Does anyone know if the ADRV900X or AD9361 have been used to meet EN300113?
https://www.etsi.org/deliver/etsi_en/300100_300199/300113/02.02.01_60/en_300113v020201p.pdf
https://www.tuvsud.com/en-us/resource-centre/stories/etsi-en-300-113-guidance
AD9361
Recommended for New Designs
The AD9361 is a high performance, highly integrated radio
frequency (RF) Agile Transceiver™ designed for use in 3G and
4G base station applications. Its...
Datasheet
AD9361 on Analog.com
AD9364
The AD9364 is a 1 x 1 channel high performance, highly integrated RF Agile Transceiver™. Its programmability and wideband capability make it ideal for...
Datasheet
AD9364 on Analog.com
ADRV9003
Production
The ADRV9003 is a highly integrated RF transceiver that has a single-channel transmitter, dual-channel receivers, integrated synthesizers, and digital...
Datasheet
ADRV9003 on Analog.com
AD9361
Datasheet
ADRV9002
The ADRV9002 is a highly integrated RF transceiver that has dual-channel transmitters, dual-channel receivers, integrated synthesizers, and digital signal...
Datasheet
ADRV9002 on Analog.com
Moved thread to design support for AD9001 forum. They should be able to help.
Hi natural_inquisitive,
We did not design this part to conform to any particular standard - in general, this is not something that we do.
That being said, we do have a lot of customers using these parts for DMR/LMR applications; I just can't say whether any of them have built a system that conforms to the standard you specified. I recommend that you read through this article, as it shows how the ADRV9002 can be used to meet many (if not all) specifications set out: How a High Dynamic Range RF Transceiver Solves the Blocking Challenge for Mission Critical Communications | Analog Devices
Ultimately though, it is down to the customer to implement and configure the part in a way that satisfies their requirements.
Kind Regards,
Michał
