RF Amplifer for Keysight Genesys
Which ADI amplifiers are available as Sys-Parameter models in Keysight Genesys?
    on Jun 7, 2016 6:58 PM
    The attached list details all of the ADI RF Amplifier Sys-Parameter models that are available in the 2015.08 release of Keysight Genesys.  This library will be updated over time.
    PartNumber RealPartNumber Description
    ADL5240AMP ADL5240 RF/IF Digitally Controlled VGA - AMP only (100 MHz - 4 GHz)
    ADL5243_A1 ADL5243 RF/IF Digitally Controlled VGA - AMP1 only (100 MHz - 4 GHz)
    ADL5243_A2 ADL5243 RF/IF Digitally Controlled VGA - AMP2 only (100 MHz - 4 GHz)
    ADL5320-3V ADL5320 RF Driver Amplifer ¼ Watt (400 MHz - 2.7 GHz)
    ADL5320-5V ADL5320 RF Driver Amplifer ¼ Watt (400 MHz - 2.7 GHz)
    ADL5321-3V ADL5321 RF Driver Amplifer ¼ Watt (2.3 GHz - 4 GHz)
    ADL5321-5V ADL5321 RF Driver Amplifer ¼ Watt (2.3 GHz - 4 GHz)
    ADL5322 ADL5322 Matched RF PA Pre-Driver GaAs (700 MHz - 1 GHz)
    ADL5323 ADL5323 Matched RF PA Pre-Driver GaAs (1.7 GHz - 2.4 GHz)
    ADL5324-3V ADL5324 RF Driver Amplifer ½ Watt (400 MHz - 4 GHz)
    ADL5324-5V ADL5324 RF Driver Amplifer ½ Watt (400 MHz - 4 GHz)
    ADL5521-3V ADL5521 Low Noise Amplifier (400 MHz - 4 GHz)
    ADL5521-5V ADL5521 Low Noise Amplifier (400 MHz - 4 GHz)
    ADL5523-3V ADL5523 Low Noise Amplifier (400 MHz - 4 GHz)
    ADL5523-5V ADL5523 Low Noise Amplifier (400 MHz - 4 GHz)
    ADL5530 ADL5530 IF Gain Block Amplifier (DC - 1 GHz)
    ADL5531 ADL5531 IF Gain Block Amplifier (20 MHz - 500 MHz)
    ADL5534 ADL5534 IF Amplifier (20 MHz - 500 MHz)
    ADL5535 ADL5535 IF Gain Block Amplifier (20 MHz - 1 GHz)
    ADL5536 ADL5536 IF Gain Block Amplifier (20 MHz - 1 GHz)
    ADL5541 ADL5541 RF/IF Gain Block Fixed Gain of 15 dB (20 MHz - 6 GHz)
    ADL5542 ADL5542 RF/IF Gain Block Fixed Gain of 20 dB (20 MHz - 6 GHz)
    ADL5544 ADL5544 RF/IF Gain Block Amplifier (30 MHz - 6 GHz)
    ADL5545 ADL5545 RF/IF Gain Block Amplifier (30 MHz - 6 GHz)
    ADL5601 ADL5601 RF/IF Gain Block Amplifier (50 MHz - 4 GHz)
    ADL5602 ADL5602 RF/IF Gain Block Amplifier (50 MHz - 4 GHz)
    ADL5604 ADL5604 RF Driver Amplifer 1 W (700 MHz - 2.7 GHz)
    ADL5605 ADL5605 RF Driver Amplifer 1 W (700 MHz - 1 GHz)
    ADL5606 ADL5606 RF Driver Amplifer 1 W (1800 MHz - 2.7 GHz)
    ADL5610 ADL5610 RF/IF Gain Block Amplifier (30 MHz - 6 GHz)
    ADL5611 ADL5611 RF/IF Gain Block Amplifier (30 MHz - 6 GHz)
    AML5240AMP ADL5240 RF/IF Digitally Controlled VGA (100 MHz - 4 GHz)
    HMC-ALH444 HMC-ALH444 Low Noise Amplifier Chip (1 GHz - 12 GHz)
    HMC1040LP3CE HMC1040 Low Noise Amplifier GaAs pHEMT MMIC SMT (24 GHz - 43.5 GHz)
    HMC1049 HMC1049-Die Low Noise Amplifier GaAs pHEMT MMIC (0.3 GHz - 20 GHz)
    HMC1049LP5E HMC1049LP5E Low Noise Amplifier GaAs pHEMT MMIC (0.3 GHz - 20 GHz)
    HMC1082LP4E HMC1082LP4E Medium Power Amplifier GaAs pHEMT MMIC (5.5 GHz - 18 GHz)
    HMC1086 HMC1086 Power Amplifier GaN MMIC 25 Watt (2 GHz - 6 GHz)
    HMC1086F10 HMC1086F10 Power Amplifier GaN MMIC 25 Watt (2 GHz - 6 GHz)
    HMC1087 HMC1087-Die Power Amplifier GaN MMIC 8 Watt (2 GHz - 20 GHz)
    HMC1087F10 HMC1087F10 Power Amplifier GaN MMIC 8 Watt (2 GHz - 20 GHz)
    HMC1099LP5DE HMC1099LP5DE Power Amplifier GaN 10 Watt (0.01 GHz - 1.1 GHz)
    HMC1126 HMC1126 Power Amplifier GaAs pHEMT (2 GHz - 50 GHz)
    HMC1127 HMC1127 Power Amplifier High Gain GaAs pHEMT (2 GHz - 50 GHz)
    HMC263 HMC263-Die Low Noise Amplifier Chip SMT (24 GHz - 36 GHz)
    HMC311SC70 HMC311SC70 HBT Gain Block Amplifier InGaP SMT (DC - 6 GHz)
    HMC313E HMC313E Gain Block Amplifier InGaP HBT SMT (DC - 6 GHz)
    HMC3587LP3BE HMC3587LP3BE Gain Block Amplifier HBT MMIC (4 GHz - 10 GHz)
    HMC3653LP3BE HMC3653LP3BE Gain Block Amplifier HBT MMIC (7 GHz - 15 GHz)
    HMC374E HMC374-Die Low Noise Amplifier Chip GaAs pHEMT SMT (300 MHz - 3 GHz)
    HMC374SC70E HMC374SC70E Low Noise Amplifier GaAs pHEMT SMT (300 MHz - 3 GHz)
    HMC441 HMC441-Die Medium Power Amplifier Chip (6 GHz - 18 GHz)
    HMC441LC3B HMC441LC3B Medium Power Amplifier SMT (6 GHz - 18 GHz)
    HMC441LH5 HMC441LH5 Medium Power Amplifier SMT (7 GHz - 15.5 GHz)
    HMC441LM1 HMC441LM1 Medium Power Amplifier SMT (7 GHz - 15.5 GHz)
    HMC441LP3E HMC441-Die Medium Power Amplifier Chip (6 GHz - 18 GHz)
    HMC451 HMC451-Die Medium Power Amplifier Chip (5 GHz - 20 GHz)
    HMC451LC3 HMC451LC3 Medium Power Amplifier SMT (5 GHz - 20 GHz)
    HMC451LP3E HMC451LP3 Medium Power Amplifier GaAs pHEMT MMIC (5 GHz - 18 GHz)
    HMC460 HMC460-Die Wideband Low Noise Amplifier Chip (DC - 20 GHz)
    HMC460LC5 HMC460LC5 Wideband Low Noise Amplifier SMT (DC - 20 GHz)
    HMC462 HMC462-Die Wideband Low Noise Amplifier Chip (2 GHz - 20 GHz)
    HMC462LP5E HMC462-Die Wideband Low Noise Amplifier Chip (2 GHz - 20 GHz)
    HMC464 HMC464-Die Wideband Low Noise Amplifier Chip (2 GHz - 20 GHz)
    HMC464LP5E HMC464LP5 Wideband Low Noise Amplifier SMT (2 GHz - 20 GHz)
    HMC465 HMC465-Die Wideband Driver Amplifier Chip (DC - 20 GHz)
    HMC465LP5E HMC465LP5 Wideband Driver Amplifier SMT (DC - 20 GHz)
    HMC490 HMC490-Die Low Noise Amplifier High IP3 Chip (12 GHz - 17 GHz)
    HMC490LP5 HMC490LP5E Low Noise Amplifier High IP3 SMT (12 GHz - 16 GHz)
    HMC498 HMC498-Die Medium Power Amplifier Chip (17 GHz - 24 GHz)
    HMC498LC4 HMC498LC4 Medium Power Amplifier SMT (17 GHz - 24 GHz)
    HMC516 HMC516-Die Low Noise Amplifier Chip (7 GHz - 17 GHz)
    HMC564 HMC564-Die Low Noise Amplifier Chip (7 GHz - 13.5 GHz)
    HMC564LC4 HMC564LC4 Low Noise Amplifier SMT (7 GHz - 14 GHz)
    HMC565 HMC565-Die Low Noise Amplifier Chip (7 GHz - 20 GHz)
    HMC565LC5 HMC565LC5 Low Noise Amplifier SMT (6 GHz - 20 GHz)
    HMC606 HMC606-Die Wideband Low Phase Noise Amplifier Chip (2 GHz - 18 GHz)
    HMC606LC5 HMC606LC5 Wideband Low Phase Noise Amplifier SMT (2 GHz - 18 GHz)
    HMC634 HMC634-Die Driver Amplifier Chip (5 GHz - 20 GHz)
    HMC636ST89 HMC636 Wideband Gain Block Amplifier High IP3 SMT (200 MHz - 4 GHz)
    HMC637ALP5E HMC637A Power Amplifier GaAs pHEMT MMIC 1 Watt (DC - 6 GHz)
    HMC6981LS6 HMC6981 Power Amplifier SMT 2 Watt (15 GHz - 20 GHz)
    HMC717LP3E-3V HMC717 Low Noise Amplifier SMT (4.8 GHz - 6 GHz)
    HMC717LP3E-5V HMC717 Low Noise Amplifier SMT (4.8 GHz - 6 GHz)
    HMC7229LS6 HMC7229 Power Amplifier GaAs pHEMT MMIC 1 Watt with Power Detector (37 GHz - 40
      GHz)
    HMC7357LP5GE HMC7357 Power Amplifier GaAs pHEMT MMIC 2 Watt (5.5 GHz - 8.5 GHz)
    HMC740ST89E HMC740 Gain Block Amplifier InGaP HBT Active Bias MMIC (0.05 GHz - 3 GHz)
    HMC741ST89 HMC741 Gain Block Amplifier InGaP HBT Active Bias MMIC (0.05 GHz - 3 GHz)
    HMC753LP4E HMC753 Low Noise Amplifier SMT (1 GHz - 11 GHz)
    HMC772LC4 HMC772 Low Noise Amplifier SMT (2 GHz - 12 GHz)
    HMC788ALP2E HMC788A Gain Block Amplifier pHEMT MMIC (DC - 10 GHz)
    HMC788LP2E HMC788A Gain Block Amplifier pHEMT MMIC (DC - 10 GHz)
    HMC863LP4E HMC863 Power Amplifier ½ Watt SMT (24 GHz - 29.5 GHz)
    HMC902 HMC902-Die Low Noise Amplifier Chip (5 GHz - 10 GHz)
    HMC902LP3E HMC902LP3E Low Noise Amplifier SMT (5 GHz - 10 GHz)
    HMC903 HMC903-Die Low Noise Amplifier Chip (6 GHz - 18 GHz)
    HMC903LP3E HMC903LP3E Low Noise Amplifier SMT (6 GHz - 17 GHz)
    HMC994LP5E HMC994 Power Amplifer GaAs pHEMT MMIC ½ Watt (400 MHz - 4 GHz)
