Hello all,
LOIN– (pin 33) and LOIN+ (pin 34) are 50Ohm each or 50 Ohm differential (25Ohm each)? Checking your eval board (AD9114/ADRF6720), it seems that it is 100Ohm diff so I want to double check with you.
Thanks for your help.
Best,
Chris
Hello all,
Best,
Chris
Thanks Liam,
Well, it is what I thought but by opening the layout of AD9144-M6720-EBZ, I can see the balun followed by 100Ohms differential pair (J18 connetor), is it a mistake then?
Thanks again,
Best
Chris
Hi Chris,
On the layout I only see spaces for the series capacitors and the balun before it goes to J18 SMA connector
This is the layout I am looking at:
ftp://ftp.analog.com/pub/HSSP_SW/HSCDAC/Documents/AD9144/AD9144-ADRF6720-EBZ%20RevC.brd
Hello Liam,
I am looking at the same layout. If I am correct, the differential impedance after the balun is 100Ohm.
Best,
Chris
Chris,
I'm afraid I don't understand. You said " I can see the balun followed by 100Ohms differential pair (J18 connetor)" but there are no resistors between the balun and the J18 SMA connector.
Hello Liam,
Sorry for the confusion. So there is the J18 connector, the balun and then the serie capacitors that are conneceted to the ADRF. The connection uses 100Ohm differential pair while the balun is 50Ohm and the external LO input impedance is 50 Ohm differential. Am I wrong?
Best,
Chris
Hi Chris,
Yes I understand now. Ideally these lines would be 50 ohm differential but since they are quite short there should not be much impact. When designing your own board you could use 50 ohm differential lines.
