Is it ok to operate the ADA4961 with a supply between the 3.3 volts and 5 volts quoted in the data sheet ( say 4.5 volts)?
My assumption is that the performance will then be somewhere between the specs quoted for 3.3 volts and 5 volt operation - is this correct?
