Error on Schematic/Eval Board on the ADL5367 Data Sheet
I don't have the eval board, so I cannot tell whether or not the error in the schematic of the eval board (page 20) is actually an error on the eval board. The schematic shows a voltage divider (R22 and R23) which is supposed to provide 3V logic from the 5V supply. You will notice that R22 has a hard-wired short across it, which defeats the purpose of the divider and will apply 5V to the supposedly 3V logic control pins.
Thanks for pointing this out, Roy. This is an error on data sheet schematic. The actual eval board does not have that "hard-wire" between 5V and 3V nodes bypassing R22. We will fix this in next data sheet revision.
Rui
    Thank you,
    EZ Admin
