HMC637 / HMC637A eval board
The HMC637LP5 has been discontinued, replaced by the HMC637ALP5E.  The HMC637LP5 had an eval board, part # 108347-HMC637LP5.  How do I do about ordering an eval board with the HMC637ALP5E ?
Tim
Parents
  • Hi Bill,
    Yes the HMC637ALP5E part, bypass CAPs, RF connectors and DC pins are mounted on the EVB. But external bias tee is required to test the part. External connectorized bias-tees are also used during lab data collection for the datasheet, which is also mentioned on the datasheet.
    List of materials for EVB can also be found on the datasheet.
    There is no documentation or data included with the EVB. Typical performance should be consistent with datasheet plots. All amplifiers on the EVBs are tested.
    Best,
    Kagan
Reply
  • Hi Bill,
    Best,
    Kagan
Children
No Data
