Digital attenuator swithing
   Hello!
Dear colleagues, could You clear,
is it possible to switch  digital attenuator, like HMC1018LP4E, when in use (signal forwarding),
and what switching effect rejection ratio ?
thanks a lot!
Parents
  • FormerMember
    FormerMember
on Aug 1, 2016 6:38 AM
0
The digital attenuators can be switched into different states when the RF input signal is present if the RF signal level is kept below a certain value. The maximum input power spec is generally derated by 3 dB (for the HMC1018, the maximum RF input power needs to be derated from 25 dBm to 22 dBm) if the attenuator is switched when RF input signal is applied.
Best.
Reply
  • FormerMember
    FormerMember
0
Best.
Children
No Data
