HMC830 Frequency Hopping - Direct LUT ?
I'm working with the PLL VCO HMC830.
I want to use a look-up table (LUT) for manual calibration, as decribe in "Frequency Hopping with Hittite PLLVCOs Application Note" (attached) (https : // www . hittite.com/content/documents/application_notes/Fast_Frequency_Hopping_Application_Note.pdf).
It should have equivalence between the desired frequency and capacitors switches configuration (Reg 10h Register Tune VCO).
I wonder if somebody already have those data and could provide it.
Thank you very much in advance.
  • Hello again,
    We have another question: Which sequence needs to be sent in manual mode? We configure the PLL registers in the following order in manual mode:
    1 Reg 0A (bit 11 = 1 , Bypass VCO Tuning)
    2 VCO_Reg 02h K (K>1 or K=1, depending on the frequency required)
    3 Reg 05h 00 (Recommended in Datasheet)
    4 Reg 03h Integer Part
    5 Reg 04h Fractional Part
    6 VCO_Reg 00h Tuning (LUT Table data)
    Each time a frequency is set we need to program Reg 0A to remain in Manual mode.
    If we program Reg 03 (Nint) and Reg 04 (Nfrac) before VCO_Reg 02h, then the sequence does not work.
    Please, could you help us?, thank you very much.
    on Jul 9, 2015 6:01 PM
    Once autocal is turned off (Reg 0x0A[11]=1) it should stay off unless you perform a soft reset ( Reg 0x00[5]=1).  Can you read Reg 0x0A[11] during the manual tuning procedure to see if it has changed from "1" to "0"?
    Manual tuning should work when Nint and Nfrac are set before the output divider (VCO_Reg 02h).  You do not need step #3 (Reg 05h 00) since autocal is off.
