AD8319
Hello
If the Vout of the AD8319 is run open loop will the device act as a comparator and give essentially a digital output? If the input power is lower than Vset, Vout is high and if the input power is higher than Vset, Vout is low. Can you confirm that the AD8319 will behave as we expected? Are there any issue in using it this way, such as oscillation etc?
Thanks.
