How to fix register values for ADRF6602.
Once I set the values of REF and LO-Output, and upload the registers; I get the result accurately. However, as soon as I remove the USB connection and switch off the 5V supply, the Registers get nulled and once again I see no Output.
Meaning to say, that I have to connect the ADRF with the PC and set the desired values, every time I switch off the supply. Hence, I would like you to suggest me a way to fix the value of registers so that it won't change even if the supply is turned off.
