HMC-T2220B outdoor application
Dear sirs,
Our customer would like to use HMC-T2220B for outdoor applications. The environment conditions are: -15...+35 degrees (C), hummidity up to 90%.
Operating temperature shown in DataSheet is: 0 to 35 °C. How does the customer can implement this generator if it is possible? Will it be enough to use a termocase?
The customer is also would like to have the Ingress Protection Rating of generator. I can't find this data. The customer needs at least IP54. I've seen this generator and seems like it is not a dust protected device. Do ADI has some kind of protection case for using this product in real outdoor applications?
Best Regards,
Sergey Pavlov
    on Mar 4, 2016 11:04 PM
    Hello Sergey,
    I hate to rain on your parade (joke... but not a very funny joke) The HMC-T2220B is really a low cost well performing Signal Generator that can be used in the field, running on battery power. It competes with some of the high-end, high price signal generators available for the bench top.
    You are correct to assume there is no moisture ingress seal or dust seal.
    I looked around and I can not even find a weather proof signal generator to compare this with.
    I apologize if the term "field" or "portable" was understood to be outdoor operation.
    Think of this as a portable, battery operated version of the HMC-T2220.
    additionally, I am not familiar with the thermocase.
  • Hi Jarrett,
    I expect this selling these generators more than 5 years. Just wanted to be sure.
    Thanls for reply!
    Best Regards,
    Sergey Pavlov
