I am going to use HMC322LP4E as SP8T RF switch at ~5G band.
There is VEE: -5 Vdc requirement for the switch,
Any recommendation of RF LDO to provide -5 Vdc?
Thanks !!
Kevin
Thanks !!
Kevin
Please take a look at Switched Capacitor Converters from Analog Devices. ADM8828/ADM8829 might be a good fit if you have 5V supply available on your system.
Switched Capacitor Converters | Analog Devices
You will also need to use a driver circuit for voltage conversion at each control inputs of HMC322 if you only have positive control voltages. Our suggested driver circuit is below.
Best.
Thanks for your suggestion !!
BR
Kevin
