Is it possible to bias this part with +3.3v? Is there a similar part that will run on +3.3v?
Tim
HMC858
Recommended for New Designs
The HMC858LC4B is a 2:1 Selector designed to sup-port data transmission rates of up to 14 Gbps, and selector port operation of up to 14 GHz. The selector...
Datasheet
HMC858 on Analog.com
Tim
Copied from previous email conversion:
Is the customer looking for differential input/output I/O’s? If yes, HMC858 is the recommended part.
If his application can use single-ended I/O, HMC748LC3C might be lower cost and default for +3.3V for his 7.6Gbps should be sufficient.
http://www.hittite.com/products/view.html/view/HMC748LC3C
Yes, he can design his board to reference all GND pin to +3.3V and ground the Vee terminal and bias up and set the common mode as 3.3V CML for the I/O’s.
