Dear Sir,
I had a question for ADF4157 and please see the attachment.
While I had write all registers and why the phase seems shift the 90 degree??
Thank you.
Dear Sir,
Thank you.
Please post the attachment. You need to click "Use advanced editor" for attachments.
The attachment is test result , thank you.
I'm assuming the phase jump happens after a write to R0. Every time you write R0, the ADF4157 will re-lock to the desired frequency. This re-locking process causes the phase shift you are seeing.
As an experiment, you could try disabled sigma-delta reset - set R3, DB14 to 1. This will disable the resetting of the sigma-delta modulator and may remove the phase jump.
