ADISIMPLL problem
Dear All,
I had use the ADISIMPLL which version is 3.50 and meet a problem as below.
Problem:
If I choose the chip is ADF4360-7 and output frequency  set  to sweep at 1.2G~1.7GHz and why the software shows the "PLL Frequency range out of ADF4360-7 VCO range"?
The ADF4360-7 seems to support on 350MHz ~ 1800MHz and what's wrong with it ?
Could you please help me to solve this problem , tks!
Parents
  • The VCO in the ADF4360-7 can only cover a frequency range with Fmax/Fmin < 1.2. The exact centre frequency is set using Lext.  So whilst the ADF4360-7 can be used over the entire frequency range, any individual design cannot cover a frequency range with Fmax/Fmin > 1.2.
    See datasheet:
    P4: VCO Frequency Range    max = 1.2
    P22: Choosing the Correct Inductor Value
Reply
    See datasheet:
Children
No Data
