HMC995 and HMC980
I want to use the HMC980 bias controller to supply the HMC995 PA.  Has anyone used this combination?  I am interested in particular as I have recently found that the HMC980 will not (easily) sequence the HMC487 due to gate current drawn levels as noted in this forum.
    We have tested HMC980 with HMC995.
    The Igate for HMC995 typically stays within +-1.5 mA; hence you should not have any problems like the ones you had with HMC487.
    Let us know if you face any issues, we will provide the support.
    ps. I have also tested HMC487 with HMC980 in the past. In parallel I am investigating the issue you and another customer had recently when biasing HMC487 with HMC980. HMC487 has a shunt resistor at the Vgate input which leads to high Igate during power up. In the past I was able to limit the Igate current during power up by limiting min Vgate value using external resistors on HMC980. I believe the part to part variation of HMC487 leads to the problem you are facing. Anyway, that is a discussion for that EZ post.
    Best,
    Kagan
  • Hi Kagan,
    I think I am having the same issue when trying to bias the Macom MAAP-118260 PA with the HMC980, can you share details of the fix that you made through 'limiting the min Vgate value using external resistors on HMC980'?
