What is the pFIR update rate? Is it high enough for real-time adaptive equalization?
, additionally, if you have to constantly update the pFIR, you will have to stream the coefficients continuously via SPI. The SPI port is rated for a max speed of 33MHz. Do you have a specific use case in mind?
This was a customer question from one of the webinars on hardened DSP in the MxFE vs. FPGA DSP. A particular use case was not specified. The note about speed at 33MHz is helpful. Thanks!
