I am using ADRV9371 EVALUATION BOARD on custom ULTRASCALE (ZCU11EG) BOARD.
I am getting following error
Clock PLL Charge Pump Cal event timed out in MYKONOS_waitForEvent()
how to solve this issue?
AD9371
Recommended for New Designs
The AD9371 is a highly integrated, wideband RF transceiver
offering dual channel transmitters and receivers, integrated synthesizers, and digital signal...
Datasheet
AD9371 on Analog.com
vanitha - Moved from Microcontroller no-OS Drivers to Design Support AD9371/AD9375. Post date updated from Friday, January 31, 2025 1:01 PM UTC to Monday, February 17, 2025 4:20 PM UTC to reflect the move.
Moving to AD9371 forum
What is the device clock, and the profile used?
This issue might be related to clock.
Can you please check if the AD9371 PLL's are locked and device clock is present, locked as per the exact set frequency.
