Can the AD9082 DAC generate an I/Q signal at 7GHz? Does it have the option for RFZ signaling? The graphs seem to suggest that the DAC can only output 3GHz if two DACs are used for I/Q generation.
AD9802
Obsolete
The AD9802 includes a low-noise, wideband amplifier with
analog variable gain from 0 dB to 31.5 dB (linear in dB).
The AD9802 is a complete CCD signal...
AD9802 on Analog.com
I guess another way to ask this is, Does the AD9082 generate meaningful power in it's 3rd nyquist zone? If not, do you have any MxFE that can generate signals in the 7G-8G range?
Could you clarify "IQ signal at 7 GHz"? Signal in the 3rd Nyquist zone would be heavily attenuated by the inherent sinc function of the DAC output, but the signal in 7-8 GHz can be generated from the second Nyquist zone using AD9802. The following thread may answer some of your question.
And the Table 9 of the AD9082 data sheet specifies the maximum data rate for various DAC configuration.
Hope it helps.
