Memory Map not updating after clicking "Apply" of Quick configuration (NO HARWARE)
Product Number: ACE
Software Version: 1.25.3217.1403
I don't have  a EVAL board but want to generate the Memory Map of AD9082 registers for my configurations.
The intention of me using ACE software is that, I am trying to generate proper SPI register values for my configuration so that the same can be loaded onto my hardware and for this, I am configuring the settings as per my requirements as shown in steps 3-24, after clicking "Apply" button I am expecting the memory map window to be updated as per my configurations. But, the configured values are not getting updated in Memory configuration and remain the same default values.
When I hit apply the Apply fails and Memory Map is not updated.
I have attached images of my steps recorder file of my use case:
It is requested to kindly provide me a solution so that I can generate memory map as per my configuration without hardware requirements so that I can correctly configure my custom board.
PDF
Faiz Ahmed.
Edit Notes
Corrected the body.
[edited by: faiz321 at 4:10 AM (GMT -4) on 5 May 2022]
The ACE software only works when using the AD9xxx FMCA or FMCB EVB's along with the ADS9V2 data capture board.
To facilitate the software development process and debug, it is recommended that you purchase AD9082 FMCA board along with the ADS9V2 board.
Regards
  • Hi Faiz,
    The AD9082 evaluation software doesn't support any SPI based transaction anymore, no matter if you have hardware or not. Instead, to help our customer to accelerate their integration process, we provide platform agnostic device APIs. Use this link to request API source code and documents.
  • Hi Lihui Zhou,
    I have downloaded API, and trying to implement my use case.
