Is it possible to produce a 500 kHz sample rate for I/Q data trasmission?
Does exist a command line(s) (for example by teraterm) to set this parameter?
Thank you
ADRV9002
Recommended for New Designs
The ADRV9002 is a highly integrated RF transceiver that has dual-channel transmitters, dual-channel receivers, integrated synthesizers, and digital signal...
Datasheet
ADRV9002 on Analog.com
Thank you
Moved from RF and Microwave to Design Support ADRV9001 – ADRV9007 on Monday, October 30, 2023 4:48:43 PM by GenevaCooper
Hi Ilariawork,
As per Table 40 in the ADRV9001 System Development User Guide, 500 kHz is not in any of the dead zones. Therefore, the ADRV9002 does support this sample rate.
However, for guidance on how to do this, you'll need to contact the distributor or manufacturer of your BP-2CG1C-9002KT module. Here, we only support the software available from the ADRV9002 Product Page.
Kind Regards,
Michał
