As a local distributor, our customer is facing to error when starting up ADF4212L. By studying in the customer's side, they found VDD1=VDD2=3.3V might be a cause when it relatively slow / long ramp-up period, as shown in below at yellow line indicates.
It seems there is no description defined in datasheet in regard to power up, so if you provide required specification how long, how fast, how steep or any to achieve normal start up of this PLL device. Other words, the customer may be able to see good result when shorten above ramp-up period, but feeling needs to confirm what is defined power up sequences.
Any of your comments or supports would be very much appreciated.
