HMC544A: DC blocks at ports RFC, RF1 and RF2
I am working on a high speed data aquistion system. The low power RF signal of interest is DC coupled and therefore I was thinking of using the HMC544A as a switch. The datasheet looked promising (DC - 4GHz) until I have found the section that DC blocks are required. Using DC block capacitors is not an option. Would it be worth a try to leave out the DC blocks?
Thanks and best regards,
Gerald
    thanks for your help!
    I checked with my system and the following conditions will apply:
    - DC voltage level of RF signal                --> up to 1.5V
    - Minimum frequency of operation           --> Down to 0Hz
    - Maximum RF signal power                   --> Max. 17dBm
    I hope this will help you.
    Thanks in advance for your help!
    Gerald
    on Aug 2, 2018 3:20 PM over 2 years ago
    Thank you,
    EZ Admin
