding the HOP signal steady. When you toggle the HOP signal after X ms, the device switches to 2.4 GHz and remains at that frequency for Y ms, until the next HOP signal transition occurs.
    Regards
    Rahul
Reply
    Regards
    Rahul
Children
No Data
