1.Custom board, using No-OS-2021-R1 (xilinx zu19eg) configuration 9002. Dev_clk_in = 50M, FDD, 2T2R. Sampling rate = 60MSPS, RF channel bandwidth 38MHz,
2.adi_adrv9001_cals_InitCals_Run Failed to calibrate with ADI_ADRV9001_INIT_CAL_RX_GAIN_PATH_DELAY option. Return -2 error message.
3.Calibration passes when adi_adrv9001_cals_InitCals_Run does not use the ADI_ADRV9001_INIT_CAL_RX_GAIN_PATH_DELAY option. But the receive channel has no signal (set GAIN mode ADI_ADRV9001_RX_GAIN_CONTROL_MODE_SPI, Rx_Gain_Set is 255)
ret = adrv9002_digital_init(phy); function returns 0
Can you give some advice to solve the problem?
my config file
#include "adi_adrv9001.h" #include "adi_adrv9001_arm.h" #include "adi_adrv9001_cals.h" #include "adi_adrv9001_gpio.h" #include "adi_adrv9001_mcs.h" #include "adi_adrv9001_powermanagement.h" #include "adi_adrv9001_powersavingandmonitormode.h" #include "adi_adrv9001_radio.h" #include "adi_adrv9001_rx.h" #include "adi_adrv9001_ssi.h" #include "adi_adrv9001_stream.h" #include "adi_adrv9001_tx.h" #include "adi_fpga9001.h" #include "adi_fpga9001_clock.h" #include "adi_fpga9001_hal_wrapper.h" #include "adi_fpga9001_ssi.h" #include <stdlib.h> #include "linux_uio_init.h" adi_adrv9001_Init_t initialize_init_7 = { .clocks = { .deviceClock_kHz = 50000, .clkPllVcoFreq_daHz = 864000000, .clkPllHsDiv = ADI_ADRV9001_HSDIV_4, .clkPllMode = ADI_ADRV9001_CLK_PLL_HP_MODE, .clk1105Div = ADI_ADRV9001_INTERNAL_CLOCK_DIV_2, .armClkDiv = ADI_ADRV9001_INTERNAL_CLOCK_DIV_6, .armPowerSavingClkDiv = 1, .refClockOutEnable = true, .auxPllPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .clkPllPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .padRefClkDrv = 0, .extLo1OutFreq_kHz = 0, .extLo2OutFreq_kHz = 0, .rfPll1LoMode = ADI_ADRV9001_INT_LO1, .rfPll2LoMode = ADI_ADRV9001_INT_LO1, .ext1LoType = ADI_ADRV9001_EXT_LO_DIFFERENTIAL, .ext2LoType = ADI_ADRV9001_EXT_LO_DIFFERENTIAL, .rx1RfInputSel = ADI_ADRV9001_RX_A, .rx2RfInputSel = ADI_ADRV9001_RX_A, .extLo1Divider = 2, .extLo2Divider = 2, .rfPllPhaseSyncMode = ADI_ADRV9001_RFPLLMCS_NOSYNC, .rx1LoSelect = ADI_ADRV9001_LOSEL_LO2, .rx2LoSelect = ADI_ADRV9001_LOSEL_LO2, .tx1LoSelect = ADI_ADRV9001_LOSEL_LO1, .tx2LoSelect = ADI_ADRV9001_LOSEL_LO1, .rx1LoDivMode = ADI_ADRV9001_LO_DIV_MODE_LOW_POWER, .rx2LoDivMode = ADI_ADRV9001_LO_DIV_MODE_LOW_POWER, .tx1LoDivMode = ADI_ADRV9001_LO_DIV_MODE_LOW_POWER, .tx2LoDivMode = ADI_ADRV9001_LO_DIV_MODE_LOW_POWER, .loGen1Select = ADI_ADRV9001_LOGENPOWER_RFPLL_LDO, .loGen2Select = ADI_ADRV9001_LOGENPOWER_RFPLL_LDO} , .rx = { .rxInitChannelMask = 195, .rxChannelCfg = { { .profile = { .primarySigBandwidth_Hz = 38000000, .rxOutputRate_Hz = 60000000, .rxInterfaceSampleRate_Hz = 60000000, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 20000000, .lpAdcCorner = 0, .adcClk_kHz = 2160000, .rxCorner3dB_kHz = 10000, .rxCorner3dBLp_kHz = 10000, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 1, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 1, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 1, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_SINC6, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_A, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 1} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 38000000, .rxOutputRate_Hz = 60000000, .rxInterfaceSampleRate_Hz = 60000000, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 20000000, .lpAdcCorner = 0, .adcClk_kHz = 2160000, .rxCorner3dB_kHz = 10000, .rxCorner3dBLp_kHz = 10000, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 2, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 1, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 1, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_SINC6, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_C, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 1} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 12500, .rxOutputRate_Hz = 0, .rxInterfaceSampleRate_Hz = 0, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 0, .lpAdcCorner = 0, .adcClk_kHz = 0, .rxCorner3dB_kHz = 0, .rxCorner3dBLp_kHz = 0, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 0, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 0, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 0, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_ZERO, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_A, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_DISABLE, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_2_BIT_SYMBOL_DATA, .numLaneSel = ADI_ADRV9001_SSI_1_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = false, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 12500, .rxOutputRate_Hz = 0, .rxInterfaceSampleRate_Hz = 0, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 0, .lpAdcCorner = 0, .adcClk_kHz = 0, .rxCorner3dB_kHz = 0, .rxCorner3dBLp_kHz = 0, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 0, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 0, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 0, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_ZERO, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_A, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_DISABLE, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_2_BIT_SYMBOL_DATA, .numLaneSel = ADI_ADRV9001_SSI_1_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = false, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 38000000, .rxOutputRate_Hz = 60000000, .rxInterfaceSampleRate_Hz = 60000000, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 50000000, .lpAdcCorner = 0, .adcClk_kHz = 2160000, .rxCorner3dB_kHz = 100000, .rxCorner3dBLp_kHz = 100000, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 64, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 1, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 1, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_SINC6, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB2, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_B, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 38000000, .rxOutputRate_Hz = 60000000, .rxInterfaceSampleRate_Hz = 60000000, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 50000000, .lpAdcCorner = 0, .adcClk_kHz = 2160000, .rxCorner3dB_kHz = 100000, .rxCorner3dBLp_kHz = 100000, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 128, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 1, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 1, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_SINC6, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB2, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_D, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 12500, .rxOutputRate_Hz = 0, .rxInterfaceSampleRate_Hz = 0, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 0, .lpAdcCorner = 0, .adcClk_kHz = 0, .rxCorner3dB_kHz = 0, .rxCorner3dBLp_kHz = 0, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 0, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 0, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 0, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_ZERO, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_A, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_DISABLE, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_2_BIT_SYMBOL_DATA, .numLaneSel = ADI_ADRV9001_SSI_1_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = false, .rxMaskStrobeEn = false} } }, { .profile = { .primarySigBandwidth_Hz = 12500, .rxOutputRate_Hz = 0, .rxInterfaceSampleRate_Hz = 0, .rxOffsetLo_kHz = 0, .rxNcoEnable = false, .outputSignaling = ADI_ADRV9001_RX_IQ, .filterOrder = 1, .filterOrderLp = 1, .hpAdcCorner = 0, .lpAdcCorner = 0, .adcClk_kHz = 0, .rxCorner3dB_kHz = 0, .rxCorner3dBLp_kHz = 0, .tiaPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .tiaPowerLp = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .channelType = 0, .adcType = ADI_ADRV9001_ADC_HP, .lpAdcCalMode = ADI_ADRV9001_ADC_LOWPOWER_PERIODIC, .gainTableType = ADI_ADRV9001_RX_GAIN_CORRECTION_TABLE, .rxDpProfile = { .rxNbDecTop = { .scicBlk23En = 0, .scicBlk23DivFactor = 0, .scicBlk23LowRippleEn = 0, .decBy2Blk35En = 0, .decBy2Blk37En = 0, .decBy2Blk39En = 0, .decBy2Blk41En = 0, .decBy2Blk43En = 0, .decBy3Blk45En = 0, .decBy2Blk47En = 0} , .rxWbDecTop = { .decBy2Blk25En = 0, .decBy2Blk27En = 0, .decBy2Blk29En = 0, .decBy2Blk31En = 0, .decBy2Blk33En = 0, .wbLpfBlk33p1En = 0} , .rxDecTop = { .decBy3Blk15En = 0, .decBy2Hb3Blk17p1En = 0, .decBy2Hb4Blk17p2En = 0, .decBy2Hb5Blk19p1En = 0, .decBy2Hb6Blk19p2En = 0} , .rxSincHBTop = { .sincGainMux = ADI_ADRV9001_RX_SINC_GAIN_MUX_6_DB, .sincMux = ADI_ADRV9001_RX_SINC_MUX5_OUTPUT_ZERO, .hbMux = ADI_ADRV9001_RX_HB_MUX_OUTPUT_HB1, .isGainCompEnabled = 0, .gainComp9GainI = { 16384, 16384, 16384, 16384, 16384, 16384 }, .gainComp9GainQ = { 0, 0, 0, 0, 0, 0 }} , .rxNbDem = { .dpInFifo = { .dpInFifoEn = 0, .dpInFifoMode = ADI_ADRV9001_DP_IN_FIFO_MODE_DETECTING, .dpInFifoTestDataSel = ADI_ADRV9001_DP_IN_FIFO_INPUT_DP_SEL} , .rxNbNco = { .rxNbNcoEn = 0, .rxNbNcoConfig = { .freq = 0, .sampleFreq = 0, .phase = 0, .realOut = 0} } , .rxWbNbCompPFir = { .bankSel = ADI_ADRV9001_PFIR_BANK_A, .rxWbNbCompPFirInMuxSel = ADI_ADRV9001_RP_FIR_IN_MUX_INT_IN, .rxWbNbCompPFirEn = 0} , .resamp = { .rxResampEn = 0, .resampPhaseI = 0, .resampPhaseQ = 0} , .gsOutMuxSel = ADI_ADRV9001_GS_OUT_MUX_BYPASS, .rxOutSel = ADI_ADRV9001_RX_OUT_IQ_SEL, .rxRoundMode = ADI_ADRV9001_RX_ROUNDMODE_IQ, .dpArmSel = ADI_ADRV9001_DP_SEL} } , .lnaConfig = { .externalLnaPresent = false, .gpioSourceSel = ADI_ADRV9001_GPIO_ANALOG_PIN_NIBBLE_UNASSIGNED, .externalLnaPinSel = ADI_ADRV9001_EXTERNAL_LNA_PIN_RX1_LOWER_RX2_UPPER, .settlingDelay = 0, .numberLnaGainSteps = 0, .lnaGainSteps_mdB = { 0, 0, 0, 0 }, .lnaDigitalGainDelay = 0, .minGainIndex = 0} , .rxSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_DISABLE, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_2_BIT_SYMBOL_DATA, .numLaneSel = ADI_ADRV9001_SSI_1_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DISABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = false, .rxMaskStrobeEn = false} } } }} , .tx = { .txInitChannelMask = 12, .txProfile = { { .primarySigBandwidth_Hz = 38000000, .txInputRate_Hz = 60000000, .txInterfaceSampleRate_Hz = 60000000, .txOffsetLo_kHz = 0, .validDataDelay = 0, .txBbf3dBCorner_kHz = 50000, .outputSignaling = ADI_ADRV9001_TX_IQ, .txPdBiasCurrent = 1, .txPdGainEnable = 0, .txPrePdRealPole_kHz = 1000000, .txPostPdRealPole_kHz = 530000, .txBbfPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .txExtLoopBackType = 0, .txExtLoopBackForInitCal = 0, .txPeakLoopBackPower = 0, .frequencyDeviation_Hz = 0, .txDpProfile = { .txPreProc = { .txPreProcSymbol0 = 0, .txPreProcSymbol1 = 0, .txPreProcSymbol2 = 0, .txPreProcSymbol3 = 0, .txPreProcSymMapDivFactor = 1, .txPreProcMode = ADI_ADRV9001_TX_DP_PREPROC_IQ_DATA_WITH_PFIRS, .txPreProcWbNbPfirIBankSel = ADI_ADRV9001_PFIR_BANK_A, .txPreProcWbNbPfirQBankSel = ADI_ADRV9001_PFIR_BANK_B} , .txWbIntTop = { .txInterpBy2Blk30En = 0, .txInterpBy2Blk28En = 0, .txInterpBy2Blk26En = 0, .txInterpBy2Blk24En = 0, .txInterpBy2Blk22En = 0, .txWbLpfBlk22p1En = 0} , .txNbIntTop = { .txInterpBy2Blk20En = 0, .txInterpBy2Blk18En = 0, .txInterpBy2Blk16En = 0, .txInterpBy2Blk14En = 0, .txInterpBy2Blk12En = 0, .txInterpBy3Blk10En = 0, .txInterpBy2Blk8En = 0, .txScicBlk32En = 0, .txScicBlk32DivFactor = 1} , .txIntTop = { .interpBy3Blk44p1En = 1, .sinc3Blk44En = 0, .sinc2Blk42En = 0, .interpBy3Blk40En = 1, .interpBy2Blk38En = 0, .interpBy2Blk36En = 0} , .txIntTopFreqDevMap = { .rrc2Frac = 0, .mpll = 0, .nchLsw = 0, .nchMsb = 0, .freqDevMapEn = 0, .txRoundEn = 1} , .txIqdmDuc = { .iqdmDucMode = ADI_ADRV9001_TX_DP_IQDMDUC_MODE0, .iqdmDev = 0, .iqdmDevOffset = 0, .iqdmScalar = 0, .iqdmThreshold = 0, .iqdmNco = { .freq = 0, .sampleFreq = 60000000, .phase = 0, .realOut = 0} } } , .txSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DCLK_OUT_ENABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} }, { .primarySigBandwidth_Hz = 38000000, .txInputRate_Hz = 60000000, .txInterfaceSampleRate_Hz = 60000000, .txOffsetLo_kHz = 0, .validDataDelay = 0, .txBbf3dBCorner_kHz = 50000, .outputSignaling = ADI_ADRV9001_TX_IQ, .txPdBiasCurrent = 1, .txPdGainEnable = 0, .txPrePdRealPole_kHz = 1000000, .txPostPdRealPole_kHz = 530000, .txBbfPower = ADI_ADRV9001_COMPONENT_POWER_LEVEL_HIGH, .txExtLoopBackType = 0, .txExtLoopBackForInitCal = 0, .txPeakLoopBackPower = 0, .frequencyDeviation_Hz = 0, .txDpProfile = { .txPreProc = { .txPreProcSymbol0 = 0, .txPreProcSymbol1 = 0, .txPreProcSymbol2 = 0, .txPreProcSymbol3 = 0, .txPreProcSymMapDivFactor = 1, .txPreProcMode = ADI_ADRV9001_TX_DP_PREPROC_IQ_DATA_WITH_PFIRS, .txPreProcWbNbPfirIBankSel = ADI_ADRV9001_PFIR_BANK_C, .txPreProcWbNbPfirQBankSel = ADI_ADRV9001_PFIR_BANK_D} , .txWbIntTop = { .txInterpBy2Blk30En = 0, .txInterpBy2Blk28En = 0, .txInterpBy2Blk26En = 0, .txInterpBy2Blk24En = 0, .txInterpBy2Blk22En = 0, .txWbLpfBlk22p1En = 0} , .txNbIntTop = { .txInterpBy2Blk20En = 0, .txInterpBy2Blk18En = 0, .txInterpBy2Blk16En = 0, .txInterpBy2Blk14En = 0, .txInterpBy2Blk12En = 0, .txInterpBy3Blk10En = 0, .txInterpBy2Blk8En = 0, .txScicBlk32En = 0, .txScicBlk32DivFactor = 1} , .txIntTop = { .interpBy3Blk44p1En = 1, .sinc3Blk44En = 0, .sinc2Blk42En = 0, .interpBy3Blk40En = 1, .interpBy2Blk38En = 0, .interpBy2Blk36En = 0} , .txIntTopFreqDevMap = { .rrc2Frac = 0, .mpll = 0, .nchLsw = 0, .nchMsb = 0, .freqDevMapEn = 0, .txRoundEn = 1} , .txIqdmDuc = { .iqdmDucMode = ADI_ADRV9001_TX_DP_IQDMDUC_MODE0, .iqdmDev = 0, .iqdmDevOffset = 0, .iqdmScalar = 0, .iqdmThreshold = 0, .iqdmNco = { .freq = 0, .sampleFreq = 60000000, .phase = 0, .realOut = 0} } } , .txSsiConfig = { .ssiType = ADI_ADRV9001_SSI_TYPE_LVDS, .ssiDataFormatSel = ADI_ADRV9001_SSI_FORMAT_16_BIT_I_Q_DATA, .numLaneSel = ADI_ADRV9001_SSI_2_LANE, .strobeType = ADI_ADRV9001_SSI_SHORT_STROBE, .lsbFirst = 0, .qFirst = 0, .txRefClockPin = ADI_ADRV9001_SSI_TX_REF_CLOCK_PIN_DCLK_OUT_ENABLED, .lvdsIBitInversion = false, .lvdsQBitInversion = false, .lvdsStrobeBitInversion = false, .lvdsUseLsbIn12bitMode = 0, .lvdsRxClkInversionEn = false, .cmosDdrPosClkEn = false, .cmosClkInversionEn = false, .ddrEn = true, .rxMaskStrobeEn = false} } }} , .sysConfig = { .duplexMode = ADI_ADRV9001_FDD_MODE, .fhModeOn = 0, .numDynamicProfiles = ADI_ADRV9001_NUM_DYNAMIC_PROFILES_DISABLED, .mcsMode = ADI_ADRV9001_MCSMODE_DISABLED, .mcsInterfaceType = ADI_ADRV9001_SSI_TYPE_DISABLE, .adcTypeMonitor = ADI_ADRV9001_ADC_HP, .pllLockTime_us = 750, .pllPhaseSyncWait_us = 0, .pllModulus = { .modulus = { 8388593, 8388593, 8388593, 8388593, 8388593 }, .dmModulus = { 8388593, 8388593 }} , .warmBootEnable = false} , .pfirBuffer = { .pfirRxWbNbChFilterCoeff_A = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirRxWbNbChFilterCoeff_B = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirRxWbNbChFilterCoeff_C = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirRxWbNbChFilterCoeff_D = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirTxWbNbPulShpCoeff_A = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirTxWbNbPulShpCoeff_B = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirTxWbNbPulShpCoeff_C = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirTxWbNbPulShpCoeff_D = { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .tapsSel = ADI_ADRV9001_PFIR_128_TAPS, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} , .pfirRxNbPulShp = { { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .taps = 128, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }}, { .numCoeff = 128, .symmetricSel = ADI_ADRV9001_PFIR_COEF_NON_SYMMETRIC, .taps = 128, .gainSel = ADI_ADRV9001_PFIR_GAIN_ZERO_DB, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 8388608, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} }, .pfirRxMagLowTiaLowSRHp = { { .numCoeff = 21, .coefficients = { -330, 1272, -1131, -1236, 1274, 2645, -1330, -5707, -906, 12142, 19384, 12142, -906, -5707, -1330, 2645, 1274, -1236, -1131, 1272, -330 }}, { .numCoeff = 21, .coefficients = { -330, 1272, -1131, -1236, 1274, 2645, -1330, -5707, -906, 12142, 19384, 12142, -906, -5707, -1330, 2645, 1274, -1236, -1131, 1272, -330 }} }, .pfirRxMagLowTiaHighSRHp = { { .numCoeff = 21, .coefficients = { -2341, 894, 5792, 4053, -7409, -15271, -5716, 12984, 18392, 6281, -2549, 6281, 18392, 12984, -5716, -15271, -7409, 4053, 5792, 894, -2341 }}, { .numCoeff = 21, .coefficients = { -2341, 894, 5792, 4053, -7409, -15271, -5716, 12984, 18392, 6281, -2549, 6281, 18392, 12984, -5716, -15271, -7409, 4053, 5792, 894, -2341 }} }, .pfirRxMagHighTiaHighSRHp = { { .numCoeff = 21, .coefficients = { 35, -190, 547, -1030, 1238, -501, -1767, 5470, -9255, 8699, 26276, 8699, -9255, 5470, -1767, -501, 1238, -1030, 547, -190, 35 }}, { .numCoeff = 21, .coefficients = { 35, -190, 547, -1030, 1238, -501, -1767, 5470, -9255, 8699, 26276, 8699, -9255, 5470, -1767, -501, 1238, -1030, 547, -190, 35 }} }, .pfirRxMagLowTiaLowSRLp = { { .numCoeff = 21, .coefficients = { -330, 1272, -1131, -1236, 1274, 2644, -1330, -5707, -906, 12142, 19383, 12142, -906, -5707, -1330, 2644, 1274, -1236, -1131, 1272, -330 }}, { .numCoeff = 21, .coefficients = { -330, 1272, -1131, -1236, 1274, 2644, -1330, -5707, -906, 12142, 19383, 12142, -906, -5707, -1330, 2644, 1274, -1236, -1131, 1272, -330 }} }, .pfirRxMagLowTiaHighSRLp = { { .numCoeff = 21, .coefficients = { -2341, 894, 5791, 4052, -7408, -15269, -5715, 12983, 18390, 6281, -2548, 6281, 18390, 12983, -5715, -15269, -7408, 4052, 5791, 894, -2341 }}, { .numCoeff = 21, .coefficients = { -2341, 894, 5791, 4052, -7408, -15269, -5715, 12983, 18390, 6281, -2548, 6281, 18390, 12983, -5715, -15269, -7408, 4052, 5791, 894, -2341 }} }, .pfirRxMagHighTiaHighSRLp = { { .numCoeff = 21, .coefficients = { 35, -190, 546, -1027, 1235, -501, -1758, 5450, -9230, 8701, 26249, 8701, -9230, 5450, -1758, -501, 1235, -1027, 546, -190, 35 }}, { .numCoeff = 21, .coefficients = { 35, -190, 546, -1027, 1235, -501, -1758, 5450, -9230, 8701, 26249, 8701, -9230, 5450, -1758, -501, 1235, -1027, 546, -190, 35 }} }, .pfirTxMagComp1 = { .numCoeff = 21, .coefficients = { 64, -326, 870, -1405, 1008, 1605, -6922, 13144, -13030, 3744, 35269, 3744, -13030, 13144, -6922, 1605, 1008, -1405, 870, -326, 64 }} , .pfirTxMagComp2 = { .numCoeff = 21, .coefficients = { 64, -326, 870, -1405, 1008, 1605, -6922, 13144, -13030, 3744, 35269, 3744, -13030, 13144, -6922, 1605, 1008, -1405, 870, -326, 64 }} , .pfirTxMagCompNb = { { .numCoeff = 13, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }}, { .numCoeff = 13, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} }, .pfirRxMagCompNb = { { .numCoeff = 13, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }}, { .numCoeff = 13, .coefficients = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }} }} };
chanInitCalMask
sdk configuration file 0.21.0
