I want to use the HMC920LP5E Active Bias Controller with the HMC1049LP5E LNA.
The data sheet for the HMC1049LP5E is not one of the amplifies listed in the HMC920LP5E's
data sheet. The list also provides resistor values for the given amplifier.
Is this amplifier compatible with the HMC920LP5E and do you have the resistor values to set the
drain voltage to 7.0 volts at 70 mA. Also the Gate set resistor value.
Thank you
