Hello, I will need to S-Parameters and Performance Measurements for,
Wideband Low Noise Amplifier Module, 1 - 12 GHz
HMC-C059
Katherine Cortes
HMC-C059
Last Time Buy
The HMC-C059 is a GaAs MMIC pHEMT Low Noise Distributed Amplifier in a miniature, hermetic module with replaceable SMA connectors which operates between...
Datasheet
HMC-C059 on Analog.com
HMC-C059
Katherine Cortes
Thank you for your inquiry. Someone from enash or The specified item was not found.'s team will assist you.
Katty,
Please find attached, IP3, Compression, and S parameters for the HMC-C059.
Mikecs
