AD9084 + VCK190 RX Calibration Error and DAC not transmitting
Product Number: AD9084
Setup
  • Carrier: VCK190 [rev], EVAL-AD9084 / AD9084-FMCA-EBZ [board rev C]
  • Linux: analogdevicesinc/linux, branch xlnx/release/v6.12.y-2026r1, config adi_versal_apollo_defconfig
  • HDL: analogdevicesinc/hdl, branch hdl_2026_r1, ad9084_ebz/vck190, default JESD parameters
  • Device tree: [versal-vck190-reva-ad9084-204C-M4-L4-NP16-20p0-4x4.dts], profile 204C_M4_L4_NP16_20p0_4x4.bin
  • Boot image: default Versal image from Kuiper 2026.1.0 and build from xlnx/release/v6.12.y-2026r1 + hdl_2026_r1
  • JESD204C, 64b/66b, L=4, M=4, F=2, S=1, Np=16, lane rate 20.625 Gbps, device clock 312.5 MHz
During boot, the SERDES JRx initialization calibration fails on both JRx deframer links, preventing the links from coming up cleanly. However, I am able to receive ADC data, but I am unable to transmit data through the DAC. See log below:
[ 69.843899] ad9088 spi1.0: JESD TX (JRX Deframer Link A0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
[ 70.876046] ad9088 spi1.0: cpu_status = 0x00
[ 70.880315] ad9088 spi1.0: cals_duration_msec = 58027
[ 70.885363] ad9088 spi1.0: init_err_codes[0] = 0x208 init_err_cals[0] = 0x04
[ 70.892580] ad9088 spi1.0: init_err_codes[1] = 0x00 init_err_cals[1] = 0x00
[ 70.899710] ad9088 spi1.0: Apollo API call adi_apollo_serdes_jrx_init_cal failed with error: SERDES cal error (-85)
[ 70.910139] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] In clocks_enable got error from cb: -5 (ignoring!)
[ 72.011014] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
[ 72.023366] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable
[ 72.035712] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage5 -> clocks_enable
[ 72.048057] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage5 -> clocks_enable
[ 72.063661] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clocks_enable -> link_enable
[ 72.075577] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clocks_enable -> link_enable
[ 72.087490] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clocks_enable -> link_enable
[ 72.099401] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clocks_enable -> link_enable
[ 72.123646] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Phase Difference 0
[ 72.199663] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-0@5 status: Link is good
[ 72.208631] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-1@1 status: Undef
[ 72.216988] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-2@3 status: Undef
[ 72.225343] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-3@7 status: Undef
[ 72.233688] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C User status: Fail, SYSREF Phase: Locked
I also tested with the default image come with the Kuiper 2026.1.0 full and I seeing the same issue as building from HDL & Linux repo, where the calibration failed but RX working and TX not working. I also notice the result varies between boots and power cycles. In one boot only lane 0@5 (side A) is “Link is good”. In another boot only lane 1@1 is good.
Here are more status messages:
dmesg | grep -i "ad9088\|jesd"
cat /sys/kernel/debug/iio/iio:device*/status
[    1.037875] jesd204: created con: id=0, topo=0, link=4, /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.049913] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
[    1.061940] jesd204: created con: id=2, topo=0, link=0, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-tx@a4b90000
[    1.073176] jesd204: created con: id=3, topo=0, link=4, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-rx@a4a90000
[    1.084410] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@a4b90000 <-> /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000
[    1.096607] jesd204: created con: id=5, topo=0, link=4, /fpga-axi@0/axi-jesd204-rx@a4a90000 <-> /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000
[    1.108809] jesd204: created con: id=6, topo=0, link=4, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.119344] jesd204: created con: id=7, topo=0, link=0, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
[    1.129883] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:0] transition uninitialized -> initialized
[    1.139800] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:2] transition uninitialized -> initialized
[    1.149715] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:4] transition uninitialized -> initialized
[    1.159631] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:6] transition uninitialized -> initialized
[    1.169547] jesd204: found 7 devices and 1 topologies
[    2.296465] jesd204: /axi/spi@ff040000/adf4030@2,jesd204:1,parent=spi2.2: Using as SYSREF provider
[    2.602329] axi-jesd204-rx a4a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.614075] axi-jesd204-tx a4b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
[    2.626009] ad9088 spi1.0: supply vdd not found, using dummy regulator
[    2.637056] ad9088 spi1.0: api v2.0.10
[    2.640896] ad9088 spi1.0: host is using little endian mode.
[    2.649695] ad9088 spi1.0: Waiting for link to establish...
[    2.657390] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
[    2.662947] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
[    2.684160] ad9088 spi1.0: Waiting for link to establish...
[    2.691853] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
[    2.697407] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
[    2.719365] ad9088 spi1.0: adi_apollo_startup_execute: startup_type 0x0000007f
[    2.726580] ad9088 spi1.0: adi_apollo_startup_execute: profile checksum 1922412250
[    2.734144] ad9088 spi1.0: adi_apollo_startup_execute: fw_provider desc 'Linux Firmware Provider'
[    2.748495] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_FW_LOAD
[    2.760674] ad9088 spi1.0: adi_apollo_startup_execute: TyE bypassed: 0
[    2.767197] ad9088 spi1.0: adi_apollo_startup_execute: Running scenario = 4
[    2.777197] ad9088 spi1.0: adi_apollo_startup_execute: Apollo Silicon Grade = 01
[    2.784625] ad9088 spi1.0: adi_apollo_startup_execute: Loading TyE SecureBoot Header image...
[    2.793149] ad9088 spi1.0: Loading 4096 bytes
[    2.797795] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core0 firmware image...
[    2.805710] ad9088 spi1.0: Loading 196604 bytes
[    2.824095] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core1 firmware image...
[    2.832009] ad9088 spi1.0: Loading 360444 bytes
[    2.861935] ad9088 spi1.0: adi_apollo_startup_execute: Loading TinyE Operation firmware image...
[    2.870721] ad9088 spi1.0: Loading 23540 bytes
[    2.876825] ad9088 spi1.0: adi_apollo_startup_execute: Boot Ready bit has been set
[    3.111276] ad9088 spi1.0: BF_RAM_BOOT_CORE1_STATUS: 29.
[    3.116606] ad9088 spi1.0: SECURE_BOOT_STAGE_0 CHECK: Passed.
[    3.122354] ad9088 spi1.0: SECURE_BOOT_STAGE_1 CHECK: Passed.
[    3.128095] ad9088 spi1.0: adi_apollo_startup_execute: seq_fw_load: OK
[    3.134617] ad9088 spi1.0: ADI_APOLLO_STARTUP_SEQ_PROFILE_LOAD
[    3.195272] ad9088 spi1.0: Core 1 Ram Boot Status: 0x1D
[    3.200498] ad9088 spi1.0: adi_apollo_startup_execute: Loading device profile (ver=10.1.2, 4T4R)...
[    3.209538] ad9088 spi1.0: adi_apollo_startup_execute: Profile checksum: 1922412250
[    3.217199] ad9088 spi1.0: Device Profile address: 0x21028860
[    3.222940] ad9088 spi1.0: Loading 23720 bytes
[    3.387271] ad9088 spi1.0: Core 1 Ram Boot Status: 0x25
[    5.743268] ad9088 spi1.0: Core 1 Ram Boot Status: 0x03
[    5.803269] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
[    5.808495] ad9088 spi1.0: adi_apollo_startup_execute: seq_profile_load: OK
[    5.815451] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TMU_EN
[    5.827238] ad9088 spi1.0: adi_apollo_startup_execute: seq_tmu_enable: OK
[    5.834026] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_DP_CONFIG
[    6.787312] ad9088 spi1.0: adi_apollo_startup_execute: seq_dp_config: OK
[    6.794013] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_LINK_EN
[    6.801896] ad9088 spi1.0: adi_apollo_startup_execute: seq_link_en: OK
[    6.808418] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TXRX_ACTIVATE
[    6.817113] ad9088 spi1.0: adi_apollo_startup_execute: seq_txrx_activate: OK
[    6.824156] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_SYNC
[    6.832349] ad9088 spi1.0: adi_apollo_startup_execute: seq_sync: OK
[    6.838614] ad9088 spi1.0: API ver: 2.0.10
[    6.842721] ad9088 spi1.0: REG_RAM_BOOT_ERROR 0x0
[    6.847425] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
[    6.856704] ad9088 spi1.0: Ping (core 1) cmd/res: 0x00000000/0x00000001
[    6.867289] ad9088 spi1.0: Ping (core 0) cmd/res: 0x12345678/0x1234567a
[    6.877986] ad9088 spi1.0: FW ver: 2.0.6
[    6.881974] ad9088 spi1.0: AD9084  Rev. 4 Grade 3 (API 2.0.10) probed
[    6.888553] ad9088 spi1.0: BMEM sniffer: 4 channels (4T4R mode)
[    6.894832] ad9088 spi1.0: ad9088-fft-sniffer-A: No IRQ found, using polling mode
[    6.902521] ad9088 spi1.0: ad9088-fft-sniffer-B: No IRQ found, using polling mode
[    6.942622] cf_axi_adc a4a10000.axi-ad9084-rx-hpc: ADI AIM (10.03.\x00) probed ADC AD9088 as MASTER
[    6.975002] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
[    6.986320] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
[    6.997626] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
[    7.008930] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
[    7.020237] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> initialized
[    7.031548] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> initialized
[    7.042853] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> initialized
[    7.054156] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> initialized
[    7.065466] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
[    7.076769] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
[    7.088072] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
[    7.099381] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
[    7.110688] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> idle
[    7.121384] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> idle
[    7.132079] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> idle
[    7.142777] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> idle
[    7.153475] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition idle -> device_init
[    7.164608] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition idle -> device_init
[    7.175737] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition idle -> device_init
[    7.186866] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition idle -> device_init
[    7.198000] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
[    7.209565] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
[    7.221128] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition device_init -> link_init
[    7.232693] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition device_init -> link_init
[    7.244270] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
[    7.256095] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
[    7.267919] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_init -> link_supported
[    7.279743] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_init -> link_supported
[    7.291856] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
[    7.304120] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
[    7.316378] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_supported -> link_pre_setup
[    7.328636] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_supported -> link_pre_setup
[    7.353194] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
[    7.365544] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
[    7.377889] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_pre_setup -> clk_sync_stage1
[    7.390234] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_pre_setup -> clk_sync_stage1
[    7.402585] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
[    7.415017] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
[    7.427451] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage1 -> clk_sync_stage2
[    7.439883] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage1 -> clk_sync_stage2
[    7.452321] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
[    7.464754] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
[    7.477185] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage2 -> clk_sync_stage3
[    7.489618] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage2 -> clk_sync_stage3
[    8.797742] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage4
[    8.810185] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage4
[    8.822619] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage3 -> clk_sync_stage4
[    8.835051] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage3 -> clk_sync_stage4
[    8.847483] jesd204: /fpga-axi@0/axi-jesd204-rx@a4a90000,jesd204:4,parent=a4a90000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 8, Link[4] lanes 4
[    8.862697] jesd204: /fpga-axi@0/axi-jesd204-tx@a4b90000,jesd204:5,parent=a4b90000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
[    8.887729] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage4 -> link_setup
[    8.899732] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage4 -> link_setup
[    8.911733] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage4 -> link_setup
[    8.923732] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage4 -> link_setup
[    8.973584] ad9088 spi1.0: Run clock conditioning cal (can take up to 10 secs)...
[   11.471606] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.480790] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.489960] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.499129] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.508294] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.517463] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.526628] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
[   11.535791] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
[   11.545000] ad9088 spi1.0: Run ADC cal from NVM (can take up to 100 secs)...
[   11.556172] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_setup -> opt_setup_stage1
[   11.568261] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_setup -> opt_setup_stage1
[   11.580348] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_setup -> opt_setup_stage1
[   11.592436] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_setup -> opt_setup_stage1
[   70.013722] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
[   70.026346] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2
[   70.038952] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage1 -> opt_setup_stage2
[   70.051561] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage1 -> opt_setup_stage2
[   70.064178] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
[   70.076785] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3
[   70.089390] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage2 -> opt_setup_stage3
[   70.101996] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage2 -> opt_setup_stage3
[   70.114604] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
[   70.127212] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4
[   70.139818] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage3 -> opt_setup_stage4
[   70.152423] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage3 -> opt_setup_stage4
[   70.165030] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
[   70.177636] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5
[   70.190243] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage4 -> opt_setup_stage5
[   70.202849] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage4 -> opt_setup_stage5
[   70.227609] ad9088 spi1.0: JESD TX (JRX Deframer Link A0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
[   71.259673] ad9088 spi1.0: cpu_status = 0x00
[   71.263942] ad9088 spi1.0: cals_duration_msec = 58023
[   71.268989] ad9088 spi1.0: init_err_codes[0] = 0x208          init_err_cals[0] = 0x04
[   71.276206] ad9088 spi1.0: init_err_codes[1] = 0x00   init_err_cals[1] = 0x00
[   71.283336] ad9088 spi1.0: Apollo API call adi_apollo_serdes_jrx_init_cal failed with error: SERDES cal error (-85)
[   71.293765] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] In clocks_enable got error from cb: -5 (ignoring!)
[   71.306633] ad9088 spi1.0: JESD TX (JRX Deframer Link B0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
[   72.347693] ad9088 spi1.0: cpu_status = 0x00
[   72.351963] ad9088 spi1.0: cals_duration_msec = 58023
[   72.357010] ad9088 spi1.0: init_err_codes[0] = 0x00   init_err_cals[0] = 0x00
[   72.364139] ad9088 spi1.0: init_err_codes[1] = 0x208          init_err_cals[1] = 0x04
[   72.371355] ad9088 spi1.0: Apollo API call adi_apollo_serdes_jrx_init_cal failed with error: SERDES cal error (-85)
[   72.381784] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] In clocks_enable got error from cb: -5 (ignoring!)
[   72.394664] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
[   72.407014] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable
[   72.419362] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage5 -> clocks_enable
[   72.431708] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage5 -> clocks_enable
[   72.448144] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clocks_enable -> link_enable
[   72.460059] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clocks_enable -> link_enable
[   72.471970] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clocks_enable -> link_enable
[   72.483882] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clocks_enable -> link_enable
[   72.511273] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Phase Difference 0
[   72.587290] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-0@5 status: Undef
[   72.595650] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-1@1 status: Undef
[   72.604006] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-2@3 status: Undef
[   72.612361] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-3@7 status: Undef
[   72.620707] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C User status: Fail, SYSREF Phase: Locked
[   72.630532] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] In link_running got error from cb: -1 (ignoring!)
[   72.643318] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Phase Difference 0
[   72.719287] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-0@1 status: Undef
[   72.727647] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-1@7 status: Link is good
[   72.736611] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-2@10 status: Undef
[   72.745052] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-3@3 status: Undef
[   72.753398] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C User status: Fail, SYSREF Phase: Locked
[   72.763222] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] In link_running got error from cb: -1 (ignoring!)
[   72.776017] ad9088 spi1.0: JESD RX (JTX Framer Link A0) Link4 204C PLL locked, PHASE established, MODE valid
[   72.785858] ad9088 spi1.0: JESD RX (JTX Framer Link B0) Link6 204C PLL locked, PHASE established, MODE valid
[   72.795680] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_enable -> link_running
[   72.807505] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_enable -> link_running
[   72.819331] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_enable -> link_running
[   72.831155] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_enable -> link_running
[   73.783645] ad9088 spi1.0: Total BSYNC path delay 2162065 fs
[   74.238899] ad9088 spi1.0: MCS Initcal Status: Passed
[   76.355497] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_running -> opt_post_setup_stage1
[   76.368192] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_running -> opt_post_setup_stage1
[   76.380888] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_running -> opt_post_setup_stage1
[   76.393582] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_running -> opt_post_setup_stage1
[   76.406281] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.419756] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.433229] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.446703] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage1 -> opt_post_setup_stage2
[   76.460182] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.473658] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.487132] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.500606] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage2 -> opt_post_setup_stage3
[   76.514099] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY0)
[   76.518988] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY1)
[   76.523876] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY2)
[   76.528764] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY3)
[   76.533653] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY4)
[   76.542600] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.556165] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.569729] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage3 -> opt_post_running_stage
[   76.583289] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage3 -> opt_post_running_stage
--- PLL1 ---
Status: Locked
Using:  CLKIN1 @ 125000000 Hz
PFD:    6250 kHz
--- PLL2 ---
Status: Locked (Synchronized)
Frequency:      2500000000 Hz (Autocal cap bank value: 10)
SYSREF Status:  Valid & Locked
SYNC Status:    Synchronized
Lock Status:    PLL1 & PLL2 Locked
REF Status:     OK
PLL Status:     Locked
TDC Error:      OK
Temp Align Error:       OK
FSM Status:     Idle
ADC Status:     Idle
Math Status:    Idle
DL Status:      Idle
TDC Status:     Idle
JRX ADI_APOLLO_LINK_A0: JESD204C Subclass=1 L=4 M=4 F=2 S=1 Np=16 CS=0 link_en=Enabled
    Lane0 status: Reset
    Lane1 status: Undef
    Lane2 status: Reset
    Lane3 status: Undef
    Lane4 status: Reset
    Lane5 status: Undef
    Lane6 status: Reset
    Lane7 status: Undef
    Lane8 status: Reset
    Lane9 status: Reset
    Lane10 status: Reset
    Lane11 status: Reset
JRX ADI_APOLLO_LINK_B0: JESD204C Subclass=1 L=4 M=4 F=2 S=1 Np=16 CS=0 link_en=Enabled
    Lane0 status: Reset
    Lane1 status: Undef
    Lane2 status: Reset
    Lane3 status: Undef
    Lane4 status: Reset
    Lane5 status: Reset
    Lane6 status: Reset
    Lane7 status: Link is good
    Lane8 status: Reset
    Lane9 status: Reset
    Lane10 status: Undef
JTX ADI_APOLLO_LINK_A0: JESD204C Subclass=1 L=4 M=4 F=2 S=1 Np=16 CS=0 link_en=Enabled
JTX ADI_APOLLO_LINK_B0: JESD204C Subclass=1 L=4 M=4 F=2 S=1 Np=16 CS=0 link_en=Enabled
Is this failure expected with the default hdl_2026_r1 and xlnx/release/v6.12.y-2026r1 branch on the VCK190? And am I using the correct branch?
  • Hi ,
    I just checked the boot files provided in kuiper_full_64_image_2026.1.0.zip and everything works on our side. I attached a bootlog.
    Can you share the AD9084 eval board serial and revision that you are using?
    Bogdan
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
    [    0.000000] Linux version 6.12.77-g4b2e305bc496 (root@b7fad4fd30e3) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Wed Jul 15 15:56:08 UTC 2026
    [    0.000000] Machine model: Analog Devices AD9084-FMCA-EBZ (Rev. B0) @Xilinx/vck190
    [    0.000000] earlycon: pl11 at MMIO32 0x00000000ff000000 (options '115200n8')
    [    0.000000] printk: legacy bootconsole [pl11] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x000000097fffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
    [    0.000000]   node   0: [mem 0x0000000800000000-0x000000097fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000097fffffff]
    [    0.000000] cma: Reserved 256 MiB at 0x0000000069e00000 on node -1
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 21 pages/cpu s45912 r8192 d31912 u86016
    [    0.000000] pcpu-alloc: s45912 r8192 d31912 u86016 alloc=21*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: Spectre-v2
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyAMA0 earlycon=pl011,mmio32,0xFF000000,115200n8 clk_ignore_unused root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x000000007c000000-0x0000000080000000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 160 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000f9080000
    [    0.000000] ITS: No ITS available, not enabling LPIs
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x1ffffffffffffff max_cycles: 0x1710239320, max_idle_ns: 440795206806 ns
    [    0.000000] sched_clock: 57 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
    [    0.008314] Console: colour dummy device 80x25
    [    0.012820] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.99 BogoMIPS (lpj=399999)
    [    0.023367] pid_max: default: 32768 minimum: 301
    [    0.028096] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.035760] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.044228] cacheinfo: Unable to detect cache hierarchy for CPU 0
    [    0.050908] rcu: Hierarchical SRCU implementation.
    [    0.055749] rcu: 	Max phase no-delay instances is 1000.
    [    0.061174] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.069460] EFI services will not be available.
    [    0.074128] smp: Bringing up secondary CPUs ...
    [    0.079003] Detected PIPT I-cache on CPU1
    [    0.079038] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
    [    0.079058] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
    [    0.079118] smp: Brought up 1 node, 2 CPUs
    [    0.100829] SMP: Total of 2 processors activated.
    [    0.105576] CPU: All CPU(s) started at EL2
    [    0.109709] CPU features: detected: 32-bit EL0 Support
    [    0.114895] CPU features: detected: CRC32 instructions
    [    0.120109] alternatives: applying system-wide alternatives
    [    0.126204] Memory: 7855124K/8388608K available (19520K kernel code, 2004K rwdata, 15068K rodata, 3648K init, 735K bss, 267716K reserved, 262144K cma-reserved)
    [    0.141027] devtmpfs: initialized
    [    0.148141] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.158004] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.166537] 22464 pages in range for non-PLT usage
    [    0.166545] 513984 pages in range for PLT usage
    [    0.171750] DMI not present or invalid.
    [    0.180457] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.186835] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.194152] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.202231] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.210342] audit: initializing netlink subsys (disabled)
    [    0.215883] audit: type=2000 audit(0.132:1): state=initialized audit_enabled=0 res=1
    [    0.223723] cpuidle: using governor menu
    [    0.227741] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.234623] ASID allocator initialised with 65536 entries
    [    0.240165] Serial: AMBA PL011 UART driver
    [    0.246611] /axi/interrupt-controller@f9000000: Fixed dependency cycle(s) with /axi/interrupt-controller@f9000000
    [    0.261479] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.268346] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.274677] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.281531] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.287859] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.294712] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.301041] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.307894] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.382270] raid6: neonx8   gen()  4145 MB/s
    [    0.454627] raid6: neonx4   gen()  4056 MB/s
    [    0.526983] raid6: neonx2   gen()  3372 MB/s
    [    0.599338] raid6: neonx1   gen()  2441 MB/s
    [    0.671689] raid6: int64x8  gen()  2334 MB/s
    [    0.744051] raid6: int64x4  gen()  2285 MB/s
    [    0.816403] raid6: int64x2  gen()  2222 MB/s
    [    0.888766] raid6: int64x1  gen()  1712 MB/s
    [    0.893075] raid6: using algorithm neonx8 gen() 4145 MB/s
    [    0.966565] raid6: .... xor() 3028 MB/s, rmw enabled
    [    0.971576] raid6: using neon recovery algorithm
    [    0.976496] iommu: Default domain type: Translated
    [    0.981335] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.987810] SCSI subsystem initialized
    [    0.991614] libata version 3.00 loaded.
    [    0.991707] usbcore: registered new interface driver usbfs
    [    0.997264] usbcore: registered new interface driver hub
    [    1.002644] usbcore: registered new device driver usb
    [    1.007870] mc: Linux media interface: v0.10
    [    1.012199] videodev: Linux video capture interface: v2.00
    [    1.017766] pps_core: LinuxPPS API ver. 1 registered
    [    1.022782] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    1.032012] PTP clock support registered
    [    1.035984] EDAC MC: Ver: 3.0.0
    [    1.039454] jesd204: created con: id=0, topo=0, link=4, /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
    [    1.051512] jesd204: created con: id=1, topo=0, link=0, /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000 <-> /fpga-axi@0/spi@a4a80000/ad9084@0
    [    1.063560] jesd204: created con: id=2, topo=0, link=0, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-tx@a4b90000
    [    1.074816] jesd204: created con: id=3, topo=0, link=4, /axi/spi@ff040000/hmc7044@1 <-> /fpga-axi@0/axi-jesd204-rx@a4a90000
    [    1.086077] jesd204: created con: id=4, topo=0, link=0, /fpga-axi@0/axi-jesd204-tx@a4b90000 <-> /fpga-axi@0/axi-ad9084-tx-hpc@a4b10000
    [    1.098296] jesd204: created con: id=5, topo=0, link=4, /fpga-axi@0/axi-jesd204-rx@a4a90000 <-> /fpga-axi@0/axi-ad9084-rx-hpc@a4a10000
    [    1.110517] jesd204: created con: id=6, topo=0, link=4, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
    [    1.121072] jesd204: created con: id=7, topo=0, link=0, /axi/spi@ff040000/adf4030@2 <-> /axi/spi@ff040000/hmc7044@1
    [    1.131631] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:0] transition uninitialized -> initialized
    [    1.141566] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:2] transition uninitialized -> initialized
    [    1.151500] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:4] transition uninitialized -> initialized
    [    1.161435] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0: JESD204[0:6] transition uninitialized -> initialized
    [    1.171370] jesd204: found 7 devices and 1 topologies
    [    1.176509] FPGA manager framework
    [    1.179959] Advanced Linux Sound Architecture Driver Initialized.
    [    1.186442] Bluetooth: Core ver 2.22
    [    1.190064] NET: Registered PF_BLUETOOTH protocol family
    [    1.195430] Bluetooth: HCI device and connection manager initialized
    [    1.201847] Bluetooth: HCI socket layer initialized
    [    1.206772] Bluetooth: L2CAP socket layer initialized
    [    1.211878] Bluetooth: SCO socket layer initialized
    [    1.217195] clocksource: Switched to clocksource arch_sys_counter
    [    1.223469] VFS: Disk quotas dquot_6.6.0
    [    1.227441] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    1.238575] NET: Registered PF_INET protocol family
    [    1.243702] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    1.254905] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    1.263566] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    1.271393] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    1.279684] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    1.288247] TCP: Hash tables configured (established 65536 bind 65536)
    [    1.294913] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    1.301896] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    1.309372] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    1.315331] RPC: Registered named UNIX socket transport module.
    [    1.321317] RPC: Registered udp transport module.
    [    1.326067] RPC: Registered tcp transport module.
    [    1.330816] RPC: Registered tcp-with-tls transport module.
    [    1.336354] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.343307] PCI: CLS 0 bytes, default 64
    [    1.347846] Initialise system trusted keyrings
    [    1.352469] workingset: timestamp_bits=62 max_order=21 bucket_order=0
    [    1.359316] NFS: Registering the id_resolver key type
    [    1.364435] Key type id_resolver registered
    [    1.368668] Key type id_legacy registered
    [    1.372724] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    1.379498] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    1.386981] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
    [    1.394152] fuse: init (API version 7.41)
    [    1.429562] NET: Registered PF_ALG protocol family
    [    1.434407] xor: measuring software checksum speed
    [    1.439732]    8regs           :  6713 MB/sec
    [    1.444580]    32regs          :  7287 MB/sec
    [    1.449559]    arm64_neon      :  5649 MB/sec
    [    1.453957] xor: using function: 32regs (7287 MB/sec)
    [    1.459058] Key type asymmetric registered
    [    1.463198] Asymmetric key parser 'x509' registered
    [    1.468156] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    1.475638] io scheduler mq-deadline registered
    [    1.480212] io scheduler kyber registered
    [    1.484269] io scheduler bfq registered
    [    1.490757] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.521717] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    1.529062] Serial: AMBA driver
    [    1.535986] brd: module loaded
    [    1.541199] loop: module loaded
    [    1.545027] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    1.554418] tun: Universal TUN/TAP device driver, 1.6
    [    1.559640] CAN device driver interface
    [    1.563884] SPI driver wl1271_spi has no spi_device_id for ti,wl1271
    [    1.570311] SPI driver wl1271_spi has no spi_device_id for ti,wl1273
    [    1.576731] SPI driver wl1271_spi has no spi_device_id for ti,wl1281
    [    1.583154] SPI driver wl1271_spi has no spi_device_id for ti,wl1283
    [    1.589571] SPI driver wl1271_spi has no spi_device_id for ti,wl1285
    [    1.595988] SPI driver wl1271_spi has no spi_device_id for ti,wl1801
    [    1.602403] SPI driver wl1271_spi has no spi_device_id for ti,wl1805
    [    1.608819] SPI driver wl1271_spi has no spi_device_id for ti,wl1807
    [    1.615234] SPI driver wl1271_spi has no spi_device_id for ti,wl1831
    [    1.621650] SPI driver wl1271_spi has no spi_device_id for ti,wl1835
    [    1.628066] SPI driver wl1271_spi has no spi_device_id for ti,wl1837
    [    1.634568] usbcore: registered new interface driver asix
    [    1.640042] usbcore: registered new interface driver ax88179_178a
    [    1.646219] usbcore: registered new interface driver cdc_ether
    [    1.652127] usbcore: registered new interface driver net1080
    [    1.657863] usbcore: registered new interface driver cdc_subset
    [    1.663861] usbcore: registered new interface driver zaurus
    [    1.669510] usbcore: registered new interface driver cdc_ncm
    [    1.675245] usbcore: registered new interface driver r8153_ecm
    [    1.681683] usbcore: registered new interface driver uas
    [    1.687077] usbcore: registered new interface driver usb-storage
    [    1.693209] usbcore: registered new interface driver usbserial_generic
    [    1.699814] usbserial: USB Serial support registered for generic
    [    1.705897] usbcore: registered new interface driver ftdi_sio
    [    1.711710] usbserial: USB Serial support registered for FTDI USB Serial Device
    [    1.719108] usbcore: registered new interface driver upd78f0730
    [    1.725097] usbserial: USB Serial support registered for upd78f0730
    [    1.732051] i2c_dev: i2c /dev entries driver
    [    1.737283] usbcore: registered new interface driver uvcvideo
    [    1.743794] Bluetooth: HCI UART driver ver 2.3
    [    1.748288] Bluetooth: HCI UART protocol H4 registered
    [    1.753476] Bluetooth: HCI UART protocol BCSP registered
    [    1.758852] Bluetooth: HCI UART protocol LL registered
    [    1.764041] Bluetooth: HCI UART protocol ATH3K registered
    [    1.769505] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [    1.775860] Bluetooth: HCI UART protocol Intel registered
    [    1.781326] Bluetooth: HCI UART protocol QCA registered
    [    1.786624] usbcore: registered new interface driver bcm203x
    [    1.792361] usbcore: registered new interface driver bpa10x
    [    1.798006] usbcore: registered new interface driver bfusb
    [    1.803563] usbcore: registered new interface driver btusb
    [    1.809133] usbcore: registered new interface driver ath3k
    [    1.814908] sdhci: Secure Digital Host Controller Interface driver
    [    1.821156] sdhci: Copyright(c) Pierre Ossman
    [    1.825557] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.831402] SMCCC: SOC_ID: ID = jep106:0049:0000 Revision = 0x00000000
    [    1.838101] zynqmp_firmware_probe Platform Management API v1.0
    [    1.844034] zynqmp_firmware_probe Trustzone version v1.0
    [    1.849863] xlnx_event_manager xlnx_event_manager: SGI 15 Registered over TF-A
    [    1.857170] xlnx_event_manager xlnx_event_manager: Xilinx Event Management driver probed
    [    1.904281] zynqmp-aes zynqmp-aes.0: will run requests pump with realtime priority
    [    1.912100] zynqmp_rsa zynqmp_rsa.0: RSA is not supported on the platform
    [    1.919055] usbcore: registered new interface driver usbhid
    [    1.924685] usbhid: USB HID core driver
    [    1.928663] SPI driver fb_seps525 has no spi_device_id for syncoam,seps525
    [    1.940099] ARM CCI_500 PMU driver probed
    [    1.940220] axi_sysid a5000000.axi-sysid-0: AXI System ID core version (1.01.a) found
    [    1.952351] axi_sysid a5000000.axi-sysid-0: [ad9084_ebz] on [vck190] git branch <hdl_2026_r1> git <4840c81f2af172b036cb3ccb3f9f2dc45ed9c1d3> clean [2026-07-16 13:38:41] UTC
    [    1.968209] fpga_manager fpga0: Xilinx Versal FPGA Manager registered
    [    1.974992] usbcore: registered new interface driver snd-usb-audio
    [    1.982293] pktgen: Packet Generator for packet performance testing. Version: 2.75
    [    1.991013] Initializing XFRM netlink socket
    [    1.995364] NET: Registered PF_INET6 protocol family
    [    2.000762] Segment Routing with IPv6
    [    2.004491] In-situ OAM (IOAM) with IPv6
    [    2.008516] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.014755] NET: Registered PF_PACKET protocol family
    [    2.019865] NET: Registered PF_KEY protocol family
    [    2.024780] can: controller area network core
    [    2.029208] NET: Registered PF_CAN protocol family
    [    2.034048] can: raw protocol
    [    2.037039] can: broadcast manager protocol
    [    2.041264] can: netlink gateway - max_hops=1
    [    2.045717] Bluetooth: RFCOMM TTY layer initialized
    [    2.050651] Bluetooth: RFCOMM socket layer initialized
    [    2.055852] Bluetooth: RFCOMM ver 1.11
    [    2.059639] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.065003] Bluetooth: BNEP filters: protocol multicast
    [    2.070279] Bluetooth: BNEP socket layer initialized
    [    2.075297] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    2.081278] Bluetooth: HIDP socket layer initialized
    [    2.086447] 9pnet: Installing 9P2000 support
    [    2.090771] NET: Registered PF_IEEE802154 protocol family
    [    2.096242] Key type dns_resolver registered
    [    2.105925] registered taskstats version 1
    [    2.110078] Loading compiled-in X.509 certificates
    [    2.120227] Btrfs loaded, zoned=no, fsverity=no
    [    2.163355] ff000000.serial: ttyAMA0 at MMIO 0xff000000 (irq = 18, base_baud = 0) is a PL011 rev3
    [    2.172349] printk: legacy console [ttyAMA0] enabled
    [    2.182332] printk: legacy bootconsole [pl11] disabled
    [    2.227249] adf4382 spi2.0: VCO=20000000000 PFD=125000000 RFout_div=1 N=160 FRAC1=0 FRAC2=0 MOD2=0
    [    2.238570] adf4382 spi2.0: PLL Locked, REF OK
    [    2.292357] hmc7044 spi2.1: PLL1: Locked, CLKIN1 @ 125000000 Hz, PFD: 6250 kHz - PLL2: Locked @ 2500.000000 MHz
    [    2.310374] jesd204: /axi/spi@ff040000/adf4030@2,jesd204:1,parent=spi2.2: Using as SYSREF provider
    [    2.324246] macb ff0c0000.ethernet eth0: Cadence GEM rev 0x0107010b at 0xff0c0000 irq 36 (9a:02:00:37:53:de)
    [    2.454834] macb ff0d0000.ethernet eth1: Cadence GEM rev 0x0107010b at 0xff0d0000 irq 37 (00:0a:23:00:00:01)
    [    2.465783] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    2.471286] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    2.479018] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    2.485025] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238fe65 hci version 0x110 quirks 0x0000808000000810
    [    2.494438] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xfe200000
    [    2.500502] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
    [    2.508771] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.515994] usb usb1: Product: xHCI Host Controller
    [    2.520870] usb usb1: Manufacturer: Linux 6.12.77-g4b2e305bc496 xhci-hcd
    [    2.527567] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    2.532721] hub 1-0:1.0: USB hub found
    [    2.536489] hub 1-0:1.0: 1 port detected
    [    2.541260] rtc_zynqmp f12a0000.rtc: registered as rtc0
    [    2.546493] rtc_zynqmp f12a0000.rtc: setting system clock to 2038-05-27T06:45:37 UTC (2158555537)
    [    2.555843] cdns-i2c ff020000.i2c: 100 kHz mmio ff020000 irq 42
    [    2.562388] at24 1-0050: supply vcc not found, using dummy regulator
    [    2.596433] cdns-i2c ff030000.i2c: 100 kHz mmio ff030000 irq 43
    [    2.603589] axi-jesd204-rx a4a90000.axi-jesd204-rx: AXI-JESD204-RX (1.07.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
    [    2.615347] axi-jesd204-tx a4b90000.axi-jesd204-tx: AXI-JESD204-TX (1.06.a). Encoder 64b66b, width 8/8, lanes 8, jesd204-fsm.
    [    2.627276] ad9088 spi1.0: supply vdd not found, using dummy regulator
    [    2.638332] ad9088 spi1.0: api v2.0.10
    [    2.642168] ad9088 spi1.0: host is using little endian mode.
    [    2.650115] ad9088 spi1.0: Waiting for link to establish...
    [    2.657812] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
    [    2.663373] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
    [    2.664527] mmc0: SDHCI controller on f1050000.mmc [f1050000.mmc] using ADMA 64-bit
    [    2.684618] ad9088 spi1.0: Waiting for link to establish...
    [    2.692312] ad9088 spi1.0: Apollo HSCI Auto Link: Active.
    [    2.697872] ad9088 spi1.0: Apollo HSCI Auto Link: Established.
    [    2.708580] Test direct register Passed
    [    2.712437] Test indirect register Passed
    [    2.716463] Test ARM memory Passed
    [    2.719863] ad9088 spi1.0: adi_apollo_startup_execute: startup_type 0x0000007f
    [    2.723809] mmc0: new high speed SDHC card at address aaaa
    [    2.727080] ad9088 spi1.0: adi_apollo_startup_execute: profile checksum 1922412250
    [    2.727085] ad9088 spi1.0: adi_apollo_startup_execute: fw_provider desc 'Linux Firmware Provider'
    [    2.732838] mmcblk0: mmc0:aaaa SP32G 29.7 GiB
    [    2.740123] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_FW_LOAD
    [    2.740133] ad9088 spi1.0: adi_apollo_startup_execute: TyE bypassed: 0
    [    2.752001]  mmcblk0: p1 p2 p3
    [    2.753343] ad9088 spi1.0: adi_apollo_startup_execute: Running scenario = 4
    [    2.753352] ad9088 spi1.0: adi_apollo_startup_execute: Apollo Silicon Grade = 00
    [    2.785123] ad9088 spi1.0: adi_apollo_startup_execute: Loading TyE SecureBoot Header image...
    [    2.793647] ad9088 spi1.0: Loading 4096 bytes
    [    2.798291] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core0 firmware image...
    [    2.806208] ad9088 spi1.0: Loading 196604 bytes
    [    2.824580] ad9088 spi1.0: adi_apollo_startup_execute: Loading Core1 firmware image...
    [    2.832494] ad9088 spi1.0: Loading 360444 bytes
    [    2.862408] ad9088 spi1.0: adi_apollo_startup_execute: Loading TinyE Operation firmware image...
    [    2.871195] ad9088 spi1.0: Loading 23424 bytes
    [    2.877292] ad9088 spi1.0: adi_apollo_startup_execute: Boot Ready bit has been set
    [    3.109208] ad9088 spi1.0: BF_RAM_BOOT_CORE1_STATUS: 29.
    [    3.114538] ad9088 spi1.0: SECURE_BOOT_STAGE_0 CHECK: Passed.
    [    3.120286] ad9088 spi1.0: SECURE_BOOT_STAGE_1 CHECK: Passed.
    [    3.126028] ad9088 spi1.0: adi_apollo_startup_execute: seq_fw_load: OK
    [    3.132549] ad9088 spi1.0: ADI_APOLLO_STARTUP_SEQ_PROFILE_LOAD
    [    3.193200] ad9088 spi1.0: Core 1 Ram Boot Status: 0x1D
    [    3.198427] ad9088 spi1.0: adi_apollo_startup_execute: Loading device profile (ver=10.1.2, 4T4R)...
    [    3.207467] ad9088 spi1.0: adi_apollo_startup_execute: Profile checksum: 1922412250
    [    3.215127] ad9088 spi1.0: Device Profile address: 0x21028860
    [    3.220869] ad9088 spi1.0: Loading 23720 bytes
    [    3.385200] ad9088 spi1.0: Core 1 Ram Boot Status: 0x25
    [    6.637199] ad9088 spi1.0: Core 1 Ram Boot Status: 0x32
    [    6.697198] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
    [    6.702426] ad9088 spi1.0: adi_apollo_startup_execute: seq_profile_load: OK
    [    6.709384] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TMU_EN
    [    6.721174] ad9088 spi1.0: adi_apollo_startup_execute: seq_tmu_enable: OK
    [    6.727961] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_DP_CONFIG
    [    7.681240] ad9088 spi1.0: adi_apollo_startup_execute: seq_dp_config: OK
    [    7.687941] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_LINK_EN
    [    7.695826] ad9088 spi1.0: adi_apollo_startup_execute: seq_link_en: OK
    [    7.702350] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_TXRX_ACTIVATE
    [    7.711045] ad9088 spi1.0: adi_apollo_startup_execute: seq_txrx_activate: OK
    [    7.718087] ad9088 spi1.0: adi_apollo_startup_execute: ADI_APOLLO_STARTUP_SEQ_SYNC
    [    7.726282] ad9088 spi1.0: adi_apollo_startup_execute: seq_sync: OK
    [    7.732548] ad9088 spi1.0: API ver: 2.0.10
    [    7.736655] ad9088 spi1.0: REG_RAM_BOOT_ERROR 0x0
    [    7.741359] ad9088 spi1.0: Core 1 Ram Boot Status: 0x34
    [    7.750639] ad9088 spi1.0: Ping (core 1) cmd/res: 0x00000000/0x00000001
    [    7.761317] ad9088 spi1.0: Ping (core 0) cmd/res: 0x12345678/0x1234567a
    [    7.772015] ad9088 spi1.0: FW ver: 2.0.6
    [    7.776004] ad9088 spi1.0: AD9084  Rev. 4 Grade 3 (API 2.0.10) probed
    [    7.782584] ad9088 spi1.0: BMEM sniffer: 4 channels (4T4R mode)
    [    7.788853] ad9088 spi1.0: ad9088-fft-sniffer-A: No IRQ found, using polling mode
    [    7.796542] ad9088 spi1.0: ad9088-fft-sniffer-B: No IRQ found, using polling mode
    [    7.825797] iio_dmaengine_buffer_alloc:295 width 0 (DMA width >= 256-bits ?)
    [    7.836618] cf_axi_adc a4a10000.axi-ad9084-rx-hpc: ADI AIM (10.03.\x00) probed ADC AD9088 as MASTER
    [    7.861217] iio_dmaengine_buffer_alloc:295 width 0 (DMA width >= 256-bits ?)
    [    7.868911] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
    [    7.880223] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
    [    7.891527] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
    [    7.902830] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
    [    7.914137] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> initialized
    [    7.925443] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> initialized
    [    7.936746] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> initialized
    [    7.948048] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> initialized
    [    7.959353] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition initialized -> probed
    [    7.970661] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition initialized -> probed
    [    7.981965] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition initialized -> probed
    [    7.993270] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition initialized -> probed
    [    8.004575] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition probed -> idle
    [    8.015274] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition probed -> idle
    [    8.025971] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition probed -> idle
    [    8.036665] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition probed -> idle
    [    8.047363] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition idle -> device_init
    [    8.058494] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition idle -> device_init
    [    8.069624] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition idle -> device_init
    [    8.080755] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition idle -> device_init
    [    8.091898] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition device_init -> link_init
    [    8.103463] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition device_init -> link_init
    [    8.115026] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition device_init -> link_init
    [    8.126591] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition device_init -> link_init
    [    8.138164] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_init -> link_supported
    [    8.149989] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_init -> link_supported
    [    8.161811] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_init -> link_supported
    [    8.173634] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_init -> link_supported
    [    8.185743] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_supported -> link_pre_setup
    [    8.198012] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_supported -> link_pre_setup
    [    8.210271] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_supported -> link_pre_setup
    [    8.222531] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_supported -> link_pre_setup
    [    8.247087] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_pre_setup -> clk_sync_stage1
    [    8.259439] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_pre_setup -> clk_sync_stage1
    [    8.271784] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_pre_setup -> clk_sync_stage1
    [    8.284127] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_pre_setup -> clk_sync_stage1
    [    8.296478] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage1 -> clk_sync_stage2
    [    8.308910] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage1 -> clk_sync_stage2
    [    8.321345] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage1 -> clk_sync_stage2
    [    8.333776] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage1 -> clk_sync_stage2
    [    8.346210] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage2 -> clk_sync_stage3
    [    8.358641] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage2 -> clk_sync_stage3
    [    8.371071] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage2 -> clk_sync_stage3
    [    8.383505] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage2 -> clk_sync_stage3
    [    9.686866] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage3 -> clk_sync_stage4
    [    9.699303] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage3 -> clk_sync_stage4
    [    9.711735] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage3 -> clk_sync_stage4
    [    9.724166] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage3 -> clk_sync_stage4
    [    9.736600] jesd204: /fpga-axi@0/axi-jesd204-rx@a4a90000,jesd204:4,parent=a4a90000.axi-jesd204-rx: Possible instantiation for multiple chips; HDL lanes 8, Link[4] lanes 4
    [    9.751816] jesd204: /fpga-axi@0/axi-jesd204-tx@a4b90000,jesd204:5,parent=a4b90000.axi-jesd204-tx: Possible instantiation for multiple chips; HDL lanes 8, Link[0] lanes 4
    [    9.776849] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clk_sync_stage4 -> link_setup
    [    9.788857] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clk_sync_stage4 -> link_setup
    [    9.800855] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clk_sync_stage4 -> link_setup
    [    9.812854] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clk_sync_stage4 -> link_setup
    [    9.862669] ad9088 spi1.0: Run clock conditioning cal (can take up to 10 secs)...
    [   12.865565] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
    [   12.874740] ad9088 spi1.0: JRX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
    [   12.883909] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
    [   12.893080] ad9088 spi1.0: JRX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
    [   12.902247] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
    [   12.911413] ad9088 spi1.0: JTX ADI_APOLLO_LINK_A1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
    [   12.920577] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B0: L= 4 M= 4 F= 2 S= 1 Np=16 CS= 0 link_en= Enabled
    [   12.929740] ad9088 spi1.0: JTX ADI_APOLLO_LINK_B1: L= 1 M= 1 F= 1 S= 1 Np= 1 CS= 0 link_en= Disabled
    [   12.938949] ad9088 spi1.0: Run ADC cal from NVM (can take up to 100 secs)...
    [   12.950121] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_setup -> opt_setup_stage1
    [   12.962212] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_setup -> opt_setup_stage1
    [   12.974297] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_setup -> opt_setup_stage1
    [   12.986381] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_setup -> opt_setup_stage1
    [   71.395580] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage1 -> opt_setup_stage2
    [   71.408206] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage1 -> opt_setup_stage2
    [   71.420814] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage1 -> opt_setup_stage2
    [   71.433421] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage1 -> opt_setup_stage2
    [   71.446034] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage2 -> opt_setup_stage3
    [   71.458644] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage2 -> opt_setup_stage3
    [   71.471250] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage2 -> opt_setup_stage3
    [   71.483857] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage2 -> opt_setup_stage3
    [   71.496464] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage3 -> opt_setup_stage4
    [   71.509073] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage3 -> opt_setup_stage4
    [   71.521679] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage3 -> opt_setup_stage4
    [   71.534283] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage3 -> opt_setup_stage4
    [   71.546892] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage4 -> opt_setup_stage5
    [   71.559499] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage4 -> opt_setup_stage5
    [   71.572105] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage4 -> opt_setup_stage5
    [   71.584714] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage4 -> opt_setup_stage5
    [   71.609472] ad9088 spi1.0: JESD TX (JRX Deframer Link A0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
    [   72.641288] ad9088 spi1.0: JESD TX (JRX Deframer Link B0): SERDES JRx cal Rate 20625000 kBps via INIT_CAL ...
    [   73.697325] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_setup_stage5 -> clocks_enable
    [   73.709674] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_setup_stage5 -> clocks_enable
    [   73.722019] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_setup_stage5 -> clocks_enable
    [   73.734364] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_setup_stage5 -> clocks_enable
    [   73.750801] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition clocks_enable -> link_enable
    [   73.762717] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition clocks_enable -> link_enable
    [   73.774627] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition clocks_enable -> link_enable
    [   73.786542] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition clocks_enable -> link_enable
    [   73.813202] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Phase Difference 31
    [   73.820362] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-0@5 status: Link is good
    [   73.829326] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-1@1 status: Link is good
    [   73.838290] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-2@3 status: Link is good
    [   73.847253] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C Lane-3@7 status: Link is good
    [   73.856209] ad9088 spi1.0: JESD TX (JRX Deframer Link A0) Link0 204C User status: Ready, SYSREF Phase: Locked
    [   73.866124] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Phase Difference 31
    [   73.873282] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-0@1 status: Link is good
    [   73.882245] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-1@7 status: Link is good
    [   73.891210] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-2@10 status: Link is good
    [   73.900259] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C Lane-3@3 status: Link is good
    [   73.909215] ad9088 spi1.0: JESD TX (JRX Deframer Link B0) Link2 204C User status: Ready, SYSREF Phase: Locked
    [   73.919138] ad9088 spi1.0: JESD RX (JTX Framer Link A0) Link4 204C PLL locked, PHASE established, MODE valid
    [   73.928975] ad9088 spi1.0: JESD RX (JTX Framer Link B0) Link6 204C PLL locked, PHASE established, MODE valid
    [   73.938799] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_enable -> link_running
    [   73.950625] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_enable -> link_running
    [   73.962452] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_enable -> link_running
    [   73.974276] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_enable -> link_running
    [   74.921206] ad9088 spi1.0: Total BSYNC path delay 2179102 fs
    [   75.372582] ad9088 spi1.0: MCS Initcal Status: Passed
    [   75.410654] adf4382 spi2.0: Phase 125 fs too small to represent at Icp 11100 uA.
    [   77.481452] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition link_running -> opt_post_setup_stage1
    [   77.494147] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition link_running -> opt_post_setup_stage1
    [   77.506842] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition link_running -> opt_post_setup_stage1
    [   77.519534] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition link_running -> opt_post_setup_stage1
    [   77.532236] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage1 -> opt_post_setup_stage2
    [   77.545711] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage1 -> opt_post_setup_stage2
    [   77.559184] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage1 -> opt_post_setup_stage2
    [   77.572656] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage1 -> opt_post_setup_stage2
    [   77.586133] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage2 -> opt_post_setup_stage3
    [   77.599608] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage2 -> opt_post_setup_stage3
    [   77.613083] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage2 -> opt_post_setup_stage3
    [   77.626556] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage2 -> opt_post_setup_stage3
    [   77.640048] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY0)
    [   77.644937] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY1)
    [   77.649825] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY2)
    [   77.654713] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY3)
    [   77.659603] ad9088 spi1.0: SYSREF_PHASE = 40 (TRY4)
    [   77.668551] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:0] transition opt_post_setup_stage3 -> opt_post_running_stage
    [   77.682115] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:2] transition opt_post_setup_stage3 -> opt_post_running_stage
    [   77.695676] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:4] transition opt_post_setup_stage3 -> opt_post_running_stage
    [   77.709238] jesd204: /fpga-axi@0/spi@a4a80000/ad9084@0,jesd204:6,parent=spi1.0: JESD204[0:6] transition opt_post_setup_stage3 -> opt_post_running_stage
    [   77.722810] cf_axi_dds a4b10000.axi-ad9084-tx-hpc: Analog Devices CF_AXI_DDS_DDS MASTER (9.02.b) at 0xA4B10000 mapped to 0x(____ptrval____), probed DDS AD9081
    [   77.737173] of_cfs_init
    [   77.739636] of_cfs_init: OK
    [   77.742474] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   77.769695] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   77.775752] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [   77.783006] clk: Not disabling unused clocks
    [   77.787272] PM: genpd: Disabling unused power domains
    [   77.792727] ALSA device list:
    [   77.795690]   No soundcards found.
    [   77.799321] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [   77.807940] cfg80211: failed to load regulatory.db
    [   77.957163] EXT4-fs (mmcblk0p2): mounted filesystem 5b950520-50b5-4445-b465-3291bcc7be79 r/w with ordered data mode. Quota mode: none.
    [   77.969324] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   77.977539] devtmpfs: mounted
    [   77.981340] Freeing unused kernel memory: 3648K
    [   77.985926] Run /sbin/init as init process
    [   77.990019]   with arguments:
    [   77.990022]     /sbin/init
    [   77.990024]   with environment:
    [   77.990027]     HOME=/
    [   77.990029]     TERM=linux
    [   78.594282] systemd[1]: Failed to find module 'autofs4'
    [   78.657249] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
    [   78.691581] systemd[1]: Detected architecture arm64.
    [   78.729704] systemd[1]: Hostname set to <analog>.
    [   78.808724] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
    [   80.212815] systemd[1]: /usr/lib/systemd/system/iiod.service:16: Invalid environment assignment, ignoring: $IIOD_EXTRA_OPTS=
    [   80.379063] systemd[1]: Queued start job for default target graphical.target.
    [   80.389487] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
    [   80.409938] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
    [   80.429901] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
    [   80.453876] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
    [   80.477547] systemd[1]: Created slice user.slice - User and Session Slice.
    [   80.497419] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
    [   80.521381] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point skipped, unmet condition check ConditionPathExists=/proc/sys/fs/binfmt_misc
    [   80.539001] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-20da5528\x2d01.device - /dev/disk/by-partuuid/20da5528-01...
    [   80.561246] systemd[1]: Expecting device dev-ttyAMA0.device - /dev/ttyAMA0...
    [   80.577245] systemd[1]: Expecting device dev-ttyGS0.device - /dev/ttyGS0...
    [   80.593238] systemd[1]: Expecting device dev-ttyGS1.device - /dev/ttyGS1...
    [   80.609243] systemd[1]: Expecting device dev-ttyPS0.device - /dev/ttyPS0...
    [   80.625250] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
    [   80.641316] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
    [   80.661286] systemd[1]: Reached target remote-fs.target - Remote File Systems.
    [   80.681273] systemd[1]: Reached target slices.target - Slice Units.
    [   80.697297] systemd[1]: Reached target swap.target - Swaps.
    [   80.717594] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
    [   80.741496] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
    [   80.765493] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
    [   80.789508] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
    [   80.809333] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
    [   80.821384] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
    [   80.833426] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
    [   80.853425] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
    [   80.877276] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
    [   80.894567] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
    [   80.905454] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
    [   80.942383] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
    [   80.965500] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System skipped, unmet condition check ConditionPathExists=/sys/kernel/tracing
    [   80.982628] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
    [   81.002946] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
    [   81.021491] systemd[1]: kmod-static-nodes.service - Create List of Static Device Nodes skipped, unmet condition check ConditionFileNotEmpty=/lib/modules/6.12.77-g4b2e305bc496/modules.devname
    [   81.045555] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
    [   81.069570] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
    [   81.093649] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
    [   81.118996] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
    [   81.137548] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
    [   81.158081] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [   81.170979] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
    [   81.193559] systemd[1]: Starting systemd-journald.service - Journal Service...
    [   81.225584] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
    [   81.245337] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
    [   81.261628] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
    [   81.297373] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
    [   81.311704] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
    [   81.328808] systemd-journald[198]: Collecting audit messages is disabled.
    [   81.340468] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
    [   81.387690] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
    [   81.410244] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
    [   81.429989] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
    [   81.461715] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
    [   81.489640] systemd[1]: Started systemd-journald.service - Journal Service.
    [   81.905404] EXT4-fs (mmcblk0p2): re-mounted 5b950520-50b5-4445-b465-3291bcc7be79.
    [   82.010110] systemd-journald[198]: Received client request to flush runtime journal.
    [   82.131590] systemd-journald[198]: /var/log/journal/9f4a3def851f416e960bf20d9e97cc3a/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
    [   82.131609] systemd-journald[198]: Rotating system journal.
    [   82.753220] random: crng init done
    [   86.530609] macb ff0c0000.ethernet eth0: PHY [ff0c0000.ethernet-ffffffff:01] driver [TI DP83867] (irq=POLL)
    [   86.530625] macb ff0c0000.ethernet eth0: configuring for phy/rgmii-id link mode
    [   86.531218] macb ff0c0000.ethernet: gem-ptp-timer ptp clock registered.
    [   86.558697] macb ff0d0000.ethernet eth1: PHY [ff0c0000.ethernet-ffffffff:02] driver [TI DP83867] (irq=POLL)
    [   86.558713] macb ff0d0000.ethernet eth1: configuring for phy/rgmii-id link mode
    [   86.559975] macb ff0d0000.ethernet: gem-ptp-timer ptp clock registered.
    [   90.649668] macb ff0d0000.ethernet eth1: Link is Up - 1Gbps/Full - flow control tx
  • Can you also check if there are ferrites on SVDD1P0_TX and SVDD1P0_RX
    -Travis
    Here is the board information:
    • Board: 08-068355 REV C
    • S/N: C1692A 0064
    I also checked the ferrites on SVDD1P0_TX/RX, both are on the board. I noticed that the E30/E31 ferrite on SVDD1P0_TX/RX (it has 000 printed on the ferrite) physically look different from same part# in the schematic and BOM.
    80 9 E040835 IND CHIP FERRITE BEAD, 0.0016OHM DCR MAX, 12A, GENERAL PURPOSE  50OHM AT 100MEGHZ L1206-3 12.5OHM N/A N/A E20,E21,E22,E23,E24,E26,E27,E30,E31 MURATA  BLM31SN500SN1L REL
  • Please remove/short that ferrite. It is removed on Rev D.
    -Travis
