Problems with the HMC1032
I'm having troubles to properly configure the HMC1032 for my purposes. Does anybody else uses this device?
I need a differential clock signal from 140MHz - 210MHz and I thought this device is perfect for me. I have a board similar to the evaluation board but I cannot properly set the device up.
My problems in short:
I communicate with a microcontroller. This communication works fine, I can read back the ID and most of the registers properly.
The first question: what is the VCO quiescent frequency? I need it to properly set the N-divider. I didn't find anything in the datasheets. From my trail and error method I think its around 4.2GHz. Is that right?
I have a reference at 10MHz in I could set the reference divider properly. I investigatet it by setting the R-div output to the GPO pin and it looked as expected. I did the same with the VCO divider output, this is how I came to the assumtion of 4.2GHz frequency (5MHz output at N=840)
however. the PLL apparently does not lock. I tried to read out Reg10h (VCO Tune Register) but here I think the values are not ok. I also tried to disable the autocalibration feature and set some values for the capbank but this did not change anything. In my desperation I also unconnected the loop filter and just set known dc-voltage to the vtune but the oscillation frequency (N-div-output at GPO) did not change.
Can anybody help me. If you need further informations, just ask.
thanks in advance!!!
Parents
    on Aug 2, 2018 3:02 PM
    Thank you,
    EZ Admin
Reply
    Thank you,
    EZ Admin
Children
No Data
