Hi All,
I am interesting HMC9000 board.
Is it possible to set to operate in equivalent sampling mode?
Best Regards,
Ricky
Yes, the HMC9000 is designed to be used in an equivalent time sampling manner. By virtue of the track-and-hold device's very wideband capability, much higher signal frequencies then the Nyquist rate of the ADC can be input into the board. Then, through the use of the timing adjustment circuit also built into the HMC9000 board, fine-step adjustment of the ADC's sample clock is possible. This allows you to do "equivalent time" sampling of a very high frequency repetitive signal at the input.
Hi ress:adi san,
Good!, I would like to promote it to my customer.
However, I couldn't receive its data sheet yet form mail.
If you can handle it, please send it to me.
Thank you for your support,
