Dear,
Can you please help to get BOM(Bill of Materials) file of below each EVB ?
EVAL-HMC406MS8G
EVAL-HMC408LP3
EVAL-HMC425LP3
EVAL-HMC624ALP4
I found HMC425A. This part is pre-released part. Can I get release schedule ?
Thanks a lot.
Dear,
EVAL-HMC406MS8G
EVAL-HMC408LP3
EVAL-HMC425LP3
EVAL-HMC624ALP4
Thanks a lot.
What I really want to know is full part number and manufacturer of all caps and resistors designed in below EVBs.
EVAL-HMC406MS8G
EVAL-HMC408LP3
EVAL-HMC425LP3
EVAL-HMC624ALP4
EVAL-HMC840LP6CE
Thanks.
Hello Jiwon
I just checked each of the datasheets has the BOM listed inside. You asked for specific part numbers, this will be very easy for you to figure out. These components were designed so they are not overly sensitive to a component vendor. The only thing you will need to do is ensure the Voltage and Current rating of the discrete elements are not exceeded. most of these HMC components are +5V, so a BOM component with a +10 Volt max would be fine, regardless of the vendor. Be careful to look at the max current rating of the inductors (RF chokes) for the amplifiers. (usually cant go wrong with coilcraft). You should use the suggested physical size if possible, but as long as you provide the correct voltage and current ratings, size is less important (0402 is usually OK).
good luck.
