We are using the no-OS library and have good JESD links. The DAC and ADC are working fine. We have a boot time requirement we are trying to meet, and the no-OS API function adi_ad9081_device_reset() the reset sequency is quite long:
AD9082
Recommended for New Designs
The AD9082 mixed signal front-end (MxFE®) is a highly integrated device with a 16-bit, 12 GSPS maximum sample rate, RF digital-to-analog converter (DAC...
Datasheet
AD9082 on Analog.com
Hi Mark,
The minimum RESETB hold time required to trigger a device reset is specified in Table 18 of the AD9081 datasheet. It appears that this information was inadvertently omitted from the AD9082 datasheet.
If you are looking for the reset-to-ready time, that parameter is not specified in the datasheet/userguide and would need to be characterized and validated within your specific system environment.
Please let me know if you have any questions.
Thanks SAM, I didn't think to look at the AD9081 DS. You can close this out.
