VCK190 and AD-9084 bring up, testing and validation for the reference design
Product Number: AD9084
Software Version: Kuiper Linux (arm64)
Need Guidance on AD9084 + VCK190 Sample Design Validation
Hi everyone,
I have followed the attached reference design documentation to interface the VCK190 FPGA with the AD9084 daughter card. The system boots successfully, and the AD9084 card is detected correctly. Based on the boot logs, all relevant PLLs appear to be locking properly, and the PLL status LEDs on the board are illuminated as expected.
However, when I probe the DAC outputs using an oscilloscope, I do not observe any output signal.
At the moment, I only have the prebuilt image files that came with the reference design and do not have access to the source code. Because of this, I am unsure how to:
  • Program or configure the DAC channels
  • Configure the NCOs
  • Verify PLL configuration
  • Configure and test the ADCs
  • Perform SYSREF alignment
  • Validate JESD204 link synchronization and clock synchronization
  • Generate a known test tone or waveform at the DAC output
Could anyone please suggest:
  1. How to validate that the complete setup is functioning correctly?
  2. Whether there are any Linux utilities, drivers, IIO tools, or test applications available for exercising the AD9084 in this reference design?
  3. How to generate a test signal on the DAC outputs to confirm proper operation?
  4. Where I can obtain the corresponding source code or reference software for this design?
  5. Any recommended debug steps to verify JESD204 link status, SYSREF alignment, clocking, and data path functionality?
Any guidance, documentation links, example projects or debugging recommendations would be greatly appreciated.
Thank you!
Reference Design Link (ADI Developer) : analogdevicesinc.github.io/system-level/solutions/reference-designs/ad9084_ebz/quickstart/versal/
ion#: 0x3, Size: 4599264 Bytes
[1633.680]---Loading Partition#: 0x4, Id: 0x5
[1844.482] 206.748 ms for Partition#: 0x4, Size: 750512 Bytes
[1847.080]+++Loading Image#: 0x3, Name: fpd, Id: 0x0420C003
[1852.319]---Loading Partition#: 0x5, Id: 0x8
[1860.678] 4.307 ms for Partition#: 0x5, Size: 4544 Bytes
[1863.203]+++Loading Image#: 0x4, Name: apu_subsystem, Id: 0x1C000000
[1869.030]---Loading Partition#: 0x6, Id: 0x0
[1886.427] 13.344 ms for Partition#: 0x6, Size: 51136 Bytes
[1888.840]---Loading Partition#: 0x7, Id: 0x0
[1907.403] 14.513 ms for Partition#: 0x7, Size: 67632 Bytes
[1909.817]---Loading Partition#: 0x8, Id: 0x0
[2160.870] 247.000 ms for Partition#: 0x8, Size: 1201568 Bytes
[2163.590]***********Boot PDI Load: Done***********
[2168.109]299.022 ms: ROM Time
[2170.854]Total PLM Boot Time
INFO:    BL31: Early console setup
NOTICE:  TF-A running on SILICON 0
INFO:    BL31: GET_HANDOFF_PARAMS call success=0
INFO:    BL31: PLM to TF-A handover success 0
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v2.10.0	(debug):xlnx_rebase_v2.10_2024.1-27-g14cea4616-dirty
NOTICE:  BL31: Built : 04:42:28, Sep 19 2024
INFO:    GICv3 with legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 191
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a72: CPU workaround for erratum 859971 was applied
INFO:    BL31: cortex_a72: CPU workaround for erratum 1319367 was applied
INFO:    BL31: cortex_a72: CPU workaround for CVE 2017_5715 was applied
INFO:    BL31: cortex_a72: CPU workaround for CVE 2018_3639 was applied
INFO:    BL31: cortex_a72: CPU workaround for CVE 2022_23960 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x8000000
INFO:    SPSR = 0x3c9
U-Boot 2024.01 (Oct 24 2024 - 10:42:51 +0000)
CPU:   Versal
Silicon: v2
Chip:  v2
Model: Xilinx Versal vck190 Eval board revA
DRAM:  2 GiB (effective 16 GiB)
EL Level:	EL2
Core:  38 devices, 21 uclasses, devicetree: board
MMC:   mmc@f1050000: 0
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Net:
ZYNQ GEM: ff0c0000, mdio bus ff0c0000, phyaddr 1, interface rgmii-id
Warning: ethernet@ff0c0000 (eth0) using random MAC address - e6:30:17:dd:8e:c4
eth0: ethernet@ff0c0000Get shared mii bus on ethernet@ff0d0000
ZYNQ GEM: ff0d0000, mdio bus ff0c0000, phyaddr 2, interface rgmii-id
, eth1: ethernet@ff0d0000
Hit any key to stop autoboot:  5  4  3  2  1  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
208 bytes read in 11 ms (17.6 KiB/s)
## Executing script at 20000000
Unknown command 'Load' - try 'help'
41374208 bytes read in 5187 ms (7.6 MiB/s)
36840 bytes read in 21 ms (1.7 MiB/s)
## Flattened Device Tree blob at 00001000
   Booting using the fdt blob at 0x001000
Working FDT set to 1000
   Loading Device Tree to 0000000079e8a000, end 0000000079e95fe7 ... OK
Working FDT set to 79e8a000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 6.12.77-g4b2e305bc496 (root@b7fad4fd30e3) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Wed Jul 15 15:56:08 UTC 2026
[    0.000000] Machine model: Analog Devices AD9084-FMCA-EBZ (Rev. B0) @Xilinx/vck190
[    0.000000] earlycon: pl11 at MMIO32 0x00000000ff000000 (options '115200n8')
[    0.000000] printk: legacy bootconsole [pl11] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000097fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000]   node   0: [mem 0x0000000800000000-0x000000097fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000097fffffff]
[    0.000000] cma: Reserved 256 MiB at 0x0000000069e00000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 21 pages/cpu s45912 r8192 d31912 u86016
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyAMA0 earlycon=pl011,mmio32,0xFF000000,115200n8 clk_ignore_unused root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x000000007c000000-0x0000000080000000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 160 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000f9080000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x1ffffffffffffff max_cycles: 0x1710239320, max_idle_ns: 440795206806 ns
[    0.000000] sched_clock: 57 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008299] Console: colour dummy device 80x25
[    0.012795] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399999)
[    0.023323] pid_max: default: 32768 minimum: 301
[    0.028042] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.035692] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.044143] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.050815] rcu: Hierarchical SRCU implementation.
[    0.055646] rcu: 	Max phase no-delay instances is 1000.
[    0.061060] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.069329] EFI services will not be available.
[    0.073990] smp: Bringing up secondary CPUs ...
[    0.078857] Detected PIPT I-cache on CPU1
[    0.078891] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
[    0.078911] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.078971] smp: Brought up 1 node, 2 CPUs
[    0.100641] SMP: Total of 2 processors activated.
[    0.105379] CPU: All CPU(s) started at EL2
[    0.109505] CPU features: detected: 32-bit EL0 Support
[    0.114681] CPU features: detected: CRC32 instructions
[    0.119884] alternatives: applying system-wide alternatives
[    0.125969] Memory: 7855124K/8388608K available (19520K kernel code, 2004K rwdata, 15068K rodata, 3648K init, 735K bss, 267716K reserved, 262144K cma-reserved)
[    0.140762] devtmpfs: initialized
[    0.147876] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.157722] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.166241] 22464 pages in range for non-PLT usage
[    0.166249] 513984 pages in range for PLT usage
[    0.171449] DMI not present or invalid.
[    0.180140] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.186509] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.193813] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.201877] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.209973] audit: initializing netlink subsys (disabled)
[    0.215503] audit: type=2000 audit(0.132:1): state=initialized audit_enabled=0 res=1
[    0.223331] cpuidle: using governor menu
[    0.227340] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.234207] ASID allocator initialised with 65536 entries
[    0.239738] Serial: AMBA PL011 UART driver
[    0.246169] /axi/interrupt-controller@f9000000: Fixed dependency cycle(s) with /axi/interrupt-controller@f9000000
[    0.261010] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.267864] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.274182] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.281023] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.287341] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.294181] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.300497] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.307338] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.381705] raid6: neonx8   gen()  4151 MB/s
[    0.454056] raid6: neonx4   gen()  4050 MB/s
[    0.526399] raid6: neonx2   gen()  3375 MB/s
[    0.598749] raid6: neonx1   gen()  2441 MB/s
[    0.671093] raid6: int64x8  gen()  2334 MB/s
[    0.743446] raid6: int64x4  gen()  2285 MB/s
[    0.815798] raid6: int64x2  gen()  2222 MB/s
[    0.888144] raid6: int64x1  gen()  1712 MB/s
[    0.892444] raid6: using algorithm neonx8 gen() 4151 MB/s
[    0.965923] raid6: .... xor() 3028 MB/s, rmw enabled
[    0.970926] raid6: using neon recovery algorithm
[    0.975838] iommu: Default domain type: Translated
[    0.980669] iommu: DMA domain TLB invalidation policy: strict mode
[    0.987127] SCSI subsystem initialized
[    0.991017] usbcore: registered new interface driver usbfs
[    0.996566] usbcore: registered new interface driver hub
[    1.001936] usbcore: registered new device driver usb
[    1.007152] mc: Linux media interface: v0.10
[    1.011471] videodev: Linux video capture interface: v2.00
[    1.017028] pps_core: LinuxPPS API ver. 1 registered
[    1.022033] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.031244] PTP clock support registered
[    1.035208] EDAC MC: Ver: 3.0.0
[    1.038671] jesd204: created con: id=0, topo=0, link=4, /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.050709] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.062733] jesd204: created con: id=2, topo=0, link=0, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-tx@a4b90000
[    1.073969] jesd204: created con: id=3, topo=0, link=4, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-rx@a4a90000
[    1.085208] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@a4b90000 <-> /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000
[    1.097405] jesd204: created con: id=5, topo=0, link=4, /fpga-axi@0/axi-jesd204-rx@a4a90000 <-> /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000
[    1.109607] jesd204: created con: id=6, topo=0, link=4, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.120143] jesd204: created con: id=7, topo=0, link=0, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.130681] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:0] transition uninitialized -> initialized
[    1.140598] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:2] transition uninitialized -> initialized
[    1.150514] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:4] transition uninitialized -> initialized
[    1.160430] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:6] transition uninitialized -> initialized
[    1.170345] jesd204: found 7 devices and 1 topologies
[    1.175471] FPGA manager framework
[    1.178915] Advanced Linux Sound Architecture Driver Initialized.
[    1.185386] Bluetooth: Core ver 2.22
[    1.189002] NET: Registered PF_BLUETOOTH protocol family
[    1.194357] Bluetooth: HCI device and connection manager initialized
[    1.200765] Bluetooth: HCI socket layer initialized
[    1.205680] Bluetooth: L2CAP socket layer initialized
[    1.210777] Bluetooth: SCO socket layer initialized
[    1.216084] clocksource: Switched to clocksource arch_sys_counter
[    1.222345] VFS: Disk quotas dquot_6.6.0
[    1.226314] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.237448] NET: Registered PF_INET protocol family
[    1.242566] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.253749] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.262394] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.270206] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.278482] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    1.287030] TCP: Hash tables configured (established 65536 bind 65536)
[    1.293695] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.300665] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.308131] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.314072] RPC: Registered named UNIX socket transport module.
[    1.320048] RPC: Registered udp transport module.
[    1.324789] RPC: Registered tcp transport module.
[    1.329528] RPC: Registered tcp-with-tls transport module.
[    1.335057] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.341995] PCI: CLS 0 bytes, default 64
[    1.346502] Initialise system trusted keyrings
[    1.351105] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[    1.357945] NFS: Registering the id_resolver key type
[    1.363055] Key type id_resolver registered
[    1.367277] Key type id_legacy registered
[    1.371327] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.378088] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.385557] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.392716] fuse: init (API version 7.41)
[    1.428056] NET: Registered PF_ALG protocol family
[    1.432899] xor: measuring software checksum speed
[    1.438217]    8regs           :  6710 MB/sec
[    1.443056]    32regs          :  7287 MB/sec
[    1.448021]    arm64_neon      :  5710 MB/sec
[    1.452412] xor: using function: 32regs (7287 MB/sec)
[    1.457504] Key type asymmetric registered
[    1.461637] Asymmetric key parser 'x509' registered
[    1.466582] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.474047] io scheduler mq-deadline registered
[    1.478616] io scheduler kyber registered
[    1.482666] io scheduler bfq registered
[    1.489141] ledtrig-cpu: registered to indicate activity on CPUs
[    1.520088] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.527413] Serial: AMBA driver
[    1.534315] brd: module loaded
[    1.539504] loop: module loaded
[    1.543339] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.552707] tun: Universal TUN/TAP device driver, 1.6
[    1.557922] CAN device driver interface
[    1.562164] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[    1.568576] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[    1.574980] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[    1.581389] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[    1.587794] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[    1.594199] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[    1.600603] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[    1.607005] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[    1.613408] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[    1.619812] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[    1.626216] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[    1.632707] usbcore: registered new interface driver asix
[    1.638168] usbcore: registered new interface driver ax88179_178a
[    1.644334] usbcore: registered new interface driver cdc_ether
[    1.650233] usbcore: registered new interface driver net1080
[    1.655955] usbcore: registered new interface driver cdc_subset
[    1.661944] usbcore: registered new interface driver zaurus
[    1.667580] usbcore: registered new interface driver cdc_ncm
[    1.673307] usbcore: registered new interface driver r8153_ecm
[    1.679732] usbcore: registered new interface driver uas
[    1.685112] usbcore: registered new interface driver usb-storage
[    1.691217] usbcore: registered new interface driver usbserial_generic
[    1.697810] usbserial: USB Serial support registered for generic
[    1.703879] usbcore: registered new interface driver ftdi_sio
[    1.709683] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.717067] usbcore: registered new interface driver upd78f0730
[    1.723043] usbserial: USB Serial support registered for upd78f0730
[    1.729978] i2c_dev: i2c /dev entries driver
[    1.735192] usbcore: registered new interface driver uvcvideo
[    1.741702] Bluetooth: HCI UART driver ver 2.3
[    1.746188] Bluetooth: HCI UART protocol H4 registered
[    1.751366] Bluetooth: HCI UART protocol BCSP registered
[    1.756732] Bluetooth: HCI UART protocol LL registered
[    1.761911] Bluetooth: HCI UART protocol ATH3K registered
[    1.767360] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.773705] Bluetooth: HCI UART protocol Intel registered
[    1.779161] Bluetooth: HCI UART protocol QCA registered
[    1.784449] usbcore: registered new interface driver bcm203x
[    1.790173] usbcore: registered new interface driver bpa10x
[    1.795809] usbcore: registered new interface driver bfusb
[    1.801356] usbcore: registered new interface driver btusb
[    1.806916] usbcore: registered new interface driver ath3k
[    1.812679] sdhci: Secure Digital Host Controller Interface driver
[    1.818917] sdhci: Copyright(c) Pierre Ossman
[    1.823306] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.829139] SMCCC: SOC_ID: ID = jep106:0049:0000 Revision = 0x00000000
[    1.835824] zynqmp_firmware_probe Platform Management API v1.0
[    1.841747] zynqmp_firmware_probe Trustzone version v1.0
[    1.847552] xlnx_event_manager xlnx_event_manager: SGI 15 Registered over TF-A
[    1.854845] xlnx_event_manager xlnx_event_manager: Xilinx Event Management driver probed
[    1.901999] zynqmp-aes zynqmp-aes.0: will run requests pump with realtime priority
[    1.909809] zynqmp_rsa zynqmp_rsa.0: RSA is not supported on the platform
[    1.916755] usbcore: registered new interface driver usbhid
[    1.922374] usbhid: USB HID core driver
[    1.926342] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[    1.937780] ARM CCI_500 PMU driver probed
[    1.937899] axi_sysid a5000000.axi-sysid-0: AXI System ID core version (1.01.a) found
[    1.950012] axi_sysid a5000000.axi-sysid-0: [ad9084_ebz] on [vck190] git branch <hdl_2026_r1> git <4840c81f2af172b036cb3ccb3f9f2dc45ed9c1d3> clean [2026-07-16 13:38:41] UTC
[    1.965842] fpga_manager fpga0: Xilinx Versal FPGA Manager registered
[    1.972609] usbcore: registered new interface driver snd-usb-audio
[    1.979893] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.988529] Initializing XFRM netlink socket
[    1.992870] NET: Registered PF_INET6 protocol family
[    1.998261] Segment Routing with IPv6
[    2.001983] In-situ OAM (IOAM) with IPv6
[    2.005999] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.012235] NET: Registered PF_PACKET protocol family
[    2.017333] NET: Registered PF_KEY protocol family
[    2.022241] can: controller area network core
[    2.026656] NET: Registered PF_CAN protocol family
[    2.031486] can: raw protocol
[    2.034475] can: broadcast manager protocol
[    2.038691] can: netlink gateway - max_hops=1
[    2.043137] Bluetooth: RFCOMM TTY layer initialized
[    2.048061] Bluetooth: RFCOMM socket layer initialized
[    2.053250] Bluetooth: RFCOMM ver 1.11
[    2.057030] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.062384] Bluetooth: BNEP filters: protocol multicast
[    2.067651] Bluetooth: BNEP socket layer initialized
[    2.072660] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.078629] Bluetooth: HIDP socket layer initialized
[    2.083787] 9pnet: Installing 9P2000 support
[    2.088118] NET: Registered PF_IEEE802154 protocol family
[    2.093588] Key type dns_resolver registered
[    2.103295] registered taskstats version 1
[    2.107436] Loading compiled-in X.509 certificates
[    2.117578] Btrfs loaded, zoned=no, fsverity=no
[    2.132409] ff000000.serial: ttyAMA0 at MMIO 0xff000000 (irq = 18, base_baud = 0) is a PL011 rev3
[    2.141383] printk: legacy console [ttyAMA0] enabled
[    2.151404] printk: legacy bootconsole [pl11] disabled
[    2.171698] adf4382 spi2.0: error -EINVAL: Scratch pad test failed please check SPI connection
[    2.180341] adf4382 spi2.0: error -EINVAL: adf4382 init failed
[    2.186184] adf4382 spi2.0: probe with driver adf4382 failed with error -22
[    2.198847] hmc7044 spi2.1: Read/Write check failed (0xFF)
[    2.272312] hmc7044 spi2.1: Probed, SPI read support failed
[    2.279699] adf4030 spi2.2: error -EIO: Failed SPI write/read verify test REG_0x0A=0xFF
[    2.287714] adf4030 spi2.2: error -EIO: Failed to configure device
[    2.293890] adf4030 spi2.2: probe with driver adf4030 failed with error -5
[    2.309712] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x0107010b at 0xff0c0000 irq 36 (e6:30:17:dd:8e:c4)
[    2.438070] macb ff0d0000.ethernet eth1: Cadence GEM rev 0x0107010b at 0xff0d0000 irq 37 (00:0a:23:00:00:01)
[    2.449027] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.454535] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.462265] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    2.468274] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238fe65 hci version 0x110 quirks 0x0000808000000810
[    2.477687] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xfe200000
[    2.483745] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    2.492015] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.499243] usb usb1: Product: xHCI Host Controller
[    2.504121] usb usb1: Manufacturer: Linux 6.12.77-g4b2e305bc496 xhci-hcd
[    2.510821] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.515965] hub 1-0:1.0: USB hub found
[    2.519742] hub 1-0:1.0: 1 port detected
[    2.524486] rtc_zynqmp f12a0000.rtc: registered as rtc0
[    2.529725] rtc_zynqmp f12a0000.rtc: setting system clock to 1970-01-12T14:05:57 UTC (1001157)
[    2.538814] cdns-i2c ff020000.i2c: 100 kHz mmio ff020000 irq 42
[    2.545327] at24 1-0050: supply vcc not found, using dummy regulator
[    2.579224] cdns-i2c ff030000.i2c: 100 kHz mmio ff030000 irq 43
[    2.587272] axi-jesd204-rx a4a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.599059] axi-jesd204-tx a4b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.611385] of_cfs_init
[    2.613872] of_cfs_init: OK
[    2.616708] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.640086] mmc0: SDHCI controller on f1050000.mmc [f1050000.mmc] using ADMA 64-bit
[    2.648226] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.654413] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    2.661671] clk: Not disabling unused clocks
[    2.665940] PM: genpd: Disabling unused power domains
[    2.671397] ALSA device list:
[    2.674360]   No soundcards found.
[    2.678004] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.686623] cfg80211: failed to load regulatory.db
[    2.691499] Waiting for root device /dev/mmcblk0p2...
[    2.734417] mmc0: new high speed SDHC card at address aaaa
[    2.740214] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[    2.748886]  mmcblk0: p1 p2 p3
[    3.134607] EXT4-fs (mmcblk0p2): recovery complete
[    3.140873] EXT4-fs (mmcblk0p2): mounted filesystem 5b950520-50b5-4445-b465-3291bcc7be79 r/w with ordered data mode. Quota mode: none.
[    3.153003] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.162130] devtmpfs: mounted
[    3.165921] Freeing unused kernel memory: 3648K
[    3.170512] Run /sbin/init as init process
[    3.819337] systemd[1]: System time advanced to built-in epoch: Mon 2026-04-13 15:38:05 EDT
[    3.847091] systemd[1]: Failed to find module 'autofs4'
[!p]104 [?7h[    3.900137] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[    3.934469] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 13 (trixie)!
[    3.976878] systemd[1]: Hostname set to <analog>.
[    4.048514] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[    5.421147] systemd[1]: /usr/lib/systemd/system/iiod.service:16: Invalid environment assignment, ignoring: $IIOD_EXTRA_OPTS=
[    5.597204] systemd[1]: Queued start job for default target graphical.target.
[    5.607530] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[  OK  ] Created slice system-getty.slice - Slice /system/getty.
[    5.628832] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[  OK  ] Created slice system-modprobe.slice - Slice /system/modprobe.
[    5.648776] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[  OK  ] Created slice system-serial\x2dget…slice - Slice /system/serial-getty.
[    5.672759] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[  OK  ] Created slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[    5.696449] systemd[1]: Created slice user.slice - User and Session Slice.
[  OK  ] Created slice user.slice - User and Session Slice.
[    5.716307] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[  OK  ] Started systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[    5.740316] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point skipped, unmet condition check ConditionPathExists=/proc/sys/fs/binfmt_misc
[    5.757944] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-20da5528\x2d01.device - /dev/disk/by-partuuid/20da5528-01...
         Expecting device dev-disk-by\x2dpa…dev/disk/by-partuuid/20da5528-01...
[    5.780135] systemd[1]: Expecting device dev-ttyAMA0.device - /dev/ttyAMA0...
[    5.796133] systemd[1]: Expecting device dev-ttyGS0.device - /dev/ttyGS0...
[    5.812133] systemd[1]: Expecting device dev-ttyGS1.device - /dev/ttyGS1...
[    5.828131] systemd[1]: Expecting device dev-ttyPS0.device - /dev/ttyPS0...
[    5.844133] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[    5.860217] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[  OK  ] Reached target nss-user-lookup.target - User and Group Name Lookups.
[    5.880181] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[  OK  ] Reached target remote-fs.target - Remote File Systems.
[    5.900162] systemd[1]: Reached target slices.target - Slice Units.
[  OK  ] Reached target slices.target - Slice Units.
[    5.916181] systemd[1]: Reached target swap.target - Swaps.
[  OK  ] Reached target swap.target - Swaps.
[    5.936858] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[  OK  ] Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    5.960397] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[  OK  ] Listening on systemd-initctl.socke…- initctl Compatibility Named Pipe.
[    5.984401] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[  OK  ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log).
[    6.008409] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[  OK  ] Listening on systemd-journald.socket - Journal Sockets.
[    6.028223] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    6.040290] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    6.052312] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[  OK  ] Listening on systemd-udevd-control.socket - udev Control Socket.
[    6.072322] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[  OK  ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    6.096598] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    6.117475] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    6.132331] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[    6.175605] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    6.196521] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System skipped, unmet condition check ConditionPathExists=/sys/kernel/tracing
[    6.217451] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[    6.240463] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[    6.260382] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes skipped, unmet condition check ConditionFileNotEmpty=/lib/modules/6.12.77-g4b2e305bc496/modules.devname
[    6.280471] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    6.307432] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    6.332435] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
         Starting modprobe@efi_pstore.servi… - Load Kernel Module efi_pstore...
[    6.360484] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    6.380450] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    6.400996] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    6.413875] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[    6.426028] systemd[1]: Starting systemd-journald.service - Journal Service...
[    6.452029] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    6.472325] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    6.505700] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
         Starting systemd-tmpfiles-setup-de… Device Nodes in /dev gracefully...
[    6.528246] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    6.545618] systemd-journald[198]: Collecting audit messages is disabled.
[    6.564923] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
         Starting systemd-udev-load-credent…Load udev Rules from Credentials...
[    6.606831] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    6.636330] systemd[1]: Started systemd-journald.service - Journal Service.
[  OK  ] Started systemd-journald.service - Journal Service.
[  OK  ] Mounted dev-hugepages.mount - Huge Pages File System.
[  OK  ] Mounted dev-mqueue.mount - POSIX Message Queue File System.
[  OK  ] Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[  OK  ] Mounted sys-kernel-debug.mount - Kernel Debug File System.
[  OK  ] Mounted tmp.mount - Temporary Directory /tmp.
[  OK  ] Finished fake-hwclock-load.service - Restore the current clock.
[  OK  ] Finished modprobe@configfs.service - Load Kernel Module configfs.
[  OK  ] Finished modprobe@drm.service - Load Kernel Module drm.
[  OK  ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[  OK  ] Finished modprobe@fuse.service - Load Kernel Module fuse.
[  OK  ] Finished systemd-modules-load.service - Load Kernel Modules.
[  OK  ] Finished systemd-tmpfiles-setup-de…ic Device Nodes in /dev gracefully.
[  OK  ] Finished systemd-udev-load-credent…- Load udev Rules from Credentials.
         Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
         Mounting sys-kernel-config.mount - Kernel Configuration File System...
         Starting systemd-remount-fs.servic…unt Root and Kernel File Systems...
         Starting systemd-sysctl.service - Apply Kernel Variables...
[  OK  ] Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[  OK  ] Mounted sys-kernel-config.mount - Kernel Configuration File System.
[  OK  ] Finished systemd-sysctl.service - Apply Kernel Variables.
[  OK  ] Finished systemd-remount-fs.servic…mount Root and Kernel File Systems.
         Starting systemd-journal-flush.ser…sh Journal to Persistent Storage...
         Starting systemd-random-seed.service - Load/Save OS Random Seed...
         Starting systemd-tmpfiles-setup-de…eate Static Device Nodes in /dev...
[  OK  ] Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[  OK  ] Finished systemd-tmpfiles-setup-de…Create Static Device Nodes in /dev.
[  OK  ] Reached target local-fs-pre.target…Preparation for Local File Systems.
         Starting ifupdown-pre.service - He…synchronize boot up for ifupdown...
         Starting systemd-udev-settle.servi…o Complete Device Initialization...
         Starting systemd-udevd.service - R…ager for Device Events and Files...
[  OK  ] Finished ifupdown-pre.service - He…o synchronize boot up for ifupdown.
[  OK  ] Finished systemd-journal-flush.ser…lush Journal to Persistent Storage.
[  OK  ] Started systemd-udevd.service - Ru…anager for Device Events and Files.
         Starting plymouth-start.service - Show Plymouth Boot Screen...
[  OK  ] Finished systemd-random-seed.service - Load/Save OS Random Seed.
[  OK  ] Found device dev-ttyAMA0.device - /dev/ttyAMA0.
[  OK  ] Found device dev-disk-by\x2dpartuu… /dev/disk/by-partuuid/20da5528-01.
[  OK  ] Started plymouth-start.service - Show Plymouth Boot Screen.
[  OK  ] Finished systemd-udev-settle.servi… To Complete Device Initialization.
[  OK  ] Started systemd-ask-password-plymo…quests to Plymouth Directory Watch.
[  OK  ] Reached target paths.target - Path Units.
[  OK  ] Listening on systemd-rfkill.socket…ll Switch Status /dev/rfkill Watch.
         Starting systemd-fsck@dev-disk-by\…dev/disk/by-partuuid/20da5528-01...
[  OK  ] Finished systemd-fsck@dev-disk-by\… /dev/disk/by-partuuid/20da5528-01.
         Mounting boot.mount - /boot...
[  OK  ] Mounted boot.mount - /boot.
[  OK  ] Reached target local-fs.target - Local File Systems.
[  OK  ] Listening on systemd-sysext.socket… System Extension Image Management.
         Starting networking.service - Raise network interfaces...
         Starting plymouth-read-write.servi…ymouth To Write Out Runtime Data...
         Starting systemd-tmpfiles-setup.se…ate System Files and Directories...
[  OK  ] Finished plymouth-read-write.servi…Plymouth To Write Out Runtime Data.
[  OK  ] Finished systemd-tmpfiles-setup.se…reate System Files and Directories.
[  OK  ] Reached target sysinit.target - System Initialization.
[  OK  ] Started apt-daily.timer - Daily apt download activities.
[  OK  ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities.
[  OK  ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
[  OK  ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems.
[  OK  ] Started fake-hwclock-save.timer - Periodically save current clock.
[  OK  ] Started fstrim.timer - Discard unused filesystem blocks once a week.
[  OK  ] Started logrotate.timer - Daily rotation of log files.
[  OK  ] Started man-db.timer - Daily man-db regeneration.
[  OK  ] Started ntpsec-rotate-stats.timer - Rotate ntpd stats daily.
[  OK  ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
[  OK  ] Reached target timers.target - Timer Units.
[  OK  ] Listening on avahi-daemon.socket -…DNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on dbus.socket - D-Bus System Message Bus Socket.
[  OK  ] Listening on sshd-unix-local.socke…temd-ssh-generator, AF_UNIX Local).
[  OK  ] Listening on systemd-hostnamed.socket - Hostname Service Socket.
[  OK  ] Reached target sockets.target - Socket Units.
[  OK  ] Reached target basic.target - Basic System.
         Starting accounts-daemon.service - Accounts Service...
         Starting adi-power.service - Analog Devices power up/down sequence...
         Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack...
         Starting blueman-mechanism.service - Bluetooth management mechanism...
[  OK  ] Started cron.service - Regular background program processing daemon.
         Starting dbus.service - D-Bus System Message Bus...
         Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots...
[  OK  ] Started fan-control.service - fan-control.
         Starting fix-display-port.service - Fix DP audio and X11...
         Starting iiod_context_attr.service…ating IIOD Context Attributes......
         Starting systemd-logind.service - User Login Management...
         Starting udisks2.service - Disk Manager...
[  OK  ] Finished networking.service - Raise network interfaces.
[  OK  ] Started systemd-logind.service - User Login Management.
[  OK  ] Finished fix-display-port.service - Fix DP audio and X11.
[  OK  ] Started dbus.service - D-Bus System Message Bus.
         Starting NetworkManager.service - Network Manager...
         Starting wpa_supplicant.service - WPA supplicant...
[  OK  ] Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
         Starting polkit.service - Authorization Manager...
[  OK  ] Finished iiod_context_attr.service…reating IIOD Context Attributes....
[  OK  ] Started wpa_supplicant.service - WPA supplicant.
[  OK  ] Finished adi-power.service - Analog Devices power up/down sequence.
[  OK  ] Started polkit.service - Authorization Manager.
[  OK  ] Started accounts-daemon.service - Accounts Service.
         Starting systemd-hostnamed.service - Hostname Service...
[  OK  ] Started systemd-hostnamed.service - Hostname Service.
[  OK  ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots.
[  OK  ] Started udisks2.service - Disk Manager.
         Starting NetworkManager-dispatcher…anager Script Dispatcher Service...
[  OK  ] Started NetworkManager.service - Network Manager.
[  OK  ] Reached target network.target - Network.
         Starting htpdate.service - HTTP based time synchronization tool...
[  OK  ] Started iiod.service - IIO Daemon.
         Starting ntpsec.service - Network Time Service...
         Starting ssh.service - OpenBSD Secure Shell server...
         Starting systemd-user-sessions.service - Permit User Sessions...
[  OK  ] Started udiskie.service - Udiskie …rvice for managing removable media.
[  OK  ] Started NetworkManager-dispatcher.… Manager Script Dispatcher Service.
[  OK  ] Finished systemd-user-sessions.service - Permit User Sessions.
         Starting lightdm.service - Light Display Manager...
         Starting plymouth-quit-wait.servic…d until boot process finishes up...
[  OK  ] Started htpdate.service - HTTP based time synchronization tool.
[  OK  ] Started ntpsec.service - Network Time Service.
[!p]104 [?7h[!p]104 [?7h
Debian GNU/Linux 13 analog ttyAMA0
analog login: root (automatic login)
Password:
Linux analog 6.12.77-g4b2e305bc496 #1 SMP Wed Jul 15 15:56:08 UTC 2026 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[?2004hroot@analog:~#
[?2004l
[?2004hroot@analog:~# reboot
[?2004l
[?2004hroot@analog:~# [?2004l
[?2004h[?2004l
[?2004h[!p]104 [?7hmtdoops: mtd device (mtddev=name/number) must be supplied
[  OK  ] Started plymouth-reboot.service - Show Plymouth Reboot Screen.
[  OK  ] Stopped user@0.service - User Manager for UID 0.
         Stopping user-runtime-dir@0.servic…er Runtime Directory /run/user/0...
[  OK  ] Stopped user@1000.service - User Manager for UID 1000.
         Stopping systemd-user-sessions.service - Permit User Sessions...
         Stopping user-runtime-dir@1000.ser…Runtime Directory /run/user/1000...
[  OK  ] Unmounted run-user-0.mount - /run/user/0.
[  OK  ] Stopped user-runtime-dir@0.service…User Runtime Directory /run/user/0.
[  OK  ] Removed slice user-0.slice - User Slice of UID 0.
[  OK  ] Stopped systemd-user-sessions.service - Permit User Sessions.
[  OK  ] Stopped target network.target - Network.
[  OK  ] Stopped target remote-fs.target - Remote File Systems.
         Stopping NetworkManager.service - Network Manager...
         Stopping networking.service - Raise network interfaces...
         Stopping wpa_supplicant.service - WPA supplicant...
[  OK  ] Stopped wpa_supplicant.service - WPA supplicant.
[  OK  ] Unmounted run-user-1000.mount - /run/user/1000.
[  OK  ] Stopped user-runtime-dir@1000.serv…r Runtime Directory /run/user/1000.
[  OK  ] Removed slice user-1000.slice - User Slice of UID 1000.
         Stopping systemd-logind.service - User Login Management...
[  OK  ] Stopped systemd-logind.service - User Login Management.
[  OK  ] Stopped target nss-user-lookup.target - User and Group Name Lookups.
[  OK  ] Stopped NetworkManager.service - Network Manager.
         Stopping dbus.service - D-Bus System Message Bus...
[  OK  ] Stopped dbus.service - D-Bus System Message Bus.
[  OK  ] Stopped target basic.target - Basic System.
[  OK  ] Stopped systemd-ask-password-plymo…quests to Plymouth Directory Watch.
[  OK  ] Stopped target paths.target - Path Units.
[  OK  ] Stopped systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[  OK  ] Stopped target slices.target - Slice Units.
[  OK  ] Removed slice user.slice - User and Session Slice.
[  OK  ] Stopped target sockets.target - Socket Units.
[  OK  ] Closed avahi-daemon.socket - Avahi…DNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed dbus.socket - D-Bus System Message Bus Socket.
[  OK  ] Closed sshd-unix-local.socket - Op…temd-ssh-generator, AF_UNIX Local).
[  OK  ] Closed systemd-hostnamed.socket - Hostname Service Socket.
[  OK  ] Stopped target sysinit.target - System Initialization.
[  OK  ] Stopped systemd-tmpfiles-setup.ser…reate System Files and Directories.
[  OK  ] Stopped networking.service - Raise network interfaces.
[  OK  ] Stopped target local-fs.target - Local File Systems.
         Unmounting boot.mount - /boot...
         Unmounting run-lock.mount - Legacy Locks Directory /run/lock...
         Unmounting tmp.mount - Temporary Directory /tmp...
[  OK  ] Stopped systemd-sysctl.service - Apply Kernel Variables.
[  OK  ] Stopped systemd-modules-load.service - Load Kernel Modules.
[  OK  ] Unmounted run-lock.mount - Legacy Locks Directory /run/lock.
[  OK  ] Unmounted boot.mount - /boot.
[  OK  ] Stopped systemd-fsck@dev-disk-by\x… /dev/disk/by-partuuid/20da5528-01.
[  OK  ] Removed slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[  OK  ] Stopped target local-fs-pre.target…Preparation for Local File Systems.
[  OK  ] Stopped systemd-remount-fs.service…mount Root and Kernel File Systems.
[  OK  ] Stopped systemd-tmpfiles-setup-dev…Create Static Device Nodes in /dev.
[  OK  ] Stopped systemd-tmpfiles-setup-dev…ic Device Nodes in /dev gracefully.
[  OK  ] Unmounted tmp.mount - Temporary Directory /tmp.
[  OK  ] Stopped target swap.target - Swaps.
[  OK  ] Reached target shutdown.target - System Shutdown.
[  OK  ] Reached target umount.target - Unmount All Filesystems.
[  OK  ] Reached target final.target - Late Shutdown Services.
[  OK  ] Finished systemd-reboot.service - System Reboot.
[  OK  ] Reached target reboot.target - System Reboot.
[ 1172.890894] reboot: Restarting system
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 1, parent_node 4294967295, State ON (0x0)
INFO:      Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x1, parent_node 0, State ON (0x0)
 [0.012]****************************************
[0.045]Xilinx Versal Platform Loader and Manager
[0.080]Release 2025.1   Jul 16 2026  -  15:37:11
[0.116]Platform Version: v2.0 PMC: v2.0, PS: v2.0
[0.158]BOOTMODE: 0xE, MULTIBOOT: 0xF0000000
[0.192]****************************************
[0.411]Non Secure Boot
[3.560]PLM Initialization Time
[3.589]***********Boot PDI Load: Started***********
[3.647]Loading PDI from SD1_LS
[3.675]Monolithic/Master Device
[420.372]416.736 ms: PDI initialization time
[420.414]+++Loading Image#: 0x1, Name: lpd, Id: 0x04210002
[420.463]---Loading Partition#: 0x1, Id: 0xC
[475.665] 55.154 ms for Partition#: 0x1, Size: 10672 Bytes
[480.774]---Loading Partition#: 0x2, Id: 0xB
[500.533] 15.787 ms for Partition#: 0x2, Size: 63008 Bytes
[503.050]+++Loading Image#: 0x2, Name: pl_cfi, Id: 0x18700000
[508.294]---Loading Partition#: 0x3, Id: 0x3
[1624.310] 1112.042 ms for Partition#: 0x3, Size: 4599264 Bytes
[1627.072]---Loading Partition#: 0x4, Id: 0x5
[1838.185] 207.055 ms for Partition#: 0x4, Size: 750512 Bytes
[1840.786]+++Loading Image#: 0x3, Name: fpd, Id: 0x0420C003
[1846.031]---Loading Partition#: 0x5, Id: 0x8
[1854.408] 4.321 ms for Partition#: 0x5, Size: 4544 Bytes
[1856.936]+++Loading Image#: 0x4, Name: apu_subsystem, Id: 0x1C000000
[1862.772]---Loading Partition#: 0x6, Id: 0x0
[1880.196] 13.367 ms for Partition#: 0x6, Size: 51136 Bytes
[1882.614]---Loading Partition#: 0x7, Id: 0x0
[1901.169] 14.498 ms for Partition#: 0x7, Size: 67632 Bytes
[1903.588]---Loading Partition#: 0x8, Id: 0x0
[2154.998] 247.351 ms for Partition#: 0x8, Size: 1201568 Bytes
[2157.723]***********Boot PDI Load: Done***********
[2162.251]362.231 ms: ROM Time
[2165.001]Total PLM Boot Time
INFO:    SPSR = 0x3c9
CPU:   Versal
Silicon: v2
Chip:  v2
EL Level:	EL2
In:    serial@ff000000
Net:
Warning: ethernet@ff0c0000 (eth0) using random MAC address - fa:0c:6e:71:98:2a
Scanning mmc 0:1...
208 bytes read in 10 ms (19.5 KiB/s)
41374208 bytes read in 5186 ms (7.6 MiB/s)
Starting kernel ...
[    0.023321] pid_max: default: 32768 minimum: 301
[    0.044145] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.050816] rcu: Hierarchical SRCU implementation.
[    0.055647] rcu: 	Max phase no-delay instances is 1000.
[    0.061059] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.069330] EFI services will not be available.
[    0.078858] Detected PIPT I-cache on CPU1
[    0.078893] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
[    0.078912] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.078973] smp: Brought up 1 node, 2 CPUs
[    0.100643] SMP: Total of 2 processors activated.
[    0.105381] CPU: All CPU(s) started at EL2
[    0.109506] CPU features: detected: 32-bit EL0 Support
[    0.114683] CPU features: detected: CRC32 instructions
[    0.119886] alternatives: applying system-wide alternatives
[    0.125970] Memory: 7855124K/8388608K available (19520K kernel code, 2004K rwdata, 15068K rodata, 3648K init, 735K bss, 267716K reserved, 262144K cma-reserved)
[    0.140759] devtmpfs: initialized
[    0.147869] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.157714] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.166232] 22464 pages in range for non-PLT usage
[    0.166241] 513984 pages in range for PLT usage
[    0.171440] DMI not present or invalid.
[    0.180130] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.186499] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.193802] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.201867] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.209964] audit: initializing netlink subsys (disabled)
[    0.215493] audit: type=2000 audit(0.132:1): state=initialized audit_enabled=0 res=1
[    0.223321] cpuidle: using governor menu
[    0.227332] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.234201] ASID allocator initialised with 65536 entries
[    0.239733] Serial: AMBA PL011 UART driver
[    0.246162] /axi/interrupt-controller@f9000000: Fixed dependency cycle(s) with /axi/interrupt-controller@f9000000
[    0.261019] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.267875] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.274193] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.281034] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.287351] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.294193] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.300509] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.307349] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.381716] raid6: neonx8   gen()  4145 MB/s
[    0.454063] raid6: neonx4   gen()  4063 MB/s
[    0.526409] raid6: neonx2   gen()  3375 MB/s
[    0.598755] raid6: neonx1   gen()  2444 MB/s
[    0.671101] raid6: int64x8  gen()  2334 MB/s
[    0.743451] raid6: int64x4  gen()  2285 MB/s
[    0.815794] raid6: int64x2  gen()  2222 MB/s
[    0.888145] raid6: int64x1  gen()  1712 MB/s
[    0.892447] raid6: using algorithm neonx8 gen() 4145 MB/s
[    0.965926] raid6: .... xor() 3028 MB/s, rmw enabled
[    0.970929] raid6: using neon recovery algorithm
[    0.975843] iommu: Default domain type: Translated
[    0.980674] iommu: DMA domain TLB invalidation policy: strict mode
[    0.987136] SCSI subsystem initialized
[    0.991025] usbcore: registered new interface driver usbfs
[    0.996572] usbcore: registered new interface driver hub
[    1.001942] usbcore: registered new device driver usb
[    1.007158] mc: Linux media interface: v0.10
[    1.011477] videodev: Linux video capture interface: v2.00
[    1.017034] pps_core: LinuxPPS API ver. 1 registered
[    1.022037] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.031249] PTP clock support registered
[    1.035214] EDAC MC: Ver: 3.0.0
[    1.038674] jesd204: created con: id=0, topo=0, link=4, /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.050711] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.062736] jesd204: created con: id=2, topo=0, link=0, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-tx@a4b90000
[    1.073972] jesd204: created con: id=3, topo=0, link=4, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-rx@a4a90000
[    1.085210] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@a4b90000 <-> /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000
[    1.097407] jesd204: created con: id=5, topo=0, link=4, /fpga-axi@0/axi-jesd204-rx@a4a90000 <-> /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000
[    1.109610] jesd204: created con: id=6, topo=0, link=4, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.120144] jesd204: created con: id=7, topo=0, link=0, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.130683] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:0] transition uninitialized -> initialized
[    1.140600] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:2] transition uninitialized -> initialized
[    1.150515] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:4] transition uninitialized -> initialized
[    1.160431] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:6] transition uninitialized -> initialized
[    1.170346] jesd204: found 7 devices and 1 topologies
[    1.175473] FPGA manager framework
[    1.185388] Bluetooth: Core ver 2.22
[    1.189004] NET: Registered PF_BLUETOOTH protocol family
[    1.194359] Bluetooth: HCI device and connection manager initialized
[    1.200767] Bluetooth: HCI socket layer initialized
[    1.205684] Bluetooth: L2CAP socket layer initialized
[    1.210780] Bluetooth: SCO socket layer initialized
[    1.216086] clocksource: Switched to clocksource arch_sys_counter
[    1.222348] VFS: Disk quotas dquot_6.6.0
[    1.226318] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.237444] NET: Registered PF_INET protocol family
[    1.242563] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.253748] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.262393] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.270205] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.278481] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    1.287029] TCP: Hash tables configured (established 65536 bind 65536)
[    1.293696] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.308128] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.314068] RPC: Registered named UNIX socket transport module.
[    1.320044] RPC: Registered udp transport module.
[    1.324785] RPC: Registered tcp transport module.
[    1.329523] RPC: Registered tcp-with-tls transport module.
[    1.335051] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.341993] PCI: CLS 0 bytes, default 64
[    1.346506] Initialise system trusted keyrings
[    1.351081] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[    1.357912] NFS: Registering the id_resolver key type
[    1.363024] Key type id_resolver registered
[    1.367246] Key type id_legacy registered
[    1.371295] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.378052] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.385518] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    1.392672] fuse: init (API version 7.41)
[    1.428084] NET: Registered PF_ALG protocol family
[    1.432917] xor: measuring software checksum speed
[    1.438234]    8regs           :  6709 MB/sec
[    1.443074]    32regs          :  7288 MB/sec
[    1.448038]    arm64_neon      :  5713 MB/sec
[    1.452428] xor: using function: 32regs (7288 MB/sec)
[    1.457519] Key type asymmetric registered
[    1.461649] Asymmetric key parser 'x509' registered
[    1.466594] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.474062] io scheduler mq-deadline registered
[    1.478629] io scheduler kyber registered
[    1.482678] io scheduler bfq registered
[    1.489143] ledtrig-cpu: registered to indicate activity on CPUs
[    1.519812] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.527151] Serial: AMBA driver
[    1.534053] brd: module loaded
[    1.539257] loop: module loaded
[    1.543104] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.552478] tun: Universal TUN/TAP device driver, 1.6
[    1.557687] CAN device driver interface
[    1.561924] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
[    1.568339] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
[    1.574743] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
[    1.581149] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
[    1.587553] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
[    1.593961] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
[    1.600366] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
[    1.606769] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
[    1.613174] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
[    1.619578] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
[    1.625982] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
[    1.632472] usbcore: registered new interface driver asix
[    1.637936] usbcore: registered new interface driver ax88179_178a
[    1.644096] usbcore: registered new interface driver cdc_ether
[    1.649992] usbcore: registered new interface driver net1080
[    1.655719] usbcore: registered new interface driver cdc_subset
[    1.661707] usbcore: registered new interface driver zaurus
[    1.667343] usbcore: registered new interface driver cdc_ncm
[    1.673069] usbcore: registered new interface driver r8153_ecm
[    1.679492] usbcore: registered new interface driver uas
[    1.684874] usbcore: registered new interface driver usb-storage
[    1.690986] usbcore: registered new interface driver usbserial_generic
[    1.697579] usbserial: USB Serial support registered for generic
[    1.703648] usbcore: registered new interface driver ftdi_sio
[    1.709450] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.716835] usbcore: registered new interface driver upd78f0730
[    1.722812] usbserial: USB Serial support registered for upd78f0730
[    1.729748] i2c_dev: i2c /dev entries driver
[    1.734957] usbcore: registered new interface driver uvcvideo
[    1.741473] Bluetooth: HCI UART driver ver 2.3
[    1.745958] Bluetooth: HCI UART protocol H4 registered
[    1.751136] Bluetooth: HCI UART protocol BCSP registered
[    1.756503] Bluetooth: HCI UART protocol LL registered
[    1.761683] Bluetooth: HCI UART protocol ATH3K registered
[    1.767132] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.773475] Bluetooth: HCI UART protocol Intel registered
[    1.778932] Bluetooth: HCI UART protocol QCA registered
[    1.784220] usbcore: registered new interface driver bcm203x
[    1.789945] usbcore: registered new interface driver bpa10x
[    1.795582] usbcore: registered new interface driver bfusb
[    1.801129] usbcore: registered new interface driver btusb
[    1.806688] usbcore: registered new interface driver ath3k
[    1.812451] sdhci: Secure Digital Host Controller Interface driver
[    1.818688] sdhci: Copyright(c) Pierre Ossman
[    1.823079] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.828914] SMCCC: SOC_ID: ID = jep106:0049:0000 Revision = 0x00000000
[    1.835578] zynqmp_firmware_probe Platform Management API v1.0
[    1.841499] zynqmp_firmware_probe Trustzone version v1.0
[    1.847294] xlnx_event_manager xlnx_event_manager: SGI 15 Registered over TF-A
[    1.854588] xlnx_event_manager xlnx_event_manager: Xilinx Event Management driver probed
[    1.901796] zynqmp-aes zynqmp-aes.0: will run requests pump with realtime priority
[    1.909608] zynqmp_rsa zynqmp_rsa.0: RSA is not supported on the platform
[    1.916553] usbcore: registered new interface driver usbhid
[    1.922173] usbhid: USB HID core driver
[    1.926139] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
[    1.937568] ARM CCI_500 PMU driver probed
[    1.937687] axi_sysid a5000000.axi-sysid-0: AXI System ID core version (1.01.a) found
[    1.949798] axi_sysid a5000000.axi-sysid-0: [ad9084_ebz] on [vck190] git branch <hdl_2026_r1> git <4840c81f2af172b036cb3ccb3f9f2dc45ed9c1d3> clean [2026-07-16 13:38:41] UTC
[    1.965629] fpga_manager fpga0: Xilinx Versal FPGA Manager registered
[    1.972397] usbcore: registered new interface driver snd-usb-audio
[    1.979679] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.988359] Initializing XFRM netlink socket
[    1.992700] NET: Registered PF_INET6 protocol family
[    1.998088] Segment Routing with IPv6
[    2.001810] In-situ OAM (IOAM) with IPv6
[    2.005825] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.012055] NET: Registered PF_PACKET protocol family
[    2.017155] NET: Registered PF_KEY protocol family
[    2.022062] can: controller area network core
[    2.026478] NET: Registered PF_CAN protocol family
[    2.031309] can: raw protocol
[    2.034297] can: broadcast manager protocol
[    2.038514] can: netlink gateway - max_hops=1
[    2.042958] Bluetooth: RFCOMM TTY layer initialized
[    2.047881] Bluetooth: RFCOMM socket layer initialized
[    2.053071] Bluetooth: RFCOMM ver 1.11
[    2.056855] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.062210] Bluetooth: BNEP filters: protocol multicast
[    2.067477] Bluetooth: BNEP socket layer initialized
[    2.072487] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.078455] Bluetooth: HIDP socket layer initialized
[    2.083612] 9pnet: Installing 9P2000 support
[    2.087934] NET: Registered PF_IEEE802154 protocol family
[    2.093395] Key type dns_resolver registered
[    2.103012] registered taskstats version 1
[    2.107154] Loading compiled-in X.509 certificates
[    2.117312] Btrfs loaded, zoned=no, fsverity=no
[    2.132152] ff000000.serial: ttyAMA0 at MMIO 0xff000000 (irq = 18, base_baud = 0) is a PL011 rev3
[    2.141122] printk: legacy console [ttyAMA0] enabled
[    2.151145] printk: legacy bootconsole [pl11] disabled
[    2.169222] adf4382 spi2.0: VCO=20000000000 PFD=125000000 RFout_div=1 N=160 FRAC1=0 FRAC2=0 MOD2=0
[    2.180859] adf4382 spi2.0: PLL Locked, REF OK
[    2.243256] hmc7044 spi2.1: PLL1: Locked, CLKIN1 @ 125000000 Hz, PFD: 6250 kHz - PLL2: Locked @ 2500.000000 MHz
[    2.261482] jesd204: /axi/spi@ff040000/adf4030@2,jesd204:1,parent=spi2.2: Using as SYSREF provider
[    2.275375] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x0107010b at 0xff0c0000 irq 36 (fa:0c:6e:71:98:2a)
[    2.404558] macb ff0d0000.ethernet eth1: Cadence GEM rev 0x0107010b at 0xff0d0000 irq 37 (00:0a:23:00:00:01)
[    2.415499] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    2.421012] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    2.428740] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    2.434745] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238fe65 hci version 0x110 quirks 0x0000808000000810
[    2.444159] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xfe200000
[    2.450221] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    2.458493] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.465720] usb usb1: Product: xHCI Host Controller
[    2.470593] usb usb1: Manufacturer: Linux 6.12.77-g4b2e305bc496 xhci-hcd
[    2.477289] usb usb1: SerialNumber: xhci-hcd.0.auto
[    2.482428] hub 1-0:1.0: USB hub found
[    2.486195] hub 1-0:1.0: 1 port detected
[    2.490939] rtc_zynqmp f12a0000.rtc: registered as rtc0
[    2.496189] rtc_zynqmp f12a0000.rtc: setting system clock to 1970-01-12T14:25:45 UTC (1002345)
[    2.505272] cdns-i2c ff020000.i2c: 100 kHz mmio ff020000 irq 42
[    2.511750] at24 1-0050: supply vcc not found, using dummy regulator
[    2.547398] cdns-i2c ff030000.i2c: 100 kHz mmio ff030000 irq 43
[    2.555500] axi-jesd204-rx a4a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.567238] axi-jesd204-tx a4b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.579170] ad9088 spi1.0: supply vdd not found, using dummy regulator
[    2.590099] ad9088 spi1.0: api v2.0.10
[    2.593958] ad9088 spi1.0: host is using little endian mode.
[    2.602740] ad9088 spi1.0: Waiting for link to establish...
[    2.610446] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
[    2.616011] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
[    2.616089] mmc0: SDHCI controller on f1050000.mmc [f1050000.mmc] using ADMA 64-bit
[    2.629641] ad9088 spi1.0: Waiting for link to establish...
[    2.637348] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
[    2.642912] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
[    2.653852] Test direct register Passed
[    2.657715] Test indirect register Passed
[    2.661745] Test ARM memory Passed
[    2.665150] ad9088 spi1.0: adi_apollo_startup_execute: startup_type 0x0000007f
[    2.672369] ad9088 spi1.0: adi_apollo_startup_execute: profile checksum 1922412250
[    2.679932] ad9088 spi1.0: adi_apollo_startup_execute: fw_provider desc 'Linux Firmware Provider'
[    2.688801] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_FW_LOAD
[    2.696636] ad9088 spi1.0: adi_apollo_startup_execute: TyE bypassed: 0
[    2.703160] ad9088 spi1.0: adi_apollo_startup_execute: Running scenario = 4
[    2.710120] ad9088 spi1.0: adi_apollo_startup_execute: Apollo Silicon Grade = 01
[    2.717550] ad9088 spi1.0: adi_apollo_startup_execute: Loading TyE SecureBoot Header image...
[    2.726078] ad9088 spi1.0: Loading 4096 bytes
[    2.730725] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core0 firmware image...
[    2.738642] ad9088 spi1.0: Loading 196604 bytes
[    2.757022] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core1 firmware image...
[    2.764937] ad9088 spi1.0: Loading 360444 bytes
[    2.794844] ad9088 spi1.0: adi_apollo_startup_execute: Loading TinyE Operation firmware image...
[    2.803627] ad9088 spi1.0: Loading 23540 bytes
[    2.809733] ad9088 spi1.0: adi_apollo_startup_execute: Boot Ready bit has been set
[    2.837547] mmc0: new high speed SDHC card at address aaaa
[    2.843367] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[    2.852356]  mmcblk0: p1 p2 p3
[    3.044101] ad9088 spi1.0: BF_RAM_BOOT_CORE1_STATUS: 29.
[    3.049433] ad9088 spi1.0: SECURE_BOOT_STAGE_0 CHECK: Passed.
[    3.055182] ad9088 spi1.0: SECURE_BOOT_STAGE_1 CHECK: Passed.
[    3.060925] ad9088 spi1.0: adi_apollo_startup_execute: seq_fw_load: OK
[    3.067447] ad9088 spi1.0: ADI_APOLLO_STARTUP_SEQ_PROFILE_LOAD
[    3.128093] ad9088 spi1.0: Core 1 Ram Boot Status: 0x1D
[    3.133319] ad9088 spi1.0: adi_apollo_startup_execute: Loading device profile (ver=10.1.2, 4T4R)...
[    3.142359] ad9088 spi1.0: adi_apollo_startup_execute: Profile checksum: 1922412250
[    3.150020] ad9088 spi1.0: Device Profile address: 0x21028860
[    3.155762] ad9088 spi1.0: Loading 23720 bytes
[    3.320094] ad9088 spi1.0: Core 1 Ram Boot Status: 0x25
[    5.676089] ad9088 spi1.0: Core 1 Ram Boot Status: 0x32
[    5.736089] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
[    5.741315] ad9088 spi1.0: adi_apollo_startup_execute: seq_profile_load: OK
[    5.748271] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TMU_EN
[    5.760058] ad9088 spi1.0: adi_apollo_startup_execute: seq_tmu_enable: OK
[    5.766848] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_DP_CONFIG
[    6.720132] ad9088 spi1.0: adi_apollo_startup_execute: seq_dp_config: OK
[    6.726833] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_LINK_EN
[    6.734718] ad9088 spi1.0: adi_apollo_startup_execute: seq_link_en: OK
[    6.741240] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TXRX_ACTIVATE
[    6.749935] ad9088 spi1.0: adi_apollo_startup_execute: seq_txrx_activate: OK
[    6.756978] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_SYNC
[    6.765172] ad9088 spi1.0: adi_apollo_startup_execute: seq_sync: OK
[    6.771439] ad9088 spi1.0: API ver: 2.0.10
[    6.775546] ad9088 spi1.0: REG_RAM_BOOT_ERROR 0x0
[    6.780251] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
[    6.789531] ad9088 spi1.0: Ping (core 1) cmd/res: 0x00000000/0x00000001
[    6.800109] ad9088 spi1.0: Ping (core 0) cmd/res: 0x12345678/0x1234567a
[    6.810807] ad9088 spi1.0: FW ver: 2.0.6
[    6.814797] ad9088 spi1.0: AD9084  Rev. 4 Grade 3 (API 2.0.10) probed
[    6.821376] ad9088 spi1.0: BMEM sniffer: 4 channels (4T4R mode)
[    6.827646] ad9088 spi1.0: ad9088-fft-sniffer-A: No IRQ found, using polling mode
[    6.835340] ad9088 spi1.0: ad9088-fft-sniffer-B: No IRQ found, using polling mode
[    6.864596] iio_dmaengine_buffer_alloc:295 width 0 (DMA width >= 256-bits ?)
[    6.875316] cf_axi_adc a4a10000.axi-ad9084-rx-hpc: ADI AIM (10.03. ) probed ADC AD9088 as MASTER
[    6.900098] iio_dmaengine_buffer_alloc:295 width 0 (DMA width >= 256-bits ?)
[    6.907781] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
[    6.919099] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
[    6.930408] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
[    6.941712] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
[    6.953018] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> initialized
[    6.964327] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> initialized
[    6.975632] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> initialized
[    6.986935] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> initialized
[    6.998241] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
[    7.009544] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
[    7.020846] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
[    7.032153] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
[    7.043459] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> idle
[    7.054155] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> idle
[    7.064853] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> idle
[    7.075549] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> idle
[    7.086247] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    7.097387] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    7.108518] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition idle -> device_init
[    7.119646] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition idle -> device_init
[    7.130782] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    7.142349] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    7.153912] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition device_init -> link_init
[    7.165477] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition device_init -> link_init
[    7.177053] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    7.188878] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    7.200701] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_init -> link_supported
[    7.212524] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_init -> link_supported
[    7.224631] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    7.236899] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    7.249159] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_supported -> link_pre_setup
[    7.261418] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_supported -> link_pre_setup
[    7.285974] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
[    7.298325] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
[    7.310669] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_pre_setup -> clk_sync_stage1
[    7.323013] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_pre_setup -> clk_sync_stage1
[    7.335364] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
[    7.347796] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
[    7.360231] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage1 -> clk_sync_stage2
[    7.372662] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage1 -> clk_sync_stage2
[    7.385101] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
[    7.397533] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
[    7.409963] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage2 -> clk_sync_stage3
[    7.422396] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage2 -> clk_sync_stage3
[    8.726463] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage4
[    8.738906] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage4
[    8.751341] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage3 -> clk_sync_stage4
[    8.763772] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage3 -> clk_sync_stage4
[    8.776204] jesd204: /fpga-axi@0/axi-jesd204-rx@a4a90000,jesd204:4,parent=a4a90000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 8, Link[4] lanes 4
[    8.791418] jesd204: /fpga-axi@0/axi-jesd204-tx@a4b90000,jesd204:5,parent=a4b90000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
[    8.816463] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage4 -> link_setup
[    8.828466] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage4 -> link_setup
[    8.840468] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage4 -> link_setup
[    8.852467] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage4 -> link_setup
[    8.902362] ad9088 spi1.0: Run clock conditioning cal (can take up to 10 secs)...
[   11.256257] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.265431] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.274599] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.283768] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.292933] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.302101] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.311267] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.320431] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.329638] ad9088 spi1.0: Run ADC cal from NVM (can take up to 100 secs)...
[   11.340813] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_setup -> opt_setup_stage1
[   11.352904] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_setup -> opt_setup_stage1
[   11.364990] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_setup -> opt_setup_stage1
[   11.377074] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_setup -> opt_setup_stage1
[   69.794560] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
[   69.807185] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2
[   69.819794] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage1 -> opt_setup_stage2
[   69.832400] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage1 -> opt_setup_stage2
[   69.845014] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
[   69.857620] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3
[   69.870224] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage2 -> opt_setup_stage3
[   69.882831] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage2 -> opt_setup_stage3
[   69.895445] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
[   69.908053] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4
[   69.920657] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage3 -> opt_setup_stage4
[   69.933261] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage3 -> opt_setup_stage4
[   69.945871] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
[   69.958478] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5
[   69.971082] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage4 -> opt_setup_stage5
[   69.983687] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage4 -> opt_setup_stage5
[   70.008449] ad9088 spi1.0: JESD TX (JRX Deframer Link A0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
[   71.040494] ad9088 spi1.0: cpu_status = 0x00
[   71.044764] ad9088 spi1.0: cals_duration_msec = 58026
[   71.049812] ad9088 spi1.0: init_err_codes[0] = 0x208 	 init_err_cals[0] = 0x04
[   71.057029] ad9088 spi1.0: init_err_codes[1] = 0x00 	 init_err_cals[1] = 0x00
[   71.064162] ad9088 spi1.0: Apollo API call adi_apollo_serdes_jrx_init_cal failed with error: SERDES cal error (-85)
[   71.074592] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] In clocks_enable got error from cb: -5 (ignoring!)
[   71.087459] ad9088 spi1.0: JESD TX (JRX Deframer Link B0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
[   72.128518] ad9088 spi1.0: cpu_status = 0x00
[   72.132787] ad9088 spi1.0: cals_duration_msec = 58026
[   72.137834] ad9088 spi1.0: init_err_codes[0] = 0x00 	 init_err_cals[0] = 0x00
[   72.144963] ad9088 spi1.0: init_err_codes[1] = 0x208 	 init_err_cals[1] = 0x04
[   72.152179] ad9088 spi1.0: Apollo API call adi_apollo_serdes_jrx_init_cal failed with error: SERDES cal error (-85)
[   72.162609] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] In clocks_enable got error from cb: -5 (ignoring!)
[   72.175487] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
[   72.187842] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable
[   72.200188] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage5 -> clocks_enable
[   72.212532] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage5 -> clocks_enable
[   72.228968] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clocks_enable -> link_enable
[   72.240885] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clocks_enable -> link_enable
[   72.252798] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clocks_enable -> link_enable
[   72.264709] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clocks_enable -> link_enable
[   72.292089] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Phase Difference 0
[   72.368109] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-0@5 status: Undef
[   72.376470] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-1@1 status: Undef
[   72.384826] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-2@3 status: Undef
[   72.393185] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-3@7 status: Undef
[   72.401531] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C User status: Fail, SYSREF Phase: Locked
[   72.411352] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] In link_running got error from cb: -1 (ignoring!)
[   72.424138] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Phase Difference 0
[   72.500107] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-0@1 status: Undef
[   72.508467] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-1@7 status: Undef
[   72.516823] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-2@10 status: Undef
[   72.525264] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-3@3 status: Undef
[   72.533609] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C User status: Fail, SYSREF Phase: Locked
[   72.543432] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] In link_running got error from cb: -1 (ignoring!)
[   72.556228] ad9088 spi1.0: JESD RX (JTX Framer Link A0) Link4 204C PLL locked, PHASE established, MODE valid
[   72.566068] ad9088 spi1.0: JESD RX (JTX Framer Link B0) Link6 204C PLL locked, PHASE established, MODE valid
[   72.575891] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_enable -> link_running
[   72.587715] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_enable -> link_running
[   72.599538] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_enable -> link_running
[   72.611363] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_enable -> link_running
[   73.564464] ad9088 spi1.0: Total BSYNC path delay 2173669 fs
[   74.015709] ad9088 spi1.0: MCS Initcal Status: Passed
[   74.053672] adf4382 spi2.0: Phase 125 fs too small to represent at Icp 11100 uA.
[   76.136322] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_running -> opt_post_setup_stage1
[   76.149018] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_running -> opt_post_setup_stage1
[   76.161715] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_running -> opt_post_setup_stage1
[   76.174409] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_running -> opt_post_setup_stage1
[   76.187111] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.200586] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.214059] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.227532] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.241012] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.254488] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.267963] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.281437] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.294928] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY0)
[   76.299817] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY1)
[   76.304705] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY2)
[   76.309593] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY3)
[   76.314483] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY4)
[   76.323432] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.336998] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.350561] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.364121] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.377692] cf_axi_dds a4b10000.axi-ad9084-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.02.b) at 0xA4B10000 mapped to 0x(____ptrval____), probed DDS AD9081
[   76.392053] of_cfs_init
[   76.394517] of_cfs_init: OK
[   76.397359] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   76.424595] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   76.430648] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   76.437898] clk: Not disabling unused clocks
[   76.442163] PM: genpd: Disabling unused power domains
[   76.447620] ALSA device list:
[   76.450583]   No soundcards found.
[   76.454217] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   76.462836] cfg80211: failed to load regulatory.db
[   76.640747] EXT4-fs (mmcblk0p2): mounted filesystem 5b950520-50b5-4445-b465-3291bcc7be79 r/w with ordered data mode. Quota mode: none.
[   76.652885] VFS: Mounted root (ext4 filesystem) on device 179:2.
[   76.661921] devtmpfs: mounted
[   76.665711] Freeing unused kernel memory: 3648K
[   76.670304] Run /sbin/init as init process
[   77.335265] systemd[1]: System time advanced to built-in epoch: Mon 2026-04-13 15:38:05 EDT
[   77.366334] systemd[1]: Failed to find module 'autofs4'
[!p]104 [?7h[   77.432141] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[   77.466482] systemd[1]: Detected architecture arm64.
Welcome to Debian GNU/Linux 13 (trixie)!
[   77.508883] systemd[1]: Hostname set to <analog>.
[   77.580535] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[   78.980277] systemd[1]: /usr/lib/systemd/system/iiod.service:16: Invalid environment assignment, ignoring: $IIOD_EXTRA_OPTS=
[   79.156446] systemd[1]: Queued start job for default target graphical.target.
[   79.166887] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[  OK  ] Created slice system-getty.slice - Slice /system/getty.
[   79.188831] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[  OK  ] Created slice system-modprobe.slice - Slice /system/modprobe.
[   79.208795] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[  OK  ] Created slice system-serial\x2dget…slice - Slice /system/serial-getty.
[   79.232776] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[  OK  ] Created slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[   79.256457] systemd[1]: Created slice user.slice - User and Session Slice.
[  OK  ] Created slice user.slice - User and Session Slice.
[   79.276314] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[  OK  ] Started systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[   79.300252] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point skipped, unmet condition check ConditionPathExists=/proc/sys/fs/binfmt_misc
[   79.317871] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-20da5528\x2d01.device - /dev/disk/by-partuuid/20da5528-01...
         Expecting device dev-disk-by\x2dpa…dev/disk/by-partuuid/20da5528-01...
[   79.340136] systemd[1]: Expecting device dev-ttyAMA0.device - /dev/ttyAMA0...
[   79.356130] systemd[1]: Expecting device dev-ttyGS0.device - /dev/ttyGS0...
[   79.372133] systemd[1]: Expecting device dev-ttyGS1.device - /dev/ttyGS1...
[   79.388132] systemd[1]: Expecting device dev-ttyPS0.device - /dev/ttyPS0...
[   79.404133] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[   79.420213] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[  OK  ] Reached target nss-user-lookup.target - User and Group Name Lookups.
[   79.440185] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[  OK  ] Reached target remote-fs.target - Remote File Systems.
[   79.460160] systemd[1]: Reached target slices.target - Slice Units.
[  OK  ] Reached target slices.target - Slice Units.
[   79.476179] systemd[1]: Reached target swap.target - Swaps.
[  OK  ] Reached target swap.target - Swaps.
[   79.496809] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[  OK  ] Listening on systemd-creds.socket - Credential Encryption/Decryption.
[   79.520386] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[  OK  ] Listening on systemd-initctl.socke…- initctl Compatibility Named Pipe.
[   79.544384] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[  OK  ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log).
[   79.568409] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[  OK  ] Listening on systemd-journald.socket - Journal Sockets.
[   79.588230] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[   79.600274] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[   79.612293] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[  OK  ] Listening on systemd-udevd-control.socket - udev Control Socket.
[   79.632321] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[  OK  ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   79.656594] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   79.677484] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   79.692356] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[   79.720347] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   79.748436] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System skipped, unmet condition check ConditionPathExists=/sys/kernel/tracing
[   79.765816] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[   79.789822] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   79.808411] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes skipped, unmet condition check ConditionFileNotEmpty=/lib/modules/6.12.77-g4b2e305bc496/modules.devname
[   79.828446] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   79.852456] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   79.873998] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
         Starting modprobe@efi_pstore.servi… - Load Kernel Module efi_pstore...
[   79.900478] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   79.920447] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[   79.941077] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   79.953982] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[   79.966137] systemd[1]: Starting systemd-journald.service - Journal Service...
[   79.990632] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   80.012230] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[   80.032206] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
         Starting system[   80.052494] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
d-tmpfiles-setup-de… Device Nodes in /dev [   80.069946] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
gracefully...
         Starting systemd-udev-load-credent…Load udev Rules from Credentials...
[   80.105988] systemd-journald[200]: Collecting audit messages is disabled.
[   80.120429] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   80.162280] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[  OK  ] Mounted dev-hugepages.mount - Huge Pages File System.
[   80.180510] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[  OK  ] Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   80.200582] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[  OK  ] Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[   80.224852] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[  OK  ] Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   80.256598] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[  OK  ] Mounted tmp.mount - Temporary Directory /tmp.
[   80.284446] systemd[1]: Started systemd-journald.service - Journal Service.
[  OK  ] Started systemd-journald.service - Journal Service.
[  OK  ] Finished fake-hwclock-load.service - Restore the current clock.
[  OK  ] Finished modprobe@configfs.service - Load Kernel Module configfs.
[  OK  ] Finished modprobe@drm.service - Load Kernel Module drm.
[  OK  ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[  OK  ] Finished modprobe@fuse.service - Load Kernel Module fuse.
[  OK  ] Finished systemd-modules-load.service - Load Kernel Modules.
[  OK  ] Finished systemd-tmpfiles-setup-de…ic Device Nodes in /dev gracefully.
[  OK  ] Finished systemd-udev-load-credent…- Load udev Rules from Credentials.
         Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
         Mounting sys-kernel-config.mount - Kernel Configuration File System...
         Starting systemd-remount-fs.servic…unt Root and Kernel File Systems...
         Starting systemd-sysctl.service - Apply Kernel Variables...
[  OK  ] Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[  OK  ] Mounted sys-kernel-config.mount - Kernel Configuration File System.
[  OK  ] Finished systemd-sysctl.service - Apply Kernel Variables.
[  OK  ] Finished systemd-remount-fs.servic…mount Root and Kernel File Systems.
         Starting systemd-journal-flush.ser…sh Journal to Persistent Storage...
         Starting systemd-random-seed.service - Load/Save OS Random Seed...
         Starting systemd-tmpfiles-setup-de…eate Static Device Nodes in /dev...
[  OK  ] Finished systemd-tmpfiles-setup-de…Create Static Device Nodes in /dev.
[  OK  ] Reached target local-fs-pre.target…Preparation for Local File Systems.
         Starting systemd-udevd.service - R…ager for Device Events and Files...
[  OK  ] Finished systemd-udev-trigger.service - Coldplug All udev Devices.
         Starting ifupdown-pre.service - He…synchronize boot up for ifupdown...
         Starting systemd-udev-settle.servi…o Complete Device Initialization...
[  OK  ] Finished ifupdown-pre.service - He…o synchronize boot up for ifupdown.
[  OK  ] Started systemd-udevd.service - Ru…anager for Device Events and Files.
         Starting plymouth-start.service - Show Plymouth Boot Screen...
[  OK  ] Found device dev-ttyAMA0.device - /dev/ttyAMA0.
[  OK  ] Finished systemd-random-seed.service - Load/Save OS Random Seed.
[  OK  ] Started plymouth-start.service - Show Plymouth Boot Screen.
[  OK  ] Found device dev-disk-by\x2dpartuu… /dev/disk/by-partuuid/20da5528-01.
[  OK  ] Finished systemd-journal-flush.ser…lush Journal to Persistent Storage.
[  OK  ] Finished systemd-udev-settle.servi… To Complete Device Initialization.
[  OK  ] Started systemd-ask-password-plymo…quests to Plymouth Directory Watch.
[  OK  ] Reached target paths.target - Path Units.
[  OK  ] Listening on systemd-rfkill.socket…ll Switch Status /dev/rfkill Watch.
         Starting systemd-fsck@dev-disk-by\…dev/disk/by-partuuid/20da5528-01...
[  OK  ] Finished systemd-fsck@dev-disk-by\… /dev/disk/by-partuuid/20da5528-01.
         Mounting boot.mount - /boot...
[  OK  ] Mounted boot.mount - /boot.
[  OK  ] Reached target local-fs.target - Local File Systems.
[  OK  ] Listening on systemd-sysext.socket… System Extension Image Management.
         Starting networking.service - Raise network interfaces...
         Starting plymouth-read-write.servi…ymouth To Write Out Runtime Data...
         Starting systemd-tmpfiles-setup.se…ate System Files and Directories...
[  OK  ] Finished plymouth-read-write.servi…Plymouth To Write Out Runtime Data.
[  OK  ] Finished systemd-tmpfiles-setup.se…reate System Files and Directories.
[  OK  ] Reached target sysinit.target - System Initialization.
[  OK  ] Started apt-daily.timer - Daily apt download activities.
[  OK  ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities.
[  OK  ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
[  OK  ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems.
[  OK  ] Started fake-hwclock-save.timer - Periodically save current clock.
[  OK  ] Started fstrim.timer - Discard unused filesystem blocks once a week.
[  OK  ] Started logrotate.timer - Daily rotation of log files.
[  OK  ] Started man-db.timer - Daily man-db regeneration.
[  OK  ] Started ntpsec-rotate-stats.timer - Rotate ntpd stats daily.
[  OK  ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
[  OK  ] Reached target timers.target - Timer Units.
[  OK  ] Listening on avahi-daemon.socket -…DNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on dbus.socket - D-Bus System Message Bus Socket.
[  OK  ] Listening on sshd-unix-local.socke…temd-ssh-generator, AF_UNIX Local).
[  OK  ] Listening on systemd-hostnamed.socket - Hostname Service Socket.
[  OK  ] Reached target sockets.target - Socket Units.
[  OK  ] Reached target basic.target - Basic System.
         Starting accounts-daemon.service - Accounts Service...
         Starting adi-power.service - Analog Devices power up/down sequence...
         Starting avahi-daemon.service - Avahi mDNS/DNS-SD Stack...
         Starting blueman-mechanism.service - Bluetooth management mechanism...
[  OK  ] Started cron.service - Regular background program processing daemon.
         Starting dbus.service - D-Bus System Message Bus...
         Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots...
[  OK  ] Started fan-control.service - fan-control.
         Starting fix-display-port.service - Fix DP audio and X11...
         Starting iiod_context_attr.service…ating IIOD Context Attributes......
         Starting systemd-logind.service - User Login Management...
         Starting udisks2.service - Disk Manager...
[  OK  ] Finished networking.service - Raise network interfaces.
[  OK  ] Started systemd-logind.service - User Login Management.
[  OK  ] Finished fix-display-port.service - Fix DP audio and X11.
[  OK  ] Started dbus.service - D-Bus System Message Bus.
         Starting NetworkManager.service - Network Manager...
         Starting wpa_supplicant.service - WPA supplicant...
[  OK  ] Started avahi-daemon.service - Avahi mDNS/DNS-SD Stack.
[  OK  ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots.
         Starting polkit.service - Authorization Manager...
[  OK  ] Finished iiod_context_attr.service…reating IIOD Context Attributes....
[  OK  ] Finished adi-power.service - Analog Devices power up/down sequence.
[  OK  ] Started wpa_supplicant.service - WPA supplicant.
[  OK  ] Started polkit.service - Authorization Manager.
[  OK  ] Started accounts-daemon.service - Accounts Service.
         Starting systemd-hostnamed.service - Hostname Service...
[  OK  ] Started systemd-hostnamed.service - Hostname Service.
[  OK  ] Started udisks2.service - Disk Manager.
         Starting NetworkManager-dispatcher…anager Script Dispatcher Service...
[  OK  ] Started NetworkManager.service - Network Manager.
[  OK  ] Reached target network.target - Network.
         Starting htpdate.service - HTTP based time synchronization tool...
[  OK  ] Started iiod.service - IIO Daemon.
         Starting ntpsec.service - Network Time Service...
         Starting ssh.service - OpenBSD Secure Shell server...
         Starting systemd-user-sessions.service - Permit User Sessions...
[  OK  ] Started udiskie.service - Udiskie …rvice for managing removable media.
[  OK  ] Started NetworkManager-dispatcher.… Manager Script Dispatcher Service.
[  OK  ] Started htpdate.service - HTTP based time synchronization tool.
[  OK  ] Finished systemd-user-sessions.service - Permit User Sessions.
         Starting lightdm.service - Light Display Manager...
         Starting plymouth-quit-wait.servic…d until boot process finishes up...
[  OK  ] Started ntpsec.service - Network Time Service.
[!p]104 [?7h[!p]104 [?7h
Debian GNU/Linux 13 analog ttyAMA0
analog login: root (automatic login)
Password:
Linux analog 6.12.77-g4b2e305bc496 #1 SMP Wed Jul 15 15:56:08 UTC 2026 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[?2004hroot@analog:~# ls
[?2004l
[?2004hroot@analog:~# cd ..
[?2004l
[?2004hroot@analog:/# ls
[?2004l
bin   config	 dev  home  lib		  lost+found  mnt  proc  run   srv  tmp  var
boot  copyright  etc  img   LICENSE.html  media       opt  root  sbin  sys  usr
[?2004hroot@analog:/# cd root
[?2004l
[?2004l
[?2004l
[?2004l
[?2004hroot@analog:/# cd home/
[?2004l
[?2004hroot@analog:/home# ls
[?2004l
analog
[?2004hroot@analog:/home# cd analog/
[?2004l
[?2004hroot@analog:/home/analog# ls
[?2004l
Desktop  Documents  Downloads  Music  Pictures	Public	Templates  Videos
[?2004hroot@analog:/home/analog# cd ../..
[?2004l
[?2004hroot@analog:/# cd ..
[?2004l
[?2004l
[?2004hroot@analog:/# cd linu   x
[?2004l
-bash: cd: linux: No such file or directory
[?2004hroot@analog:/# sed -i 's/^CONFIG_EXTRA_FIRMWARE="/&new_profile.bin /' arch/arm64/configs/adi_versal_defconfig
[?2004l
sed: can't read arch/arm64/configs/adi_versal_defconfig: No such file or directory
/cfs-file/__key/communityserver-discussions-components-files/967/Bootlog_5F00_AD9084_5F00_VCK190.txt
  • Reference Design Link: analogdevicesinc.github.io/system-level/solutions/reference-designs/ad9084_ebz/quickstart/versal/
  • Start at the root page https://analogdevicesinc.github.io/system-level/solutions/reference-designs/ad9084_ebz/
    Your ADC side is not creating a link
    This is likely due to populated ferrites on your supplies to the JTX lines. See  AD9084 + VCK190 RX Calibration Error and DAC not transmitting
    -Travis
