The AMR table for the HMC637A shows that the input is limited to +25dBm with a 12 volt supply. Could you please tell me what the limit would be using an 11 volt supply?
Thanks and Best Regards.
I can't find more data about non normal conditions of using in datasheet.For power amplifier,you may set input power threshold.
We have not tested the max input power limit with 11V supply voltage, hence it is not possible to commit to a value. Based on experience on amplifiers with similar architecture, we expect the the max RF input AMR for 11V supply to be higher than 12 V supply, but giving a value is not applicable without further testing.
Best,
Kagan
