I am currently working with the ADPD6000 Kit for PPG signal acquisition (Green, Red, IR).
Observed Behaviour:
The PPG waveform polarity is not constant
The signal:
Sometimes appears as expected (systolic peak upwards)
Sometimes appears inverted (systolic peak downwards)
More importantly:
The inversion can change during runtime
It is also different across subjects and even between hands of the same subject
Example:
Red LED appears consistently inverted for some subjects
Green LED may be inverted on one hand but not the other
This behaviour makes it difficult to rely on simple post-processing inversion.
Questions:
What could cause dynamic polarity inversion in PPG signals on ADPD6000?
Are there recommended register settings or debugging methods to ensure stable polarity?
Could you please suggest:
Possible root causes
Debugging steps (register-level if possible)
Recommended signal conditioning approach
Thanks in advance!
