HMC-C074
Last Time Buy
The HMC-C074 is a single stage power amplifier that operates
between 10 MHz and 6 GHz. The amplifier provides 13 dB of
gain, 40 dBm output IP3, and 29...
Datasheet
HMC-C074 on Analog.com
I have got a following request.
HMC-C074 was damaged by shock hazard. When metal cover was disassembled 2 inductors were damaged inside the module (see picture below).
Could you please recommend me original part numbers for the output inductors? Thank you in advance.
Ivan
