Can We Run Only RX Code on AD9371
Product Number: AD9371
I am currently working with the AD9371 transceiver and would like to implement a receive-only (RX-only) configuration for my application. My setup does not require any transmission functionality.I only need to capture and process incoming RF signals.
I am using the AD9371 RF transceiver with the Xilinx ZC706 evaluation board. The connection between the ZC706 and AD9371 is made via the standard FMC interface. The reference design used is based on ADI's No-OS framework, built and programmed using Xilinx Vivado and Vitis tools.
Thread Notes
  • Yes, we can implement the Rx only configuration and use them for your testing.
  • Headless.c :
    * @file ad9371/src/app/headless.c
    * @brief Implementation of Main Function.
    * Copyright 2017(c) Analog Devices, Inc.
    * All rights reserved.
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions are met:
    * - Redistributions of source code must retain the above copyright
    * notice, this list of conditions and the following disclaimer.
    * - Redistributions in binary form must reproduce the above copyright
    * notice, this list of conditions and the following disclaimer in
    * the documentation and/or other materials provided with the
    * distribution.
    * - Neither the name of Analog Devices, Inc. nor the names of its
    * contributors may be used to endorse or promote products derived
    * from this software without specific prior written permission.
    * - The use of this software may or may not infringe the patent rights
    * of one or more patent holders. This license does not release you
    * from the requirement that you obtain separate licenses from these
    * patent holders to use this software.
    * - Use of the software either in source or binary form, must be run
    * on or directly connected to an Analog Devices Inc. component.
    * THIS SOFTWARE IS PROVIDED BY ANALOG DEVICES "AS IS" AND ANY EXPRESS OR
    * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, NON-INFRINGEMENT,
    * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL ANALOG DEVICES BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, INTELLECTUAL PROPERTY RIGHTS, PROCUREMENT OF SUBSTITUTE GOODS OR
    * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
    * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
    * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    /***************************** Include Files **********************************/
    #include <stdlib.h>
    #include <stdio.h>
    #include <string.h>
    #include "common.h"
    #include "ad9528.h"
    #include "mykonos.h"
    #include "Mykonos_M3.h"
    #include "mykonos_gpio.h"
    #include "parameters.h"
    #include "no_os_util.h"
    #include "no_os_error.h"
    #include "no_os_delay.h"
    #include "xil_io.h"
    #include "xparameters.h"
    #ifdef ALTERA_PLATFORM
    #include "clk_altera_a10_fpll.h"
    #include "altera_adxcvr.h"
    #else
    #include "xil_cache.h"
    #include "clk_axi_clkgen.h"
    #include "axi_adxcvr.h"
    #endif
    #include "axi_jesd204_rx.h"
    #include "axi_jesd204_tx.h"
    #include "axi_dac_core.h"
    #include "axi_adc_core.h"
    #include "axi_dmac.h"
    #include "app_config.h"
    #ifdef IIO_SUPPORT
    #include "iio_axi_adc.h"
    #include "iio_axi_dac.h"
    #include "iio_app.h"
    #include "xilinx_uart.h"
    #endif // IIO_SUPPORT
    /************************ Variables Definitions *******************************/
    extern ad9528Device_t clockAD9528_;
    extern mykonosDevice_t mykDevice;
    #define DAC_BUFFER_SAMPLES 16777216             //1024                  //(1 * 1024 * 1024) // 250Mb
    #define ADC_BUFFER_SAMPLES 16777216             //1024                  //(1 * 1024 * 1024) // 250Mb
    #define SINE_LUT_SIZE 1024 // Size of the sine waveform lookup table
    //#define DAC_BUFFER_SAMPLES (250 * 1024 * 1024) // 250Mb
    //#define ADC_BUFFER_SAMPLES (50 * 1024 * 1024) // 250Mb
    #define ADC_CHANNELS 4
    #define DMA_EXAMPLE
    #if defined(DMA_EXAMPLE) || defined(IIO_SUPPORT)
    uint32_t dac_buffer[DAC_BUFFER_SAMPLES] __attribute__ ((aligned));
    uint16_t adc_buffer[ADC_BUFFER_SAMPLES * ADC_CHANNELS] __attribute__ ((
                aligned));
    #endif
    // AXI GPIO Variables for global_en and mod_type
    //u32* global_en = (u32*) XPAR_AXI_GPIO_EN_BASEADDR;
    //u32* mod_type = (u32*) XPAR_AXI_GPIO_MOD_TYPE_BASEADDR;
    //u32* global_rst = (u32*) XPAR_AXI_GPIO_RST_BASEADDR;
    * @brief main
    int main(void)
        ADI_ERR error;
        ad9528Device_t *clockAD9528_device = &clockAD9528_;
        mykonosErr_t mykError;
        const char *errorString;
        uint8_t pllLockStatus;
        uint8_t mcsStatus;
        uint8_t arm_major;
        uint8_t arm_minor;
        uint8_t arm_release;
        mykonosGpioErr_t mykGpioErr;
        uint32_t initCalMask = TX_BB_FILTER | ADC_TUNER | TIA_3DB_CORNER | DC_OFFSET |
                 TX_ATTENUATION_DELAY | RX_GAIN_DELAY | FLASH_CAL |
                 PATH_DELAY | TX_LO_LEAKAGE_INTERNAL | TX_QEC_INIT |
                 LOOPBACK_RX_LO_DELAY | LOOPBACK_RX_RX_QEC_INIT |
                 RX_LO_DELAY | RX_QEC_INIT ;
        uint8_t errorFlag = 0;
        uint8_t errorCode = 0;
        uint32_t initCalsCompleted;
        uint8_t framerStatus;
        uint8_t obsFramerStatus;
        uint8_t deframerStatus;
        uint32_t trackingCalMask = TRACK_ORX1_QEC | TRACK_ORX2_QEC | TRACK_RX1_QEC |
                     TRACK_RX2_QEC | TRACK_TX1_QEC | TRACK_TX2_QEC;
        int32_t status;
        int32_t ret;
        //sleep(2);
        // AXI GPIO Inputs:
        //*mod_type = 0x00000000;
        //*global_en = 0x00000000;
        struct altera_a10_fpll_init rx_device_clk_pll_init = {
            "rx_device_clk_pll",
            RX_A10_FPLL_BASEADDR,
            clockAD9528_device->outputSettings->outFrequency_Hz[1]
        struct altera_a10_fpll_init tx_device_clk_pll_init = {
            "tx_device_clk_pll",
            TX_A10_FPLL_BASEADDR,
        struct altera_a10_fpll_init rx_os_device_clk_pll_init = {
            "rx_os_device_clk_pll",
            RX_OS_A10_FPLL_BASEADDR,
        struct altera_a10_fpll *rx_device_clk_pll;
        struct altera_a10_fpll *tx_device_clk_pll;
        struct altera_a10_fpll *rx_os_device_clk_pll;
    #else
        struct axi_clkgen_init rx_clkgen_init = {
            "rx_clkgen",
            RX_CLKGEN_BASEADDR,
        //Gayathri
        struct axi_clkgen_init tx_clkgen_init = {
            "tx_clkgen",
            TX_CLKGEN_BASEADDR,
        struct axi_clkgen_init rx_os_clkgen_init = {
            "rx_os_clkgen",
            RX_OS_CLKGEN_BASEADDR,
        struct axi_clkgen *rx_clkgen;
        struct axi_clkgen *tx_clkgen;
        struct axi_clkgen *rx_os_clkgen;
    #endif
        //Gayathri
        uint32_t rx_lane_rate_khz = mykDevice.rx->rxProfile->iqRate_kHz *
                     mykDevice.rx->framer->M * (20 /
                             no_os_hweight8(mykDevice.rx->framer->serializerLanesEnabled));
        //printf("RX Lane Rate: %u kHz\n", rx_lane_rate_khz);
        uint32_t rx_div40_rate_hz = rx_lane_rate_khz * (1000 / 40);
        //printf("RX DIV40 Rate: %u Hz\n", rx_div40_rate_hz);
        uint32_t tx_lane_rate_khz = mykDevice.tx->txProfile->iqRate_kHz *
                     mykDevice.tx->deframer->M * (20 /
                             no_os_hweight8(mykDevice.tx->deframer->deserializerLanesEnabled));
        //printf("TX Lane Rate: %u kHz\n", tx_lane_rate_khz);
        uint32_t tx_div40_rate_hz = tx_lane_rate_khz * (1000 / 40);
        //printf("TX DIV40 Rate: %u Hz\n", tx_div40_rate_hz);
        uint32_t rx_os_lane_rate_khz = mykDevice.obsRx->orxProfile->iqRate_kHz *
                     mykDevice.obsRx->framer->M * (20 /
                             no_os_hweight8(mykDevice.obsRx->framer->serializerLanesEnabled));
        //printf("RX OS Lane Rate: %u kHz\n", rx_os_lane_rate_khz);
        uint32_t rx_os_div40_rate_hz = rx_os_lane_rate_khz * (1000 / 40);
        //printf("RX OS DIV40 Rate: %u Hz\n", rx_os_div40_rate_hz);
        struct jesd204_rx_init rx_jesd_init = {
            "rx_jesd",
            RX_JESD_BASEADDR,
            4,
            32,
            1,
            rx_div40_rate_hz / 1000,
            rx_lane_rate_khz
        struct jesd204_tx_init tx_jesd_init = {
            "tx_jesd",
            TX_JESD_BASEADDR,
            2,
            32,
            4,
            14,
            16,
            false,
            2,
            1,
            tx_div40_rate_hz / 1000,
            tx_lane_rate_khz
        struct jesd204_rx_init rx_os_jesd_init = {
            "rx_os_jesd",
            RX_OS_JESD_BASEADDR,
            2,
            32,
            1,
            rx_os_div40_rate_hz / 1000,
            rx_os_lane_rate_khz
        struct axi_jesd204_rx *rx_jesd;
        struct axi_jesd204_tx *tx_jesd;
        struct axi_jesd204_rx *rx_os_jesd;
        struct adxcvr_init rx_adxcvr_init = {
            "rx_adxcvr",
            RX_XCVR_BASEADDR,
            {RX_ADXCFG_0_BASEADDR, RX_ADXCFG_1_BASEADDR, 0, 0},
            0,
            rx_lane_rate_khz,
            mykDevice.clocks->deviceClock_kHz,
        struct adxcvr_init tx_adxcvr_init = {
            "tx_adxcvr",
            TX_XCVR_BASEADDR,
            {TX_ADXCFG_0_BASEADDR, TX_ADXCFG_1_BASEADDR, TX_ADXCFG_2_BASEADDR, TX_ADXCFG_3_BASEADDR},
            TX_PLL_BASEADDR,
            tx_lane_rate_khz,
        struct adxcvr_init rx_os_adxcvr_init = {
            "rx_os_adxcvr",
            RX_OS_XCVR_BASEADDR,
            {RX_OS_ADXCFG_0_BASEADDR, RX_OS_ADXCFG_1_BASEADDR, 0, 0},
            0,
            rx_os_lane_rate_khz,
    #else
            .name = "rx_adxcvr",
            .base = RX_XCVR_BASEADDR,
            .sys_clk_sel = ADXCVR_SYS_CLK_CPLL,
            .out_clk_sel = ADXCVR_REFCLK,
            .lpm_enable = 1,
            .lane_rate_khz = rx_lane_rate_khz,
            .ref_rate_khz = mykDevice.clocks->deviceClock_kHz,
            .name = "tx_adxcvr",
            .base = TX_XCVR_BASEADDR,
            .sys_clk_sel = ADXCVR_SYS_CLK_QPLL0,
            .lpm_enable = 0,
            .lane_rate_khz = tx_lane_rate_khz,
            .name = "rx_os_adxcvr",
            .base = RX_OS_XCVR_BASEADDR,
            .lpm_enable = 1,
            .lane_rate_khz = rx_os_lane_rate_khz,
    #endif
        struct adxcvr *rx_adxcvr;
        struct adxcvr *tx_adxcvr;
        struct adxcvr *rx_os_adxcvr;
            //TTR
        /*  struct axi_dac_channel {
                uint32_t dds_frequency_0; // in hz (1000*1000 for MHz)
                uint32_t dds_phase_0; // in milli(?) angles (90*1000 for 90 degrees = pi/2)
                int32_t dds_scale_0; // in micro units (1.0*1000*1000 is 1.0)
                uint32_t dds_frequency_1; // in hz (1000*1000 for MHz)
                uint32_t dds_phase_1; // in milli(?) angles (90*1000 for 90 degrees = pi/2)
                int32_t dds_scale_1; // in micro units (1.0*1000*1000 is 1.0)
                uint32_t dds_dual_tone; // if using single tone for this channel, set to 0x0
                uint32_t pat_data; // if using SED/debug that sort of thing
                enum axi_dac_data_sel sel; // set to one of the enumerated type above.
    struct axi_dac_channel ad9371_tx_channels[4] = {
                        10*1000*1000,   // dds_frequency_tone0
                        0,          // dds_phase_tone0
                        50*1000,        // dds_scale_tone0  1.0*1000*1000
                        0,              // dds_frequency_tone1
                        0,              // dds_phase_tone1
                        0,              // dds_scale_tone1
                        0,              // dds_dual_tone
                        0,              // pat_data
                        AXI_DAC_DATA_SEL_DMA        // sel
                        20*1000*1000,   // dds_frequency_tone0
                        0,              // dds_dual_tone
                        0,              // pat_data
                        30*1000*1000,   // dds_frequency_tone0
                        90000,          // dds_phase_tone0
                        1,              // dds_dual_tone
                        0,              // pat_data
                        40*1000*1000,   // dds_frequency_tone0
                        1,              // dds_dual_tone
                        0,              // pat_data
         /* struct axi_dac_channel ad9371_tx_channels[1] = {
                            0,              // dds_dual_tone
                            0,              // pat_data
        struct axi_dac_init tx_dac_init = {
            "tx_dac",
            TX_CORE_BASEADDR,
            4,
            &ad9371_tx_channels//NULL
        struct axi_dac *tx_dac;
        struct axi_adc_init rx_adc_init = {
            "rx_adc",
            RX_CORE_BASEADDR,
            4
        struct axi_adc *rx_adc;
        struct axi_adc_init rx_obs_adc_init = {
            "rx_obs_adc",
            RX_OS_CORE_BASEADDR,
            2
        struct axi_adc *rx_obs_adc;
        struct axi_dmac_init rx_dmac_init = {
            "rx_dmac",
            RX_DMA_BASEADDR,
            IRQ_DISABLED
        struct axi_dmac *rx_dmac;
        struct axi_dmac_init rx_obs_dmac_init = {
            "rx_obs_dmac",
            RX_OBS_DMA_BASEADDR,
            IRQ_DISABLED
        struct axi_dmac *rx_obs_dmac;
    #ifdef DMA_EXAMPLE
        struct axi_dmac_init tx_dmac_init = {
            "tx_dmac",
            TX_DMA_BASEADDR,
            IRQ_DISABLED
        struct axi_dmac *tx_dmac;
        extern const uint32_t sine_lut_iq[1024];
    #endif
        uint32_t i;
        /* Allocating memory for the errorString */
        errorString = NULL;
        printf("Please wait...\n");
    #ifdef XILINX_PLATFORM
        /* Enable the instruction cache. */
        Xil_ICacheEnable();
        Xil_DCacheEnable();
    #endif //XILINX_PLATFORM
        ret = platform_init();
        if (ret != 0) {
            printf("error: platform_init() failed\n");
            goto error_0;
        /***** System Clocks Initialization Initialization Sequence *****/
        /* Perform a hard reset on the AD9528 DUT */
        error = AD9528_resetDevice(clockAD9528_device);
        if (error != ADIERR_OK) {
            printf("AD9528_resetDevice() failed\n");
            error = ADIERR_FAILED;
            goto error_1;
        error = AD9528_initDeviceDataStruct(clockAD9528_device,
                         clockAD9528_device->pll1Settings->vcxo_Frequency_Hz,
                         clockAD9528_device->pll1Settings->refA_Frequency_Hz,
                         clockAD9528_device->outputSettings->outFrequency_Hz[1]);
            printf("AD9528_initDeviceDataStruct() failed\n");
            goto error_1;
        /* Initialize the AD9528 by writing all SPI registers */
        error = AD9528_initialize(clockAD9528_device);
            printf("WARNING: AD9528_initialize() issues. Possible cause: REF_CLK not connected.\n");
        /* Initialize A10 FPLLs */
        status = altera_a10_fpll_init(&rx_device_clk_pll,
                     &rx_device_clk_pll_init);
        if (status != 0) {
            printf("error: %s: altera_a10_fpll_init() failed\n",
             rx_device_clk_pll_init.name);
            goto error_1;
        status = altera_a10_fpll_init(&tx_device_clk_pll,
                     &tx_device_clk_pll_init);
        if (status != 0) {
             tx_device_clk_pll_init.name);
            goto error_2;
        status = altera_a10_fpll_init(&rx_os_device_clk_pll,
                     &rx_os_device_clk_pll_init);
        if (status != 0) {
             rx_os_device_clk_pll_init.name);
            goto error_3;
        altera_a10_fpll_disable(rx_device_clk_pll);
        status = altera_a10_fpll_set_rate(rx_device_clk_pll,
                         rx_div40_rate_hz);
        if (status != 0) {
            printf("error: %s: altera_a10_fpll_set_rate() failed\n",
             rx_device_clk_pll->name);
            goto error_4;
        altera_a10_fpll_enable(rx_device_clk_pll);
        altera_a10_fpll_disable(tx_device_clk_pll);
        status = altera_a10_fpll_set_rate(tx_device_clk_pll,
                         tx_div40_rate_hz);
        if (status != 0) {
             tx_device_clk_pll->name);
            goto error_4;
        altera_a10_fpll_enable(tx_device_clk_pll);
        altera_a10_fpll_disable(rx_os_device_clk_pll);
        status = altera_a10_fpll_set_rate(rx_os_device_clk_pll,
        if (status != 0) {
             rx_os_device_clk_pll->name);
            goto error_4;
        altera_a10_fpll_enable(rx_os_device_clk_pll);
    #else
        /* Initialize CLKGEN */
        status = axi_clkgen_init(&rx_clkgen, &rx_clkgen_init);
        if (status != 0) {
            printf("error: %s: axi_clkgen_init() failed\n", rx_clkgen_init.name);
            goto error_1;
        //Gayathri
        status = axi_clkgen_init(&tx_clkgen, &tx_clkgen_init);
        if (status != 0) {
            //Gayathri
            printf("error: %s: axi_clkgen_init() failed\n", tx_clkgen_init.name);
            goto error_2;
        status = axi_clkgen_init(&rx_os_clkgen, &rx_os_clkgen_init);
        if (status != 0) {
            printf("error: %s: axi_clkgen_set_rate() failed\n", rx_os_clkgen_init.name);
            goto error_3;
        status = axi_clkgen_set_rate(rx_clkgen, rx_div40_rate_hz);
        if (status != 0) {
            printf("error: %s: axi_clkgen_set_rate() failed\n", rx_clkgen->name);
            goto error_4;
        status = axi_clkgen_set_rate(tx_clkgen, tx_div40_rate_hz);
        if (status != 0) {
            printf("error: %s: axi_clkgen_set_rate() failed\n", tx_clkgen->name);
            goto error_4;
        status = axi_clkgen_set_rate(rx_os_clkgen, rx_os_div40_rate_hz);
        if (status != 0) {
            printf("error: %s: axi_clkgen_set_rate() failed\n", rx_os_clkgen->name);
            goto error_4;
    #endif
        /* Initialize JESDs */
        status = axi_jesd204_rx_init(&rx_jesd, &rx_jesd_init);
        if (status != 0) {
            printf("error: %s: axi_jesd204_rx_init() failed\n", rx_jesd_init.name);
            goto error_4;
        status = axi_jesd204_tx_init(&tx_jesd, &tx_jesd_init);
        if (status != 0) {
            printf("error: %s: axi_jesd204_tx_init() failed\n", tx_jesd_init.name);
            goto error_5;
        status = axi_jesd204_rx_init(&rx_os_jesd, &rx_os_jesd_init);
        if (status != 0) {
            goto error_6;
        /* Initialize ADXCVRs */
        status = adxcvr_init(&rx_adxcvr, &rx_adxcvr_init);
        //printf("adxcvr_init() returned %d\n", status);
        if (status != 0) {
            printf("error: %s: adxcvr_init() failed\n", rx_adxcvr_init.name);
            goto error_7;
        status = adxcvr_init(&tx_adxcvr, &tx_adxcvr_init);
        if (status != 0) {
            printf("error: %s: adxcvr_init() failed\n", tx_adxcvr_init.name);
            goto error_8;
        status = adxcvr_init(&rx_os_adxcvr, &rx_os_adxcvr_init);
        if (status != 0) {
            printf("error: %s: adxcvr_init() failed\n", rx_os_adxcvr_init.name);
            goto error_9;
        /***** Mykonos Initialization Sequence *****/
        /* Perform a hard reset on the MYKONOS DUT (Toggle RESETB pin on device) */
        if ((mykError = MYKONOS_resetDevice(&mykDevice)) != MYKONOS_ERR_OK) {
            errorString = getMykonosErrorMessage(mykError);
            goto error_11;
        if ((mykError = MYKONOS_initialize(&mykDevice)) != MYKONOS_ERR_OK) {
            goto error_11;
        /***** Mykonos CLKPLL Status Check *****/
        if ((mykError = MYKONOS_checkPllsLockStatus(&mykDevice,
                &pllLockStatus)) != MYKONOS_ERR_OK) {
            goto error_11;
        /***** Mykonos Perform MultiChip Sync *****/
        if ((mykError = MYKONOS_enableMultichipSync(&mykDevice, 1,
                &mcsStatus)) != MYKONOS_ERR_OK) {
            goto error_11;
        /* Minimum 3 SYSREF pulses from Clock Device has to be produced for MulticChip Sync */
        AD9528_requestSysref(clockAD9528_device, 1);
        no_os_mdelay(1);
        no_os_mdelay(1);
        no_os_mdelay(1);
        no_os_mdelay(1);
        /***** Mykonos Verify MultiChip Sync *****/
        if ((mykError = MYKONOS_enableMultichipSync(&mykDevice, 0,
            goto error_11;
        if ((mcsStatus & 0x0B) == 0x0B)
            printf("MCS successful\n");
        else
            printf("MCS failed\n");
        /***** Mykonos Load ARM file *****/
        if (pllLockStatus & 0x01) {
            printf("CLKPLL locked\n");
            if ((mykError = MYKONOS_initArm(&mykDevice)) != MYKONOS_ERR_OK) {
                goto error_11;
            if ((mykError = MYKONOS_loadArmFromBinary(&mykDevice,
                    &firmware_Mykonos_M3_bin[0], firmware_Mykonos_M3_bin_len)) != MYKONOS_ERR_OK) {
                goto error_11;
        } else {
            printf("CLKPLL not locked (0x%x)\n", pllLockStatus);
            goto error_2;
        /* Read back the version of the ARM binary loaded into the Mykonos ARM memory */
        if ((mykError = MYKONOS_getArmVersion(&mykDevice, &arm_major, &arm_minor,
                         &arm_release, NULL)) == MYKONOS_ERR_OK)
            printf("AD9371 ARM version %d.%d.%d\n", arm_major, arm_minor, arm_release);
        /***** Mykonos Set RF PLL Frequencies *****/
            if ((mykError = MYKONOS_setRfPllFrequency(&mykDevice, RX_PLL,
                    mykDevice.rx->rxPllLoFrequency_Hz)) != MYKONOS_ERR_OK) {
                goto error_11;
                    goto error_11;
    //  if ((mykError = MYKONOS_setRfPllFrequency(&mykDevice, TX_PLL,
    //              mykDevice.tx->txPllLoFrequency_Hz)) != MYKONOS_ERR_OK) {
    //          errorString = getMykonosErrorMessage(mykError);
    //          goto error_11;
    //  if ((mykError = MYKONOS_checkPllsLockStatus(&mykDevice,
    //                  &pllLockStatus)) != MYKONOS_ERR_OK) {
    //                  goto error_11;
    //  if ((mykError = MYKONOS_setRfPllFrequency(&mykDevice, SNIFFER_PLL,
    //              mykDevice.obsRx->snifferPllLoFrequency_Hz)) != MYKONOS_ERR_OK) {
    //          goto error_11;
        /* Wait 200ms for PLLs to lock */
        no_os_mdelay(200);
    //      goto error_11;
    //  if ((pllLockStatus & 0x0F) == 0x0F)
    //      printf("PLLs locked\n");
    //  else {
    //      printf("PLLs not locked (0x%x)\n", pllLockStatus);
    //      error = ADIERR_FAILED;
    //      goto error_2;
        /***** Mykonos Set GPIOs *****/
        if ((mykGpioErr = MYKONOS_setRx1GainCtrlPin(&mykDevice, 0, 0, 0, 0,
                 0)) != MYKONOS_ERR_GPIO_OK) {
            errorString = getGpioMykonosErrorMessage(mykGpioErr);
            goto error_11;
        if ((mykGpioErr = MYKONOS_setupGpio(&mykDevice)) != MYKONOS_ERR_GPIO_OK) {
            goto error_11;
        /***** Mykonos Set manual gains values *****/
        if ((mykError = MYKONOS_setRx1ManualGain(&mykDevice, 255)) != MYKONOS_ERR_OK) {
            goto error_11;
        /***** Mykonos ARM Initialization Calibrations *****/
    //  printf("ARM Intialization Calibrations\n");
        if ((mykError = MYKONOS_runInitCals(&mykDevice,
                         (initCalMask & ~TX_LO_LEAKAGE_EXTERNAL))) != MYKONOS_ERR_OK) {
            goto error_11;
    //  if ((mykError = MYKONOS_waitInitCals(&mykDevice, 60000, &errorFlag,
    //                   &errorCode)) != MYKONOS_ERR_OK) {
    //      goto error_11;
        if ((errorFlag != 0) || (errorCode != 0)) {
            /*** < Info: abort init cals > ***/
            if ((mykError = MYKONOS_abortInitCals(&mykDevice,
                             &initCalsCompleted)) != MYKONOS_ERR_OK) {
                goto error_11;
            if (initCalsCompleted)
                printf("Completed calibrations: %x\n", (unsigned int)initCalsCompleted);
        } else
            printf("Calibrations completed successfully\n");
        /***** Mykonos ARM Initialization External LOL Calibrations with PA *****/
        /* Please ensure PA is enabled operational at this time */
    //  if (initCalMask & TX_LO_LEAKAGE_EXTERNAL) {
    //      if ((mykError = MYKONOS_runInitCals(&mykDevice,
    //                       TX_LO_LEAKAGE_EXTERNAL)) != MYKONOS_ERR_OK) {
    //          goto error_11;
    //          goto error_11;
    //      if ((errorFlag != 0) || (errorCode != 0)) {
    //          /*** < Info: abort init cals > ***/
    //          if ((mykError = MYKONOS_abortInitCals(&mykDevice,
    //                           &initCalsCompleted)) != MYKONOS_ERR_OK) {
    //              goto error_11;
    //      } else
    //          printf("External LOL Calibrations completed successfully\n");
        /***** SYSTEM JESD bring up procedure *****/
        if ((mykError = MYKONOS_enableSysrefToRxFramer(&mykDevice,
                1)) != MYKONOS_ERR_OK) {
            goto error_11;
        /*** < Info: Mykonos is waiting for sysref in order to start
         * transmitting CGS from the RxFramer> ***/
    //  if ((mykError = MYKONOS_enableSysrefToObsRxFramer(&mykDevice,
    //          1)) != MYKONOS_ERR_OK) {
    //      goto error_11;
         * transmitting CGS from the ObsRxFramer> ***/
        if ((mykError = MYKONOS_enableSysrefToDeframer(&mykDevice,
                0)) != MYKONOS_ERR_OK) {
            goto error_11;
        if ((mykError = MYKONOS_resetDeframer(&mykDevice)) != MYKONOS_ERR_OK) {
            goto error_11;
    #ifndef ALTERA_PLATFORM
        status = adxcvr_clk_enable(tx_adxcvr);
        if (status != 0) {
            printf("error: %s: adxcvr_clk_enable() failed\n", tx_adxcvr->name);
            goto error_10;
    #endif
        axi_jesd204_tx_lane_clk_enable(tx_jesd);
            goto error_11;
        /***** Enable SYSREF to Mykonos and BBIC *****/
        /* Request a SYSREF from the AD9528 */
        no_os_mdelay(1);
        /*** < Info: Mykonos is actively transmitting CGS from the RxFramer> ***/
        /*** < Info: Mykonos is actively transmitting CGS from the ObsRxFramer> ***/
        status = adxcvr_clk_enable(rx_adxcvr);
        if (status != 0) {
            printf("error: %s: adxcvr_clk_enable() failed\n", rx_adxcvr->name);
            goto error_10;
    #endif
        axi_jesd204_rx_lane_clk_enable(rx_jesd);
        status = adxcvr_clk_enable(rx_os_adxcvr);
        if (status != 0) {
            printf("error: %s: adxcvr_clk_enable() failed\n", rx_os_adxcvr->name);
            goto error_10;
    #endif
        axi_jesd204_rx_lane_clk_enable(rx_os_jesd);
        /* Request two SYSREFs from the AD9528 */
        no_os_mdelay(1);
        no_os_mdelay(5);
        /***** Check Mykonos Framer Status *****/
        if ((mykError = MYKONOS_readRxFramerStatus(&mykDevice,
                &framerStatus)) != MYKONOS_ERR_OK) {
            goto error_11;
        } else if (framerStatus != 0x3E)
            printf("RxFramerStatus = 0x%x\n", framerStatus);
    //  if ((mykError = MYKONOS_readOrxFramerStatus(&mykDevice,
    //          &obsFramerStatus)) != MYKONOS_ERR_OK) {
    //      goto error_11;
    //  } else if (obsFramerStatus != 0x3E)
    //      printf("OrxFramerStatus = 0x%x\n", obsFramerStatus);
        /***** Check Mykonos Deframer Status *****/
        if ((mykError = MYKONOS_readDeframerStatus(&mykDevice,
                &deframerStatus)) != MYKONOS_ERR_OK) {
            goto error_11;
        } else if (deframerStatus != 0x28)
            printf("DeframerStatus = 0x%x\n", deframerStatus);
        /***** Mykonos enable tracking calibrations *****/
    //  if ((mykError = MYKONOS_enableTrackingCals(&mykDevice,trackingCalMask)) != MYKONOS_ERR_OK) {
    //      goto error_11;
        /*** < Info: Allow Rx1/2 QEC tracking and Tx1/2 QEC tracking to run when in the radioOn state
         * Tx calibrations will only run if radioOn and the obsRx path is set to OBS_INTERNAL_CALS > ***/
        /*** < Info: Function to turn radio on, Enables transmitters and receivers
         * that were setup during MYKONOS_initialize() > ***/
        if ((mykError = MYKONOS_radioOn(&mykDevice)) != MYKONOS_ERR_OK) {
        goto error_11;
    //  /*** < Info: Allow TxQEC to run when User: is not actively using ORx receive path > ***/
    //  if ((mykError = MYKONOS_setObsRxPathSource(&mykDevice,
    //          OBS_RXOFF)) != MYKONOS_ERR_OK) {
    //      goto error_11;
    //          OBS_INTERNALCALS)) != MYKONOS_ERR_OK) {
    //      goto error_11;
        axi_jesd204_rx_watchdog(rx_jesd);
        axi_jesd204_rx_watchdog(rx_os_jesd);
        no_os_mdelay(1000);
        /* Print JESD status */
        axi_jesd204_rx_status_read(rx_jesd);
        for (i = 0; i < rx_jesd->num_lanes; i++)
            axi_jesd204_rx_laneinfo_read(rx_jesd, i);
        axi_jesd204_tx_status_read(tx_jesd);
        axi_jesd204_rx_status_read(rx_os_jesd);
        for (i = 0; i < rx_os_jesd->num_lanes; i++)
            axi_jesd204_rx_laneinfo_read(rx_os_jesd, i);
        /* Initialize the DAC DDS */
        axi_dac_init(&tx_dac, &tx_dac_init);
        /* Initialize the ADC core */
        axi_adc_init(&rx_adc, &rx_adc_init);
    //          OBS_RX1_SNIFFERLO)) != MYKONOS_ERR_OK) {
    //      goto error_11;
        axi_adc_init(&rx_obs_adc, &rx_obs_adc_init);
    #ifdef DMA_EXAMPLE
        // AXI GPIO global_en:
        //*global_en = 0xFFFFFFFF;
        //*global_rst = 0xFFFFFFFF;
        //sleep(3);
        //*global_rst = 0x00000000;
        axi_dac_load_custom_data(tx_dac, sine_lut_iq, NO_OS_ARRAY_SIZE(sine_lut_iq), (uintptr_t)dac_buffer);
        //memset(dac_buffer, 0, sizeof(dac_buffer));
        Xil_DCacheFlush();
    #endif
        axi_dmac_init(&tx_dmac, &tx_dmac_init);
        struct axi_dma_transfer transfer = {
            // Number of bytes to write/read
            //.size = 16777216,//sizeof(sine_lut_iq),
            .size = sizeof(sine_lut_iq),
            // Transfer done flag
            .transfer_done = 0,
            // Signal transfer mode
            //.cyclic = NO,
            .cyclic = CYCLIC,
            // Address of data source
            .src_addr = (uintptr_t)dac_buffer,
            // Address of data destination
            .dest_addr = 0
        axi_dmac_transfer_start(tx_dmac, &transfer);
        /* Flush cache data. */
        Xil_DCacheInvalidateRange((uintptr_t)dac_buffer, sizeof(sine_lut_iq));
        no_os_mdelay(1000);
        /* Initialize the DMAC and transfer 16384 samples from ADC to MEM */
        axi_dmac_init(&rx_dmac, &rx_dmac_init);
        axi_dmac_init(&rx_obs_dmac, &rx_obs_dmac_init);
        struct axi_dma_transfer read_transfer = {
            //.size = 16777216,//sizeof(adc_buffer),
            .transfer_done = 0,
            //.cyclic = NO,
            .cyclic = CYCLIC,
            .src_addr = 0,
            .dest_addr = (uintptr_t)adc_buffer
        xil_printf("before axi_dmac_transfer\n");
        axi_dmac_transfer_start(rx_dmac, &read_transfer);
        xil_printf("after axi_dmac_transfer\n");
        /* Wait until transfer finishes */
        status = axi_dmac_transfer_wait_completion(rx_dmac, 500);
        if(status)
            return status;
        Xil_DCacheInvalidateRange((uintptr_t)adc_buffer, sizeof(adc_buffer));
    #endif
        printf("DMA_EXAMPLE: address=%#lx samples=%lu channels=%u bits=%lu\n",
         (uintptr_t)adc_buffer, NO_OS_ARRAY_SIZE(adc_buffer), rx_adc_init.num_channels,
         8 * sizeof(adc_buffer[0]));
    #endif
    #ifdef IIO_SUPPORT
         * Transmit DMA initial configuration.
            "tx_dmac",
            TX_DMA_BASEADDR,
            IRQ_DISABLED
         * Pointer to transmit DMA instance.
         * iio application configurations.
        struct iio_init_param iio_init_par;
         * UART init params
        struct xil_uart_init_param platform_uart_init_par = {
    #ifdef XPAR_XUARTLITE_NUM_INSTANCES
            .type = UART_PL,
    #else
            .type = UART_PS,
            .irq_id = UART_IRQ_ID
    #endif
        struct no_os_uart_init_param iio_uart_ip = {
            .device_id = UART_DEVICE_ID,
            .irq_id = UART_IRQ_ID,
            .baud_rate = UART_BAUDRATE,
            .size = NO_OS_UART_CS_8,
            .parity = NO_OS_UART_PAR_NO,
            .stop = NO_OS_UART_STOP_1_BIT,
            .extra = &platform_uart_init_par,
            .platform_ops = &xil_uart_ops
         * IIO application descriptor
        struct iio_app_desc *app;
         * IIO application initialization parameters
        struct iio_app_init_param app_init_param = { 0 };
         * iio axi adc configurations.
        struct iio_axi_adc_init_param iio_axi_adc_init_par;
         * iio axi adc configurations, for observation chain
        struct iio_axi_adc_init_param iio_axi_adc_obs_init_par;
         * iio axi dac configurations.
        struct iio_axi_dac_init_param iio_axi_dac_init_par;
         * iio application instance descriptor.
        struct iio_desc *iio_app_desc;
         * iio instance descriptor.
        struct iio_axi_adc_desc *iio_axi_adc_desc;
         * iio instance descriptor, for observation chain
        struct iio_axi_adc_desc *iio_axi_adc_obs_desc;
        struct iio_axi_dac_desc *iio_axi_dac_desc;
         * iio device instance descriptor.
        struct iio_device *adc_dev_desc, *dac_dev_desc;
        status = axi_dmac_init(&tx_dmac, &tx_dmac_init);
        if(status < 0)
            return status;
        iio_axi_adc_init_par = (struct iio_axi_adc_init_param) {
            .rx_adc = rx_adc,
            .rx_dmac = rx_dmac,
    #ifndef PLATFORM_MB
            .dcache_invalidate_range = (void (*)(uint32_t,
                             uint32_t))Xil_DCacheInvalidateRange,
    #endif
        status = iio_axi_adc_init(&iio_axi_adc_desc, &iio_axi_adc_init_par);
        if(status < 0)
            return status;
        iio_axi_adc_obs_init_par = (struct iio_axi_adc_init_param) {
            .rx_adc = rx_obs_adc,
            .rx_dmac = rx_obs_dmac,
    #ifndef PLATFORM_MB
    #endif
        status = iio_axi_adc_init(&iio_axi_adc_obs_desc,
                     &iio_axi_adc_obs_init_par);
        if(status < 0)
            return status;
        struct iio_data_buffer read_buff = {
            .buff = (void *)adc_buffer,
            .size = sizeof(adc_buffer),
        iio_axi_adc_get_dev_descriptor(iio_axi_adc_desc, &adc_dev_desc);
        if (status < 0)
            return status;
        iio_axi_dac_init_par = (struct iio_axi_dac_init_param) {
            .tx_dac = tx_dac,
            .tx_dmac = tx_dmac,
    #ifndef PLATFORM_MB
            .dcache_flush_range = (void (*)(uint32_t, uint32_t))Xil_DCacheFlushRange,
    #endif
        status = iio_axi_dac_init(&iio_axi_dac_desc, &iio_axi_dac_init_par);
        if(status < 0)
            return status;
        struct iio_data_buffer write_buff = {
            .buff = (void *)dac_buffer,
            .size = sizeof(dac_buffer),
        iio_axi_dac_get_dev_descriptor(iio_axi_dac_desc, &dac_dev_desc);
        struct iio_app_device devices[] = {
            IIO_APP_DEVICE("cf-ad9371-lpc", iio_axi_adc_desc, adc_dev_desc, &read_buff, NULL, NULL),
            IIO_APP_DEVICE("cf-ad9371-dds-core-lpc", iio_axi_dac_desc, dac_dev_desc, NULL, &write_buff, NULL)
        app_init_param.devices = devices;
        app_init_param.nb_devices = NO_OS_ARRAY_SIZE(devices);
        app_init_param.uart_init_params = iio_uart_ip;
        status = iio_app_init(&app, app_init_param);
        if (status)
            return status;
        return iio_app_run(app);
        printf("Done\n");
        /* Disable the instruction cache. */
        Xil_ICacheDisable();
        /* Disable the data cache. */
        Xil_DCacheDisable();
        return 0;
    error_11:
        printf("%s", errorString);
    error_10:
    #endif
        adxcvr_remove(rx_os_adxcvr);
    error_9:
        adxcvr_remove(tx_adxcvr);
    error_8:
        adxcvr_remove(rx_adxcvr);
    error_7:
        axi_jesd204_rx_remove(rx_os_jesd);
    error_6:
        axi_jesd204_tx_remove(tx_jesd);
    error_5:
        axi_jesd204_rx_remove(rx_jesd);
    error_4:
        altera_a10_fpll_remove(rx_os_device_clk_pll);
    #else
        axi_clkgen_remove(rx_os_clkgen);
    #endif
    error_3:
        altera_a10_fpll_remove(tx_device_clk_pll);
    #else
        axi_clkgen_remove(tx_clkgen);
    #endif
    error_2:
        altera_a10_fpll_remove(rx_device_clk_pll);
    #else
        axi_clkgen_remove(rx_clkgen);
    #endif
    error_1:
        platform_remove();
    error_0:
    	return -1;
    On my custom AD9371 board, when I run only the RX code, I encounter the error: 'ARM command to move to RadioOn state failed.' Since the RadioOn function enables both the transmitter and the receiver, I cannot be certain that the RX path is functioning correctly without successfully entering the RadioOn state.
    Can I skip the RadioOn function and still run the rest of the RX path code?
  • Can you try disabling the Tx/ORX in the Mykonos profile settings and see if you are still facing issue during radioOn()?
