Can I use the chip of HMC492LP3 to get a 5G sine wave while giving a input of 10G sine wave ?
Can I use the chip of HMC492LP3 to get a 5G sine wave while giving a input of 10G sine wave ? For the datasheet gives an example of the 100M square wave,but I want to get an standard output sine wave,so dose this chip have such function? and what about  other chips that can meet the function?
Parents
    on Dec 14, 2015 10:23 PM over 5 years ago
    The HMC492 frequency divider output will be a square wave with strong odd harmonics.  If you wish, you can low pass or band pass filter the output to achieve a sine wave.
    Generally speaking, most frequency dividers/counters are edge triggered logic devices and the output will be square in nature (regardless if the input is sine, square, pulse, etc).  The fixed even-divisors products will have a duty cycle 50% (odd harmonics).  Whereas, the fixed odd-divisors and counter products will have a duty cycle proportional to 1/N, which means both even and odd harmonics may be present depending upon product and configuration.
    Best Regards,
    David Mailloux
Reply
    Best Regards,
    David Mailloux
Children
No Data
