HMC772
I have a few questions regarding the HMC772LC4:
1. Can I use electrically and thermallyconductive epoxy like Epotek H20E to mount the device to an LTCC module instead of soldering it?
2. Will the device work with a +3.3 V supply, and are there any issues with using the HMC772LC4 with Vdd = 3.3 V?
3. If I use multiple HMC772LC4 in a circuit, will I need to supply a separately adjustable Vgg gate bias voltages to each device?
Thanks.
  • 1. We have not tested this device with this configuration but I suspect this should be ok if the epoxy meets the thermal and electrical requirements.
    2. We have only tested operation down with Vdd=3.5V. At Vdd=3.5V, the device exhibits slightly degraded specs - some drop in IP3 and compression but works fine otherwise.
    3. You could use a single negative supply to provide gate bias to multiple HMC772LC4 devices on a circuit as long as the supply has adequate current headroom. In general, we recommend that gate control for each device be tuned to achieve the target drain for optimal performance.
