MCS--2 adrv9002s--one cpu
The user wants to synchronize two ADRV9002 devices using MCS and control them with a single Zynq UltraScale+ MPSoC APU core. The solution involves configuring two distinct chip-select lines for SPI communication and ensuring the MCS pulses and dev_clk signals are synchronized. The ADRV9002 HDL IP and SDK firmware can coexist, with the HDL IP handling data and control for both devices, and the MCS API functions supporting individual chip communication via chip-select or ID variables.
Product Number: ADRV9002
Software Version: v0.28
Is it possible to synchronize two adrv9002s MCS and also control them with one cpu?
I want to achieve the following:
  • Communicate over SPI to two adrv9002 ICs using a single zynq us+ mpsoc APU core.
  • Synchronize both adrv9002s using MCS
  • Generate MCS pulses from zynq us+ mpsoc
  • Supply dev_clk to both adrv9002s using a dedicated clock chip.
  • Create the necessary HDL to handle 4 channels of TX and RX so I can take Rx samples into RAM and pull Tx samples out of RAM.
Is there anything special I need to do in order to make this work?
    Yes, synchronizing two ADRV9002 devices is achievable using the MCS (Multi-Chip Synchronization) feature. Your outlined steps are generally correct. However, please ensure that the MCS pulses reach both ADRV9002 devices within the same clock cycle to maintain proper synchronization. Additionally, it's important to verify that both the FPGA and the clock distribution chip are synchronized to avoid timing mismatches.
    Regards
    Rahul
  • What kind of timing mismatches will occur if the fpga-produced MCS signal and the dev_clk signal are not synchronized?
    Is there a document that describes this "timing mismatch" hazard?
  • Please note one important aspect of the question above is "using a single zynq us+ mpsoc APU core". Are there any problems or caveats with connecting two ADRV900x transceivers to a single ultrascale+? Can two distinct copies of the IP and SDK firmware coexist in the one device without issues?
  • Thanks for focusing this conversation on the "using a single zynq us+ mpsoc APU core" part of my post.
    I do want to use two distinct copies of the ADRV9002 HDL IP, but I only want to use one copy of the ADRV9002 SDK firmware.
    Do the available MCS api functions have a chip-select or ID variable that allows a single cpu to talk to multiple adrv9002 chips?
    To communicate with two ADRV9002 devices using a single Zynq UltraScale+ MPSoC APU core, you only need one instance of the ADRV9002 HDL IP that supports both devices. The same SDK firmware will be loaded onto each ADRV9002 chip.
    However, to enable the FPGA to interact with both devices individually, you must configure two distinct chip-select lines. These chip-selects allow the MCS API functions to target each ADRV9002 separately, even though the firmware and API interface are shared.
    Regards
    Rahul
  • How would I set up the adrv9002 hdl ip to handle data and control for two adrv9002s?
    I just looked at the adrv9002 hdl ip re-customization gui and it's not obvious.
    I would like both adrv9002s to be able to pipe data through the HDL driver simultaneously.
