Hi Tech support,
HMC992LP5E is not recommended for new design.
May I know is there a replacement part for HMC992LP5E and when will it be available ?
Thank you.
HP
Hi Tech support,
Thank you.
HP
Hello HP,
There is no planned replacement for the HMC992LP5E.
Depending upon how you're using the HMC992LP5E (e.g., using AGC?), perhaps one of the following would serve as a suitable replacement:
AD8368: VGA with AGC detector, 800 MHz
HMC628: DGA = (DSA + Amp), 50 MHz - 800 MHz
HMC626A: DGA = (Amp + DSA + Amp), DC to 1 GHz
ADL5240: DGA = (Gain block + DSA), 100 MHz - 4000 MHz
ADL5243: DGA = (Gain block + DSA + 1/4W driver amp), 100 MHz - 4000 MHz
ADL5246: VG-LNA = (LNA + high linearity VGA + 1/2 W output driver amp), 0.6 GHz - 3.0 GHz
ADL5330: VGA, 10 MHz to 3 GHz
SMcBride
