Question: Would it be possible to share the gerber files for the HMC1163 evaluation board?
HMC534
Recommended for New Designs
The HMC534LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC534LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC534 on Analog.com
HMC515
The HMC515LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC515LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC515 on Analog.com
HMC512
The HMC512LP5(E) is a GaAs InGaP Herterojunction Bipolar Transistor (HBT) MMIC VCOs. The HMC512LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC512 on Analog.com
HMC1167
The HMC1167 is a monolithic microwave integrated circuit (MMIC) voltage controlled oscillator (VCO) that integrates a resonator, a negative resistance...
Datasheet
HMC1167 on Analog.com
HMC1163
The HMC1163 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator (VCO) that integrates a resonator, a negative resistance...
Datasheet
HMC1163 on Analog.com
HMC1164
The HMC1164 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator that integrates a resonator, a negative resistance device...
Datasheet
HMC1164 on Analog.com
HMC511
Production
The HMC511LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC511LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC511 on Analog.com
HMC1161
The HMC1161 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator (VCO) that integrates a resonator, a negative resistance...
Datasheet
HMC1161 on Analog.com
HMC1169
The HMC1169 is a monolithic microwave integrated circuit
Datasheet
HMC1169 on Analog.com
HMC513
The HMC513LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCOs. The HMC513LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC513 on Analog.com
HMC530
Production
The HMC530LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCOs. The HMC530LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC530 on Analog.com
HMC1160
The HMC1160 is a MMIC voltage controlled oscillator that integrates a resonator, a negative resistance device, and a varactor diode, and features a half...
Datasheet
HMC1160 on Analog.com
HMC1162
The HMC1162 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator (VCO) that integrates the resonator, a negative resistance...
Datasheet
HMC1162 on Analog.com
HMC514
The HMC514LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC514LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC514 on Analog.com
HMC1165
The HMC1165 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator (VCO) that integrates a resonator, a negative resistance...
Datasheet
HMC1165 on Analog.com
HMC508
The HMC508LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC508LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC508 on Analog.com
HMC509
The HMC509LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCOs. The HMC509LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC509 on Analog.com
HMC1168
The HMC1168 is a monolithic microwave integrated circuit
Datasheet
HMC1168 on Analog.com
HMC529
The HMC529LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC529LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC529 on Analog.com
HMC510
The HMC510LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC510LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC510 on Analog.com
HMC1166
The HMC1166 is a monolithic microwave integrated circuit (MMIC), voltage controlled oscillator (VCO) that integrates a resonator, a negative resistance...
Datasheet
HMC1166 on Analog.com
HMC507
The HMC507LP5(E) is a GaAs InGaP Heterojunction Bipolar Transistor (HBT) MMIC VCO. The HMC507LP5(E) integrates resonators, negative resistance devices...
Datasheet
HMC507 on Analog.com
HMC1163
Datasheet
Yes of course.
I should mention that many of Analog Devices' catalog microwave VCO's in the LP5 package share this same board including:
HMC507 thru HMC515
HMC529, HMC530,HMC531 & HMC534
HMC1160 thru HMC1169
These same files can be used for each of these models.
Best Regards,
Marty
