September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADF5355
Recommended for New Designs
The ADF5355 allows implementation of fractional-N or integer-N phase-locked loop (PLL) frequency synthesizers when used with an external loop filter and...
Datasheet
ADF5355 on Analog.com
ADF4351
The ADF4351 allows implementation of fractional-N or integer-N
Datasheet
ADF4351 on Analog.com
HMC830
Last Time Buy
The HMC830LP6GE is a low noise, wideband, Fractional-N Phase-Locked-Loop (PLL) that features an integrated Voltage Controlled Oscillator (VCO) with a fundamental...
Datasheet
HMC830 on Analog.com
HMC7044
Not Recommended for New Designs
The HMC7044 is a high performance, dual-loop, integer-N jitter attenuator capable of performing reference selection and generation of ultralow phase noise...
Datasheet
HMC7044 on Analog.com
ADIsimFrequencyPlanner enables fast, accurate simulation and elimination of integer boundary spurs from Analog Devices PLL synthesizers. The tool analyzes the user's output requirements, and then optimizes the PFD frequency for each output step to give the best integer boundary spur performance. The optimum PFD frequency is selected by changing the output divider of the clock generation chip (e.g. HMC7044) and changing the reference input divider of the PLLVCO (e.g. ADF5355, HMC830).
Typical results are better than -100 dBc for integer boundary spurs across output frequencies from 55 MHz to 13.6 GHz.
Change history:
Does the Windows installer work on Windows 10? It does not seem to work for me.
Can you try running it in Compatibility mode (right click and choose Troubleshoot compatibility (or similar))?
Yes I did. It said that it is not compatible.
Does it give you an error message? Either in normal or compatible mode?
It doesn't do anything. So I ran the compatibility check and it gave me the message that it's not compatible. I can run it again and send you the message.
Sent from my iPhone
I turned off a protection setting. I am now able to install the app.
However, I now have encountered an exception when I hit "generate
settings". I am trying to use the cascaded PLLVCO tool.
On Mon, May 15, 2017 at 12:47 PM, rbrennan <
That's good. Thanks for figuring it out.
Can you expand the Details of the error message and send me the text? And/or take a screenshot of the settings that cause the error so I can recreate it.
I attached the configuration file. I get the exception when I hit 'generate
settings'. I do not get any outputs in the spur power window. I get a phase
noise plot. (first two error blocks) But when I try to set a new frequency,
it throws another exception. (last two error blocks)
[image: Machine generated alternative text: ADlsimFrequencyPlanner (beta) X
Unhandled exception has occurred in your application, li you *** Continue,
the application will ignore this error and attempt to continue, Il you ***
Quit, the application will dose immediately. Arithmetic operation resulted
in an overflow. a Details Continue Quit See the end of this message for
details on invoking A ¡ust’in4ime (J IT) debugging instead of this dialog
box. Exception Text Systern.OverflowException: Arithmetic operation
resulted in an overflow. at
IBS_Planner.Mainjorrn.GenerateButton_Click(Qbject sender, EverrtArgs e) in
C at System .Windows.Forms Control .OnClick(EventAis e) at System
.Windows.Forms.Button .OnClick(EventArgs e) at System Windows. Forms.
Button On Mouse Up(MouseEventArgs mevent) at
System.Wìndows.Forms.Control.WmMouseUp(Message& m, MouseButtons buttc y (
in an overflow. a Details Continue Quit at
System.Windows.Forms.Button.OnClick(EventAxgs e) A at System Windows.
Forms. Button On Mouse Up(MouseEventAips mevent) at System
.Windows.Forrns.Coritrol.WmMouseUp(Message& m, Mouse Buttons buttc at
System .Wìndows.Forms Control .WndProc(Message& m) at System
.Wmndows.Forms.Button Base .WndProc(Messageš m) at System
.Windows.Forms.Button .WndProc(Message& m) at System .Windows.Forms Control
Control Native Window.On Message(Message& m: at System .Windows.Forms
Control .Control Native Window.Wnd Proc(Message& m) at
System.Wmndows.Forrns.NativeWìndow.CaHbadcQritPtr hWnd, 1nt32 msg, lntPtr’.
Quit, the application will dose immediately. Attempted to divide by zero. a
Details Continue Quit Exception Text A System.OEvideByZero Exception:
Attempted to divide by zero. at System.Decimal.FCallDivide(Decimal& dl.
Decimalš dZ at System.Decimal.opjYvision(Decimal dl, Decimal dZ at
IBS_Planner.PhaseNoise.GeneratePhaseNoise(1nt32 R, Decimal fvco, Decimal f
at IBS_Planner.Mainjom, Generate Phase Noise Plot With Spurs(Decimal fvco.
Deci at IBS_Planner.Main_Form.SetCarrierFrequencyButton_Click(Object
sender, Event, at System .Windows.Forms Control .OnClick(Event,%gs e) at
System.Windows.Forrns.Button .OnClick(EventArgs e) at System Windows.
Forms. Button On Mouse Up(MouseEventkgs mevent) y ),]
Details Continue Quit at System.Windows.Forrns.Button.OnClick(EventAzgs e)
A at System Windows. Forms. Button On Mouse Up(MouseEventAips mevent) at
System .Windows.Forrns.Coritrol.WmMouseUp(Message& m, Mouse Buttons buttc
at System .Wìndows.Forms Control .WndProc(Message& m) at System
.Wìndows.Forms.Button Base .WndProc(Messageš m) at System
System.Wmndows.Forrns.NativeWìndow.CaHbackQritPtr hWnd, 1nt32 msg,
lr,tPtr’. >]
On Mon, May 22, 2017 at 2:26 PM, rbrennan <
Hi. The error seems to be caused by your configuration of the first PLLVCO in the cascade (ADF4351).
The actual error you're seeing happens because the 'Available frefs' box is empty. This means no acceptable Fref is available.
Hi, in my application, the tool does not seem to take account of the minimum VCO frequency. Please see attached txt file for configuration. Can the tool be made to acknowledge the minimum VCO frequency?
Thanks
John
