Using Direct Clock on AD9081
Product Number: AD9081
We would like to use AD9081 Direct Clock. (12GHz)
The datasheet says 0 to 6 dBm range when Direct RF input.
ez.analog.com/.../using-an-external-clock-with-ad9081-fmca-ebz
However, when we tried it, we found that it works only when we input higher power like the answer above.
(12GHz, 15 dBm or more , Source : Keysight E8257D)
When input below 9.5 GHz, it operates below 6 dBm.
Is it okay to use Direct CLK input at 12GHz with such a high input?
If not, is there anything I need to set up?
Thank you!
