HMC832 tcal time and settling time
The user inquired about the definition of tcal and settling time in the HMC832LP6GE, specifically when using the Autocalibration setting. The final answer clarifies that tcal is the time for the internal VCO Auto-calibration to select the best VCO core and sub-band for the programmed frequency, and this time is included in the total settling time shown in Figure 30 of the datasheet. The PLL settling behavior follows after the VCO Auto-calibration is complete.
Please teach the definition of tcal and settling time in HMC832LP6GE.
I would like to use the frequency change that uses the Autocalibration setting.
There is Fig30 in data sheet P12.
There are Table7 and expression 8 in data sheet P18.
When the frequency was changed, tcal was guessed to be time until the setting was reflected.
Is the tcal time included in settling time of Fig30?
The setting of tcal is included in the condition of Fig30.
I think that the total time from the setting change to the settling is SETLING TIME in Fig30.
Is this correct?
Thank you.
Parents
  • Tcal is the time required for the internal VCO Auto-calibration state machine to select the best VCO core and VCO sub-band (capacitor setting) for the programmed frequency.  There are 4 separate VCO cores inside the HMC832 to cover the 1.5 to 3GHz frequency range.  VCO Auto-calibration initiates when Reg04h (when in Fractional mode) or Reg03h (when in Integer mode) is programmed.
    Upon completion of VCO Auto-calibration, control of Vt (VCO's tuning port) is relinquished to the PLL's CP and normal PLL settling behavior occurs.
    The times shown in Figure 30 of the datasheet include VCO Auto-calibration time plus the PLL settling time.
Reply
Children
No Data
